MeshKit  1.0
QuadMesher Class Reference
Triangle to Quad Transformation. More...
#include <QuadMesh.hpp>
Inheritance diagram for QuadMesher:
List of all members.
Public Types
enum  MeshCleanOps { LOCAL_MESH_CLEANUP, GLOBAL_MESH_CLEANUP }
Public Member Functions
 QuadMesher (MKCore *mk_core, const MEntVector &me_vec)
 ~QuadMesher ()
virtual void setup_this ()
 Pure virtual, derived class must define.
virtual void execute_this ()
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
void allow_boundary_steiner_points (bool a=0)
 Should we allow boundary modification. By Default: No. When boundary is not allowed to modify and if the number of segments are not even, "All Quads" not possible.
void mesh_cleanup (MeshCleanOps mcleanup=GLOBAL_MESH_CLEANUP)
 Performs mesh clean to reduce the irreguarity of the of the quad mesh.
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
 Function returning whether this scheme can mesh entities of t the specified dimension.
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Detailed Description
Examples:
example_jaalquad.cpp.
Definition at line 25 of file QuadMesh.hpp.
Member Enumeration Documentation
Enumerator:
LOCAL_MESH_CLEANUP
GLOBAL_MESH_CLEANUP
Definition at line 28 of file QuadMesh.hpp.
QuadMesher ( MKCore *  mk_core,
const MEntVector &  me_vec
Definition at line 19 of file QuadMesh.cpp.
~QuadMesher ( ) [inline]
Definition at line 33 of file QuadMesh.hpp.
Member Function Documentation
void allow_boundary_steiner_points ( bool  a = 0)
static bool can_mesh ( iBase_EntityType  dim) [inline, static]
Parameters:
dimentity dimension
Definition at line 48 of file QuadMesh.hpp.
static bool can_mesh ( ModelEnt *  me) [inline, static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 57 of file QuadMesh.hpp.
void execute_this ( ) [virtual]
Implements GraphNode.
Definition at line 70 of file QuadMesh.cpp.
virtual const moab::EntityType* mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 69 of file QuadMesh.hpp.
static const char* name ( ) [inline, static]
Get class name.
Definition at line 42 of file QuadMesh.hpp.
const moab::EntityType * output_types ( ) [static]
Returns:
Definition at line 14 of file QuadMesh.cpp.
void setup_this ( ) [virtual]
Definition at line 26 of file QuadMesh.cpp.
