MeshKit  1.0
CopyGeom Class Reference
#include <CopyGeom.hpp>
Inheritance diagram for CopyGeom:
List of all members.
Public Member Functions
 CopyGeom (MKCore *mkcore, const MEntVector &me_vec)
virtual ~CopyGeom ()
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
virtual bool add_modelent (ModelEnt *model_ent)
 Re-implemented here so we can check topological dimension of model_ent.
virtual void setup_this ()
 Setup is a no-op, but must be provided since it's pure virtual.
virtual void execute_this ()
 The only setup/execute function we need, since meshing vertices is trivial.
void set_location (const Vector< 3 > &dx)
void tag_copied_sets (const char **tag_names, const char **tag_vals, const int num_tags)
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
 Function returning whether this scheme can mesh entities of t the specified dimension.
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Private Attributes
iGeom * igeomImpl
Vector< 3 > m_x
Detailed Description
Examples:
example_copygeom.cpp.
Definition at line 26 of file CopyGeom.hpp.
CopyGeom ( MKCore *  mkcore,
const MEntVector &  me_vec
Definition at line 23 of file CopyGeom.cpp.
~CopyGeom ( ) [virtual]
Definition at line 32 of file CopyGeom.cpp.
Member Function Documentation
bool add_modelent ( ModelEnt *  model_ent) [virtual]
Parameters:
model_entModelEnt being added
Reimplemented from MeshOp.
Definition at line 35 of file CopyGeom.cpp.
bool can_mesh ( iBase_EntityType  dim) [inline, static]
Parameters:
dimentity dimension
Definition at line 97 of file CopyGeom.hpp.
bool can_mesh ( ModelEnt *  me) [inline, static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 104 of file CopyGeom.hpp.
void execute_this ( ) [virtual]
Implements GraphNode.
Definition at line 43 of file CopyGeom.cpp.
const moab::EntityType * mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 109 of file CopyGeom.hpp.
const char * name ( ) [inline, static]
Get class name.
Definition at line 92 of file CopyGeom.hpp.
const moab::EntityType * output_types ( ) [static]
Returns:
Definition at line 20 of file CopyGeom.cpp.
void set_location ( const Vector< 3 > &  dx)
Examples:
Definition at line 57 of file CopyGeom.cpp.
void setup_this ( ) [virtual]
Definition at line 40 of file CopyGeom.cpp.
void tag_copied_sets ( const char **  tag_names,
const char **  tag_vals,
const int  num_tags
Definition at line 62 of file CopyGeom.cpp.
Member Data Documentation
iGeom* igeomImpl [private]
Definition at line 88 of file CopyGeom.hpp.
Vector<3> m_x [private]
Definition at line 89 of file CopyGeom.hpp.
