MeshKit
1.0
The wrapper for the Netgen tet mesher. More...
#include <meshkit/NGTetMesher.hpp>
Public Member Functions | |
| NGTetMesher (MKCore *mk_core, const MEntVector &me_vec) | |
| Constructor. | |
| ~NGTetMesher () | |
| Destructor. | |
| virtual void | setup_this () |
| Setup function for this mesher, simply calls setup_boundary. | |
| virtual void | execute_this () |
| Execute the mesher (calling Netgen mesher on this volume) | |
| virtual const moab::EntityType * | mesh_types_arr () const |
| Return the mesh entity types operated on by this scheme. | |
Static Public Member Functions | |
| static const char * | name () |
| Get class name. | |
| static bool | can_mesh (iBase_EntityType dim) |
| Function returning whether this scheme can mesh entities of t the specified dimension. | |
| static bool | can_mesh (ModelEnt *me) |
| Function returning whether this scheme can mesh the specified entity. | |
| static const moab::EntityType * | output_types () |
| Get list of mesh entity types that can be generated. | |
Static Public Attributes | |
| static bool | meshopRegistered |
| Static variable for registering this meshop. | |
| static iBase_EntityType | geomTps [] |
| Static list of geometry types treated by this scheme. | |
| static moab::EntityType | meshTps [] = {moab::MBVERTEX, moab::MBTET, moab::MBMAXTYPE} |
| Static list of mesh types treated by this scheme. | |
Private Member Functions | |
| MeshOp * | get_tri_mesher () |
| Construct a MeshOp that can generate triangle elements. | |
This class calls the Netgen tet mesher and converts mesh to/from the required format for that mesher.
Definition at line 27 of file NGTetMesher.hpp.
| NGTetMesher | ( | MKCore * | mk_core, |
| const MEntVector & | me_vec | ||
Constructor.
| mk_core | MKCore instance |
| me_vec | ModelEnts this mesher will be applied to |
Definition at line 20 of file NGTetMesher.cpp.
| ~NGTetMesher | ( | ) |
Destructor.
Definition at line 25 of file NGTetMesher.cpp.
| static bool can_mesh | ( | iBase_EntityType | dim | ) | [inline, static] |
| dim | entity dimension |
Definition at line 69 of file NGTetMesher.hpp.
Used by MeshOpFactory to find scheme for an entity.
| me | ModelEnt being queried |
Definition at line 78 of file NGTetMesher.hpp.
| void execute_this | ( | ) | [virtual] |
Implements GraphNode.
Definition at line 70 of file NGTetMesher.cpp.
| MeshOp * get_tri_mesher | ( | ) | [private] |
Definition at line 29 of file NGTetMesher.cpp.
| virtual const moab::EntityType* mesh_types_arr | ( | ) | const [inline, virtual] |
moab::MBMAXTYPE Implements MeshOp.
Definition at line 90 of file NGTetMesher.hpp.
| static const char* name | ( | ) | [inline, static] |
Get class name.
Definition at line 62 of file NGTetMesher.hpp.
| static const moab::EntityType* output_types | ( | ) | [inline, static] |
moab::MBMAXTYPE Definition at line 84 of file NGTetMesher.hpp.
| void setup_this | ( | ) | [virtual] |
Definition at line 37 of file NGTetMesher.cpp.
iBase_EntityType geomTps[] [static] |
Definition at line 54 of file NGTetMesher.hpp.
bool meshopRegistered [static] |
Definition at line 50 of file NGTetMesher.hpp.
moab::EntityType meshTps = {moab::MBVERTEX, moab::MBTET, moab::MBMAXTYPE} [static] |
Definition at line 58 of file NGTetMesher.hpp.
