MeshKit
1.0
Fixed-size matrix class. More...
#include <Matrix.hpp>
Public Types | |
| enum | { ROWS = R, COLS = C } |
| typedef Matrix< R, C > | my_type |
Public Member Functions | |
| Matrix () | |
| Matrix (double v) | |
| Matrix (const double *v) | |
| Matrix (const double v[R][C]) | |
| Matrix (const Matrix< R, 1 > *c) | |
| Matrix (const Matrix< 1, C > *r) | |
| Matrix (const char *s) | |
| Matrix (const std::string &s) | |
| Matrix (const Matrix< R+1, C+1 > &m, unsigned r, unsigned c) | |
| Matrix< R, C > & | operator= (double v) |
| Matrix< R, C > & | operator= (const double *v) |
| Matrix< R, C > & | operator= (const char *s) |
| Matrix< R, C > & | operator= (const std::string &s) |
| double & | operator() (unsigned r, unsigned c) |
| double | operator() (unsigned r, unsigned c) const |
| double * | data () |
| const double * | data () const |
| void | zero () |
| void | identity () |
| void | set (double v) |
| void | set (const double *v) |
| void | set (const double v[R][C]) |
| void | set (const char *s) |
| void | set (const std::string &s) |
| void | diag (double v) |
| void | diag (const double *v) |
| void | make_minor (const Matrix< R+1, C+1 > &m, unsigned r, unsigned c) |
| Extract minor of a matrix and assign to *this. | |
| Matrix< R, C > & | assign_add_transpose (const Matrix< C, R > &other) |
| Matrix< R, C > & | assign_product (double s, const Matrix< R, C > &m) |
| Matrix< R, C > & | assign_add_product (double s, const Matrix< R, C > &m) |
| Matrix< R, C > & | assign_multiply_elements (const Matrix< R, C > &m) |
| Matrix< R, C > & | operator+= (const Matrix< R, C > &other) |
| Matrix< R, C > & | operator-= (const Matrix< R, C > &other) |
| Matrix< R, C > & | operator+= (double scalar) |
| Matrix< R, C > & | operator-= (double scalar) |
| Matrix< R, C > & | operator*= (double scalar) |
| Matrix< R, C > & | operator/= (double scalar) |
| Matrix< 1, C > | row (unsigned r) const |
| Matrix< R, 1 > | column (unsigned c) const |
| Matrix< 1, R > | column_transpose (unsigned c) const |
| void | set_row (unsigned r, const Matrix< 1, C > &v) |
| void | add_row (unsigned r, const Matrix< 1, C > &v) |
| void | set_row_transpose (unsigned r, const Matrix< C, 1 > &v) |
| void | set_rows (const Matrix< 1, C > *v) |
| void | set_column (unsigned c, const Matrix< R, 1 > &v) |
| void | add_column (unsigned c, const Matrix< R, 1 > &v) |
| void | set_column_transpose (unsigned c, const Matrix< 1, R > &v) |
| void | set_columns (const Matrix< R, 1 > *v) |
Protected Attributes | |
| double | m [R *C] |
This class implements a fixed-size 2-dimensional matrix. The actual size is specified with template parameters.
Definition at line 50 of file Matrix.hpp.
Definition at line 55 of file Matrix.hpp.
| anonymous enum |
Definition at line 57 of file Matrix.hpp.
| Matrix | ( | ) | [inline] |
Constructor for uninitialized matrix
Definition at line 60 of file Matrix.hpp.
| Matrix | ( | double | v | ) | [inline] |
Initialize diagonal values, zero others
Definition at line 62 of file Matrix.hpp.
| Matrix | ( | const double * | v | ) | [inline] |
Initialize to an array of values
Definition at line 64 of file Matrix.hpp.
| Matrix | ( | const double | v[R][C] | ) | [inline] |
Initialize from 2D array
Definition at line 66 of file Matrix.hpp.
Initialize with column vectors
Definition at line 68 of file Matrix.hpp.
Initialize with row vectors
Definition at line 70 of file Matrix.hpp.
| Matrix | ( | const char * | s | ) | [inline] |
Parse initial values from string
Definition at line 72 of file Matrix.hpp.
| Matrix | ( | const std::string & | s | ) | [inline] |
Definition at line 74 of file Matrix.hpp.
Initialize to the minor of a larger matrix This matrix is the passed matrix with the specified row and column removed.
Definition at line 79 of file Matrix.hpp.
| void add_column | ( | unsigned | c, |
| const Matrix< R, 1 > & | v | ||
| ) | [inline] |
Definition at line 400 of file Matrix.hpp.
Definition at line 383 of file Matrix.hpp.
| Matrix< R, C > & assign_add_product | ( | double | s, |
| const Matrix< R, C > & | m | ||
| ) | [inline] |
*this += s*m
Definition at line 459 of file Matrix.hpp.
| Matrix< R, C > & assign_add_transpose | ( | const Matrix< C, R > & | other | ) | [inline] |
*this += transpose(other)
Definition at line 441 of file Matrix.hpp.
| Matrix< R, C > & assign_multiply_elements | ( | const Matrix< R, C > & | m | ) | [inline] |
multiply each element by the cooresponding element in m
Definition at line 449 of file Matrix.hpp.
| Matrix< R, C > & assign_product | ( | double | s, |
| ) | [inline] |
*this = s*m
Definition at line 454 of file Matrix.hpp.
Definition at line 414 of file Matrix.hpp.
| Matrix< 1, R > column_transpose | ( | unsigned | c | ) | const [inline] |
Definition at line 422 of file Matrix.hpp.
| double* data | ( | ) | [inline] |
Definition at line 89 of file Matrix.hpp.
| const double* data | ( | ) | const [inline] |
Definition at line 90 of file Matrix.hpp.
| void diag | ( | double | v | ) | [inline] |
Set diagonal value to passed values, others to zero.
Definition at line 248 of file Matrix.hpp.
| void diag | ( | const double * | v | ) | [inline] |
Set diagonal values to passed values, others to zero.
Definition at line 303 of file Matrix.hpp.
| void identity | ( | ) | [inline] |
Definition at line 93 of file Matrix.hpp.
| void make_minor | ( | const Matrix< R+1, C+1 > & | M, |
| unsigned | r, | ||
| unsigned | c | ||
| ) | [inline] |
Set this matrix to the minor of a larger matrix
Given a matrix m, a row r and an column c, set *this to the matrix that is m with row r and column c deleted.
Definition at line 363 of file Matrix.hpp.
| double& operator() | ( | unsigned | r, |
| unsigned | c | ||
| ) | [inline] |
Definition at line 87 of file Matrix.hpp.
| double operator() | ( | unsigned | r, |
| unsigned | c | ||
Definition at line 88 of file Matrix.hpp.
| Matrix< R, C > & operator*= | ( | double | scalar | ) | [inline] |
Definition at line 484 of file Matrix.hpp.
Definition at line 464 of file Matrix.hpp.
| Matrix< R, C > & operator+= | ( | double | scalar | ) | [inline] |
Definition at line 474 of file Matrix.hpp.
Definition at line 469 of file Matrix.hpp.
| Matrix< R, C > & operator-= | ( | double | scalar | ) | [inline] |
Definition at line 479 of file Matrix.hpp.
| Matrix< R, C > & operator/= | ( | double | scalar | ) | [inline] |
Definition at line 489 of file Matrix.hpp.
| Matrix<R,C>& operator= | ( | double | v | ) | [inline] |
Definition at line 82 of file Matrix.hpp.
| Matrix<R,C>& operator= | ( | const double * | v | ) | [inline] |
Definition at line 83 of file Matrix.hpp.
| Matrix<R,C>& operator= | ( | const char * | s | ) | [inline] |
Definition at line 84 of file Matrix.hpp.
| Matrix<R,C>& operator= | ( | const std::string & | s | ) | [inline] |
Definition at line 85 of file Matrix.hpp.
Definition at line 128 of file Matrix.hpp.
| void set | ( | double | v | ) | [inline] |
Definition at line 94 of file Matrix.hpp.
| void set | ( | const double * | v | ) | [inline] |
Definition at line 97 of file Matrix.hpp.
| void set | ( | const double | v[R][C] | ) | [inline] |
Definition at line 241 of file Matrix.hpp.
| void set | ( | const char * | s | ) | [inline] |
Definition at line 101 of file Matrix.hpp.
| void set | ( | const std::string & | s | ) | [inline] |
Definition at line 102 of file Matrix.hpp.
| void set_column | ( | unsigned | c, |
| ) | [inline] |
Definition at line 396 of file Matrix.hpp.
| void set_column_transpose | ( | unsigned | c, |
| const Matrix< 1, R > & | v | ||
| ) | [inline] |
Definition at line 404 of file Matrix.hpp.
| void set_columns | ( | const Matrix< R, 1 > * | v | ) | [inline] |
Definition at line 408 of file Matrix.hpp.
Definition at line 379 of file Matrix.hpp.
| void set_row_transpose | ( | unsigned | r, |
| const Matrix< C, 1 > & | v | ||
| ) | [inline] |
Definition at line 387 of file Matrix.hpp.
Definition at line 391 of file Matrix.hpp.
| void zero | ( | ) | [inline] |
Definition at line 92 of file Matrix.hpp.
double m[R *C] [protected] |
Definition at line 52 of file Matrix.hpp.
