MeshKit  1.0
ModelEnt Class Reference
The class used in MeshKit for referring to model entities and mesh associated with them. More...
#include <meshkit/ModelEnt.hpp>
List of all members.
Public Member Functions
IAVariable * ia_var () const
void ia_var (IAVariable *v)
double mesh_interval_size () const
double measure () const
void mesh_intervals (const int set_mesh_int)
Firmness interval_firmness () const
 ModelEnt ()
Public Attributes
int stub_id
IAVariable * iaVar
double meshIntervalSize
double entMeasure
Firmness entFirmness
Static Public Attributes
static int max_stub_id = 0
Constructor/destructor
 ModelEnt (MKCore *mk, iGeom::EntityHandle geom_ent, int geom_index, moab::EntityHandle mesh_ent=0, int mesh_index=-1, int irel_index=-1, int sizing_index=-1)
 Constructor; mesh entity can be missing, in which case it's retrieved or created.
 ModelEnt (MKCore *mk, iGeom::EntitySetHandle geom_set, int geom_index, moab::EntityHandle mesh_ent=0, int mesh_index=-1, int irel_index=-1, int sizing_index=-1, IAVariable *ia_var=NULL)
virtual ~ModelEnt ()
 Destructor.
Topology
void children (std::vector< MEntVector > &child_ents) const
 Return children as vectors of vectors, e.g. for loops or shells.
void children (std::vector< std::vector< moab::EntityHandle > > &child_ents) const
void children (std::vector< std::vector< iGeom::EntityHandle > > &child_ents) const
void get_adjacencies (int dim, MEntVector &adjs) const
 Return adjacencies to this model entity of the input dimension.
void get_adjacencies (int dim, std::vector< iGeom::EntityHandle > &adjs) const
void get_adjacencies (int dim, std::vector< moab::EntityHandle > &adjs) const
void get_adjacencies (int dim, moab::Range &adjs) const
ModelEnt * shared_entity (ModelEnt *ent2, int to_dim)
 Return a shared entity of specified dimension.
void get_adjs_bool (MEntVector &from_ents, int to_dim, MEntVector &to_ents, BooleanType op_type, bool only_to_ents=true)
 Get adjacent entities, with specified boolean on results.
Geometric evaluation
int dimension () const
 Return the topological dimension of this model entity.
 Measure of this entity, -DBL_MAX for vertices, or length, area, or volume.
double measure_discrete () const
 Similar as measure, but based on mesh.
void evaluate (double x, double y, double z, double *close=NULL, double *direction=NULL, double *curvature1=NULL, double *curvature2=NULL) const
 Evaluate entity at a point.
void evaluate_discrete (double x, double y, double z, double *close=NULL, double *direction=NULL, double *curvature1=NULL, double *curvature2=NULL) const
 Evaluate entity at a point, based on mesh data.
int id () const
 Get the id of the geometry/mesh entity, if any.
Mesh
void create_mesh_set (int ordered_flag=-1)
 Create mesh set for this ModelEnt.
void commit_mesh (moab::Range &mesh_ents, MeshedState mstate)
 Commit mesh to a model entity.
void commit_mesh (moab::EntityHandle *mesh_ents, int num_ents, MeshedState mstate)
void get_mesh (int dim, std::vector< moab::EntityHandle > &ments, bool bdy_too=false)
 Return the mesh on this entity, of the specified dimension or (if dim=-1) all dimensions.
void boundary (int dim, std::vector< moab::EntityHandle > &bdy, std::vector< int > *senses=NULL, std::vector< int > *group_sizes=NULL)
 Return the mesh bounding this entity, their senses, and optionally the loops/shells.
void boundary (int dim, MEntVector &elements, std::vector< int > *senses, std::vector< int > *group_sizes=NULL)
 Return the model entities bounding this entity, their senses, and optionally the loops/shells.
void boundary (int dim, moab::Range &ents) const
 Return mesh bounding this model entity in a Range (unordered wrt model entity)
void get_indexed_connect_coords (std::vector< moab::EntityHandle > &ents, std::vector< int > *senses, moab::Tag tagh, std::vector< int > &ents_as_ids, std::vector< double > &coords, moab::Range *verts_range=NULL, int start_index=0)
 From a vector of entity handles, return connectivity as integer ids, and coords of vertices if requested.
MeshedState get_meshed_state ()
 Get meshed state.
void set_meshed_state (MeshedState mstate)
 Set the meshed state.
Mesh intervals, sizing functions
int sizing_function_index () const
 Get sizing function index.
void sizing_function_index (int index, bool children_too=true)
 Set sizing function index.
 Get mesh interval size, if any Returns -1 if no size set on this entity. If intervals are set and this is a model edge, returns computed size.
int mesh_intervals () const
 Get intervals.
void mesh_intervals (int ints)
 Set intervals.
 Get firmness.
void interval_firmness (Firmness firm)
 Set firmness.
bool constrain_even () const
 Get constrainEven.
void constrain_even (bool flag)
 Set constrainEven.
MeshOps
void add_meshop (MeshOp *meshop)
 Add a MeshOp that points to this ModelEnt.
void remove_meshop (MeshOp *meshop)
 Remove a MeshOp that pointed to this ModelEnt.
void get_meshops (std::vector< MeshOp * > &meshops)
 Get MeshOps pointing to this ModelEnt.
bool is_meshops_list_empty ()
 decide if there is a meshop defined for this model entity
Interfaces, entities
MKCore * mkCore
 MeshKit instance to which this model entity is associated.
int igeomIndex
 iGeom instance index associated with this model entity
int meshIndex
 MOAB instance index associated with this model entity.
int irelIndex
 iRel pair index associated with this model entity
iGeom::EntityHandle iGeomEnt
 Geometry entity for this model entity.
iGeom::EntitySetHandle iGeomSet
 Geometry set for this model entity.
moab::EntityHandle moabEntSet
 Mesh entity set for this model entity.
int sizingFunctionIndex
 Sizing function associated with this model entity.
int meshIntervals
 Mesh intervals for this model entity.
Firmness intervalFirmness
 Mesh interval firmness for this model entity.
bool constrainEven
 Constrain mesh intervals to be even.
MeshedState meshedState
 Meshed state of this entity.
std::vector< MeshOp * > meshOps
 MeshOps pointing to this entity.
IAVariable * iaVariable
 interval assignment variable
MKCore * mk_core () const
 Get the MKCore object.
iGeom::EntityHandle geom_handle () const
 Get geometry entity handle.
iGeom::EntityHandle geom_handle (moab::EntityHandle ment) const
 Get geometry entity handle for a given mesh entity set.
iGeom * igeom_instance () const
 Get iGeom instance associated with this model entity.
moab::Interface * moab_instance () const
 Get moab instance associated with this model entity.
moab::EntityHandle mesh_handle () const
 Get mesh entity set handle.
moab::EntityHandle mesh_handle (iGeom::EntityHandle gent) const
 Get mesh entity set handle for a given geometry entity.
moab::EntityHandle mesh_handle (iGeom::EntitySetHandle gent) const
int iGeomIndex ()
int iRelPairIndex ()
const IAVariable * ia_var () const
void ia_var (IAVariable *var)
ModelEnt * next_winding (ModelEnt *this_edge, int this_sense, MEntVector &tmp_adjs)
 Return the next entity in the loop, using winding number.
void init_parents_children ()
 Initialize mesh set parents/children to parallel geometric topology.
void init_group_contents ()
 Initialize mesh set contents to parallel geometry set contents.
void set_downward_senses ()
 Set senses tag on moabEntSet wrt adjacent entities.
Detailed Description
Instances of this class are references to the entities stored in the geometry and mesh databases. Destruction/construction of ModelEnt instances does not cause destruction/construction of the corresponding database entities (one exception to this statement is that an argument to the constructor can request that the mesh entity set be created for the corresponding geometry entity).
A ModelEnt instance keeps a reference to the MKCore object to which it is associated; through that instance it can get access to the geometry/mesh/relation database instances.
Examples:
example_basic.cpp, example_copymesh.cpp, example_extrudemesh.cpp, example_graph.cpp, example_intassign.cpp, example_onetooneswept.cpp, example_setpnt2quad.cpp, and example_volice.cpp.
Definition at line 30 of file ModelEnt.hpp.
ModelEnt ( MKCore *  mk,
int  geom_index,
moab::EntityHandle  mesh_ent = 0,
int  mesh_index = -1,
int  irel_index = -1,
int  sizing_index = -1
Parameters:
mkMeshKit instance
geom_entGeometry entity corresponding to this ModelEntity
igeomiGeom instance
mesh_entMesh entity set corresponding to this ModelEntity
sizing_indexSizing function index (from MBCore) to be used to mesh this entity
Definition at line 15 of file ModelEnt.cpp.
int  geom_index,
int  sizing_index = -1,
IAVariable *  ia_var = NULL
Parameters:
mkMeshKit instance
geom_setGeometry entity set corresponding to this ModelEntity
igeomiGeom instance
Definition at line 60 of file ModelEnt.cpp.
~ModelEnt ( ) [virtual]
Destructor.
Definition at line 108 of file ModelEnt.cpp.
ModelEnt ( ) [inline]
Definition at line 40 of file IntervalAssignment/stubs/IAVariable.hpp.
Member Function Documentation
void add_meshop ( MeshOp *  meshop) [inline]
Parameters:
meshopMeshOp to add
Definition at line 645 of file ModelEnt.hpp.
void boundary ( int  dim,
std::vector< moab::EntityHandle > &  bdy,
std::vector< int > *  senses = NULL,
std::vector< int > *  group_sizes = NULL
In the case where vertices are requested (dim=0), vertices on end of loops are *not* repeated
Parameters:
dimDimension of boundary entities requested
bdyBoundary entities
sensesSenses of boundary entities
group_sizesIf non-NULL, pointer to vector where group sizes will be returned
Examples:
example_intassign.cpp.
Definition at line 530 of file ModelEnt.cpp.
MEntVector &  elements,
std::vector< int > *  senses,
Parameters:
elementsBoundary entities
Definition at line 573 of file ModelEnt.cpp.
moab::Range &  ents
) const
This function returns boundary entities in a Range, which means they're not guaranteed to be ordered consistently with respect to the model entity orientation. The input range is appended to (i.e. it is not emptied first).
Parameters:
dimDimension of requested boundary entities
entsBoundary entities requested
Definition at line 907 of file ModelEnt.cpp.
void children ( std::vector< MEntVector > &  child_ents) const [inline]
No ordered flag, since that's implied by definition
Parameters:
child_entsChild entities returned
Definition at line 674 of file ModelEnt.hpp.
void children ( std::vector< MEntVector > &  child_ents) [inline]
Parameters:
Definition at line 675 of file ModelEnt.hpp.
void children ( std::vector< std::vector< moab::EntityHandle > > &  child_ents) const [inline]
Parameters:
Definition at line 553 of file ModelEnt.hpp.
void children ( std::vector< std::vector< iGeom::EntityHandle > > &  child_ents) const [inline]
Parameters:
Definition at line 571 of file ModelEnt.hpp.
void commit_mesh ( moab::Range &  mesh_ents,
MeshedState  mstate
Takes the input mesh entities, adds them to the entity set for this model entity, and (if both-type relation on the mesh side) sets the relations to the corresponding geometry entity.
Parameters:
mesh_entsMesh entities being assigned to this model entity
mstateThe meshed state after this mesh is added
Definition at line 338 of file ModelEnt.cpp.
void commit_mesh ( moab::EntityHandle *  mesh_ents,
int  num_ents,
MeshedState  mstate
Parameters:
mesh_entsPointer to mesh entities being assigned to this model entity
num_entsNumber of mesh entities in list
Takes the input mesh entities, and adds them to the entity set for this model entity.
Parameters:
Definition at line 351 of file ModelEnt.cpp.
bool constrain_even ( ) const [inline]
Get constrainEven.
Definition at line 613 of file ModelEnt.hpp.
void constrain_even ( bool  flag) [inline]
Set constrainEven.
Parameters:
flagSet value
Definition at line 618 of file ModelEnt.hpp.
void create_mesh_set ( int  ordered_flag = -1)
This function creates the entity set for a geometry entity, and tags that set according to convention (GEOM_DIMENSION and GLOBAL_ID). It also sets the relation with the corresponding geometry entity. The value of flag controls whether a vector- or set-based entity set is created: flag = 1 : create a vector-based set flag = 0 : create a set-based set flag = -1: check dimension of iGeomEnt; if 1, vector-based set, otherwise set-based set
Parameters:
ordered_flagOrdered flag
Definition at line 145 of file ModelEnt.cpp.
int dimension ( ) const
Definition at line 382 of file ModelEnt.cpp.
void evaluate ( double  x,
double  y,
double  z,
double *  close = NULL,
double *  direction = NULL,
double *  curvature1 = NULL,
double *  curvature2 = NULL
) const
If any of the evaluation results are not wanted, pass NULL for them. At least one must be provided. This function throws an error if called on a vertex or volume and non-NULL is passed for direction or curvature. Direction is the tangent for edges, normal for surfaces.
Parameters:
xStart point x
yStart point y
zStart point z
closeClosest point
directionTangent or normal returned for edges or surfaces
curvature11st curvature for edges or surfaces
curvature22nd curvature for edges or surfaces
Definition at line 412 of file ModelEnt.cpp.
void evaluate_discrete ( double  x,
double  y,
double  z,
) const [inline]
Parameters:
xStart point x
yStart point y
zStart point z
closeClosest point
Definition at line 633 of file ModelEnt.hpp.
iGeom::EntityHandle geom_handle ( ) const [inline]
Definition at line 543 of file ModelEnt.hpp.
iGeom::EntityHandle geom_handle ( moab::EntityHandle  ment) const
Definition at line 1001 of file ModelEnt.cpp.
void get_adjacencies ( int  dim,
MEntVector &  adjs
) const
This function appends adjacencies to the input vector.
Parameters:
dimDimension of entities requested; if -1, all adjacent entities are returned
adjsAdjacent entities
Examples:
example_volice.cpp.
Definition at line 364 of file ModelEnt.cpp.
std::vector< iGeom::EntityHandle > &  adjs
) const [inline]
Parameters:
Definition at line 671 of file ModelEnt.hpp.
std::vector< moab::EntityHandle > &  adjs
) const [inline]
Parameters:
Definition at line 672 of file ModelEnt.hpp.
moab::Range &  adjs
) const [inline]
This function adds adjacencies to the input range.
Parameters:
Definition at line 673 of file ModelEnt.hpp.
void get_adjs_bool ( MEntVector &  from_ents,
int  to_dim,
MEntVector &  to_ents,
bool  only_to_ents = true
Parameters:
from_entsEntities whose adjacencies are being queried
to_dimDimension of adjacencies requested
to_entsAdjacent entities
op_typeBoolean type, intersect or union
only_to_entsif is true, get adjacencies from to_ents
Definition at line 786 of file ModelEnt.cpp.
void get_indexed_connect_coords ( std::vector< moab::EntityHandle > &  ents,
moab::Tag  tagh,
std::vector< int > &  ents_as_ids,
std::vector< double > &  coords,
moab::Range *  verts_range = NULL,
int  start_index = 0
The entity handles are ordered and made unique, assigned ids, then the id vector is assembled in the same order as the input handle vector. Optionally this function returns the moab tag used to assign ids, and the moab range used to get unique ids
Parameters:
entsVector of entities whose ids to assign
sensesSenses of entities in ents; if NULL, assume forward sense, or no sense if ents are vertices
taghTag handle to use for ids; if zero, local tag is used then deleted
ents_as_idsVector of ids that get assigned, ordered same as connectivity of ents (or ents itself if they're vertices)
coordsCoordinates of vertices corresponding to ents_as_ids
verts_rangeVertices in ents, as a range; if non-NULL, populated range is returned; this range is cleared in this function
start_indexStarting index for vertex numbering
Definition at line 913 of file ModelEnt.cpp.
void get_mesh ( int  dim,
std::vector< moab::EntityHandle > &  ments,
bool  bdy_too = false
This function will return the mesh entities on bounding entities too, if requested. This is useful for example for assembling the nodes bounding a surface, as some of those nodes are on model vertices. If requesting mesh on a periodic edge, end vertex will appear on both ends of the returned vector.
Parameters:
mentsEntities
bdy_tooIf true, returns (dim)-dimensional entities from bounding entities too
Definition at line 491 of file ModelEnt.cpp.
Get meshed state.
Returns:
Meshed state
Definition at line 623 of file ModelEnt.hpp.
void get_meshops ( std::vector< MeshOp * > &  meshops) [inline]
Parameters:
meshopsMeshOps returned
Definition at line 663 of file ModelEnt.hpp.
IAVariable* ia_var ( ) const [inline]
Definition at line 25 of file IntervalAssignment/stubs/IAVariable.hpp.
void ia_var ( IAVariable *  v) [inline]
Definition at line 26 of file IntervalAssignment/stubs/IAVariable.hpp.
IAVariable* ia_var ( ) [inline]
Definition at line 468 of file ModelEnt.hpp.
const IAVariable* ia_var ( ) const [inline]
Definition at line 469 of file ModelEnt.hpp.
void ia_var ( IAVariable *  var) [inline]
Definition at line 470 of file ModelEnt.hpp.
int id ( ) const
Definition at line 461 of file ModelEnt.cpp.
iGeom * igeom_instance ( ) const
Returns:
Returns 0 by default
Definition at line 1024 of file ModelEnt.cpp.
int iGeomIndex ( ) [inline]
Definition at line 462 of file ModelEnt.hpp.
void init_group_contents ( ) [private]
Definition at line 259 of file ModelEnt.cpp.
void init_parents_children ( ) [private]
Definition at line 214 of file ModelEnt.cpp.
Firmness interval_firmness ( ) const [inline]
Definition at line 38 of file IntervalAssignment/stubs/IAVariable.hpp.
Get firmness.
Definition at line 602 of file ModelEnt.hpp.
void interval_firmness ( Firmness  firm) [inline]
Set firmness.
Parameters:
firmSet value
Definition at line 608 of file ModelEnt.hpp.
int iRelPairIndex ( ) [inline]
Definition at line 465 of file ModelEnt.hpp.
bool is_meshops_list_empty ( ) [inline]
return true if the list of meshops is not empty
Definition at line 422 of file ModelEnt.hpp.
double measure ( ) const [inline]
Definition at line 32 of file IntervalAssignment/stubs/IAVariable.hpp.
Definition at line 399 of file ModelEnt.cpp.
double measure_discrete ( ) const
Definition at line 407 of file ModelEnt.cpp.
moab::EntityHandle mesh_handle ( ) const [inline]
Definition at line 548 of file ModelEnt.hpp.
moab::EntityHandle mesh_handle ( iGeom::EntityHandle  gent) const
Definition at line 1036 of file ModelEnt.cpp.
moab::EntityHandle mesh_handle ( iGeom::EntitySetHandle  gent) const
Definition at line 1066 of file ModelEnt.cpp.
double mesh_interval_size ( ) const [inline]
Definition at line 29 of file IntervalAssignment/stubs/IAVariable.hpp.
Get mesh interval size, if any Returns -1 if no size set on this entity. If intervals are set, returns computed size.
Returns:
Interval size for this ModelEnt.
Definition at line 1100 of file ModelEnt.cpp.
void mesh_intervals ( const int  set_mesh_int) [inline]
Definition at line 35 of file IntervalAssignment/stubs/IAVariable.hpp.
int mesh_intervals ( ) const [inline]
Get intervals.
Definition at line 590 of file ModelEnt.hpp.
void mesh_intervals ( int  ints) [inline]
Set intervals.
Parameters:
intsSet value
Definition at line 596 of file ModelEnt.hpp.
MKCore * mk_core ( ) const [inline]
Definition at line 538 of file ModelEnt.hpp.
moab::Interface * moab_instance ( ) const
Returns:
Definition at line 1030 of file ModelEnt.cpp.
ModelEnt * next_winding ( ModelEnt *  this_edge,
int  this_sense,
MEntVector &  tmp_adjs
) [private]
Parameters:
this_edgeEdge next to one being requested
this_senseSense of this_edge
tmp_adjsOptional vector of candidates
Returns:
Next edge in loop
Definition at line 830 of file ModelEnt.cpp.
void remove_meshop ( MeshOp *  meshop) [inline]
Parameters:
meshopMeshOp to remove
Definition at line 654 of file ModelEnt.hpp.
void set_downward_senses ( ) [private]
Definition at line 305 of file ModelEnt.cpp.
void set_meshed_state ( MeshedState  mstate) [inline]
Parameters:
mstate
Definition at line 628 of file ModelEnt.hpp.
ModelEnt * shared_entity ( ModelEnt *  ent2,
int  to_dim
If no shared entities are found, NULL is returned. If more than one are found, an Error is thrown with MK_MULTIPLE_FOUND as the code.
Parameters:
ent2Other entity
to_dimDimension of shared entity
Returns:
Shared entity
Definition at line 768 of file ModelEnt.cpp.
int sizing_function_index ( ) const [inline]
Returns:
Returns -1 if it has not been set for this entity
Examples:
example_basic.cpp, example_onetooneswept.cpp, and example_volice.cpp.
Definition at line 584 of file ModelEnt.hpp.
void sizing_function_index ( int  index,
bool  children_too = true
Parameters:
indexSizing function index being set
children_tooIf true, sizing function index is propagated to child (bounding) entities
Definition at line 132 of file ModelEnt.cpp.
Member Data Documentation
bool constrainEven [private]
Definition at line 526 of file ModelEnt.hpp.
double entMeasure
Definition at line 31 of file IntervalAssignment/stubs/IAVariable.hpp.
IAVariable* iaVariable [private]
Definition at line 535 of file ModelEnt.hpp.
Definition at line 508 of file ModelEnt.hpp.
int igeomIndex [private]
Definition at line 499 of file ModelEnt.hpp.
Definition at line 511 of file ModelEnt.hpp.
Definition at line 523 of file ModelEnt.hpp.
int irelIndex [private]
Definition at line 505 of file ModelEnt.hpp.
int max_stub_id = 0 [static]
Definition at line 21 of file IntervalAssignment/stubs/IAVariable.hpp.
Definition at line 529 of file ModelEnt.hpp.
int meshIndex [private]
Definition at line 502 of file ModelEnt.hpp.
int meshIntervals [private]
Definition at line 520 of file ModelEnt.hpp.
Definition at line 28 of file IntervalAssignment/stubs/IAVariable.hpp.
std::vector<MeshOp*> meshOps [private]
Definition at line 532 of file ModelEnt.hpp.
MKCore* mkCore [private]
Definition at line 496 of file ModelEnt.hpp.
moab::EntityHandle moabEntSet [private]
Definition at line 514 of file ModelEnt.hpp.
int sizingFunctionIndex [private]
Definition at line 517 of file ModelEnt.hpp.
int stub_id
Definition at line 22 of file IntervalAssignment/stubs/IAVariable.hpp.
