MeshKit  1.0
AF2DfltPlaneProjMaker Class Reference
#include <AF2DfltPlaneProjMaker.hpp>
Inheritance diagram for AF2DfltPlaneProjMaker:
List of all members.
Public Member Functions
 AF2DfltPlaneProjMaker (iGeom *iGeomPtrArg, iGeom::EntityHandle surf, MeshKit::SizingFunction *sizingArg=NULL)
 Constructor.
AF2LocalTransform * makeLocalTransform (const std::list< AF2Point3D * > &ngbhdPoints, const AF2Edge3D *const &baselineEdge, const std::list< const AF2Edge3D * > &otherNgbhdEdges) const
 Make an AF2PlaneProjection.
Private Attributes
iGeom * iGeomPtr
iGeom::EntityHandle surface
MeshKit::SizingFunction * sizing
Detailed Description
Definition at line 40 of file AF2DfltPlaneProjMaker.hpp.
AF2DfltPlaneProjMaker ( iGeom *  iGeomPtrArg,
MeshKit::SizingFunction *  sizingArg = NULL
Constructor.
This object does not own any of the objects passed into it. The memory for these objects must be managed outside of this object.
Parameters:
iGeomPtrArgan iGeom instance
surfa handle to a surface geometry representation within the iGeom instance
sizingArga sizing function that, if provided, will define the preferred size
Definition at line 10 of file AF2DfltPlaneProjMaker.cpp.
Member Function Documentation
AF2LocalTransform * makeLocalTransform ( const std::list< AF2Point3D * > &  ngbhdPoints,
const AF2Edge3D *const &  baselineEdge,
const std::list< const AF2Edge3D * > &  otherNgbhdEdges
) const [virtual]
Implements the method from the superclass AF2LocalTransformMaker to make an AF2PlaneProjection. See additional documentation in the superclass.
Implements AF2LocalTransformMaker.
Definition at line 17 of file AF2DfltPlaneProjMaker.cpp.
Member Data Documentation
iGeom* iGeomPtr [private]
Definition at line 44 of file AF2DfltPlaneProjMaker.hpp.
Definition at line 46 of file AF2DfltPlaneProjMaker.hpp.
Definition at line 45 of file AF2DfltPlaneProjMaker.hpp.
