MeshKit
1.0
This example creates a face and extrudes it.
Inputs are: coords of face, sides in the face, topology of the face and translation distance dx.
Final mesh with 10 hex elements is saved
#include "meshkit/MKCore.hpp" #include "meshkit/MeshOp.hpp" #include "meshkit/ExtrudeMesh.hpp" #include "meshkit/ModelEnt.hpp" using namespace MeshKit; #define DEFAULT_TEST_FILE "cube.cub" MKCore *mk; int main(int argc, char **argv) { mk = new MKCore(); //input size_t nverts = 4; double coords[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0 }; iMesh_EntityTopology topo = iMesh_QUADRILATERAL; // working with imesh instance iMesh *mesh = mk->imesh_instance(); std::vector<iMesh::EntityHandle> verts(nverts); iMesh::EntityHandle face; iMesh::EntitySetHandle set; mesh->createVtxArr(nverts, iBase_INTERLEAVED, coords, &verts[0]); mesh->createEnt(topo, &verts[0], nverts, face); mesh->createEntSet(true, set); mesh->addEntToSet(face, set); ModelEnt me(mk, iBase_EntitySetHandle(0), /*igeom instance*/0, (moab::EntityHandle)set); MEntVector selection; selection.push_back(&me); ExtrudeMesh *em = (ExtrudeMesh*) mk->construct_meshop("ExtrudeMesh", selection); em->set_name("extrude_mesh"); Vector<3> dx; dx[0] = 0; dx[1] = 0; dx[2] = 10; em->set_transform(Extrude::Translate(dx, 10)); em->copy_faces(true); // put them in the graph mk->get_graph().addArc(mk->root_node()->get_node(), em->get_node()); mk->get_graph().addArc(em->get_node(), mk->leaf_node()->get_node()); em->copy_sets().add_set(set); em->extrude_sets().add_set(set); // mesh embedded boundary mesh, by calling execute mk->setup_and_execute(); mk->save_mesh("out_em.exo"); return 0; }
