MeshKit
1.0
Simple brick with source surface meshed
Meshed brick
#include "meshkit/MKCore.hpp" #include "meshkit/OneToOneSwept.hpp" #include "meshkit/SizingFunction.hpp" #include "meshkit/ModelEnt.hpp" #include "meshkit/Matrix.hpp" #include "meshkit/VertexMesher.hpp" using namespace MeshKit; std::string gfile_name; std::string mfile_name; // these are indices in the volume for source and target surfaces int index_source, index_target; int mesh_intervals; MKCore *mk = NULL; void test_brick(); int main(int argc, char **argv) { if (argc==1) { #if HAVE_OCC gfile_name = (std::string) MESH_DIR + "/brick.stp"; mfile_name = (std::string) MESH_DIR + "/sf.h5m"; index_source = 0; index_target = 1; mesh_intervals = 6; #else gfile_name = (std::string) MESH_DIR + "/BrickWithSrcMeshed.cub"; mfile_name = gfile_name; index_source = 1; index_target = 0; mesh_intervals = 6; #endif std::cout<<"using default arguments: "; } else if (argc==6) { gfile_name = argv[1]; mfile_name = argv[2]; index_source = atoi(argv[3]); index_target = atoi(argv[4]); mesh_intervals = atoi(argv[5]); std::cout << "Using arguments: "; } else { std::cout<<"Usage: " << argv[0] << " <geo_file> <mesh_file> <index_src> <index_tar> <mesh_intervals>\n"; return 1; // error } std::cout << argv[0] << " " << gfile_name << " " << mfile_name << " " << index_source << " " << index_target << " " << mesh_intervals << "\n"; // start up MK and load the geometry mk = new MKCore(); int num_fail = 0; test_brick(); return num_fail; } void test_brick() { mk->load_geometry_mesh(gfile_name.c_str(), mfile_name.c_str()); // get the volumes MEntVector vols, surfs, curves, vertices; mk->get_entities_by_dimension(3, vols); std::cout << "Volume size = " << vols.size() << std::endl; ModelEnt *this_vol = (*vols.rbegin()); //make a one-to-one sweeping OneToOneSwept *sw = (OneToOneSwept*) mk->construct_meshop("OneToOneSwept", vols); sw->SetSourceSurface(index_source); sw->SetTargetSurface(index_target); //set up the size SizingFunction swSize(mk, mesh_intervals, -1); this_vol->sizing_function_index(swSize.core_index()); //set up for the sweeping and sweep mk->setup_and_execute(); //check the number of cells after OneToOneSwept moab::Range hex; mk->moab_instance()->get_entities_by_dimension(0, 3, hex); std::cout << " generated " << hex.size() << " hexahedrons\n"; mk->save_mesh("OneToOneSwept.h5m"); delete sw; delete mk->vertex_mesher(); mk->clear_graph(); }
