MeshKit
1.0
The wrapper for the CAMAL tet mesher. More...
#include <meshkit/CAMALTetMesher.hpp>
Public Member Functions | |
| CAMALTetMesher (MKCore *mk_core, const MEntVector &me_vec) | |
| Constructor. | |
| ~CAMALTetMesher () | |
| Destructor. | |
| virtual void | setup_this () |
| Setup function for this mesher, simply calls setup_boundary. | |
| virtual void | execute_this () |
| Execute the mesher (calling CAMAL mesher on this volume) | |
| virtual const moab::EntityType * | mesh_types_arr () const |
| Return the mesh entity types operated on by this scheme. | |
Static Public Member Functions | |
| static const char * | name () |
| Get class name. | |
| static bool | can_mesh (iBase_EntityType dim) |
| Function returning whether this scheme can mesh entities of t the specified dimension. | |
| static bool | can_mesh (ModelEnt *me) |
| Function returnign whether this scheme can mesh the specified entity. | |
| static const moab::EntityType * | output_types () |
| Get list of mesh entity types that can be generated. | |
Static Public Attributes | |
| static moab::EntityType | meshTps [] = {moab::MBVERTEX, moab::MBTET, moab::MBMAXTYPE} |
| Static list of mesh types treated by this scheme. | |
Private Member Functions | |
| MeshOp * | get_tri_mesher () |
| Construct a MeshOp that can generate triangle elements. | |
| void | print_debug (ModelEnt *me, std::vector< double > &coords, moab::Range &bdy_vrange, std::vector< moab::EntityHandle > &bdy, std::vector< int > &group_sizes, std::vector< int > &bdy_ids) |
| print debug information and save input boundary mesh for CAMAL library | |
Private Attributes | |
| CMLTetMesher * | cmlTetMesher |
| CAMAL mesher object called by this mesher. | |
This class calls the CAMAL tet mesher and converts mesh to/from the required format for that mesher.
Definition at line 27 of file CAMALTetMesher.hpp.
| CAMALTetMesher | ( | MKCore * | mk_core, |
| const MEntVector & | me_vec | ||
Constructor.
| mk_core | MKCore instance |
| me_vec | ModelEnts this mesher will be applied to |
Definition at line 27 of file CAMALTetMesher.cpp.
| ~CAMALTetMesher | ( | ) |
Destructor.
Definition at line 32 of file CAMALTetMesher.cpp.
| static bool can_mesh | ( | iBase_EntityType | dim | ) | [inline, static] |
| dim | entity dimension |
Definition at line 61 of file CAMALTetMesher.hpp.
Used by MeshOpFactory to find scheme for an entity.
| me | ModelEnt being queried |
Definition at line 70 of file CAMALTetMesher.hpp.
| void execute_this | ( | ) | [virtual] |
Implements GraphNode.
Definition at line 76 of file CAMALTetMesher.cpp.
| MeshOp * get_tri_mesher | ( | ) | [private] |
Definition at line 36 of file CAMALTetMesher.cpp.
| virtual const moab::EntityType* mesh_types_arr | ( | ) | const [inline, virtual] |
moab::MBMAXTYPE Implements MeshOp.
Definition at line 82 of file CAMALTetMesher.hpp.
| static const char* name | ( | ) | [inline, static] |
Get class name.
Definition at line 54 of file CAMALTetMesher.hpp.
| static const moab::EntityType* output_types | ( | ) | [inline, static] |
moab::MBMAXTYPE Definition at line 76 of file CAMALTetMesher.hpp.
| void print_debug | ( | ModelEnt * | me, |
| std::vector< double > & | coords, | ||
| moab::Range & | bdy_vrange, | ||
| std::vector< moab::EntityHandle > & | bdy, | ||
| std::vector< int > & | group_sizes, | ||
| std::vector< int > & | bdy_ids | ||
| ) | [private] |
Definition at line 156 of file CAMALTetMesher.cpp.
| void setup_this | ( | ) | [virtual] |
Definition at line 42 of file CAMALTetMesher.cpp.
CMLTetMesher* cmlTetMesher [private] |
Definition at line 102 of file CAMALTetMesher.hpp.
moab::EntityType meshTps = {moab::MBVERTEX, moab::MBTET, moab::MBMAXTYPE} [static] |
Definition at line 50 of file CAMALTetMesher.hpp.
