MeshKit
1.0
#include <cstddef>#include <iostream>#include <list>#include "meshkit/AF2Front.hpp"#include "meshkit/AF2DfltPlaneProjMaker.hpp"#include "meshkit/Error.hpp"#include "meshkit/MKCore.hpp"#include "meshkit/ModelEnt.hpp"#include "TestUtil.hpp"
Defines | |
| #define | FILE_EXT "facet" |
Functions | |
| AF2LocalTransformMaker * | makeTransformBuilder () |
| void | initHex (AF2Front *front, AF2Point3D **&pointsAry, AF2Edge3D **&edgesAry) |
| void | deletePoints (AF2Point3D **&pointsAry, int pointsAryLength) |
| void | testSelectEmpty () |
| void | testInitAndDestruct () |
| void | testQualityDecrease () |
| void | testSelectNeighborhood () |
| void | testSelectIsolatedPoint () |
| void | testSelectHourglass () |
| void | testAdvanceMissingPoints () |
| void | testAdvanceInvalidQuality () |
| void | testAdvanceFront () |
| void | testAdvanceHangingEdge () |
| void | testCompletedAdvance () |
| int | main (int argc, char **argv) |
Variables | |
| MeshKit::MKCore * | mk = NULL |
| MeshKit::MEntVector | surfs |
| MeshKit::ModelEnt * | square = NULL |
Test AF2Front, i.e., the object that manages the points and edges that are on the advancing front of the two-dimensional advancing front algorithm, and AF2DfltPlaneProjMaker, the object that implements the default method of creating AF2PlaneProjection local transforms.
Definition in file frontObj2D.cpp.
| #define FILE_EXT "facet" |
Definition at line 29 of file frontObj2D.cpp.
| void deletePoints | ( | AF2Point3D **& | pointsAry, |
| int | pointsAryLength | ||
Definition at line 130 of file frontObj2D.cpp.
| void initHex | ( | AF2Front * | front, |
| AF2Point3D **& | pointsAry, | ||
| AF2Edge3D **& | edgesAry | ||
Definition at line 98 of file frontObj2D.cpp.
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 59 of file frontObj2D.cpp.
Definition at line 82 of file frontObj2D.cpp.
| void testAdvanceFront | ( | ) |
Definition at line 622 of file frontObj2D.cpp.
| void testAdvanceHangingEdge | ( | ) |
Definition at line 662 of file frontObj2D.cpp.
| void testAdvanceInvalidQuality | ( | ) |
Definition at line 557 of file frontObj2D.cpp.
| void testAdvanceMissingPoints | ( | ) |
Definition at line 500 of file frontObj2D.cpp.
| void testCompletedAdvance | ( | ) |
Definition at line 738 of file frontObj2D.cpp.
| void testInitAndDestruct | ( | ) |
Definition at line 201 of file frontObj2D.cpp.
| void testQualityDecrease | ( | ) |
Definition at line 220 of file frontObj2D.cpp.
| void testSelectEmpty | ( | ) |
Definition at line 141 of file frontObj2D.cpp.
| void testSelectHourglass | ( | ) |
Definition at line 384 of file frontObj2D.cpp.
| void testSelectIsolatedPoint | ( | ) |
Definition at line 338 of file frontObj2D.cpp.
| void testSelectNeighborhood | ( | ) |
Definition at line 288 of file frontObj2D.cpp.
| MeshKit::MKCore* mk = NULL |
Definition at line 36 of file frontObj2D.cpp.
| MeshKit::ModelEnt* square = NULL |
Definition at line 42 of file frontObj2D.cpp.
Definition at line 41 of file frontObj2D.cpp.
