MeshKit
1.0
00001 /* 00002 * AF2Front.hpp 00003 * 00004 * An AF2Front is an object that manages the front for a two-dimensional 00005 * advancing front algorithm. It tracks which points and which half edges 00006 * are on the front. 00007 * 00008 * The main functions of an AF2Front are to initialize the front, to update 00009 * the front when a face is ready to be added, and to select a portion 00010 * of the front -- a neighborhood -- in which the algorithm should attempt 00011 * to advance the front. The first two functions are accomplished by 00012 * the addPoint and advanceFront methods. The third function is 00013 * implemented in the selectNeighborhood method. 00014 * 00015 * The AF2Front provides a method to check whether the front is emtpy, 00016 * which would indicate that the algorithm has completed if the front has 00017 * been in use. It also tracks the quality of the edges that are on 00018 * the front and provides a convenient method to determine the quality 00019 * level of the highest quality edge that is on the front. 00020 */ 00021 00022 #ifndef AF2FRONT_HPP 00023 #define AF2FRONT_HPP 00024 00025 // C++ 00026 #include <list> 00027 #include <map> 00028 #include <set> 00029 #include <vector> 00030 00031 // MeshKit 00032 #include "meshkit/AF2Edge3D.hpp" 00033 #include "meshkit/AF2LocalTransformMaker.hpp" 00034 #include "meshkit/AF2Neighborhood.hpp" 00035 #include "meshkit/AF2Point3D.hpp" 00036 00043 struct EndPointLess { 00047 bool operator()(const AF2Edge3D* const & oneEdge, 00048 const AF2Edge3D* const & otherEdge) const; 00049 }; 00050 00051 class AF2Front : QualityDecreaseObserver 00052 { 00053 friend void AF2Edge3D::decreaseQuality(); 00054 00055 private: 00056 00057 // a map from the points on the front to a count of the 00058 // number of front half edges that are incident to the point 00059 std::map<AF2Point3D*, int> points; 00060 // a set of half edges that are on the front 00061 std::set<AF2Edge3D*, EndPointLess> edges; 00062 // a vector tracking how many edges of each quality level are 00063 // currently on the front 00064 std::vector<unsigned int> qualityCount; 00065 00072 void qualityDecreased(const AF2Edge3D* const & anEdge); 00073 00074 public: 00075 00079 AF2Front(); 00080 00087 virtual ~AF2Front(); 00088 00095 AF2Front(const AF2Front & toCopy); 00096 00103 AF2Front& operator=(const AF2Front & rhs); 00104 00121 void addPoint(AF2Point3D* pointPtr); 00122 00164 void advanceFront(std::list<AF2Edge3D*> edgeList); 00165 00174 bool isEmpty() const; 00175 00185 unsigned int getMaximumQuality() const; 00186 00204 AF2Neighborhood* selectNeighborhood( 00205 const AF2LocalTransformMaker* const & transformMaker) const; 00206 }; 00207 00208 #endif
