MeshKit
1.0
Class defining a variable for interval assignment. These are the data objects shared between Interval Assignment and the rest of MeshKit. More...
#include <meshkit/IAVariable.hpp>
Public Types | |
| typedef MeshKit::Firmness | Firmness |
| Get/Set the firmness, the required fidelity of the solution to the goal. | |
Public Member Functions | |
| void | set_model_ent (ModelEnt *me) |
| Get/Set the model_entity directly associated with this variable, if any. This makes the most sense for curves. Schemes and Entities may have extra variables beyond or instead of this one, e.g. intervals for holes or sweep levels, "periodic" intervals for through holes, boundary layers, skew control decomposition, bias. | |
| ModelEnt * | get_model_ent () const |
| void | set_firmness (Firmness set_firm) |
| Firmness | get_firmness () const |
| void | set_hard () |
| void | set_soft () |
| void | unset () |
| bool | is_soft () const |
| bool | is_hard () const |
| bool | is_default () const |
| void | set_goal (double goal_value) |
| Get/Set the goal, the number of intervals we'd like this variable to have in the solution. | |
| double | get_goal () const |
| int | get_solution () const |
| Get the solution to the interval assignment problem for this variable. The solution exists if IAInterface::execute_this has been called already and it was successful, and the value returned will be >=1. Otherwise the value returned will be < 1. | |
| IAVariable (ModelEnt *model_entity=NULL, Firmness set_firmness=SOFT, double goal_value=0.) | |
| Constructor; mesh entity can be missing. Call IAInterface::create_variable instead; see that for documentation. | |
| void | unset () |
| void | unset () |
Private Attributes | |
| unsigned int | uniqueId |
Static Private Attributes | |
| static unsigned int | numVariables |
| IAInterface is friend class to it can set the solution, and use its index. | |
Friends | |
| class | IAInterface |
Internal data representation. | |
| Firmness | firmness |
| double | goal |
| goal should be >=1., non-integer is OK. | |
| int | solution |
| solution <0 notsolved, >=1 solved | |
| ModelEnt * | modelEnt |
| modelEnt, NULL is OK. | |
These should be constructed/destructed by Meshkit through IAInterface, not directly.
Definition at line 25 of file IntervalAssignment/meshkit/IAVariable.hpp.
| typedef MeshKit::Firmness Firmness |
Definition at line 41 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 41 of file meshkit/IAVariable.hpp.
Definition at line 69 of file IntervalAssignment/stubs/IAVariable.hpp.
| IAVariable | ( | ModelEnt * | model_entity = NULL, |
| Firmness | set_firmness = SOFT, |
| double | goal_value = 0. |
| ) | [inline] |
Definition at line 98 of file IntervalAssignment/meshkit/IAVariable.hpp.
| Firmness get_firmness | ( | ) | const [inline] |
Definition at line 44 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 44 of file meshkit/IAVariable.hpp.
Definition at line 72 of file IntervalAssignment/stubs/IAVariable.hpp.
| double get_goal | ( | ) | const [inline] |
Definition at line 56 of file meshkit/IAVariable.hpp.
Definition at line 56 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 84 of file IntervalAssignment/stubs/IAVariable.hpp.
| ModelEnt* get_model_ent | ( | ) | const [inline] |
Definition at line 36 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 36 of file meshkit/IAVariable.hpp.
Definition at line 64 of file IntervalAssignment/stubs/IAVariable.hpp.
| int get_solution | ( | ) | const [inline] |
Only interval assignment should be setting the solution, so we leave "set_solution" out of the public interface.
Definition at line 66 of file meshkit/IAVariable.hpp.
Definition at line 66 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 94 of file IntervalAssignment/stubs/IAVariable.hpp.
| bool is_default | ( | ) | const [inline] |
Definition at line 50 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 50 of file meshkit/IAVariable.hpp.
Definition at line 78 of file IntervalAssignment/stubs/IAVariable.hpp.
| bool is_hard | ( | ) | const [inline] |
Definition at line 49 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 49 of file meshkit/IAVariable.hpp.
Definition at line 77 of file IntervalAssignment/stubs/IAVariable.hpp.
| bool is_soft | ( | ) | const [inline] |
Definition at line 48 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 48 of file meshkit/IAVariable.hpp.
Definition at line 76 of file IntervalAssignment/stubs/IAVariable.hpp.
| void set_firmness | ( | Firmness | set_firm | ) | [inline] |
Definition at line 43 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 43 of file meshkit/IAVariable.hpp.
Definition at line 71 of file IntervalAssignment/stubs/IAVariable.hpp.
| void set_goal | ( | double | goal_value | ) | [inline] |
Definition at line 55 of file meshkit/IAVariable.hpp.
Definition at line 55 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 83 of file IntervalAssignment/stubs/IAVariable.hpp.
| void set_hard | ( | ) | [inline] |
Definition at line 45 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 45 of file meshkit/IAVariable.hpp.
Definition at line 73 of file IntervalAssignment/stubs/IAVariable.hpp.
| void set_model_ent | ( | ModelEnt * | me | ) | [inline] |
Definition at line 35 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 35 of file meshkit/IAVariable.hpp.
Definition at line 63 of file IntervalAssignment/stubs/IAVariable.hpp.
| void set_soft | ( | ) | [inline] |
Definition at line 46 of file meshkit/IAVariable.hpp.
Definition at line 46 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 74 of file IntervalAssignment/stubs/IAVariable.hpp.
| void unset | ( | ) | [inline] |
Definition at line 47 of file meshkit/IAVariable.hpp.
Definition at line 47 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 75 of file IntervalAssignment/stubs/IAVariable.hpp.
IAInterface [friend] |
Definition at line 94 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 78 of file IntervalAssignment/meshkit/IAVariable.hpp.
double goal [private] |
Definition at line 81 of file IntervalAssignment/meshkit/IAVariable.hpp.
Definition at line 87 of file IntervalAssignment/meshkit/IAVariable.hpp.
static unsigned int numVariables [static, private] |
Definition at line 92 of file IntervalAssignment/meshkit/IAVariable.hpp.
int solution [private] |
Definition at line 84 of file IntervalAssignment/meshkit/IAVariable.hpp.
unsigned int uniqueId [private] |
Definition at line 93 of file IntervalAssignment/meshkit/IAVariable.hpp.
