MeshKit
1.0
An operation that operates on mesh data. More...
#include <meshkit/MeshOp.hpp>
Public Member Functions | |
| MeshOp (const MeshOp &mesh_op) | |
| Copy constructor. | |
| MeshOp (MKCore *mkcore, const MEntVector &me_vec=MEntVector()) | |
| Bare constructor. | |
| virtual | ~MeshOp () |
| Destructor. | |
| virtual bool | add_modelent (ModelEnt *model_ent) |
| Add a ModelEnt to this operation's MEntSelection The MEntSelection is a map, and can only have a given entity once. | |
| virtual bool | remove_modelent (ModelEnt *model_ent) |
| Removes a ModelEnt from this operation's MEntSelection. | |
| virtual MEntSelection & | me_selection () |
| Return a reference to the MEntSelection list. | |
| virtual const MEntSelection & | me_selection () const |
| Return a const reference to the MEntSelection list. | |
| MKCore * | mk_core () const |
| Get the associated MKCore object; this applies a dynamic_cast to the parent's MKGraph member. | |
| virtual const moab::EntityType * | mesh_types_arr () const =0 |
| Return the mesh entity types operated on by this scheme. | |
| void | mesh_types (std::vector< moab::EntityType > &mesh_types) |
| Return what types of mesh entities this algorithm generates; pure virtual so every scheme must define them. | |
| void | setup_boundary () |
| Check that bounding entities have an assigned MeshOp, and create them for ones that don't. | |
| void | ensure_facet_dependencies (bool recurse_to_facets=true) |
| Ensure that this MeshOp depends on any MeshOp assigned to a facet of this MeshOp's selected entities. | |
| void | create_model_ents_from_previous_ops () |
| int | get_debug_verbosity () |
| void | set_debug_verbosity (int debug) |
Static Public Member Functions | |
| static bool | canmesh_vertex (ModelEnt *model_ent) |
| Helper function for meshop registration, returns true if specified ModelEnt is a vertex. | |
| static bool | canmesh_edge (ModelEnt *model_ent) |
| Helper function for meshop registration, returns true if specified ModelEnt is an edge. | |
| static bool | canmesh_face (ModelEnt *model_ent) |
| Helper function for meshop registration, returns true if specified ModelEnt is a face. | |
| static bool | canmesh_region (ModelEnt *model_ent) |
| Helper function for meshop registration, returns true if specified ModelEnt is a region. | |
Protected Attributes | |
| MEntSelection | mentSelection |
| MEntSelection that stores what this operation generated or otherwise worked on. | |
| int | debugLevel |
The class encapsulating setup/execute mesh operations on collections of entities. MeshOp objects derive from GraphNode, which encapsulates all graph-related operations on a MeshOp.
Definition at line 21 of file MeshOp.hpp.
Copy constructor.
Definition at line 14 of file MeshOp.cpp.
| MeshOp | ( | MKCore * | mkcore, |
| const MEntVector & | me_vec = MEntVector() |
Bare constructor.
Definition at line 20 of file MeshOp.cpp.
| ~MeshOp | ( | ) | [virtual] |
Destructor.
Definition at line 191 of file MeshOp.cpp.
| bool add_modelent | ( | ModelEnt * | model_ent | ) | [virtual] |
| model_ent | ModelEnt being added |
Reimplemented in EBMesher, CoreGen, PostBL, AssyGen, MergeMesh, AssyMesher, ExtrudeMesh, CopyMesh, CopyGeom, MeshOpTemplate, and VertexMesher.
Definition at line 168 of file MeshOp.cpp.
| bool canmesh_edge | ( | ModelEnt * | model_ent | ) | [static] |
| model_ent | Model entity being evaluated |
Definition at line 153 of file MeshOp.cpp.
| bool canmesh_face | ( | ModelEnt * | model_ent | ) | [static] |
Definition at line 158 of file MeshOp.cpp.
| bool canmesh_region | ( | ModelEnt * | model_ent | ) | [static] |
Definition at line 163 of file MeshOp.cpp.
| bool canmesh_vertex | ( | ModelEnt * | model_ent | ) | [static] |
Definition at line 148 of file MeshOp.cpp.
| void create_model_ents_from_previous_ops | ( | ) |
brief mesh-based geometry model ents based on previous ops it will be used for Camal advancing front meshers
| void ensure_facet_dependencies | ( | bool | recurse_to_facets = true | ) |
For each entity selected for this MeshOp, checks that this MeshOp has a dependence on any MeshOp assigned to a facet of the entity. If no such dependence can be found, inserts a direct dependency arc from this MeshOp to the MeshOp on the facet.
| recurse_to_facets | if true (default value), this method is called on each MeshOp that is assigned to one or more facets of entities that this MeshOp is assigned to |
Definition at line 73 of file MeshOp.cpp.
| int get_debug_verbosity | ( | ) | [inline] |
brief get debugging level
Definition at line 117 of file MeshOp.hpp.
| MEntSelection & me_selection | ( | ) | [inline, virtual] |
Definition at line 136 of file MeshOp.hpp.
| const MEntSelection & me_selection | ( | ) | const [inline, virtual] |
Definition at line 131 of file MeshOp.hpp.
| void mesh_types | ( | std::vector< moab::EntityType > & | mesh_types | ) |
| mesh_types | Types handled by this meshop |
Reimplemented in MyScheme, MyScheme, and ProjectShell.
Definition at line 195 of file MeshOp.cpp.
| virtual const moab::EntityType* mesh_types_arr | ( | ) | const [pure virtual] |
moab::MBMAXTYPE Implemented in IAInterface, IAInterface, SCDMesh, EBMesher, AF2DfltTriangleMeshOp, CoreGen, PostBL, CurveFacetMeshReader, AssyGen, OneToOneSwept, SubMapping, QslimMesher, NGTetMesher, TFIMapping, EdgeMesher, MergeMesh, VertexMesher, CAMALTetMesher, CAMALPaver, CAMALTriAdvance, SurfaceFacetMeshReader, AssyMesher, ExtrudeMesh, CopyMesh, ParallelMesher, TriangleMesher, QuadMesher, MBSplitOp, MBVolOp, CopyGeom, MeshOpTemplate, MyScheme, MBGeomOp, MyScheme, ParExchangeMesh, ParRecvSurfMesh, ParSendPostSurfMesh, and NoOp.
Definition at line 141 of file MeshOp.hpp.
| bool remove_modelent | ( | ModelEnt * | model_ent | ) | [virtual] |
| model_ent | ModelEnt being removed |
Definition at line 181 of file MeshOp.cpp.
| void set_debug_verbosity | ( | int | debug | ) | [inline] |
brief set debugging level; usually during / before setup phase, so execute will have it
Definition at line 121 of file MeshOp.hpp.
| void setup_boundary | ( | ) |
Uses default MeshOp for a given dimension from MeshOpFactory. If there isn't a registered MeshOp for the dimension requested, this function throws an exception with mode MK_MESHOP_NOT_FOUND.
Definition at line 30 of file MeshOp.cpp.
int debugLevel [protected] |
Definition at line 126 of file MeshOp.hpp.
MEntSelection mentSelection [protected] |
