MeshKit  1.0
AF2RuleApplication Class Reference
#include <AF2RuleApplication.hpp>
List of all members.
Public Member Functions
 AF2RuleApplication (std::list< const AF2Point2D * > const &newPointsList, std::list< const AF2Polygon2D * > const &newFacesList)
 Constructor.
 ~AF2RuleApplication ()
 Destructor.
 AF2RuleApplication (const AF2RuleApplication &toCopy)
 Copy constructor.
AF2RuleApplication & operator= (const AF2RuleApplication &rhs)
 Copy assignment.
unsigned int getNumNewFaces () const
 Get the number of new faces that would be produced by this rule application.
const AF2Polygon2D * getNewFace (unsigned int newFaceIndex) const
 Get a pointer to one of the new faces that would be added by this rule application.
unsigned int getNumNewPoints () const
 Get the number of new points that would be added by this rule application.
const AF2Point2D * getNewPoint (unsigned int newPointIndex) const
 Get a pointer to one of the new (two-dimensional) points that would be added by this rule application.
Private Member Functions
void mapCopyPolygon (const AF2Polygon2D &sourcePolygon, const AF2Polygon2D *&targetPolygon, const std::map< const AF2Point2D *, const AF2Point2D * > &vertexMap)
 construct a polygon with vertices mapped from a source polygon according to the defined map
Private Attributes
unsigned int numNewPoints
const AF2Point2D ** newPoints
unsigned int numNewFaces
const AF2Polygon2D ** newFaces
Detailed Description
Definition at line 31 of file AF2RuleApplication.hpp.
AF2RuleApplication ( std::list< const AF2Point2D * > const &  newPointsList,
std::list< const AF2Polygon2D * > const &  newFacesList
Constructor.
Construct an AF2RuleApplication, defining the (two-dimensional) points, if any, that would be added and the polygonal faces that would be added by applying some particular AF2Rule with some AF2Binding of the rule's required existing vertices and edges to the two-dimensional points and edges in some AF2Neighborhood. The vertices of the polygonal faces are assumed to be points that come from either the AF2Neighborhood or the list of new points that is passed to this constructor.
Objects that are passed into this constructor by pointer are copied, so the original instances are owned by the context that calls the constructor and their memory should be managed outside of this instance.
Parameters:
newPointsListA list of pointers to AF2Point2D points that should be projected onto the surface and added to the mesh as part of accepting this AF2RuleApplication
newFacesListA list of polygonal faces (referencing two-dimensional points from the newPointsList or from an AF2Neighborhood) that should be added to the mesh as part of accepting this AF2RuleApplication
Definition at line 4 of file AF2RuleApplication.cpp.
Destructor.
Definition at line 63 of file AF2RuleApplication.cpp.
Copy constructor.
This is the standard copy constructor.
Parameters:
toCopyan AF2RuleApplication that should be copied to construct a new AF2RuleApplication
Definition at line 78 of file AF2RuleApplication.cpp.
Member Function Documentation
const AF2Polygon2D * getNewFace ( unsigned int  newFaceIndex) const
The numbering of the new faces that would be produced begins with 0, so the valid arguments to this method are 0 through n - 1, where n is the value returned from getNumNewFaces().
Parameters:
newFaceIndexthe number of the new face to return
Returns:
a pointer to the requested new face that would be added by this rule application
Definition at line 149 of file AF2RuleApplication.cpp.
const AF2Point2D * getNewPoint ( unsigned int  newPointIndex) const
The numbering of the new points that would be added begins with 0, so the valid arguments to this method are 0 through n - 1, where n is the value returned from getNumNewPoints().
Parameters:
newPointIndexthe number of the new point to return
Returns:
a pointer to the requested new point that would be added by this rule application
Definition at line 166 of file AF2RuleApplication.cpp.
unsigned int getNumNewFaces ( ) const
Returns:
Definition at line 144 of file AF2RuleApplication.cpp.
unsigned int getNumNewPoints ( ) const
Returns:
the number of new vertices
Definition at line 161 of file AF2RuleApplication.cpp.
void mapCopyPolygon ( const AF2Polygon2D &  sourcePolygon,
const AF2Polygon2D *&  targetPolygon,
const std::map< const AF2Point2D *, const AF2Point2D * > &  vertexMap
) [private]
For use by constructors and the copy assignment operator.
Parameters:
sourcePolygonthe source polygon that is to be copied
targetPolygona (currently null) pointer to the location in memory where the copy should be constructed using new
amap of the new vertices from the rule application instance that provided the context of the source polygon to the corresponding new vertices from this rule application instance
Definition at line 178 of file AF2RuleApplication.cpp.
AF2RuleApplication & operator= ( const AF2RuleApplication &  rhs)
Copy assignment.
This is the standard copy assignment operator.
Parameters:
rhsan AF2RuleApplication that should be assigned to this AF2RuleApplication, overwriting (and destructing) whatever may be in this AF2RuleApplication
Definition at line 98 of file AF2RuleApplication.cpp.
Member Data Documentation
const AF2Polygon2D** newFaces [private]
Definition at line 38 of file AF2RuleApplication.hpp.
const AF2Point2D** newPoints [private]
Definition at line 36 of file AF2RuleApplication.hpp.
unsigned int numNewFaces [private]
Definition at line 37 of file AF2RuleApplication.hpp.
unsigned int numNewPoints [private]
Definition at line 35 of file AF2RuleApplication.hpp.
