MeshKit
1.0
#include <iostream>#include <cmath>#include <cstdlib>#include <ctime>#include <vector>#include <set>#include <algorithm>#include "moab/Core.hpp"#include "MBTagConventions.hpp"#include "moab/Range.hpp"#include "moab/Skinner.hpp"#include "meshkit/mw_func.hpp"#include "meshkit/cw_func.hpp"#include "meshkit/gen.hpp"#include "meshkit/arc.hpp"#include "meshkit/zip.hpp"#include "TestUtil.hpp"
Classes | |
| struct | coords_and_id |
| struct to hold coordinates of skin edge, it's surface id, and a matched flag More... | |
Functions | |
| ErrorCode | move_vert (EntityHandle vertex, double dx, double dy, double dz, bool verbose) |
| takes an entity handle vertex, gets the original coordinates, changes and resets the vertex coordinates in the mesh | |
| ErrorCode | rand_vert_move (EntityHandle vertex, double tol, bool verbose=false) |
| ErrorCode | move_vert_theta (EntityHandle vertex, double tolerance, bool verbose) |
| moves a vertex along the rim of the cylinder in the theta direction a distance equal to the faceting_tolerance | |
| ErrorCode | move_vert_R (EntityHandle vertex, double tol, bool verbose) |
| moves the vertex in R some distance less than tol | |
| ErrorCode | rand_adj_pair (Range verts, EntityHandle &vert1, EntityHandle &vert2) |
| ErrorCode | write_mod_file (std::string filename) |
| appends "_mod" to the original file name and writes to a new .h5m | |
| ErrorCode | reload_mesh (const char *filename, EntityHandle &meshset, bool debug=false) |
| ErrorCode | single_vert_bump (Range verts, double bump_dist_x, double bump_dist_y, double bump_dist_z, bool verbose=false) |
| bumps the last vertex in the model by the x,y,z values given to the problem | |
| ErrorCode | single_vert_bump_R (Range verts, double facet_tol, bool verbose=false) |
| bumps the last vertex in the cylinder model in the R direction | |
| ErrorCode | locked_pair_bump (Range verts, double bump_dist_x, double bump_dist_y, double bump_dist_z, std::string root_name, bool verbose=false) |
| moves the last two verticies in the model the same distance in x, y, and z | |
| ErrorCode | rand_locked_pair_bump_rand (Range verts, double facet_tol, std::string root_name, bool verbose=false) |
| selects a random pair of verticies from verts and moves them in random directions some distance less than the faceting tolerance | |
| ErrorCode | rand_locked_pair_bump_theta (Range verts, double facet_tol, std::string root_name, bool verbose=false) |
| selects a random pair of verticies and moves them along theta a distance less than the faceting tolerance | |
| ErrorCode | rand_locked_pair_bump (Range verts, double bump_dist_x, double bump_dist_y, double bump_dist_z, std::string root_name, bool verbose=false) |
| selects a random pair of adjacent verticies and bumps them in x, y, and z | |
| ErrorCode | locked_pair_bump_rand (Range verts, double facet_tol, std::string root_name, bool verbose=false) |
| moves the last two verticies in the model in the same direction some distance less than the faceting tolerance | |
| ErrorCode | rand_vert_bump (Range verts, double facet_tol, std::string root_name, bool verbose=false) |
| moves the last vertex in the model in a random direction by a distance less than the faceting tolerance | |
| ErrorCode | theta_vert_bump (Range verts, double bump_dist_theta, double tolerance, std::string root_name, bool verbose=false) |
| moves the last vertex in the model along the curve of the cylinder some distance bump distance theta | |
| ErrorCode | locked_pair_move_theta (Range verts, double tolerance, std::string root_name, bool verbose=false) |
| moves two adjacent vertices along theta a distance equal to the faceting tolerance | |
| ErrorCode | adjplone_locked_pair_bump (Range verts, double bump_dist_x, double bump_dist_y, double bump_dist_z, std::string root_name, bool verbose=false) |
| moves the third to last and the last vertices in the model the same distance in x, y, and z | |
| ErrorCode | adjplone_locked_pair_bump_theta (Range verts, double facet_tol, std::string root_name, bool verbose=false) |
| moves the third to last and the last verticies in the model in theta the same distance along theta equal to the faceting tolerance | |
| ErrorCode | adjplone_locked_pair_bump_rand (Range verts, double facet_tol, std::string root_name, bool verbose=false) |
| moves the third to last and the last verticies in the model in rand directions some distance less than the facet_tolerance | |
| ErrorCode | nonadj_locked_pair_bump (Range verts, double bump_dist_x, double bump_dist_y, double bump_dist_z, std::string root_name, bool verbose=false) |
| selects a random pair of adjacent verticies and bumps them the same distance in x, y, and z | |
| ErrorCode | nonadj_locked_pair_bump_theta (Range verts, double facet_tol, std::string root_name, bool verbose=false) |
| selects a random pair of adjacent verticies and bumps them along the theta direction a distance equal to the faceting tolerance | |
| ErrorCode | nonadj_locked_pair_bump_rand (Range verts, double facet_tol, std::string root_name, bool verbose=false) |
| ErrorCode | locked_pair_bump_R (Range verts, double facet_tol, std::string root_name, bool verbose=false) |
| ErrorCode | rand_locked_pair_bump_R (Range verts, double facet_tol, std::string root_name, bool verbose=false) |
| selects random verticies from verts and moves them in R a distance equal to the faceting tolerance | |
| ErrorCode | adjplone_locked_pair_bump_R (Range verts, double facet_tol, std::string root_name, bool verbose=false) |
| selects a the last vertex and third to last vertex in the model and moves them in R a distance equal to the faceting tolerance | |
| ErrorCode | nonadj_locked_pair_bump_R (Range verts, double facet_tol, std::string root_name, bool verbose=false) |
| moves the last vertex in the model and a randomly selected, non-adjacent vertex and moves them both in R a distance equal to the faceting tolerance | |
| int | main (int argc, char **argv) |
| ErrorCode adjplone_locked_pair_bump | ( | Range | verts, |
| double | bump_dist_x, | ||
| double | bump_dist_y, | ||
| double | bump_dist_z, | ||
| std::string | root_name, | ||
| bool | verbose = false |
Definition at line 484 of file test_make_watertight.cpp.
| ErrorCode adjplone_locked_pair_bump_R | ( | Range | verts, |
| double | facet_tol, | ||
Definition at line 648 of file test_make_watertight.cpp.
| ErrorCode adjplone_locked_pair_bump_rand | ( | Range | verts, |
Definition at line 520 of file test_make_watertight.cpp.
| ErrorCode adjplone_locked_pair_bump_theta | ( | Range | verts, |
Definition at line 502 of file test_make_watertight.cpp.
| ErrorCode locked_pair_bump | ( | Range | verts, |
Definition at line 307 of file test_make_watertight.cpp.
| ErrorCode locked_pair_bump_R | ( | Range | verts, |
Definition at line 610 of file test_make_watertight.cpp.
| ErrorCode locked_pair_bump_rand | ( | Range | verts, |
Definition at line 382 of file test_make_watertight.cpp.
| ErrorCode locked_pair_move_theta | ( | Range | verts, |
| double | tolerance, | ||
Definition at line 467 of file test_make_watertight.cpp.
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 707 of file test_make_watertight.cpp.
| ErrorCode move_vert | ( | EntityHandle | vertex, |
| double | dx, | ||
| double | dy, | ||
| double | dz, | ||
Definition at line 53 of file test_make_watertight.cpp.
| ErrorCode move_vert_R | ( | EntityHandle | vertex, |
| double | tol, | ||
Definition at line 193 of file test_make_watertight.cpp.
| ErrorCode move_vert_theta | ( | EntityHandle | vertex, |
Definition at line 143 of file test_make_watertight.cpp.
| ErrorCode nonadj_locked_pair_bump | ( | Range | verts, |
Definition at line 539 of file test_make_watertight.cpp.
| ErrorCode nonadj_locked_pair_bump_R | ( | Range | verts, |
Definition at line 666 of file test_make_watertight.cpp.
| ErrorCode nonadj_locked_pair_bump_rand | ( | Range | verts, |
Definition at line 587 of file test_make_watertight.cpp.
| ErrorCode nonadj_locked_pair_bump_theta | ( | Range | verts, |
Definition at line 563 of file test_make_watertight.cpp.
| ErrorCode rand_adj_pair | ( | Range | verts, |
| EntityHandle & | vert1, | ||
| EntityHandle & | vert2 | ||
Definition at line 689 of file test_make_watertight.cpp.
| ErrorCode rand_locked_pair_bump | ( | Range | verts, |
Definition at line 363 of file test_make_watertight.cpp.
| ErrorCode rand_locked_pair_bump_R | ( | Range | verts, |
Definition at line 628 of file test_make_watertight.cpp.
| ErrorCode rand_locked_pair_bump_rand | ( | Range | verts, |
Definition at line 324 of file test_make_watertight.cpp.
| ErrorCode rand_locked_pair_bump_theta | ( | Range | verts, |
Definition at line 344 of file test_make_watertight.cpp.
| ErrorCode rand_vert_bump | ( | Range | verts, |
Definition at line 400 of file test_make_watertight.cpp.
| ErrorCode rand_vert_move | ( | EntityHandle | vertex, |
| double | tol, | ||
| bool | verbose | ||
takes an entity handle vertex, gets the original coordinates, changes and resets the vertex coordinates in the mesh setup to move the vert no further than the faceting tolerance
Definition at line 92 of file test_make_watertight.cpp.
| ErrorCode reload_mesh | ( | const char * | filename, |
| EntityHandle & | meshset, | ||
| bool | debug = false |
Definition at line 250 of file test_make_watertight.cpp.
| ErrorCode single_vert_bump | ( | Range | verts, |
Definition at line 283 of file test_make_watertight.cpp.
| ErrorCode single_vert_bump_R | ( | Range | verts, |
Definition at line 295 of file test_make_watertight.cpp.
| ErrorCode theta_vert_bump | ( | Range | verts, |
| double | bump_dist_theta, | ||
Definition at line 414 of file test_make_watertight.cpp.
| ErrorCode write_mod_file | ( | std::string | filename | ) |
Definition at line 237 of file test_make_watertight.cpp.
