MeshKit
1.0
#include <IARoundingHeuristicMINLP.hpp>
Public Member Functions | |
| IARoundingHeuristicMINLP (const IAData *data_ptr, const IPData *ip_data_ptr, IASolution *solution_ptr) | |
| virtual | ~IARoundingHeuristicMINLP () |
| Number | eval_R_i (const Number &I_i, const Number &x_i) |
Overloaded from TNLP | |
| virtual bool | get_nlp_info (Index &n, Index &m, Index &nnz_jac_g, Index &nnz_h_lag, IndexStyleEnum &index_style) |
| virtual bool | get_bounds_info (Index n, Number *x_l, Number *x_u, Index m, Number *g_l, Number *g_u) |
| virtual bool | get_starting_point (Index n, bool init_x, Number *x_init, bool init_z, Number *z_L, Number *z_U, Index m, bool init_lambda, Number *lambda) |
| virtual bool | eval_f (Index n, const Number *x, bool new_x, Number &obj_value) |
| virtual bool | eval_grad_f (Index n, const Number *x, bool new_x, Number *grad_f) |
| virtual bool | eval_g (Index n, const Number *x, bool new_x, Index m, Number *g) |
| virtual bool | eval_jac_g (Index n, const Number *x, bool new_x, Index m, Index nele_jac, Index *iRow, Index *jCol, Number *values) |
| virtual bool | eval_h (Index n, const Number *x, bool new_x, Number obj_factor, Index m, const Number *lambda, bool new_lambda, Index nele_hess, Index *iRow, Index *jCol, Number *values) |
Solution Methods | |
| virtual void | finalize_solution (SolverReturn status, Index n, const Number *x, const Number *z_L, const Number *z_U, Index m, const Number *g, const Number *lambda, Number obj_value, const IpoptData *ip_data, IpoptCalculatedQuantities *ip_cq) |
Private Member Functions | |
| Number | eval_r_i (const Number &I_i, const Number &x_i) |
| Number | eval_grad_r_i (const Number &I_i, const Number &x_i) |
| Number | eval_hess_r_i (const Number &I_i, const Number &x_i) |
| Number | eval_s_i (const Number &I_i, const Number &x_i) |
| Number | eval_grad_s_i (const Number &I_i, const Number &x_i) |
| Number | eval_hess_s_i (const Number &I_i, const Number &x_i) |
| Number | eval_grad_R_i (const Number &I_i, const Number &x_i) |
| Number | eval_hess_R_i (const Number &I_i, const Number &x_i) |
| Number | eval_S_i (const Number &I_i, const Number &x_i) |
| Number | eval_grad_S_i (const Number &I_i, const Number &x_i) |
| Number | eval_hess_S_i (const Number &I_i, const Number &x_i) |
| IARoundingHeuristicMINLP () | |
| IARoundingHeuristicMINLP (const IARoundingHeuristicMINLP &) | |
| IARoundingHeuristicMINLP & | operator= (const IARoundingHeuristicMINLP &) |
Private Attributes | |
| IANlp | baseNlp |
| const IAData * | data |
| const IPData * | ip_data |
| IASolution * | solution |
| const bool | debugging |
| const bool | verbose |
Definition at line 52 of file IARoundingHeuristicMINLP.hpp.
| IARoundingHeuristicMINLP | ( | const IAData * | data_ptr, |
| const IPData * | ip_data_ptr, | ||
| IASolution * | solution_ptr | ||
default constructor
Definition at line 33 of file IARoundingHeuristicMINLP.cpp.
| ~IARoundingHeuristicMINLP | ( | ) | [virtual] |
default destructor
Definition at line 47 of file IARoundingHeuristicMINLP.cpp.
| IARoundingHeuristicMINLP | ( | ) | [private] |
| IARoundingHeuristicMINLP | ( | const IARoundingHeuristicMINLP & | ) | [private] |
| bool eval_f | ( | Index | n, |
| const Number * | x, | ||
| bool | new_x, | ||
| Number & | obj_value | ||
| ) | [virtual] |
Method to return the objective value
Definition at line 112 of file IARoundingHeuristicMINLP.cpp.
| bool eval_g | ( | Index | n, |
| bool | new_x, | ||
| Index | m, | ||
| Number * | g | ||
| ) | [virtual] |
Method to return the constraint residuals
Definition at line 124 of file IARoundingHeuristicMINLP.cpp.
| bool eval_grad_f | ( | Index | n, |
| bool | new_x, | ||
| Number * | grad_f | ||
| ) | [virtual] |
Method to return the gradient of the objective
Definition at line 118 of file IARoundingHeuristicMINLP.cpp.
| Number eval_grad_r_i | ( | const Number & | I_i, |
| const Number & | x_i | ||
| ) | [private] |
| Number eval_grad_R_i | ( | const Number & | I_i, |
| ) | [private] |
| Number eval_grad_s_i | ( | const Number & | I_i, |
| ) | [private] |
| Number eval_grad_S_i | ( | const Number & | I_i, |
| ) | [private] |
| bool eval_h | ( | Index | n, |
| bool | new_x, | ||
| Number | obj_factor, | ||
| Index | m, | ||
| const Number * | lambda, | ||
| bool | new_lambda, | ||
| Index | nele_hess, | ||
| Index * | iRow, | ||
| Index * | jCol, | ||
| Number * | values | ||
| ) | [virtual] |
Method to return: 1) The structure of the hessian of the lagrangian (if "values" is NULL) 2) The values of the hessian of the lagrangian (if "values" is not NULL)
Definition at line 138 of file IARoundingHeuristicMINLP.cpp.
| Number eval_hess_r_i | ( | const Number & | I_i, |
| ) | [private] |
| Number eval_hess_R_i | ( | const Number & | I_i, |
| ) | [private] |
| Number eval_hess_s_i | ( | const Number & | I_i, |
| ) | [private] |
| Number eval_hess_S_i | ( | const Number & | I_i, |
| ) | [private] |
| bool eval_jac_g | ( | Index | n, |
| bool | new_x, | ||
| Index | m, | ||
| Index | nele_jac, | ||
| ) | [virtual] |
Method to return: 1) The structure of the jacobian (if "values" is NULL) 2) The values of the jacobian (if "values" is not NULL)
Definition at line 130 of file IARoundingHeuristicMINLP.cpp.
| Number eval_r_i | ( | const Number & | I_i, |
| ) | [private] |
| Number eval_R_i | ( | const Number & | I_i, |
| Number eval_s_i | ( | const Number & | I_i, |
| ) | [private] |
| Number eval_S_i | ( | const Number & | I_i, |
| ) | [private] |
| void finalize_solution | ( | SolverReturn | status, |
| Index | n, | ||
| const Number * | z_L, | ||
| const Number * | z_U, | ||
| Index | m, | ||
| const Number * | g, | ||
| Number | obj_value, | ||
| const IpoptData * | ip_data, | ||
| IpoptCalculatedQuantities * | ip_cq | ||
| ) | [virtual] |
This method is called when the algorithm is complete so the TNLP can store/write the solution
Definition at line 146 of file IARoundingHeuristicMINLP.cpp.
| bool get_bounds_info | ( | Index | n, |
| Number * | x_l, | ||
| Number * | x_u, | ||
| Index | m, | ||
| Number * | g_l, | ||
| Number * | g_u | ||
| ) | [virtual] |
Method to return the bounds for my problem
Definition at line 57 of file IARoundingHeuristicMINLP.cpp.
| bool get_nlp_info | ( | Index & | n, |
| Index & | m, | ||
| Index & | nnz_jac_g, | ||
| Index & | nnz_h_lag, | ||
| IndexStyleEnum & | index_style | ||
| ) | [virtual] |
Method to return some info about the nlp
Definition at line 50 of file IARoundingHeuristicMINLP.cpp.
| bool get_starting_point | ( | Index | n, |
| bool | init_x, | ||
| Number * | x_init, | ||
| bool | init_z, | ||
| Index | m, | ||
| bool | init_lambda, | ||
| Number * | lambda | ||
| ) | [virtual] |
Method to return the starting point for the algorithm
Definition at line 92 of file IARoundingHeuristicMINLP.cpp.
| IARoundingHeuristicMINLP& operator= | ( | const IARoundingHeuristicMINLP & | ) | [private] |
IANlp baseNlp [private] |
Definition at line 127 of file IARoundingHeuristicMINLP.hpp.
const IAData* data [private] |
Definition at line 130 of file IARoundingHeuristicMINLP.hpp.
const bool debugging [private] |
Definition at line 135 of file IARoundingHeuristicMINLP.hpp.
const IPData* ip_data [private] |
Definition at line 131 of file IARoundingHeuristicMINLP.hpp.
IASolution* solution [private] |
Definition at line 133 of file IARoundingHeuristicMINLP.hpp.
const bool verbose [private] |
Definition at line 136 of file IARoundingHeuristicMINLP.hpp.
