MeshKit
1.0
The core MeshKit instance. More...
#include <meshkit/MKCore.hpp>
Public Member Functions | |
Constructor/destructor | |
| MKCore (iGeom *igeom=NULL, moab::Interface *moab=NULL, iMesh *imesh=NULL, iRel *irel=NULL, bool construct_missing_ifaces=true) | |
| Constructor. | |
| virtual | ~MKCore () |
| virtual destructor | |
Non-static MeshOp construction and query | |
| void | set_default_meshop (const char *op_name, unsigned short dims) |
| Make the specified MeshOp name the default for the given dimension(s) | |
| void | set_default_meshop (unsigned op_index, unsigned short dims) |
| Make the specified MeshOp the default for the given dimension(s) | |
| void | set_default_meshop (MeshOpProxy *mesh_op, unsigned short dims) |
| MeshOpProxy * | get_default_meshop (unsigned dimension) |
| Get default MeshOp for dimension. | |
| void | meshop_by_mesh_type (moab::EntityType tp, std::vector< MeshOpProxy * > &ops) |
| Return MeshOp types that can generate or operate on the specified mesh entity type. | |
| void | meshop_by_dimension (int dim, std::vector< MeshOpProxy * > &ops) |
| Return MeshOp types that can operate on geometric entities of specified dimension. | |
| void | meshop_by_modelent (ModelEnt *const ent, std::vector< MeshOpProxy * > &ops) |
| Return MeshOp types that can mesh the specified ModelEnt. | |
| MeshOp * | construct_meshop (MeshOpProxy *op_info, const MEntVector &me_vec=MEntVector()) |
| Construct a new MeshOp of the specified OpInfo type. | |
| MeshOp * | construct_meshop (std::string op_name, const MEntVector &me_vec=MEntVector()) |
| Construct a new MeshOp of the specified name. | |
| MeshOp * | construct_meshop (unsigned int dim, const MEntVector &me_vec=MEntVector()) |
| Construct the default type of MeshOp for the specified dimension. | |
Loading/saving models | |
| void | load_geometry_mesh (const char *geom_filename, const char *mesh_filename, const char *geom_options=NULL, const char *mesh_options=NULL, int geom_index=0, int mesh_index=0, int irel_index=0, bool relate_too=true, bool populate_too=true) |
| Load a geometry model from a file, and populate mesh entity sets. | |
| void | load_geometry (const char *filename, const char *options=NULL, int geom_index=0, int mesh_index=0, int irel_index=0, bool relate_too=false, bool populate_too=true) |
| void | load_mesh (const char *filename, const char *options=NULL, int geom_index=0, int mesh_index=0, int irel_index=0, bool relate_too=false, bool populate_too=true) |
| Load a mesh model from a file. | |
| void | save_geometry (const char *filename, const char *options=NULL, int index=0) |
| Save a geometry model to a file. | |
| void | save_mesh (const char *filename, const char *options=NULL, int index=0) |
| Save a mesh model to a file. | |
| void | save_mesh_from_model_ents (const char *filename, MEntVector &ments, const char *options=NULL, int index=0) |
| Save part of a model mesh to a file. | |
| void | populate_model_ents (int geom_index=0, int mesh_index=0, int irel_index=0, bool only_geom=false) |
| Populate model entities for geometry and mesh Pass -1 for geom, mesh, or irel index to disable checking for entities in those interfaces (geom, mesh) or skip the check for relations (irel) | |
| void | create_mbg_model_entities (moab::EntityHandle modelRootSet, bool geometry) |
Entity access | |
| void | get_entities_by_dimension (int dim, MEntVector &model_ents, int igindx=-1) |
| Get model entities of a given dimension. | |
| void | get_entities_by_handle (MEntVector &model_ents) |
| Get all model entities. | |
Interface instances | |
| iGeom * | igeom_instance (unsigned index=0) |
| Return the iGeom instance pointer. | |
| unsigned int | add_igeom_instance (iGeom *igeom) |
| Return the index of iGeom instance added. | |
| moab::Interface * | moab_instance (unsigned index=0) |
| Return the MOAB instance pointer. | |
| iMesh * | imesh_instance (unsigned index=0) |
| Return the iMesh instance pointer. | |
| iRel * | irel_instance (unsigned index=0) |
| Return the iRel instance pointer. | |
| unsigned int | add_irel_pair (iRel::PairHandle *pair) |
| Return the index of irel_pair added. | |
| iRel::PairHandle * | irel_pair (unsigned index=0) |
| Return the iRel pair handle used to relate geometry/mesh entities. | |
| iRel::PairHandle * | group_set_pair (unsigned index=0) |
| Return the iRel pair handle used to relate geometry sets to mesh entity sets. | |
| iGeom::TagHandle | igeom_model_tag (unsigned index=0) |
| Return the (iGeom) tag used to relate geometry entities to ModelEnts. | |
| moab::Tag | moab_model_tag (unsigned index=0) |
| Return the (MOAB) tag used to relate mesh entities to ModelEnts. | |
| moab::Tag | moab_geom_dim_tag (unsigned index=0) |
| Return the (MOAB) geometry dimension tag. | |
| moab::Tag | moab_global_id_tag (unsigned index=0) |
| Return the (MOAB) global id tag. | |
Singleton MeshOps | |
| VertexMesher * | vertex_mesher () const |
| Get the (single) VertexMesher instance. | |
| void | vertex_mesher (VertexMesher *vm) |
| Set the (single) VertexMesher instance. | |
| EBMesher * | eb_mesher () const |
| Get the (single) EBMesher instance. | |
| void | eb_mesher (EBMesher *ebm) |
| Set the (single) EBMesher instance. | |
Sizing functions | |
| SizingFunction * | sizing_function (int index) |
| Get sizing function by index If the requested index is outside the range of SizingFunction's currently registered, throws an Error. | |
| SizingFunction * | sizing_function (double size, bool create_if_missing) |
| Get sizing function by size If there is no sizing function with that size and create_if_missing is true, one is constructed and registered with MKCore. | |
| int | add_sizing_function (SizingFunction *sf) |
| Add sizing function to those managed by MeshKit. | |
| void | remove_sizing_function (int index, bool delete_too=true) |
| Remove and, optionally, delete sizing function. | |
| int | initialize_mesh_based_geometry (iBase_EntitySetHandle modelSet) |
| interpret mesh-based geometry | |
| void | remove_mesh_based_geometry (int index) |
| remove mesh-based geometry instance | |
| int | number_of_igeom_instances () |
| retrieve number of iGeom instances | |
| void | delete_model_entities () |
| delete model entities | |
| void | delete_all () |
| delete all | |
Static Public Member Functions | |
| static void | register_meshop (MeshOpProxy *proxy) |
| Register a new MeshOp factory. | |
| static MeshOpProxy * | meshop_proxy (const char *op_name) |
| Return the MeshOp type with the given name. | |
| static MeshOpProxy * | meshop_proxy (unsigned index) |
| Return the MeshOp type at the sepcified index. | |
| static unsigned | num_meshops () |
| Number of registered MeshOps. | |
| static unsigned int | meshop_index (const char *op_name) |
| Return the MeshOp index given the name. | |
Private Member Functions | |
| void | init (bool construct_missing_ifaces) |
| initialize, creating missing geom/mesh/rel interfaces if requested | |
| void | init_opsbydim () |
| Initialize the opsByDim array. | |
Private Attributes | |
| std::vector< iGeom * > | iGeomInstances |
| Geometry api instance. | |
| std::vector< moab::Interface * > | moabInstances |
| MOAB instance. | |
| std::vector< iMesh * > | iMeshInstances |
| iMesh api instance, for use in iRel | |
| std::vector< iRel * > | iRelInstances |
| IREL api instance. | |
| std::vector< iRel::PairHandle * > | iRelPairs |
| iRel pair handle used to relate geometry/mesh entities | |
| std::vector< iRel::PairHandle * > | groupSetPairs |
| iRel pair handle used to relate geometry groups to mesh entity sets | |
| std::vector< iGeom::TagHandle > | iGeomModelTags |
| Tag used to associate geometry entities with model entities. | |
| std::vector< moab::Tag > | moabModelTags |
| Tag used to associate mesh entities with model entities. | |
| std::vector< moab::Tag > | moabGeomDimTags |
| Tag used to associate existing mesh entities with model entities. | |
| std::vector< moab::Tag > | moabIDTags |
| std::vector< bool > | iCreatedIgeoms |
| If true, the corresponding interfaces will get deleted from the destructor. | |
| std::vector< bool > | iCreatedMoabs |
| std::vector< bool > | iCreatedImeshs |
| std::vector< bool > | iCreatedIrels |
| MEntVector | modelEnts [5] |
| Model entities, in array by topological dimension. | |
| VertexMesher * | vertexMesher |
| (Single) VertexMesher scheme for this MKCore | |
| EBMesher * | ebMesher |
| (Single) EBMesher scheme for this MKCore | |
| MeshOpProxy * | defaultMeshOps [4] |
| Default algorithms for each dimension. | |
| std::vector< SizingFunction * > | sizingFunctions |
| SizingFunction vector. | |
The MKCore object stores MeshKit-wide data like the geometry/mesh/relations instances, and is the object through which other MeshKit class objects are accessed. Since it is a child class of MeshOp, the MKCore instance can also be a node in the MeshOp graph. By convention, the MKCore instance serves as the root of the this (directed) graph.
If the MKCore constructor is called with no arguments, then instances of the geometry, mesh, and relations databases are created inside the constructor; these instances are then deleted in the MKCore destructor. If this is not the desired behavior, either pass in non-NULL instances to the MKCore constructor, or re-set the iCreatedIgeom, iCreatedMoab, and/or iCreatedIrel flags in this class.
Definition at line 45 of file MKCore.hpp.
| MKCore | ( | iGeom * | igeom = NULL, |
| moab::Interface * | moab = NULL, |
| iMesh * | imesh = NULL, |
| iRel * | irel = NULL, |
| bool | construct_missing_ifaces = true |
Constructor.
| igeom | iGeom instance |
| moab | MOAB instance |
| imesh | iMesh instance; if non-NULL, should use/point to moab parameter |
| irel | iRel instance |
| construct_missing_ifaces | If true, constructs the interfaces whose handles are passed in NULL |
Definition at line 44 of file MKCore.cpp.
| ~MKCore | ( | ) | [virtual] |
virtual destructor
Definition at line 88 of file MKCore.cpp.
| unsigned int add_igeom_instance | ( | iGeom * | igeom | ) |
| igeom | iGeom interface to be added |
Definition at line 210 of file MKCore.cpp.
| unsigned int add_irel_pair | ( | iRel::PairHandle * | pair | ) | [inline] |
| pair | iRel::PairHandle pointer to be added |
Definition at line 575 of file MKCore.hpp.
| int add_sizing_function | ( | SizingFunction * | sf | ) |
The argument to this function is a SizingFunction*; once added, it is MKCore's responsibility to delete this SizingFunction. Applications can tell MKCore to delete a given SizingFunction (e.g. if it requires lots of memory) by calling delete_sizing_function.
| sf | SizingFunction* to be added |
Definition at line 481 of file MKCore.cpp.
| MeshOp * construct_meshop | ( | MeshOpProxy * | op_info, |
| const MEntVector & | me_vec = MEntVector() |
| op_info | OpInfo for the MeshOp being requested |
| me_vec | MEntVector of entities the operation applies to |
Definition at line 620 of file MKCore.cpp.
| MeshOp * construct_meshop | ( | std::string | op_name, |
| op_name | MeshOp name being requested |
Definition at line 599 of file MKCore.cpp.
| MeshOp * construct_meshop | ( | unsigned int | dim, |
| dim | Dimension requested |
Definition at line 604 of file MKCore.cpp.
| void create_mbg_model_entities | ( | moab::EntityHandle | modelRootSet, |
| bool | geometry | ||
\ brief create model entities based on a set root for mesh based geometry
| modelRootSet | root model for a complete topology model (for GeomTopoTool) |
| geometry | flag true for FBiGeom geometry, false for simple mesh ModelEnts |
Definition at line 689 of file MKCore.cpp.
| void delete_all | ( | ) |
delete all
This function clears memory occupied by model entities, deletes graph, deletes mesh and geometry
Definition at line 680 of file MKCore.cpp.
| void delete_model_entities | ( | ) |
This function clears memory occupied by model entities, and empties the vectors. more careful with the lifecycles.
Definition at line 668 of file MKCore.cpp.
Definition at line 631 of file MKCore.hpp.
Definition at line 636 of file MKCore.hpp.
| MeshOpProxy * get_default_meshop | ( | unsigned | dimension | ) |
Get the default meshop for the specified dimension of entity. Throws excpetion if no there are no registered MeshOps that can mesh entities of the passed dimension.
| dimension | Dimension of entity to be meshed. |
Definition at line 543 of file MKCore.cpp.
| void get_entities_by_dimension | ( | int | dim, |
| MEntVector & | model_ents, | ||
| int | igindx = -1 |
| dim | Dimension of entities to get (-1 to get all model entities) |
| model_ents | The list these entities get appended to |
| igindx | the geometry instance index of the retrieved model ents (default -1 means no check on igeom instance index) |
Definition at line 443 of file MKCore.cpp.
| void get_entities_by_handle | ( | MEntVector & | model_ents | ) |
Definition at line 476 of file MKCore.cpp.
| iRel::PairHandle * group_set_pair | ( | unsigned | index = 0 | ) | [inline] |
Definition at line 581 of file MKCore.hpp.
| iGeom * igeom_instance | ( | unsigned | index = 0 | ) | [inline] |
| index | Index of desired iGeom, default to first |
Definition at line 535 of file MKCore.hpp.
| iGeom::TagHandle igeom_model_tag | ( | unsigned | index = 0 | ) | [inline] |
Definition at line 589 of file MKCore.hpp.
| iMesh * imesh_instance | ( | unsigned | index = 0 | ) | [inline] |
| index | Index of desired iMesh, default to first |
Definition at line 551 of file MKCore.hpp.
| void init | ( | bool | construct_missing_ifaces | ) | [private] |
Definition at line 113 of file MKCore.cpp.
| void init_opsbydim | ( | ) | [private] |
| int initialize_mesh_based_geometry | ( | iBase_EntitySetHandle | modelSet | ) |
| iRel * irel_instance | ( | unsigned | index = 0 | ) | [inline] |
Definition at line 559 of file MKCore.hpp.
| iRel::PairHandle * irel_pair | ( | unsigned | index = 0 | ) | [inline] |
Definition at line 567 of file MKCore.hpp.
| void load_geometry | ( | const char * | filename, |
| const char * | options = NULL, |
| int | geom_index = 0, |
| int | mesh_index = 0, |
| int | irel_index = 0, |
| bool | relate_too = false, |
| bool | populate_too = true |
| filename | The file to load |
| options | File options to be passed to the load function |
| geom_index | Index of geometry instance to use |
| mesh_index | Index of mesh instance to use |
| irel_index | Index of irel instance to use |
| relate_too | If true, infers all geometry-mesh relations after load |
| populate_too | If true, calls populate_modelents after load and relate |
Definition at line 384 of file MKCore.cpp.
| void load_geometry_mesh | ( | const char * | geom_filename, |
| const char * | mesh_filename, | ||
| const char * | geom_options = NULL, |
| const char * | mesh_options = NULL, |
| bool | relate_too = true, |
| geom_filename | The file from which to load geometry |
| mesh_filename | The file from which to load mesh |
| geom_options | File options to be passed to the load_geometry function |
| mesh_options | File options to be passed to the load_mesh function |
| relate_too | If true, infers all geometry-mesh relations after mesh load |
Definition at line 353 of file MKCore.cpp.
| void load_mesh | ( | const char * | filename, |
Definition at line 399 of file MKCore.cpp.
| void meshop_by_dimension | ( | int | dim, |
| std::vector< MeshOpProxy * > & | ops | ||
| dim | Entity dimension requested |
| ops | MeshOp types returned |
Definition at line 585 of file MKCore.cpp.
| void meshop_by_mesh_type | ( | moab::EntityType | tp, |
| tp | Entity type requested |
Definition at line 570 of file MKCore.cpp.
| void meshop_by_modelent | ( | ModelEnt *const | ent, |
| ent | ModelEnt* requested |
Definition at line 591 of file MKCore.cpp.
| unsigned int meshop_index | ( | const char * | op_name | ) | [static] |
| op_name | Operation name requested |
Definition at line 528 of file MKCore.cpp.
| MeshOpProxy * meshop_proxy | ( | const char * | op_name | ) | [static] |
Definition at line 513 of file MKCore.cpp.
| MeshOpProxy * meshop_proxy | ( | unsigned | index | ) | [static] |
| index | Operation index requested |
Definition at line 518 of file MKCore.cpp.
| moab::Tag moab_geom_dim_tag | ( | unsigned | index = 0 | ) | [inline] |
Definition at line 605 of file MKCore.hpp.
| moab::Tag moab_global_id_tag | ( | unsigned | index = 0 | ) | [inline] |
Definition at line 613 of file MKCore.hpp.
| moab::Interface * moab_instance | ( | unsigned | index = 0 | ) | [inline] |
| index | Index of desired moab instance, default to first |
Definition at line 543 of file MKCore.hpp.
| moab::Tag moab_model_tag | ( | unsigned | index = 0 | ) | [inline] |
Definition at line 597 of file MKCore.hpp.
| unsigned num_meshops | ( | ) | [static] |
Definition at line 523 of file MKCore.cpp.
| int number_of_igeom_instances | ( | ) | [inline] |
This function returns number of igeom instances, to be used by some mesh operations.
Definition at line 459 of file MKCore.hpp.
| void populate_model_ents | ( | int | geom_index = 0, |
| bool | only_geom = false |
| use_irel | flag to create relations or not |
Definition at line 235 of file MKCore.cpp.
| void register_meshop | ( | MeshOpProxy * | proxy | ) | [static] |
| proxy | class-specific (as opposed to instance-specific) polymorphic methods |
Definition at line 508 of file MKCore.cpp.
| void remove_mesh_based_geometry | ( | int | index | ) |
This function removes the FBiGeom instance and clears some memory (will delete the smooth tags, among other things), but it should preserve the geom topo model intact
| void remove_sizing_function | ( | int | index, |
| bool | delete_too = true |
This function removes the referenced sizing function from MKCore's list (setting the corresponding SizingFunction* to NULL, to keep others at the same index position). Throws an Error if requested sizing function is NULL.
| index | Index of SizingFunction to be removed |
| delete_too | If true, deletes the SizingFunction object too |
Definition at line 487 of file MKCore.cpp.
| void save_geometry | ( | const char * | filename, |
| int | index = 0 |
| filename | The file to save |
| options | File options to be passed to the save function |
Definition at line 415 of file MKCore.cpp.
| void save_mesh | ( | const char * | filename, |
| int | index = 0 |
Definition at line 421 of file MKCore.cpp.
| void save_mesh_from_model_ents | ( | const char * | filename, |
| MEntVector & | ments, | ||
| int | index = 0 |
| ments | vector of model entities to be exported |
Definition at line 427 of file MKCore.cpp.
| void set_default_meshop | ( | const char * | op_name, |
| unsigned short | dims | ||
If the specified MeshOp cannot produce entities of the specified dimension, an error is thrown with type MK_BAD_INPUT.
| op_name | MeshOp name being set |
| dims | Bitmask, where 2^x indicates that this MeshOp should be the default for dimension x |
Definition at line 533 of file MKCore.cpp.
| void set_default_meshop | ( | unsigned | op_index, |
| op_index | MeshOp index being set |
Definition at line 538 of file MKCore.cpp.
| void set_default_meshop | ( | MeshOpProxy * | mesh_op, |
| mesh_op | MeshOp being set |
Definition at line 557 of file MKCore.cpp.
| SizingFunction * sizing_function | ( | int | index | ) | [inline] |
| index | Index of sizing function requested |
Definition at line 641 of file MKCore.hpp.
| SizingFunction * sizing_function | ( | double | size, |
| bool | create_if_missing | ||
| size | Requested size |
| create_if_missing | If true and no sizing function exists with the specified size, one is created. |
Definition at line 497 of file MKCore.cpp.
| VertexMesher * vertex_mesher | ( | ) | const [inline] |
Definition at line 626 of file MKCore.hpp.
| void vertex_mesher | ( | VertexMesher * | vm | ) | [inline] |
| vm | VertexMesher for this MKCore |
Definition at line 621 of file MKCore.hpp.
MeshOpProxy* defaultMeshOps[4] [private] |
Definition at line 529 of file MKCore.hpp.
Definition at line 526 of file MKCore.hpp.
std::vector<iRel::PairHandle *> groupSetPairs [private] |
Definition at line 502 of file MKCore.hpp.
std::vector<bool> iCreatedIgeoms [private] |
Definition at line 517 of file MKCore.hpp.
std::vector<bool> iCreatedImeshs [private] |
std::vector<bool> iCreatedIrels [private] |
std::vector<bool> iCreatedMoabs [private] |
std::vector<iGeom *> iGeomInstances [private] |
Definition at line 487 of file MKCore.hpp.
std::vector<iGeom::TagHandle> iGeomModelTags [private] |
Definition at line 505 of file MKCore.hpp.
std::vector<iMesh *> iMeshInstances [private] |
Definition at line 493 of file MKCore.hpp.
std::vector<iRel *> iRelInstances [private] |
IREL api instance.
Definition at line 496 of file MKCore.hpp.
std::vector<iRel::PairHandle *> iRelPairs [private] |
Definition at line 499 of file MKCore.hpp.
std::vector<moab::Tag> moabGeomDimTags [private] |
Definition at line 511 of file MKCore.hpp.
std::vector<moab::Tag> moabIDTags [private] |
Definition at line 514 of file MKCore.hpp.
std::vector<moab::Interface *> moabInstances [private] |
MOAB instance.
Definition at line 490 of file MKCore.hpp.
std::vector<moab::Tag> moabModelTags [private] |
Definition at line 508 of file MKCore.hpp.
MEntVector modelEnts[5] [private] |
Definition at line 520 of file MKCore.hpp.
std::vector<SizingFunction*> sizingFunctions [private] |
Definition at line 532 of file MKCore.hpp.
VertexMesher* vertexMesher [private] |
Definition at line 523 of file MKCore.hpp.
