MeshKit  1.0
EdgeMesher Class Reference
Generate the mesh for edges. More...
#include <EdgeMesher.hpp>
Inheritance diagram for EdgeMesher:
List of all members.
Classes
struct  Point3D
Public Types
enum  EdgeSchemeType {
  EQUAL = 0, BIAS, DUAL, CURVATURE,
  VARIABLE, EQUIGNOMONIC
Public Member Functions
 EdgeMesher (MKCore *mk_core, const MEntVector &me_vec)
virtual void setup_this ()
 Pure virtual, derived class must define.
virtual void execute_this ()
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
EdgeSchemeType get_edge_scheme () const
void set_edge_scheme (EdgeSchemeType scheme)
void set_ratio (double q)
double get_ratio ()
 ~EdgeMesher ()
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
 Function returning whether this scheme can mesh entities of t the specified dimension.
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Private Member Functions
Point3D getXYZCoords (ModelEnt *ent, double u) const
double getUCoord (ModelEnt *ent, double ustart, double dist, double uguess, double umin, double umax) const
void DivideIntoMore (ModelEnt *ent, Point3D p0, Point3D pMid, Point3D p1, double u0, double u1, double uMid, int &index, vector< double > &nodes, vector< double > &URecord)
bool ErrorCalculate (ModelEnt *ent, Point3D p0, Point3D p1, Point3D pMid)
void RapidSorting (vector< double > &nodes, vector< double > &URecord, int left, int right)
void QuickSorting (vector< double > &nodes, vector< double > &URecord, int count)
void EqualMeshing (ModelEnt *ent, int num_edges, std::vector< double > &coords)
void BiasMeshing (ModelEnt *ent, int num_edges, std::vector< double > &coords)
void DualBiasMeshing (ModelEnt *ent, int &num_edges, std::vector< double > &coords)
void CurvatureMeshing (ModelEnt *ent, int &num_edges, std::vector< double > &coords)
void VariableMeshing (ModelEnt *ent, int &num_edges, std::vector< double > &coords)
void EquiAngleGnomonic (ModelEnt *ent, int num_edges, std::vector< double > &coords)
Private Attributes
EdgeSchemeType schemeType
double ratio
Detailed Description
EdgeMesher generates a mesh for edges, creating the nodes and line segments on edges. There are four schemes for edge mesher: equal meshing, Bias Meshing Dual Bias Meshing, Curvature-Based Meshing
Examples:
example_edgemesher.cpp, and example_tfimapping.cpp.
Definition at line 41 of file EdgeMesher.hpp.
Member Enumeration Documentation
Enumerator:
EQUAL
BIAS
DUAL
CURVATURE
VARIABLE
EQUIGNOMONIC
Definition at line 45 of file EdgeMesher.hpp.
EdgeMesher ( MKCore *  mk_core,
const MEntVector &  me_vec
Definition at line 22 of file EdgeMesher.cpp.
~EdgeMesher ( )
Definition at line 252 of file EdgeMesher.cpp.
Member Function Documentation
void BiasMeshing ( ModelEnt *  ent,
int  num_edges,
std::vector< double > &  coords
) [private]
Definition at line 458 of file EdgeMesher.cpp.
static bool can_mesh ( iBase_EntityType  dim) [inline, static]
Parameters:
dimentity dimension
Definition at line 66 of file EdgeMesher.hpp.
static bool can_mesh ( ModelEnt *  me) [inline, static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 75 of file EdgeMesher.hpp.
void CurvatureMeshing ( ModelEnt *  ent,
int &  num_edges,
) [private]
Definition at line 289 of file EdgeMesher.cpp.
void DivideIntoMore ( ModelEnt *  ent,
Point3D  p0,
Point3D  pMid,
Point3D  p1,
double  u0,
double  u1,
double  uMid,
int &  index,
vector< double > &  nodes,
vector< double > &  URecord
) [private]
Definition at line 493 of file EdgeMesher.cpp.
void DualBiasMeshing ( ModelEnt *  ent,
int &  num_edges,
) [private]
Definition at line 397 of file EdgeMesher.cpp.
void EqualMeshing ( ModelEnt *  ent,
int  num_edges,
) [private]
Definition at line 259 of file EdgeMesher.cpp.
void EquiAngleGnomonic ( ModelEnt *  ent,
int  num_edges,
) [private]
Definition at line 724 of file EdgeMesher.cpp.
bool ErrorCalculate ( ModelEnt *  ent,
Point3D  p0,
Point3D  p1,
Point3D  pMid
) [private]
Definition at line 884 of file EdgeMesher.cpp.
void execute_this ( ) [virtual]
Implements GraphNode.
Definition at line 133 of file EdgeMesher.cpp.
Definition at line 158 of file EdgeMesher.hpp.
double get_ratio ( ) [inline]
Definition at line 170 of file EdgeMesher.hpp.
double getUCoord ( ModelEnt *  ent,
double  ustart,
double  dist,
double  uguess,
double  umin,
double  umax
) const [private]
Definition at line 836 of file EdgeMesher.cpp.
EdgeMesher::Point3D getXYZCoords ( ModelEnt *  ent,
double  u
) const [private]
Definition at line 818 of file EdgeMesher.cpp.
virtual const moab::EntityType* mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 87 of file EdgeMesher.hpp.
static const char* name ( ) [inline, static]
Get class name.
Definition at line 59 of file EdgeMesher.hpp.
const moab::EntityType * output_types ( ) [static]
Returns:
Definition at line 17 of file EdgeMesher.cpp.
void QuickSorting ( vector< double > &  nodes,
vector< double > &  URecord,
int  count
) [private]
Definition at line 810 of file EdgeMesher.cpp.
void RapidSorting ( vector< double > &  nodes,
int  left,
int  right
) [private]
Definition at line 758 of file EdgeMesher.cpp.
void set_edge_scheme ( EdgeMesher::EdgeSchemeType  scheme) [inline]
Definition at line 152 of file EdgeMesher.hpp.
void set_ratio ( double  q) [inline]
Definition at line 164 of file EdgeMesher.hpp.
void setup_this ( ) [virtual]
Definition at line 53 of file EdgeMesher.cpp.
void VariableMeshing ( ModelEnt *  ent,
int &  num_edges,
) [private]
Definition at line 553 of file EdgeMesher.cpp.
Member Data Documentation
double ratio [private]
Definition at line 109 of file EdgeMesher.hpp.
Definition at line 108 of file EdgeMesher.hpp.
