MeshKit
1.0
Generate the all-hexahedral mesh by sweeping. More...
#include <OneToOneSwept.hpp>
Public Member Functions | |
| OneToOneSwept (MKCore *mk_core, const MEntVector &me_vec) | |
| ~OneToOneSwept () | |
| virtual void | setup_this () |
| Pure virtual, derived class must define. | |
| virtual void | execute_this () |
| virtual const moab::EntityType * | mesh_types_arr () const |
| Return the mesh entity types operated on by this scheme. | |
| void | SetSourceSurface (int index) |
| void | SetTargetSurface (int index) |
Static Public Member Functions | |
| static const char * | name () |
| Get class name. | |
| static bool | can_mesh (iBase_EntityType dim) |
| Function returning whether this scheme can mesh entities of t the specified dimension. | |
| static bool | can_mesh (ModelEnt *me) |
| Function returning whether this scheme can mesh the specified entity. | |
| static const moab::EntityType * | output_types () |
| Get list of mesh entity types that can be generated. | |
Private Member Functions | |
| bool | isConcave () |
| void | BuildLateralBoundaryLayers (ModelEnt *me, std::vector< moab::EntityHandle > &layers) |
| moab::ErrorCode | NodeAbove (moab::EntityHandle node1, moab::EntityHandle node2, moab::Range &quadsOnLateralSurfaces, moab::EntityHandle &node3, moab::EntityHandle &node4) |
| moab::ErrorCode | FourthNodeInQuad (moab::EntityHandle node1, moab::EntityHandle node2, moab::EntityHandle node3, moab::Range &quadsOnLateralSurfaces, moab::EntityHandle &node4) |
| int | TargetSurfProjection (std::vector< moab::EntityHandle > &boundLayers) |
| int | ProjectInteriorLayers (std::vector< moab::EntityHandle > &boundLayers, vector< vector< Vertex > > &linkVertexList) |
| int | CreateElements (vector< vector< Vertex > > &linkVertexList) |
| void | computeTransformationFromSourceToTarget (std::vector< Vector3D > &sNodes, Vector3D &sc, std::vector< Vector3D > &tNodes, Vector3D &tc, Matrix3D &transMatrix) |
Private Attributes | |
| iBase_EntityHandle | sourceSurface |
| iBase_EntityHandle | targetSurface |
| iBase_EntityHandle | volume |
| moab::Interface * | mb |
| int | numLayers |
| int | numLoops |
| int | sizeBLayer |
| iGeom * | igeom_inst |
| int | index_src |
| int | index_tar |
| iBase_TagHandle | geom_id_tag |
| std::vector< Vertex > | NodeList |
| std::vector< Vertex > | TVertexList |
| std::vector< Face > | FaceList |
| iBase_EntitySetHandle | volumeSet |
| std::set< moab::EntityHandle > | markedMoabEnts |
OneToOneSwept generates the all-hexahedral mesh by sweeping the source mesh to the target surface
Definition at line 49 of file OneToOneSwept.hpp.
| OneToOneSwept | ( | MKCore * | mk_core, |
| const MEntVector & | me_vec | ||
Definition at line 32 of file OneToOneSwept.cpp.
| ~OneToOneSwept | ( | ) |
Definition at line 39 of file OneToOneSwept.cpp.
| void BuildLateralBoundaryLayers | ( | ModelEnt * | me, |
| std::vector< moab::EntityHandle > & | layers | ||
| ) | [private] |
Definition at line 229 of file OneToOneSwept.cpp.
| static bool can_mesh | ( | iBase_EntityType | dim | ) | [inline, static] |
| dim | entity dimension |
Definition at line 68 of file OneToOneSwept.hpp.
Used by MeshOpFactory to find scheme for an entity.
| me | ModelEnt being queried |
Definition at line 79 of file OneToOneSwept.hpp.
| void computeTransformationFromSourceToTarget | ( | std::vector< Vector3D > & | sNodes, |
| Vector3D & | sc, | ||
| std::vector< Vector3D > & | tNodes, | ||
| Vector3D & | tc, | ||
| Matrix3D & | transMatrix | ||
| ) | [private] |
Definition at line 823 of file OneToOneSwept.cpp.
| int CreateElements | ( | vector< vector< Vertex > > & | linkVertexList | ) | [private] |
Definition at line 966 of file OneToOneSwept.cpp.
| void execute_this | ( | ) | [virtual] |
Implements GraphNode.
Definition at line 189 of file OneToOneSwept.cpp.
| moab::ErrorCode FourthNodeInQuad | ( | moab::EntityHandle | node1, |
| moab::EntityHandle | node2, | ||
| moab::EntityHandle | node3, | ||
| moab::Range & | quadsOnLateralSurfaces, | ||
| moab::EntityHandle & | node4 | ||
| ) | [private] |
Definition at line 493 of file OneToOneSwept.cpp.
| bool isConcave | ( | ) | [private] |
Definition at line 563 of file OneToOneSwept.cpp.
| virtual const moab::EntityType* mesh_types_arr | ( | ) | const [inline, virtual] |
moab::MBMAXTYPE Implements MeshOp.
Definition at line 92 of file OneToOneSwept.hpp.
| static const char* name | ( | ) | [inline, static] |
Get class name.
Definition at line 59 of file OneToOneSwept.hpp.
| moab::ErrorCode NodeAbove | ( | moab::EntityHandle | node1, |
| moab::EntityHandle & | node3, | ||
| ) | [private] |
Definition at line 440 of file OneToOneSwept.cpp.
| const moab::EntityType * output_types | ( | ) | [static] |
moab::MBMAXTYPE Definition at line 25 of file OneToOneSwept.cpp.
| int ProjectInteriorLayers | ( | std::vector< moab::EntityHandle > & | boundLayers, |
| vector< vector< Vertex > > & | linkVertexList | ||
| ) | [private] |
Definition at line 856 of file OneToOneSwept.cpp.
| void SetSourceSurface | ( | int | index | ) |
Definition at line 46 of file OneToOneSwept.cpp.
| void SetTargetSurface | ( | int | index | ) |
Definition at line 53 of file OneToOneSwept.cpp.
| void setup_this | ( | ) | [virtual] |
Definition at line 60 of file OneToOneSwept.cpp.
| int TargetSurfProjection | ( | std::vector< moab::EntityHandle > & | boundLayers | ) | [private] |
Definition at line 610 of file OneToOneSwept.cpp.
Definition at line 155 of file OneToOneSwept.hpp.
iBase_TagHandle geom_id_tag [private] |
Definition at line 150 of file OneToOneSwept.hpp.
iGeom* igeom_inst [private] |
Definition at line 148 of file OneToOneSwept.hpp.
int index_src [private] |
Definition at line 149 of file OneToOneSwept.hpp.
int index_tar [private] |
std::set<moab::EntityHandle> markedMoabEnts [private] |
Definition at line 158 of file OneToOneSwept.hpp.
moab::Interface* mb [private] |
Definition at line 144 of file OneToOneSwept.hpp.
Definition at line 152 of file OneToOneSwept.hpp.
int numLayers [private] |
Definition at line 145 of file OneToOneSwept.hpp.
int numLoops [private] |
Definition at line 146 of file OneToOneSwept.hpp.
int sizeBLayer [private] |
Definition at line 147 of file OneToOneSwept.hpp.
iBase_EntityHandle sourceSurface [private] |
Definition at line 141 of file OneToOneSwept.hpp.
iBase_EntityHandle targetSurface [private] |
Definition at line 142 of file OneToOneSwept.hpp.
std::vector<Vertex> TVertexList [private] |
Definition at line 153 of file OneToOneSwept.hpp.
iBase_EntityHandle volume [private] |
Definition at line 143 of file OneToOneSwept.hpp.
iBase_EntitySetHandle volumeSet [private] |
Definition at line 156 of file OneToOneSwept.hpp.
