MeshKit
1.0
00001 // IAInterface.cpp MeshKit version 00002 // Interval Assignment Data for Meshkit 00003 // Interface to the rest of Meshkit 00004 00005 #include "meshkit/IAInterface.hpp" 00006 #include "meshkit/IASolver.hpp" 00007 #include "meshkit/IADataBuilder.hpp" 00008 #include "meshkit/IASolution.hpp" 00009 00010 #include "meshkit/ModelEnt.hpp" // from MeshKit 00011 00012 #include <vector> 00013 #include <iterator> 00014 #include <set> 00015 #include <cstdio> 00016 #include <assert.h> 00017 #include <math.h> 00018 00019 namespace MeshKit 00020 { 00021 00022 const bool IAInterface::debugging = false; 00023 00024 //static IAVariable counter 00025 unsigned int IAVariable::numVariables(0); 00026 00027 moab::EntityType IAInterface_types[] = {moab::MBMAXTYPE}; 00028 const moab::EntityType* IAInterface::output_types() 00029 { return IAInterface_types; } 00030 00031 void IAInterface::setup_this() 00032 { 00033 ; //nothing for now 00034 } 00035 00036 IAVariable *IAInterface::get_variable( ModelEnt* model_entity, bool create_if_missing ) 00037 { 00038 // already exists? 00039 if (model_entity && model_entity->ia_var()) 00040 { 00041 // return without setting values 00042 return model_entity->ia_var(); 00043 } 00044 00045 if (model_entity && create_if_missing) 00046 { 00047 // default values 00048 double goal(1.); 00049 Firmness firm(DEFAULT); 00050 00051 const Firmness me_firm( model_entity->interval_firmness() ); 00052 const double me_edge_size( model_entity->mesh_interval_size() ); 00053 if ( me_firm == DEFAULT || me_edge_size <= 0.) 00054 { 00055 // ModelEnt was unset, so use default values 00056 ; 00057 } 00058 else 00059 { 00060 const double me_size = model_entity->measure(); 00061 assert(me_edge_size > 0.); 00062 goal = me_size / me_edge_size; 00063 firm = model_entity->interval_firmness(); 00064 } 00065 return create_variable( model_entity, firm, goal); 00066 } 00067 return NULL; 00068 } 00069 00070 00071 IAVariable *IAInterface::create_variable( ModelEnt* model_entity, IAVariable::Firmness set_firm, double goal_value) 00072 { 00073 IAVariable *ia_var = NULL; 00074 00075 // already exists? 00076 if (model_entity && model_entity->ia_var()) 00077 { 00078 // set new values and return 00079 ia_var = model_entity->ia_var(); 00080 ia_var->set_firmness(set_firm); 00081 ia_var->set_goal(goal_value); 00082 return ia_var; 00083 } 00084 00085 ia_var = new IAVariable(model_entity, set_firm, goal_value); 00086 assert( ia_var->uniqueId + 1 == IAVariable::numVariables ); 00087 variables.push_back(ia_var); 00088 assert( IAVariable::numVariables == variables.size() ); 00089 00090 return ia_var; 00091 } 00092 00093 IAInterface::IAVariableVec IAInterface::make_constraint_group( const MEntVector &model_entity_vec ) 00094 { 00095 IAVariableVec result( model_entity_vec.size() ); 00096 for (unsigned int i = 0; i < model_entity_vec.size(); ++i) 00097 { 00098 assert(model_entity_vec[i]); 00099 IAVariable *v = get_variable( model_entity_vec[i], true ); 00100 result[i] = v; 00101 } 00102 return result; 00103 } 00104 00105 void IAInterface::destroy_variable( IAVariable* ia_variable ) 00106 { 00107 if (!ia_variable) 00108 return; 00109 // model_entity shouldn't point to ia_variable anymore 00110 ModelEnt *me = ia_variable->get_model_ent(); 00111 if (me && me->ia_var() == ia_variable) 00112 me->ia_var(NULL); 00113 00114 variables[ ia_variable->uniqueId ] = NULL; 00115 delete ia_variable; 00116 } 00117 00118 00119 void IAInterface::destroy_data() 00120 { 00121 // destroy remaining variables 00122 for (unsigned int i = 0; i < variables.size(); ++i) 00123 { 00124 if ( variables[i] ) 00125 { 00126 assert( variables[i]->uniqueId == i); 00127 destroy_variable( variables[i] ); 00128 } 00129 } 00130 variables.clear(); 00131 00132 // reset global variable id? Yes if this is a singleton class, which it is right now. 00133 IAVariable::numVariables = 0; 00134 00135 // clear constraints 00136 sumEqualConstraints1.clear(); 00137 sumEqualConstraints2.clear(); 00138 sumEvenConstraints.clear(); 00139 // ... additional types of constraints ... 00140 } 00141 00142 IAInterface::~IAInterface() 00143 { 00144 destroy_data(); 00145 } 00146 00147 void IAInterface::constrain_sum_even( const IAVariableVec &sum_even_vars ) 00148 { 00149 sumEvenConstraints.push_back( sum_even_vars ); // vector copy 00150 } 00151 00152 void IAInterface::constrain_sum_equal( const IAVariableVec &side_one, const IAVariableVec &side_two ) 00153 { 00154 sumEqualConstraints1.push_back(side_one); //vector copy of side_one 00155 sumEqualConstraints2.push_back(side_two); //vector copy of side_two 00156 } 00157 00158 00159 // for global vector of variables 00160 int IAInterface::variable_to_index(const IAVariable* var) const 00161 { 00162 return var->uniqueId; 00163 } 00164 00165 IAVariable *IAInterface::index_to_variable(int ind) const 00166 { 00167 assert(ind < (int) variables.size()); 00168 return variables[ind]; 00169 } 00170 00171 void IAInterface::make_set_0_to_nm1( IndexSet &index_set, const size_t k ) 00172 { 00173 std::pair< IndexSet::iterator, bool> prior = index_set.insert( 0 ); 00174 assert(prior.second); 00175 for ( size_t i = 0; i < k; ++i) 00176 { 00177 prior.first = index_set.insert( prior.first, (int) i ); 00178 // assert(prior.second); // second = insert-success is not assigned by this version of insert! 00179 } 00180 } 00181 00182 void IAInterface::make_vec_0_to_nm1( IndexVec &index_vec, const size_t k ) 00183 { 00184 index_vec.clear(); 00185 index_vec.reserve(k); 00186 for (size_t i = 0; i < k; ++i) 00187 index_vec.push_back( (int) i); 00188 } 00189 00190 void IAInterface::make_vec_unset( IndexVec &index_vec, const size_t k ) 00191 { 00192 index_vec.clear(); 00193 index_vec.reserve(k); 00194 for (int i = 0; i < (int) k; ++i) 00195 index_vec.push_back(-1); 00196 } 00197 00198 void IAInterface::set_variable_constraint_indices( 00199 VariableConstraintDependencies &var_con_dep, 00200 const int i_start, 00201 const VariableVecVec &variable_vec_vec ) 00202 { 00203 unsigned int j; 00204 int i; 00205 for (j = 0, i = i_start; j < variable_vec_vec.size(); ++j, ++i) 00206 { 00207 for (unsigned int k = 0; k < variable_vec_vec[j].size(); ++k ) 00208 { 00209 const IAVariable *var = variable_vec_vec[j][k]; 00210 const int v = variable_to_index( var ); 00211 var_con_dep.constraintVariables[i].push_back( v ); 00212 assert( v < (int) var_con_dep.variableConstraints.size() ); 00213 var_con_dep.variableConstraints[v].push_back( i ); 00214 } 00215 } 00216 } 00217 00218 void IAInterface::set_variable_constraint_indices(VariableConstraintDependencies &var_con_dep) 00219 { 00220 // create vectors of the length of constraints and variables, but containing of empty vectors 00221 var_con_dep.constraintVariables.resize( sumEqualConstraints1.size() + sumEvenConstraints.size() ); 00222 var_con_dep.variableConstraints.resize( variables.size() ); 00223 00224 assert( sumEqualConstraints1.size() == sumEqualConstraints2.size() ); 00225 const int sum_even_start = (int) sumEqualConstraints1.size(); 00226 //zzyk hardsets 00227 // build vector map of variable-to-constraints 00228 // build vector map of constraint-to-variables 00229 set_variable_constraint_indices( var_con_dep, 0, sumEqualConstraints1 ); 00230 set_variable_constraint_indices( var_con_dep, 0, sumEqualConstraints2 ); 00231 set_variable_constraint_indices( var_con_dep, sum_even_start, sumEvenConstraints ); 00232 } 00233 00234 void IAInterface::ProblemSets::find_variable_dependent_set( 00235 const int variable_j, 00236 const VariableConstraintDependencies &var_con_dep, 00237 ProblemSets &subsets ) 00238 { 00239 // return if we've already added this variable to the subset = removed it from this set 00240 IndexSet::iterator j = variableSet.find(variable_j); 00241 if ( j == variableSet.end() ) 00242 return; 00243 00244 // add the variable to the sub-problem 00245 subsets.variableSet.insert(*j); 00246 00247 // remove the variable from the big problem 00248 variableSet.erase(j); 00249 00250 // recursively find the dependent constraints 00251 IndexVec::const_iterator i; 00252 assert( variable_j < (int) var_con_dep.variableConstraints.size() ); 00253 const IndexVec &v = var_con_dep.variableConstraints[variable_j]; 00254 for ( i = v.begin(); i != v.end(); ++i ) 00255 find_constraint_dependent_set( *i, var_con_dep, subsets ); 00256 } 00257 00258 00259 void IAInterface::ProblemSets::find_constraint_dependent_set( 00260 const int constraint_i, 00261 const VariableConstraintDependencies &var_con_dep, 00262 ProblemSets &subsets ) 00263 { 00264 // return if we've already added this constraint to the subset = removed it from this set 00265 // todo, could speed this up using some sort of mark on the entity 00266 IndexSet::iterator i = constraintSet.find(constraint_i); 00267 if ( i == constraintSet.end() ) 00268 return; 00269 00270 // add the constraint to the sub-problem 00271 subsets.constraintSet.insert(*i); 00272 00273 // remove the constraint from the global problem 00274 constraintSet.erase(i); 00275 00276 // recursively find the dependent variables 00277 IndexVec::const_iterator j; 00278 assert( constraint_i < (int) var_con_dep.constraintVariables.size() ); 00279 const IndexVec &v = var_con_dep.constraintVariables[constraint_i]; 00280 for ( j = v.begin(); j != v.end(); ++j ) 00281 find_variable_dependent_set( *j, var_con_dep, subsets ); 00282 } 00283 00284 void IAInterface::ProblemSets::find_dependent_set( 00285 const VariableConstraintDependencies &var_con_dep, 00286 ProblemSets &subsets ) 00287 { 00288 if ( !constraintSet.empty() ) 00289 { 00290 find_constraint_dependent_set( *constraintSet.begin(), var_con_dep, subsets ); 00291 } 00292 else if ( !variableSet.empty() ) 00293 { 00294 find_variable_dependent_set( *variableSet.begin(), var_con_dep, subsets ); 00295 } 00296 } 00297 00298 void IAInterface::make_global_set(ProblemSets &problem_sets) 00299 { 00300 make_set_0_to_nm1( problem_sets.constraintSet, sumEqualConstraints1.size() + sumEvenConstraints.size() ); 00301 make_set_0_to_nm1( problem_sets.variableSet, variables.size() ); 00302 make_vec_unset( problem_sets.varMap, variables.size() ); 00303 // todo hardsets, 00304 // move variables from variableSet to hard_variableSet if the variable is hard-set 00305 } 00306 00307 void IAInterface::global_to_sub_side( 00308 const VariableVec &global_constraint, 00309 IndexVec &global_var_map, 00310 IndexVec &local_constraint, int &rhs ) const 00311 { 00312 for (unsigned int j = 0; j < global_constraint.size(); ++j ) 00313 { 00314 IAVariable *v = global_constraint[j]; 00315 if (v->get_firmness() == MeshKit::HARD ) 00316 rhs -= floor( v->get_goal() + 0.5 ); // goal should be integer already for hardsets 00317 else 00318 { 00319 int local_index = global_var_map[ v->uniqueId ]; 00320 assert( local_index >= 0 ); 00321 // assert( local_index < variableSet.size() ); 00322 local_constraint.push_back( local_index ); //variable_to_index( v, sub_variables ) ); 00323 } 00324 } 00325 } 00326 00327 void IAInterface::ProblemSets::print() const 00328 { 00329 printf("ProblemSets %p:\n", this); 00330 if (!empty()) 00331 printf("non-"); 00332 printf("empty. %lu variables, %lu hardsets, %lu constraints\n", variableSet.size(), hardVariableSet.size(), constraintSet.size()); 00333 printf("Variables: "); 00334 for ( IndexSet::const_iterator i = variableSet.begin(); i != variableSet.end(); ++i ) 00335 { 00336 printf("%d ", *i); 00337 } 00338 printf("\n"); 00339 printf("HardSet Variables: "); 00340 for ( IndexSet::const_iterator i = hardVariableSet.begin(); i != hardVariableSet.end(); ++i ) 00341 { 00342 printf("%d ", *i); 00343 } 00344 printf("\n"); 00345 printf("Constraints: "); 00346 for ( IndexSet::const_iterator i = constraintSet.begin(); i != constraintSet.end(); ++i ) 00347 { 00348 printf("%d ", *i); 00349 } 00350 printf("\n\n"); 00351 } 00352 00353 void IAInterface::VariableConstraintDependencies::print() const 00354 { 00355 printf("VariableConstraintDependencies %p:\n",this); 00356 printf("%lu variables, %lu constraints\n", variableConstraints.size(), constraintVariables.size() ); 00357 for (size_t i = 0; i < variableConstraints.size(); ++i) 00358 { 00359 printf("Variable %lu depends on constraints ", i); 00360 for (size_t j = 0; j < variableConstraints[i].size(); ++j) 00361 { 00362 printf("%d ", variableConstraints[i][j]); 00363 } 00364 printf("\n"); 00365 } 00366 00367 for (size_t i = 0; i < constraintVariables.size(); ++i) 00368 { 00369 printf("Constraint %lu depends on variables ", i); 00370 for (size_t j = 0; j < constraintVariables[i].size(); ++j) 00371 { 00372 printf("%d ", constraintVariables[i][j]); 00373 } 00374 printf("\n"); 00375 } 00376 printf("\n"); 00377 } 00378 00379 00380 void IAInterface::fill_problem( ProblemSets &sub_sets, 00381 SubProblem *sub_problem, IndexVec &global_var_map ) const 00382 { 00383 IADataBuilder data_builder( sub_problem->data ); 00384 // number the variables from 0..n, by setting ia_index 00385 sub_problem->data->I.reserve(sub_sets.variableSet.size()); 00386 sub_sets.varMap.reserve(sub_sets.variableSet.size()); 00387 for (IndexSet::const_iterator i = sub_sets.variableSet.begin(); i != sub_sets.variableSet.end(); ++i) 00388 { 00389 size_t index = *i; // global index 00390 IAVariable *v = index_to_variable( (int) index ); 00391 if ( v->get_firmness() != MeshKit::HARD ) 00392 { 00393 // index maps 00394 global_var_map[index] = (int) sub_sets.varMap.size(); 00395 sub_sets.varMap.push_back( (int) index ); 00396 00397 // add the goals 00398 data_builder.add_variable( v->goal ); 00399 } 00400 else 00401 { 00402 // nothing to do, it is a constant, not a variable in the sub problem 00403 } 00404 } 00405 00406 // convert constraints to IASolver format 00407 for (IndexSet::const_iterator i = sub_sets.constraintSet.begin(); i != sub_sets.constraintSet.end(); ++i ) 00408 { 00409 unsigned int c = *i; 00410 if (c < sumEqualConstraints1.size()) // equal 00411 { 00412 IndexVec side_1, side_2; 00413 int rhs_1(0), rhs_2(0); 00414 00415 global_to_sub_side( sumEqualConstraints1[c], global_var_map, side_1, rhs_1 ); 00416 global_to_sub_side( sumEqualConstraints2[c], global_var_map, side_2, rhs_2 ); 00417 00418 data_builder.constrain_opposite_side_equal(side_1, side_2, rhs_1 - rhs_2 ); 00419 // todo check should be rhs_2 - rhs_1 ? 00420 } 00421 else // even 00422 { 00423 c -= sumEqualConstraints1.size(); 00424 assert( c >= 0 ); // not useful because it is unsigned 00425 assert( c < sumEvenConstraints.size() ); 00426 00427 IndexVec side; 00428 int rhs(0); 00429 global_to_sub_side( sumEvenConstraints[c], global_var_map, side, rhs ); // todo check if should be -rhs? 00430 data_builder.constrain_sum_even(side, rhs ); 00431 } 00432 } 00433 } 00434 00435 void IAInterface::subdivide_problem(SubProblemVec &subproblems) 00436 { 00437 // find independent subproblems, by index of constraint and variable 00438 ProblemSets global_prob_set; 00439 make_global_set(global_prob_set); 00440 if (debugging) 00441 global_prob_set.print(); 00442 VariableConstraintDependencies var_con_dep; 00443 set_variable_constraint_indices(var_con_dep); 00444 if (debugging) 00445 var_con_dep.print(); 00446 00447 while ( !global_prob_set.empty() ) 00448 { 00449 // define a sub-problem by indices 00450 SubProblem *subproblem = new SubProblem; 00451 subproblems.push_back( subproblem ); 00452 global_prob_set.find_dependent_set(var_con_dep, subproblem->problemSets); 00453 00454 if (debugging) 00455 { 00456 printf("subproblem peeled out:\n"); 00457 subproblem->print(); 00458 printf("\nremaining global problem:\n"); 00459 global_prob_set.print(); 00460 } 00461 00462 // Fill in solver with data from those indices 00463 // convert the set into an IASolver, add data 00464 fill_problem( subproblem->problemSets, subproblem, global_prob_set.varMap ); 00465 if (debugging) 00466 subproblem->print(); 00467 } 00468 } 00469 00470 void IAInterface::subdivide_problem_one(std::vector<IAData*> &subproblems) 00471 { 00472 // placeholder - just make one subproblem 00473 IAData *sub_problem = new IAData(); 00474 subproblems.push_back(sub_problem); 00475 IADataBuilder data_builder( sub_problem ); // data 00476 00477 // this grabs the whole problem and converts it 00478 // variables numbered 0..n 00479 for(VariableVec::const_iterator i = variables.begin(); i != variables.end(); ++i) 00480 { 00481 IAVariable *v = *i; 00482 data_builder.add_variable( v->goal ); 00483 } 00484 // equal constraints 00485 for (unsigned int i = 0; i < sumEqualConstraints1.size(); ++i) 00486 { 00487 std::vector<int> side_1, side_2; 00488 for (unsigned int j = 0; j < sumEqualConstraints1[i].size(); ++j) 00489 { 00490 IAVariable *v = sumEqualConstraints1[i][j]; 00491 int index = variable_to_index(v); 00492 // sanity check that the indexing was correct 00493 assert( sub_problem->I[index] == v->goal ); 00494 side_1.push_back(index); 00495 } 00496 for (unsigned int j = 0; j < sumEqualConstraints2[i].size(); ++j) 00497 { 00498 IAVariable *v = sumEqualConstraints2[i][j]; 00499 int index = variable_to_index(v); 00500 side_2.push_back(index); 00501 } 00502 data_builder.constrain_opposite_side_equal(side_1, side_2, 0.); 00503 } 00504 // even constraints 00505 for (unsigned int i = 0; i < sumEvenConstraints.size(); ++i) 00506 { 00507 std::vector<int> side; 00508 for (unsigned int j = 0; j < sumEvenConstraints[i].size(); ++j) 00509 { 00510 IAVariable *v = sumEvenConstraints[i][j]; 00511 int index = variable_to_index(v); 00512 side.push_back(index); 00513 } 00514 data_builder.constrain_sum_even(side, 0.); 00515 } 00516 00517 } 00518 00519 void IAInterface::print_problem() const 00520 { 00521 // describe variables 00522 // describe constraints 00523 } 00524 00525 void IAInterface::SubProblem::print() const 00526 { 00527 printf("subproblem %d:\n", id); 00528 problemSets.print(); 00529 IASolverTool solver_tool(data,solution); 00530 solver_tool.print(); 00531 // describe variables 00532 // describe constraints 00533 } 00534 00535 bool IAInterface::solve_subproblem( SubProblem *subproblem ) 00536 { 00537 IASolver solver( subproblem->data, subproblem->solution ); 00538 return solver.solve(); 00539 } 00540 00541 void IAInterface::assign_solution( SubProblem *subproblem ) 00542 { 00543 // assign solution value from subproblem to model entities 00544 std::vector<double> &x_solution = subproblem->solution->x_solution; // shorthand 00545 for (unsigned int i = 0; i < x_solution.size(); ++i) 00546 { 00547 const double x = x_solution[i]; 00548 // map index i to IAVariable, which will be different when we have non-full subproblems 00549 IAVariable *v = index_to_variable( subproblem->problemSets.varMap[i] ); 00550 assert(v); 00551 assert( x > 0. ); 00552 const int x_int = (int) floor( x + 0.5 ); 00553 v->solution = x_int; 00554 if (v->get_model_ent()) 00555 { 00556 v->get_model_ent()->mesh_intervals(x_int); 00557 } 00558 } 00559 } 00560 00561 void IAInterface::execute_this() 00562 { 00563 SubProblemVec subproblems; 00564 subdivide_problem(subproblems); 00565 for (unsigned int i = 0; i < subproblems.size(); ++i) 00566 { 00567 SubProblem *p = subproblems[i]; 00568 if (debugging) 00569 printf("Solving subproblem %d\n", p->id); 00570 if ( solve_subproblem(p) ) 00571 assign_solution(p); 00572 else 00573 { 00574 ; // some error statement 00575 } 00576 delete p; 00577 } 00578 subproblems.clear(); 00579 return; 00580 } 00581 00582 00583 int IAInterface::SubProblem::max_id = 0; 00584 00585 IAInterface::SubProblem::SubProblem() 00586 : id( max_id++ ) 00587 { 00588 data = new IAData; 00589 solution = new IASolution; 00590 } 00591 00592 IAInterface::SubProblem::~SubProblem() 00593 { 00594 delete data; 00595 data = NULL; 00596 delete solution; 00597 solution = NULL; 00598 } 00599 00600 } // namespace MeshKit 00601 00602
