MeshKit
1.0
00001 //-----------------------------------C++-------------------------------------// 00002 // File: src/algs/EdgeMesher.hpp 00003 // Wednesday February 11 10:50 2011 00004 // Brief: EdgeMesher class definition: four schemes are provided: equal meshing, 00005 // Bias Meshing, Dual Bias Meshing, Curvature-based meshing 00006 //---------------------------------------------------------------------------// 00007 00008 #ifndef MESHKIT_EDGE_MESHER_HPP 00009 #define MESHKIT_EDGE_MESHER_HPP 00010 00011 #include <stdlib.h> 00012 #include <stdio.h> 00013 #include <assert.h> 00014 #include <string> 00015 #include <iostream> 00016 #include <fstream> 00017 #include <string.h> 00018 #include <limits.h> 00019 00020 #include "meshkit/iGeom.hpp" 00021 #include <set> 00022 #include <vector> 00023 00024 #include "meshkit/MeshScheme.hpp" 00025 00026 namespace MeshKit 00027 { 00028 //===========================================================================// 00037 //===========================================================================// 00038 00039 using namespace std; 00040 00041 class EdgeMesher : public MeshScheme 00042 { 00043 public: 00044 //six schemes for edge meshing 00045 enum EdgeSchemeType {EQUAL=0, BIAS, DUAL, CURVATURE, VARIABLE, EQUIGNOMONIC}; 00046 00047 00048 public: 00049 //construction function for edge mesher 00050 EdgeMesher(MKCore *mk_core, const MEntVector &me_vec); 00051 00052 //set up the parameters for edge meshing, e.g. compute the number of intervals 00053 virtual void setup_this(); 00054 00055 //Generate the edge mesh 00056 virtual void execute_this(); 00057 00059 static const char* name() 00060 { return "EdgeMesher"; } 00061 00066 static bool can_mesh(iBase_EntityType dim) 00067 { return iBase_EDGE == dim; } 00068 00075 static bool can_mesh(ModelEnt *me) 00076 { return canmesh_edge(me); } 00077 00078 00082 static const moab::EntityType* output_types(); 00083 00087 virtual const moab::EntityType* mesh_types_arr() const 00088 { return output_types(); } 00089 00090 // set/get some options 00091 EdgeSchemeType get_edge_scheme() const; 00092 void set_edge_scheme(EdgeSchemeType scheme); 00093 00094 // used in bias and dual meshing schemes 00095 void set_ratio(double q); 00096 double get_ratio(); 00097 ~EdgeMesher(); 00098 00099 private: 00100 00101 struct Point3D 00102 { 00103 double px; 00104 double py; 00105 double pz; 00106 }; 00107 00108 EdgeSchemeType schemeType; 00109 double ratio; 00110 00111 //return x, y, z coordinates based on the parametric coordinate u on the edge 00112 Point3D getXYZCoords(ModelEnt *ent, double u) const; 00113 00114 //return the parametrical coordinate based the starting parametric coordinate ustart and distance in physical space 00115 double getUCoord(ModelEnt *ent, double ustart, double dist, double uguess, double umin, double umax) const; 00116 00117 //Create more nodes if there is a high curvature on the edge 00118 void DivideIntoMore(ModelEnt *ent, Point3D p0, Point3D pMid, Point3D p1, double u0, double u1, double uMid, int &index, vector<double> &nodes, vector<double> &URecord); 00119 00120 //calculate the error between the line segments and the edge in the physical space 00121 bool ErrorCalculate(ModelEnt *ent, Point3D p0, Point3D p1, Point3D pMid); 00122 00123 //Sort the nodes on the edge 00124 void RapidSorting(vector<double> &nodes, vector<double> &URecord, int left, int right); 00125 void QuickSorting(vector<double> &nodes, vector<double> &URecord, int count); 00126 00127 //four schemes for edge meshing 00128 //create the mesh for edges with equal distances 00129 void EqualMeshing(ModelEnt *ent, int num_edges, std::vector<double> &coords); 00130 00131 //create the mesh for edges with bias distances 00132 void BiasMeshing(ModelEnt *ent, int num_edges, std::vector<double> &coords); 00133 00134 //create the mesh for edges with dual bias distances 00135 void DualBiasMeshing(ModelEnt *ent, int &num_edges, std::vector<double> &coords); 00136 00137 //create the mesh for edges based on curvatures 00138 void CurvatureMeshing(ModelEnt *ent, int &num_edges, std::vector<double> &coords); 00139 00140 //create the mesh for edges based on variable size from SizingFunction (var) 00141 void VariableMeshing(ModelEnt *ent, int &num_edges, std::vector<double> &coords); 00142 00143 //create the edge mesh on the edge on a cube, such that the 00144 // dihedral angles from the center of the cube are equal (for gnomonic equi angle mesh on the sphere) 00145 void EquiAngleGnomonic(ModelEnt *ent, int num_edges, std::vector<double> &coords); 00146 //compute the distance between the parametric coordinate ustart and parametric coordinate uend. 00147 //double measure(iGeom::EntityHandle ent, double ustart, double uend) const; 00148 00149 }; 00150 00151 //set up the scheme type for edge meshing 00152 inline void EdgeMesher::set_edge_scheme(EdgeMesher::EdgeSchemeType scheme) 00153 { 00154 schemeType = scheme; 00155 } 00156 00157 //return the scheme type for edge meshing 00158 inline EdgeMesher::EdgeSchemeType EdgeMesher::get_edge_scheme() const 00159 { 00160 return schemeType; 00161 } 00162 00163 // set the ratio for bias or dual meshing 00164 inline void EdgeMesher::set_ratio(double q) 00165 { 00166 ratio = q; 00167 } 00168 00169 // get the ratio for bias or dual meshing 00170 inline double EdgeMesher::get_ratio() 00171 { 00172 return ratio; 00173 } 00174 } 00175 00176 #endif
