MeshKit  1.0
QslimMesher Class Reference
Decimate a set of triangles. More...
#include <QslimMesher.hpp>
Inheritance diagram for QslimMesher:
List of all members.
Public Member Functions
 QslimMesher (MKCore *mk_core, const MEntVector &me_vec)
virtual void setup_this ()
 Pure virtual, derived class must define.
virtual void execute_this ()
void set_options (QslimOptions &opts)
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
 ~QslimMesher ()
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Private Attributes
QslimOptions _opts
QslimDecimation * _worker
Detailed Description
QslimMesher decimates a set of triangles that form a 3d surface It uses edge collapse sequentially, while keeping the error in the quadric sense minimal at each step.
Examples:
example_qslimmesher.cpp, and example_setpnt2quad.cpp.
Definition at line 44 of file QslimMesher.hpp.
QslimMesher ( MKCore *  mk_core,
const MEntVector &  me_vec
Definition at line 22 of file QslimMesher.cpp.
Definition at line 51 of file QslimMesher.cpp.
Member Function Documentation
static bool can_mesh ( iBase_EntityType  dim) [inline, static]
Definition at line 67 of file QslimMesher.hpp.
static bool can_mesh ( ModelEnt *  me) [inline, static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 78 of file QslimMesher.hpp.
void execute_this ( ) [virtual]
Implements GraphNode.
Definition at line 42 of file QslimMesher.cpp.
virtual const moab::EntityType* mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 91 of file QslimMesher.hpp.
static const char* name ( ) [inline, static]
Get class name.
Definition at line 58 of file QslimMesher.hpp.
const moab::EntityType * output_types ( ) [static]
Returns:
Definition at line 17 of file QslimMesher.cpp.
void set_options ( QslimOptions &  opts) [inline]
Examples:
Definition at line 62 of file QslimMesher.hpp.
void setup_this ( ) [virtual]
Definition at line 30 of file QslimMesher.cpp.
Member Data Documentation
QslimOptions _opts [private]
Definition at line 100 of file QslimMesher.hpp.
Definition at line 101 of file QslimMesher.hpp.
