MeshKit
1.0
00001 #include "meshkit/AF2RuleApplication.hpp" 00002 #include "meshkit/Error.hpp" 00003 00004 AF2RuleApplication::AF2RuleApplication( 00005 std::list<const AF2Point2D*> const & newPointsList, 00006 std::list<const AF2Polygon2D*> const & newFacesList) : 00007 numNewPoints(newPointsList.size()), numNewFaces(newFacesList.size()) 00008 { 00009 // type definitions for two iterators that the constructor will use 00010 typedef std::list<const AF2Point2D*>::const_iterator ConstPntItrType; 00011 typedef std::list<const AF2Polygon2D*>::const_iterator ConstPolyItrType; 00012 00013 // check whether there is a null-valued pointer in the list of new points 00014 for (ConstPntItrType itr = newPointsList.begin(); 00015 itr != newPointsList.end(); ++itr) 00016 { 00017 if (*itr == NULL) 00018 { 00019 MeshKit::Error badArg(MeshKit::MK_BAD_INPUT); 00020 badArg.set_string("newPointsList may not contain a null pointer in AF2RuleApplication."); 00021 throw badArg; 00022 } 00023 } 00024 00025 // check whether there is a null-valued pointer in the list of faces 00026 for (ConstPolyItrType itr = newFacesList.begin(); 00027 itr != newFacesList.end(); ++itr) 00028 { 00029 if (*itr == NULL) 00030 { 00031 MeshKit::Error badArg(MeshKit::MK_BAD_INPUT); 00032 badArg.set_string( 00033 "newFacesList may not contain a null pointer in AF2RuleApplication."); 00034 throw badArg; 00035 } 00036 } 00037 00038 // map from new points passed in to the copies of the new points 00039 std::map<const AF2Point2D*, const AF2Point2D*> pointPtrCopyMap; 00040 00041 // now that the constructor has checked things that will cause it 00042 // to throw its own exceptions, proceed with allocating memory, etc. 00043 newPoints = new const AF2Point2D*[numNewPoints]; 00044 int indx = 0; 00045 for (ConstPntItrType itr = newPointsList.begin(); 00046 itr != newPointsList.end(); ++itr) 00047 { 00048 newPoints[indx] = new AF2Point2D(*(*itr)); 00049 pointPtrCopyMap[*itr] = newPoints[indx]; 00050 ++indx; 00051 } 00052 00053 newFaces = new const AF2Polygon2D*[numNewFaces]; 00054 indx = 0; 00055 for (ConstPolyItrType itr = newFacesList.begin(); 00056 itr != newFacesList.end(); ++itr) 00057 { 00058 mapCopyPolygon(*(*itr), newFaces[indx], pointPtrCopyMap); 00059 ++indx; 00060 } 00061 } 00062 00063 AF2RuleApplication::~AF2RuleApplication() 00064 { 00065 for (unsigned int plygnIndx = 0; plygnIndx < numNewFaces; ++plygnIndx) 00066 { 00067 delete newFaces[plygnIndx]; 00068 } 00069 delete[] newFaces; 00070 00071 for (unsigned int pntIndx = 0; pntIndx < numNewPoints; ++pntIndx) 00072 { 00073 delete newPoints[pntIndx]; 00074 } 00075 delete[] newPoints; 00076 } 00077 00078 AF2RuleApplication::AF2RuleApplication(const AF2RuleApplication & toCopy) : 00079 numNewPoints(toCopy.numNewPoints), numNewFaces(toCopy.numNewFaces) 00080 { 00081 std::map<const AF2Point2D*, const AF2Point2D*> pointPtrCopyMap; 00082 00083 newPoints = new const AF2Point2D*[numNewPoints]; 00084 for (unsigned int pntIndx = 0; pntIndx < numNewPoints; ++pntIndx) 00085 { 00086 newPoints[pntIndx] = new AF2Point2D(*(toCopy.newPoints[pntIndx])); 00087 pointPtrCopyMap[toCopy.newPoints[pntIndx]] = newPoints[pntIndx]; 00088 } 00089 00090 newFaces = new const AF2Polygon2D*[numNewFaces]; 00091 for (unsigned int plygnIndx = 0; plygnIndx < numNewFaces; ++plygnIndx) 00092 { 00093 mapCopyPolygon(*(toCopy.newFaces[plygnIndx]), 00094 newFaces[plygnIndx], pointPtrCopyMap); 00095 } 00096 } 00097 00098 AF2RuleApplication& AF2RuleApplication::operator=( 00099 const AF2RuleApplication & rhs) 00100 { 00101 // copy constructor functionality, but copy to 00102 // other parts of memory rather than to this 00103 std::map<const AF2Point2D*, const AF2Point2D*> pointPtrCopyMap; 00104 00105 const AF2Point2D** otherNewPoints = new const AF2Point2D*[rhs.numNewPoints]; 00106 for (unsigned int pntIndx = 0; pntIndx < rhs.numNewPoints; ++pntIndx) 00107 { 00108 otherNewPoints[pntIndx] = new AF2Point2D(*(rhs.newPoints[pntIndx])); 00109 pointPtrCopyMap[rhs.newPoints[pntIndx]] = otherNewPoints[pntIndx]; 00110 } 00111 00112 const AF2Polygon2D** otherNewFaces = new const AF2Polygon2D*[rhs.numNewFaces]; 00113 for (unsigned int plygnIndx = 0; plygnIndx < rhs.numNewFaces; ++plygnIndx) 00114 { 00115 mapCopyPolygon(*(rhs.newFaces[plygnIndx]), 00116 otherNewFaces[plygnIndx], pointPtrCopyMap); 00117 } 00118 00119 // destructor functionality to clean up current members of this 00120 for (unsigned int plygnIndx = 0; plygnIndx < numNewFaces; ++plygnIndx) 00121 { 00122 delete newFaces[plygnIndx]; 00123 } 00124 delete[] newFaces; 00125 00126 for (unsigned int pntIndx = 0; pntIndx < numNewPoints; ++pntIndx) 00127 { 00128 delete newPoints[pntIndx]; 00129 } 00130 delete[] newPoints; 00131 00132 // transfer ownership from other parts of memory to this object 00133 numNewPoints = rhs.numNewPoints; 00134 newPoints = otherNewPoints; 00135 otherNewPoints = NULL; // not necessary, but to be explicit 00136 numNewFaces = rhs.numNewFaces; 00137 newFaces = otherNewFaces; 00138 otherNewFaces = NULL; // not necessary, but to be explicit 00139 00140 // return reference to this 00141 return *this; 00142 } 00143 00144 unsigned int AF2RuleApplication::getNumNewFaces() const 00145 { 00146 return numNewFaces; 00147 } 00148 00149 const AF2Polygon2D* AF2RuleApplication::getNewFace( 00150 unsigned int newFaceIndex) const 00151 { 00152 if (newFaceIndex >= numNewFaces) 00153 { 00154 MeshKit::Error badArg(MeshKit::MK_BAD_INPUT); 00155 badArg.set_string("newFaceIndex is out of range"); 00156 throw badArg; 00157 } 00158 return newFaces[newFaceIndex]; 00159 } 00160 00161 unsigned int AF2RuleApplication::getNumNewPoints() const 00162 { 00163 return numNewPoints; 00164 } 00165 00166 const AF2Point2D* AF2RuleApplication::getNewPoint( 00167 unsigned int newPointIndex) const 00168 { 00169 if (newPointIndex >= numNewPoints) 00170 { 00171 MeshKit::Error badArg(MeshKit::MK_BAD_INPUT); 00172 badArg.set_string("newPointIndex is out of range"); 00173 throw badArg; 00174 } 00175 return newPoints[newPointIndex]; 00176 } 00177 00178 void AF2RuleApplication::mapCopyPolygon(const AF2Polygon2D & sourcePolygon, 00179 const AF2Polygon2D* & targetPolygon, 00180 const std::map<const AF2Point2D*, const AF2Point2D*> & vertexMap) 00181 { 00182 std::list<const AF2Point2D*> mapCopyVertices; 00183 for (unsigned int vIndx = 0; vIndx < sourcePolygon.getNumVertices(); ++vIndx) 00184 { 00185 const AF2Point2D* sourcePolyVertex = sourcePolygon.getVertex(vIndx); 00186 typedef std::map<const AF2Point2D*, const AF2Point2D*>::const_iterator 00187 ConstItrType; 00188 ConstItrType mappedVertex = vertexMap.find(sourcePolyVertex); 00189 if (mappedVertex == vertexMap.end()) 00190 { 00191 // The vertex is not a new vertex from rule application. 00192 // Instead it is from the neighborhood and does not need to be mapped 00193 mapCopyVertices.push_back(sourcePolyVertex); 00194 } 00195 else 00196 { 00197 // The vertex is a vertex from the rule application and 00198 // this code maps it to the appropriate pointer in the object 00199 // that is being constructed. 00200 mapCopyVertices.push_back(mappedVertex->second); 00201 } 00202 } 00203 00204 targetPolygon = new AF2Polygon2D(mapCopyVertices); 00205 }
