MeshKit
1.0
/* * test for volume creation operation * volumes are created with 2 initial surfaces, top and bottom, one cropping line, and * several splitting lines; also, a main direction for all operations, including weaving * top and bottom are first cropped, then split several times (in this example, 2 times) */ #include <iostream> #include <fstream> #include <time.h> #include <stdlib.h> #include <cstring> #include "meshkit/MKCore.hpp" #include "meshkit/MeshOp.hpp" #include "meshkit/ModelEnt.hpp" #include "meshkit/MBVolOp.hpp" #include "meshkit/MBSplitOp.hpp" using namespace MeshKit; #include "meshkit/ReadPolyLine.hpp" MKCore *mk; std::string usage_string = " <input file bottom> <input file top> input files.\n" "< direction > 3 doubles for sweeping direction\n" " <output file > output moab database \n"; std::string filename_top; std::string filename_bot; double direction[3]={0., 0., 1.}; std::string output_file_name; int main(int argc, char* argv[]) { // check command line arg filename_bot = (std::string) MESH_DIR + "/BedCropL3.h5m"; filename_top = (std::string) MESH_DIR + "/SurfCropL3.h5m";//"/polyPB.txt"; output_file_name = "volumesIce.h5m"; // output //number_tests_successful = 0; if (argc<=1) { std::cout<<usage_string; std::cout << "\n\n"; std::cout<< "default arguments:" << filename_bot << " "<<filename_top << " " << " "<<direction[0] << " " << direction[1] << " "<< direction[2]<<" " << output_file_name <<"\n"; } else if (argc==7) { filename_bot = argv[1]; filename_top = argv[2]; direction[0] = atof(argv[3]); direction[1] = atof(argv[4]); direction[2] = atof(argv[5]); output_file_name= argv[6]; } else { std::cout << usage_string << " abort.\n"; return 1; } // initialize everything mk = new MKCore(); mk->load_mesh(filename_bot.c_str()); MEntVector botFaces; // we should have 2 faces only, for top and bottom mk->get_entities_by_dimension(2, botFaces); // load a second one mk->load_mesh(filename_top.c_str()); MEntVector allFaces; mk->get_entities_by_dimension(2, allFaces); MBVolOp *eVolOp = (MBVolOp*) mk->construct_meshop("MBVolOp", allFaces); //selection.push_back(*dum.rbegin());// push just the last one retrieved from core eVolOp->set_direction(direction[0], direction[1], direction[2]); std::cout<<"Total number of faces: " << allFaces.size() << "\n"; mk->setup_and_execute(); if(output_file_name.length()>0) { std::cout << "writing output to " << output_file_name << std::endl; // output only the root set with the volume // MEntSelection & mentset = eVolOp->me_selection(); moab::Range rangeResult = (*(mentset.begin()) ).second; moab::EntityHandle resultSet = rangeResult[0]; // the first set mk->moab_instance()->write_mesh(output_file_name.c_str(), &resultSet, 1);// write the result set only } return 0; }
