MeshKit  1.0
triMeshOp.cpp File Reference
Test the AF2DfltTriangleMeshOp on a variety of surfaces, both flat and curved. More...
#include <cstddef>
#include <iostream>
#include <string>
#include "meshkit/MKCore.hpp"
#include "meshkit/AF2DfltTriangleMeshOp.hpp"
#include "meshkit/SizingFunction.hpp"
#include "meshkit/SizingFunctionVar.hpp"
#include "meshkit/ModelEnt.hpp"
#include "TestUtil.hpp"
Include dependency graph for triMeshOp.cpp:
Defines
#define HAVE_FACET
Functions
MEntVector constructMeshOp (std::string geomFile)
void testMesh (std::string geomFile, std::string meshFile, SizingFunction *sfPtr)
void testSquare ()
void testHoleySurf ()
void testSingleHoleSurf ()
void testSingleHoleSurfImprinted ()
void testSquareVarSize ()
void testPieceOfTorus ()
void testSphere ()
void testBrick ()
int main (int argc, char **argv)
Variables
std::string geomExt = ".facet"
MKCore * mk = NULL
bool saveMesh = false
std::string meshExt = ""
Detailed Description
Test:
In make check the meshes are not saved, but if this test is run separately, it accepts a command line argument specifying the file extension for the type of meshes that it should save.
Definition in file triMeshOp.cpp.
Define Documentation
#define HAVE_FACET
Definition at line 32 of file triMeshOp.cpp.
Function Documentation
MEntVector constructMeshOp ( std::string  geomFile)
Load a geometry file from the test directory with the specified file name (after appending a file name suffix depending on the geometry engine). Then extract all of the newly loaded two-dimensional geometry entities (surfaces) and create an AF2DfltTriangleMeshOp with those surfaces.
Return an MEntVector containing the new surfaces.
Definition at line 107 of file triMeshOp.cpp.
int main ( int  argc,
char **  argv
Definition at line 62 of file triMeshOp.cpp.
void testBrick ( )
Definition at line 289 of file triMeshOp.cpp.
void testHoleySurf ( )
Definition at line 206 of file triMeshOp.cpp.
void testMesh ( std::string  geomFile,
SizingFunction *  sfPtr
Load a geometry file from the test directory with the specified file name (after appending a file name suffix depending on the geometry engine). Then mesh all of the newly loaded two-dimensional geometry entities (surfaces) using an AF2DfltTriangleMeshOp.
After meshing is complete, report the number of triangles, save the mesh to a file with the specified mesh file name (after appending a suffix depending on what the user wanted) if requested, and delete the triangles from the mesh.
Definition at line 149 of file triMeshOp.cpp.
void testPieceOfTorus ( )
Definition at line 239 of file triMeshOp.cpp.
Definition at line 212 of file triMeshOp.cpp.
Definition at line 218 of file triMeshOp.cpp.
void testSphere ( )
Definition at line 245 of file triMeshOp.cpp.
void testSquare ( )
Definition at line 195 of file triMeshOp.cpp.
Definition at line 225 of file triMeshOp.cpp.
Variable Documentation
Definition at line 31 of file triMeshOp.cpp.
Definition at line 60 of file triMeshOp.cpp.
MKCore* mk = NULL
Definition at line 54 of file triMeshOp.cpp.
Definition at line 59 of file triMeshOp.cpp.
