MeshKit
1.0
00001 #ifdef _WIN32 00002 #define _USE_MATH_DEFINES 00003 #endif 00004 00005 #include "meshkit/OneToOneSwept.hpp" 00006 #include "meshkit/iMesh.hpp" 00007 #include "meshkit/EdgeMesher.hpp" 00008 #include "meshkit/TFIMapping.hpp" 00009 #ifdef HAVE_MESQUITE 00010 #include "meshkit/MeshImprove.hpp" 00011 #endif 00012 #include <iostream> 00013 #include <algorithm> 00014 #include <math.h> 00015 #include <map> 00016 #ifdef HAVE_ARMADILLO 00017 #include "SurfProHarmonicMap.hpp" 00018 #endif 00019 00020 namespace MeshKit { 00021 00022 //---------------------------------------------------------------------------// 00023 //Entity Type initialization for OneToOneSwept meshing 00024 moab::EntityType OneToOneSwept_tps[] = { moab::MBVERTEX, moab::MBQUAD, moab::MBHEX, moab::MBMAXTYPE }; 00025 const moab::EntityType* OneToOneSwept::output_types() 00026 { 00027 return OneToOneSwept_tps; 00028 } 00029 00030 //---------------------------------------------------------------------------// 00031 // construction function for OneToOneSwept class 00032 OneToOneSwept::OneToOneSwept(MKCore *mk_core, const MEntVector &me_vec) : 00033 MeshScheme(mk_core, me_vec) 00034 { 00035 } 00036 00037 //---------------------------------------------------------------------------// 00038 // deconstruction function for OneToOneSwept class 00039 OneToOneSwept::~OneToOneSwept() 00040 { 00041 } 00042 00043 // these have to be called before setup, otherwise we don't know source and target 00044 //---------------------------------------------------------------------------// 00045 // set the source surface function 00046 void OneToOneSwept::SetSourceSurface(int index) 00047 { 00048 index_src = index; 00049 } 00050 00051 //---------------------------------------------------------------------------// 00052 // set the target surface function 00053 void OneToOneSwept::SetTargetSurface(int index) 00054 { 00055 index_tar = index; 00056 } 00057 00058 //---------------------------------------------------------------------------// 00059 // setup function: define the size between the different layers 00060 void OneToOneSwept::setup_this() 00061 { 00062 //compute the number of intervals for the associated ModelEnts, from the size set on them 00063 //the sizing function they point to, or a default sizing function 00064 00065 if (mentSelection.empty()) 00066 return; 00067 ModelEnt * firstME = (mentSelection.begin())->first; 00068 igeom_inst = firstME->igeom_instance(); 00069 /*moab::Interface **/ 00070 mb = mk_core()->moab_instance();// we should get it also from 00071 // model entity, if we have multiple moab instances running around 00072 00073 const char *tag = "GLOBAL_ID"; 00074 iGeom::Error g_err = igeom_inst->getTagHandle(tag, geom_id_tag); 00075 IBERRCHK(g_err, "Trouble get the geom_id_tag for 'GLOBAL_ID'."); 00076 00077 for (MEntSelection::iterator mit = mentSelection.begin(); mit != mentSelection.end(); mit++) 00078 { 00079 ModelEnt *me = mit->first; 00080 //first check to see whether entity is meshed 00081 if (me->get_meshed_state() >= COMPLETE_MESH || me->mesh_intervals() > 0) 00082 continue; 00083 00084 SizingFunction *sf = mk_core()->sizing_function(me->sizing_function_index()); 00085 if (!sf && me -> mesh_intervals() < 0 && me -> interval_firmness() == DEFAULT && mk_core()->sizing_function(0)) 00086 sf = mk_core()->sizing_function(0); 00087 00088 if (!sf && me -> mesh_intervals() < 0 && me -> interval_firmness() == DEFAULT) 00089 { 00090 //no sizing set, just assume default #intervals as 4 00091 me->mesh_intervals(4); 00092 me->interval_firmness(DEFAULT); 00093 } 00094 else 00095 { 00096 //check # intervals first, then size, and just choose for now 00097 if (sf->intervals() > 0) 00098 { 00099 if (me->constrain_even() && sf->intervals() % 2) 00100 me -> mesh_intervals(sf->intervals() + 1); 00101 else 00102 me -> mesh_intervals(sf->intervals()); 00103 me -> interval_firmness(HARD); 00104 } 00105 else if (sf->size() > 0) 00106 { 00107 // FIXME: This calculation is bogus if size means edge lengths. 00108 // This should divide by the measurement of the source surface. 00109 int intervals = me->measure() / sf->size(); 00110 if (!intervals) 00111 intervals++; 00112 if (me->constrain_even() && intervals % 2) 00113 intervals++; 00114 me->mesh_intervals(intervals); 00115 me->interval_firmness(SOFT); 00116 } 00117 else 00118 throw Error(MK_INCOMPLETE_MESH_SPECIFICATION, "Sizing function for edge had neither positive size nor positive intervals."); 00119 } 00120 00121 int numIntervals = me->mesh_intervals(); 00122 if (!sf || sf->intervals() != numIntervals) 00123 { 00124 sf = new SizingFunction(mk_core(), numIntervals, -1.); 00125 } 00126 00127 std::vector<iBase_EntityHandle> gFaces; 00128 g_err = igeom_inst->getEntAdj(me->geom_handle(), iBase_FACE, gFaces); 00129 IBERRCHK(g_err, "Trouble get the geometrical adjacent to the solid"); 00130 //select the source surface and target surface 00131 // these were setup from the beginning, it could be different for each volume!!!! 00132 // we need a better way to decide/select target and source surfaces 00133 // this also assumes that the sourceSurface is fixed between setup and execute 00134 sourceSurface = gFaces[index_src]; 00135 targetSurface = gFaces[index_tar]; 00136 MEntVector linkingSurfaces; 00137 int index_id_src, index_id_tar; 00138 iGeom::Error g_err = igeom_inst->getIntData(sourceSurface, geom_id_tag, index_id_src); 00139 IBERRCHK(g_err, "Trouble get the int data for source surface."); 00140 g_err = igeom_inst->getIntData(targetSurface, geom_id_tag, index_id_tar); 00141 IBERRCHK(g_err, "Trouble get the int data for target surface."); 00142 std::cout << " source Global ID: " << index_id_src << " target Global ID: " << index_id_tar << "\n"; 00143 00144 for (unsigned int i = 0; i < gFaces.size(); i++) 00145 { 00146 int gid; 00147 g_err = igeom_inst->getIntData(gFaces[i], geom_id_tag, gid); 00148 IBERRCHK(g_err, "Trouble get the int data for source surface."); 00149 std::vector<iBase_EntityHandle> gEdges; 00150 g_err = igeom_inst->getEntAdj(gFaces[i], iBase_EDGE, gEdges); 00151 IBERRCHK(g_err, "Trouble get the geometrical edges adjacent to the surface"); 00152 std::cout << " face index " << i << " with ID: " << gid << " has " << gEdges.size() << " edges\n"; 00153 } 00154 MEntVector surfs; 00155 me->get_adjacencies(2, surfs);// all surfaces adjacent to the volume 00156 for (unsigned int i = 0; i < surfs.size(); i++) 00157 { 00158 int index_id_link; 00159 g_err = igeom_inst->getIntData(surfs[i]->geom_handle(), geom_id_tag, index_id_link); 00160 IBERRCHK(g_err, "Trouble get the int data for linking surface."); 00161 if ((index_id_link != index_id_src) && (index_id_link != index_id_tar)) 00162 { 00163 MEntVector edges; 00164 surfs[i]->get_adjacencies(1, edges);// all surfaces adjacent to the volume 00165 std::cout << " linking surface with global ID: " << index_id_link << " has " << edges.size() << " edges\n"; 00166 //assert((int)edges.size()==4); 00167 00168 linkingSurfaces.push_back(surfs[i]); 00169 } 00170 } 00171 // now create a TFI mapping 00172 // this will trigger edge meshers for linking edges, and for target surface edges 00173 TFIMapping *tm = (TFIMapping*) mk_core()->construct_meshop("TFIMapping", linkingSurfaces); 00174 // For now, do not assign any sizing function at all 00175 // for (unsigned int i = 0; i < linkingSurfaces.size(); i++) 00176 // { 00177 // linkingSurfaces[i]->sizing_function_index(sf->core_index()); 00178 // } 00179 mk_core()->insert_node(tm, (MeshOp*) this); 00180 } 00181 00182 mk_core()->print_graph("AfterOneSetup.eps"); 00183 00184 } 00185 00186 //---------------------------------------------------------------------------// 00187 // execute function: generate the all-hex mesh through sweeping from source 00188 // surface to target surface 00189 void OneToOneSwept::execute_this() 00190 { 00191 00192 for (MEntSelection::iterator mit = mentSelection.begin(); mit != mentSelection.end(); mit++) 00193 { 00194 ModelEnt *me = mit -> first; 00195 // maybe it will be decided later? 00196 //case 1: if numLayers = 1, then it is not necessary to create any vertices for linking surface, All the vertices have been created by source surface and target surface 00197 // bLayers will contain nodes in order, layer by layer 00198 std::vector<moab::EntityHandle> bLayers; 00199 BuildLateralBoundaryLayers(me, bLayers); 00200 //int sizeBLayer = bLayers.size()/(numLayers+1); 00201 volume = me->geom_handle(); 00202 00203 TargetSurfProjection(bLayers);// the top layer is the last list of nodes 00204 00205 //get the volume mesh entity set 00206 iRel::Error r_err = mk_core()->irel_pair(me->iRelPairIndex())->getEntSetRelation(me->geom_handle(), 0, volumeSet); 00207 IBERRCHK(r_err, 00208 "Trouble get the volume mesh entity set from the geometrical volume."); 00209 00210 vector<vector<Vertex> > linkVertexList(numLayers - 1, vector<Vertex> (NodeList.size())); 00211 // this will compute the interior points distribution, in each layer 00212 ProjectInteriorLayers(bLayers, linkVertexList); 00213 std::cout << "Projected interior layers." << std::endl; 00214 00215 CreateElements(linkVertexList); 00216 std::cout << "Created elements." << std::endl; 00217 00218 mk_core()->save_mesh("BeforeVolumeImprove.h5m"); 00219 #if HAVE_MESQUITE 00220 //MeshImprove meshImpr(mk_core()); 00221 //meshImpr.VolumeMeshImprove(volumeSet, iBase_REGION); 00222 #endif 00223 me->commit_mesh(mit->second, COMPLETE_MESH); 00224 } 00225 00226 } 00227 00228 // will also initialize NodeList, which comprises all <Vertex> data on the source sf 00229 void OneToOneSwept::BuildLateralBoundaryLayers(ModelEnt * me, std::vector<moab::EntityHandle> & layers) 00230 { 00231 // start with the source surface 00232 //ModelEnt * sourceME = ModelEnt() 00233 iGeom * igeom_inst = me->igeom_instance(); 00234 iGeom::Error g_err; 00235 moab::ErrorCode rval = moab::MB_SUCCESS; 00236 int index_id_src, index_id_tar; 00237 00238 g_err = igeom_inst->getIntData(sourceSurface, geom_id_tag, index_id_src); 00239 IBERRCHK(g_err, "Trouble get the int data for source surface."); 00240 g_err = igeom_inst->getIntData(targetSurface, geom_id_tag, index_id_tar); 00241 IBERRCHK(g_err, "Trouble get the int data for target surface."); 00242 00243 iBase_TagHandle taghandle = 0; 00244 iMesh::Error m_err = mk_core()->imesh_instance()->getTagHandle("source", taghandle); 00245 if (m_err) 00246 { 00247 m_err = mk_core()->imesh_instance()->createTag("source", 00248 1, iBase_INTEGER, taghandle); 00249 IBERRCHK(m_err, 00250 "Trouble creating the source tag handle in the mesh instance."); 00251 } 00252 // TODO: If the tag exists, we could verify that the tag is the proper one. 00253 // Probably the tag should be put in a namespace, and perhaps it should 00254 // be deleted when we are finished with it. 00255 00256 moab::Range quadsOnLateralSurfaces; 00257 ModelEnt * sME = NULL; 00258 00259 MEntVector surfs; 00260 me->get_adjacencies(2, surfs); // all surfaces adjacent to the volume 00261 00262 for (unsigned int i = 0; i < surfs.size(); i++) 00263 { 00264 int index_id_link; 00265 g_err = igeom_inst->getIntData(surfs[i]->geom_handle(), geom_id_tag, index_id_link); 00266 IBERRCHK(g_err, "Trouble get the int data for linking surface."); 00267 if ((index_id_link != index_id_src) && (index_id_link != index_id_tar)) 00268 { 00269 moab::EntityHandle surfSet = surfs[i]->mesh_handle(); 00270 // get all nodes from the surface, including the boundary nodes! 00271 rval = mb->get_entities_by_type(surfSet, moab::MBQUAD, quadsOnLateralSurfaces); 00272 MBERRCHK(rval, mb); 00273 } 00274 if (index_id_link == index_id_src) 00275 sME = surfs[i]; 00276 } 00277 // the lateral layers will be build from these nodes 00278 moab::Range nodesOnLateralSurfaces; 00279 rval = mb->get_connectivity(quadsOnLateralSurfaces, nodesOnLateralSurfaces); 00280 MBERRCHK(rval, mb); 00281 00282 // construct NodeList, nodes on source surface 00283 // list of node on boundary of source 00284 std::vector<moab::EntityHandle> bdyNodes; 00285 std::vector<int> group_sizes; 00286 sME-> boundary(0, bdyNodes, NULL, &group_sizes);// we do not need the senses, yet 00287 00288 numLoops = (int) group_sizes.size(); 00289 sizeBLayer = (int) bdyNodes.size(); 00290 00291 std::cout << "Execute one to one swept ....\n"; 00292 std::cout << "Nodes on boundary: " << bdyNodes.size() << "\n"; 00293 std::cout << "Number of loops: " << group_sizes.size() << "\n"; 00294 std::cout << "Nodes on lateral surfaces: " << nodesOnLateralSurfaces.size() << "\n"; 00295 std::cout << "Quads on lateral surfaces: " << quadsOnLateralSurfaces.size() << "\n"; 00296 00297 numLayers = 0; 00298 if (!bdyNodes.empty()) 00299 numLayers = nodesOnLateralSurfaces.size() / bdyNodes.size() - 1; 00300 if (bdyNodes.size() * (numLayers + 1) != nodesOnLateralSurfaces.size()) 00301 { 00302 std::cout << "Major problem: number of total nodes on boundary: " << nodesOnLateralSurfaces.size() << "\n"; 00303 std::cout << " number of nodes in one layer on the boundary:" << bdyNodes.size() << "\n"; 00304 std::cout << " we expect bdyNodes.size()*(numLayers+1) == nodesOnLateralSurfaces.size(), but " << bdyNodes.size() * (numLayers + 1) 00305 << " != " << nodesOnLateralSurfaces.size() << "\n"; 00306 } 00307 // start from this list of boundary nodes (on the source) 00308 00309 // get all nodes from the source surface 00310 moab::Range sourceNodes; 00311 moab::EntityHandle surfSet = sME->mesh_handle(); 00312 // get all nodes from the surface, including the boundary nodes! 00313 moab::Range quads; 00314 rval = mb->get_entities_by_type(surfSet, moab::MBQUAD, quads); 00315 MBERRCHK(rval, mb); 00316 // we do not really care about corners, only about boundary 00317 rval = mb->get_connectivity(quads, sourceNodes); 00318 MBERRCHK(rval, mb); 00319 00320 NodeList.resize(sourceNodes.size()); 00321 int i = 0; 00322 for (moab::Range::iterator it = sourceNodes.begin(); it != sourceNodes.end(); it++, i++) 00323 { 00324 moab::EntityHandle node = *it; 00325 NodeList[i].gVertexHandle = (iBase_EntityHandle) sourceNodes[i]; 00326 NodeList[i].index = i; 00327 00328 rval = mb->get_coords(&node, 1, &(NodeList[i].xyz[0])); 00329 MBERRCHK(rval, mb); 00330 NodeList[i].onBoundary = false; 00331 00332 //set the int data to the entity 00333 m_err = mk_core()->imesh_instance()->setIntData(NodeList[i].gVertexHandle, taghandle, NodeList[i].index); 00334 IBERRCHK(m_err, "Trouble set the int value for nodes in the mesh instance."); 00335 } 00336 // now loop over the boundary and mark the boundary nodes as such 00337 for (unsigned int j = 0; j < bdyNodes.size(); j++) 00338 { 00339 iBase_EntityHandle node = (iBase_EntityHandle) bdyNodes[j]; 00340 int index; 00341 m_err = mk_core()->imesh_instance()->getIntData(node, taghandle, index); 00342 IBERRCHK(m_err, "Trouble set the int value for nodes in the mesh instance."); 00343 NodeList[index].onBoundary = true;// some could be corners, but it is not that important 00344 } 00345 00346 // process faces on the source 00347 FaceList.resize(quads.size());// quads is actually a range.... 00348 00349 for (unsigned int i = 0; i < quads.size(); i++) 00350 { 00351 iBase_EntityHandle currentFace = (iBase_EntityHandle) quads[i];// 00352 FaceList[i].gFaceHandle = currentFace; 00353 //FaceList[i].index = i; 00354 00355 //get the nodes on the face elements 00356 std::vector<iBase_EntityHandle> Nodes; 00357 m_err = mk_core()->imesh_instance()->getEntAdj(currentFace, iBase_VERTEX, Nodes); 00358 IBERRCHK(m_err, "Trouble get the adjacent nodes from mesh face entity."); 00359 00360 FaceList[i].connect.resize(Nodes.size()); 00361 for (unsigned int j = 0; j < Nodes.size(); j++) 00362 { 00363 int tmpIndex = -1; 00364 m_err = mk_core()->imesh_instance()->getIntData(Nodes[j], taghandle, tmpIndex); 00365 IBERRCHK(m_err, "Trouble get the int data from node handle."); 00366 00367 FaceList[i].connect[j] = &NodeList[tmpIndex];// why not store tmp Index directly? 00368 } 00369 m_err = mk_core()->imesh_instance()->setIntData(currentFace, taghandle, i); 00370 IBERRCHK(m_err, "Trouble set the int data for quads on the source surface."); 00371 00372 /* m_err = mk_core()->imesh_instance()->setIntData(currentFace, taghandle, i); 00373 IBERRCHK(m_err, "Trouble set the int data for quad mesh on the source surface.");*/ 00374 } 00375 00376 std::copy(bdyNodes.begin(), bdyNodes.end(), std::back_inserter(layers)); 00377 00378 // mark all of the boundary nodes 00379 markedMoabEnts.insert(bdyNodes.begin(), bdyNodes.end()); 00380 00381 for (int layer = 1; layer <= numLayers; layer++) // layer with index 0 is at the bottom/source 00382 { 00383 int start_index = 0;//this is the start index in group 00384 for (unsigned int k = 0; k < group_sizes.size(); k++) 00385 { 00386 // first group starts at index 0, the rest are accumulated 00387 if (k > 0) 00388 start_index += group_sizes[k - 1]; 00389 moab::EntityHandle node1 = layers[(layer - 1) * sizeBLayer + start_index]; 00390 moab::EntityHandle node2 = layers[(layer - 1) * sizeBLayer + start_index + 1]; 00391 moab::EntityHandle node3, node4; 00392 /* 00393 * node3 -- node4 --> (next layer) 00394 * | | 00395 * node1 -- node2 ---> (guide layer) 00396 */ 00397 rval = NodeAbove(node1, node2, quadsOnLateralSurfaces, node3, node4); 00398 MBERRCHK(rval, mb); 00399 // check that node3 and node4 are not yet marked 00400 if (markedMoabEnts.find(node3) != markedMoabEnts.end()) 00401 MBERRCHK(moab::MB_FAILURE, mb); 00402 if (markedMoabEnts.find(node4) != markedMoabEnts.end()) 00403 MBERRCHK(moab::MB_FAILURE, mb); 00404 layers.push_back(node3);//start of a new layer 00405 layers.push_back(node4);//node above node 2 00406 // mark node3 and node4 00407 markedMoabEnts.insert(node3); 00408 markedMoabEnts.insert(node4); 00409 // we have at least 2 nodes in every loop, otherwise we are in deep trouble 00410 //start 00411 int currentIndex = start_index + 2; 00412 while (currentIndex < start_index + group_sizes[k]) 00413 { 00414 node1 = node2; 00415 node2 = layers[(layer - 1) * sizeBLayer + currentIndex];// actually, the previous layer 00416 node3 = node4; 00417 rval = FourthNodeInQuad(node1, node2, node3, quadsOnLateralSurfaces, node4); 00418 MBERRCHK(rval, mb); 00419 if (markedMoabEnts.find(node4) != markedMoabEnts.end()) 00420 MBERRCHK(moab::MB_FAILURE, mb); 00421 layers.push_back(node4); 00422 markedMoabEnts.insert(node4); 00423 currentIndex++; 00424 } 00425 }// end group 00426 }// end layer 00427 for (int lay = 0; lay <= numLayers; lay++) 00428 { 00429 std::cout << "layer : " << lay << "\n"; 00430 for (int i = 0; i < sizeBLayer; i++) 00431 { 00432 std::cout << " " << layers[lay * sizeBLayer + i]; 00433 if (i % 10 == 9) 00434 std::cout << "\n"; 00435 } 00436 std::cout << "\n"; 00437 } 00438 } 00439 00440 moab::ErrorCode OneToOneSwept::NodeAbove(moab::EntityHandle node1, moab::EntityHandle node2, moab::Range & latQuads, 00441 moab::EntityHandle & node3, moab::EntityHandle & node4) 00442 { 00443 // look for node above node 1 in an unused quad 00444 moab::EntityHandle nds[2] = { node1, node2 }; 00445 // find all quads connected to these 2 nodes; find one in the range that is not used 00446 moab::Range adj_entities; 00447 moab::ErrorCode rval = mb->get_adjacencies(nds, 2, 2, false, adj_entities); 00448 MBERRCHK(rval, mb); 00449 // default is -1 00450 moab::EntityHandle nextQuad = 0;// null 00451 for (unsigned int i = 0; i < adj_entities.size(); i++) 00452 { 00453 if ((markedMoabEnts.find(adj_entities[i]) == markedMoabEnts.end()) && 00454 (latQuads.find(adj_entities[i]) != latQuads.end())) 00455 { 00456 // the quadrilateral is not marked but is on the lateral/linking surface 00457 nextQuad = adj_entities[i]; 00458 break; 00459 } 00460 } 00461 if (0 == nextQuad) 00462 MBERRCHK(moab::MB_FAILURE, mb); 00463 00464 // decide on which side are nodes 1 and 2, then get the opposite side 00465 const moab::EntityHandle * conn4 = NULL; 00466 int nnodes; 00467 rval = mb->get_connectivity(nextQuad, conn4, nnodes); 00468 MBERRCHK(rval, mb); 00469 int index1 = -1; 00470 for (index1 = 0; index1 < 4; index1++) 00471 if (node1 == conn4[index1]) 00472 break; 00473 if (4 == index1) 00474 MBERRCHK(moab::MB_FAILURE, mb); 00475 if (node2 == conn4[(index1 + 1) % 4]) // quad is oriented node1, node2, node4, node3 00476 { 00477 node3 = conn4[(index1 + 3) % 4]; 00478 } 00479 else if (node2 == conn4[(index1 +3) % 4]) // quad is oriented node2, node1, node3, node4 00480 { 00481 node3 = conn4[(index1 + 1) % 4]; 00482 } 00483 else 00484 MBERRCHK(moab::MB_FAILURE, mb);// something is really wrong 00485 node4 = conn4[(index1 + 2) % 4]; 00486 00487 // mark the quad to be sure not to use it again 00488 markedMoabEnts.insert(nextQuad); 00489 00490 return moab::MB_SUCCESS; 00491 } 00492 00493 moab::ErrorCode OneToOneSwept::FourthNodeInQuad(moab::EntityHandle node1, moab::EntityHandle node2, moab::EntityHandle node3, 00494 moab::Range & latQuads, moab::EntityHandle & node4) 00495 { 00496 // look for the fourth node 00497 moab::EntityHandle nds[3] = { node1, node2, node3 }; 00498 // find all quads connected to these 3 nodes; find one in the range that is not used 00499 moab::Range adj_entities; 00500 moab::ErrorCode rval = mb->get_adjacencies(nds, 3, 2, false, adj_entities); 00501 MBERRCHK(rval, mb); 00502 00503 moab::EntityHandle nextQuad = 0;// null 00504 for (unsigned int i = 0; i < adj_entities.size(); i++) 00505 { 00506 if ((markedMoabEnts.find(adj_entities[i]) == markedMoabEnts.end()) && 00507 (latQuads.find(adj_entities[i]) != latQuads.end())) 00508 { 00509 // the quadrilateral is not marked but is on the lateral/linking surface 00510 nextQuad = adj_entities[i]; 00511 break; 00512 } 00513 } 00514 if (0 == nextQuad) 00515 MBERRCHK(moab::MB_FAILURE, mb); 00516 00517 // decide on which side are nodes 1 and 2, then get the opposite side 00518 const moab::EntityHandle * conn4 = NULL; 00519 int nnodes; 00520 rval = mb->get_connectivity(nextQuad, conn4, nnodes); 00521 MBERRCHK(rval, mb); 00522 00523 node4 = 0; 00524 for (int index = 0; index < 4; index++) 00525 { 00526 moab::EntityHandle c4 = conn4[index]; 00527 if (node1 != c4 && node2 != c4 && node3 != c4) 00528 { 00529 node4 = c4; 00530 break; 00531 } 00532 } 00533 if (0 == node4) 00534 MBERRCHK(moab::MB_FAILURE, mb); 00535 00536 // mark the quad to be sure not to use it again 00537 markedMoabEnts.insert(nextQuad); 00538 00539 return moab::MB_SUCCESS; 00540 00541 } 00542 #ifdef HAVE_ARMADILLO 00543 void OneToOneSwept::SurfMeshHarmonic(iBase_EntityHandle vol, vector<iBase_EntityHandle> &newNodehandle) 00544 { 00545 00546 SurfProHarmonicMap surf_pro(mk_core(), sourceSurface, targetSurface, vol); 00547 surf_pro.match(); 00548 surf_pro.setMeshData(NodeList, TVertexList, FaceList); 00549 surf_pro.projection(); 00550 surf_pro.getMeshData(TVertexList); 00551 00552 iMesh::Error m_err; 00553 for (unsigned int i = 0; i < TVertexList.size(); i++){ 00554 if (TVertexList[i].onBoundary) 00555 continue; 00556 m_err = mk_core()->imesh_instance()->createVtx(TVertexList[i].xyz[0], TVertexList[i].xyz[1], TVertexList[i].xyz[2], TVertexList[i].gVertexHandle); 00557 IBERRCHK(m_err, "Trouble create a mesh nodes on the target surface!"); 00558 newNodehandle.push_back(TVertexList[i].gVertexHandle); 00559 } 00560 } 00561 #endif 00562 00563 bool OneToOneSwept::isConcave() 00564 { 00565 //use the quad mesh on the source surface to determine whether it is concave or not 00566 iBase_TagHandle taghandle = 0; 00567 iMesh::Error m_err = mk_core()->imesh_instance()->getTagHandle("source", taghandle); 00568 IBERRCHK(m_err, "Trouble get the tag handle in the mesh instance."); 00569 for (std::vector<Vertex>::iterator it = NodeList.begin(); it != NodeList.end(); it++){ 00570 if (!it->onBoundary) 00571 continue; 00572 //get the adjacent quads around a vertex 00573 double angle = 0.0; 00574 std::vector<iBase_EntityHandle> adj_quads; 00575 m_err = mk_core()->imesh_instance()->getEntAdj(it->gVertexHandle, iBase_FACE, adj_quads); 00576 IBERRCHK(m_err, "Trouble get the adjacent quads around a vertex!"); 00577 for (unsigned int i = 0; i < adj_quads.size(); i++){ 00578 int face_index = -1; 00579 m_err = mk_core()->imesh_instance()->getIntData(adj_quads[i], taghandle, face_index); 00580 if (m_err) continue;//this is a quad entity from the linking surface 00581 int node_index = 0, pre_index, next_index; 00582 for (int j = 0; j < 4; j++) 00583 if (FaceList[face_index].connect[j]->index == it->index){ 00584 node_index = j; 00585 break; 00586 } 00587 Vector3D v1(0.0), v2(0.0); 00588 pre_index = (FaceList[face_index].getVertex((node_index+4-1)%4))->index; 00589 next_index = (FaceList[face_index].getVertex((node_index+1)%4))->index; 00590 v1 = NodeList[pre_index].xyz - it->xyz; 00591 v2 = NodeList[next_index].xyz - it->xyz; 00592 double dotproduct = v1[0]*v2[0]+v1[1]*v2[1]+v1[2]*v2[2]; 00593 angle += acos(dotproduct/sqrt((v1[0]*v1[0]+v1[1]*v1[1]+v1[2]*v1[2])*(v2[0]*v2[0]+v2[1]*v2[1]+v2[2]*v2[2]))); 00594 } 00595 if (angle > M_PI){ 00596 return true; 00597 } 00598 } 00599 00600 return false; 00601 } 00602 00603 00604 //****************************************************************************// 00605 // function : TargetSurfProjection 00606 // Author : Shengyong Cai 00607 // Date : Feb 15, 2011 00608 // Description: map the mesh on the source surface to the target surface 00609 //***************************************************************************// 00610 int OneToOneSwept::TargetSurfProjection(std::vector<moab::EntityHandle> & bLayers) 00611 { 00612 iMesh::Error m_err; 00613 //iGeom::Error g_err; 00614 iRel::Error r_err; 00615 moab::ErrorCode rval; 00616 00617 MEntVector surfs; 00618 mk_core()->get_entities_by_dimension(2, surfs); 00619 ModelEnt *target_surf = 0; 00620 for (unsigned int i = 0; i < surfs.size(); i++) 00621 { 00622 00623 if (surfs[i]->geom_handle() == targetSurface) 00624 { 00625 target_surf = surfs[i]; 00626 break; 00627 } 00628 } 00629 int irelIndx = target_surf->iRelPairIndex(); 00630 iGeom * igeom_inst = mk_core()->igeom_instance(target_surf->iGeomIndex()); 00631 // we could have got it from model tag, too 00632 // something along this: 00633 // err = igeom_instance(geom_index)->getData(*eit, iGeomModelTags[geom_index], &this_me); 00634 00635 TVertexList.resize(NodeList.size()); 00636 // make everything not on boundary, first; the true boundary flag will be set later 00637 for (unsigned int i = 0; i < TVertexList.size(); i++) 00638 { 00639 TVertexList[i].onBoundary = false; 00640 } 00641 00642 iBase_TagHandle taghandle_tar = 0; 00643 m_err = mk_core()->imesh_instance()->getTagHandle("TargetMesh", 00644 taghandle_tar); 00645 if (m_err) 00646 { 00647 m_err = mk_core()->imesh_instance()->createTag("TargetMesh", 00648 1, iBase_INTEGER, taghandle_tar); 00649 IBERRCHK(m_err, 00650 "Trouble create the target mesh tag handle in the mesh instance."); 00651 } 00652 // TODO: If the tag exists, we could verify that the tag is the proper one. 00653 // Probably the tag should be put in a namespace, and perhaps it should 00654 // be deleted when we are finished with it. 00655 00656 iBase_TagHandle taghandle = 0; 00657 m_err = mk_core()->imesh_instance()->getTagHandle("source", taghandle); 00658 IBERRCHK(m_err, "Trouble get tag handle of the source surface."); 00659 00660 // we know the first layer of nodes (on the source) 00661 // 00662 // the first 0 , 1, ..., sizeBlayer - 1 are on bottom, were bdyNodes before 00663 // 00664 for (int i = 0; i < sizeBLayer; i++) 00665 { 00666 iBase_EntityHandle sBNode = (iBase_EntityHandle) bLayers[i]; 00667 int index; 00668 m_err = mk_core()->imesh_instance()->getIntData(sBNode, taghandle, index); 00669 IBERRCHK(m_err, "Trouble get the int value for nodes in the mesh instance."); 00670 TVertexList[index].onBoundary = true;// some could be corners, but it is not that important 00671 moab::EntityHandle topNode = bLayers[numLayers * sizeBLayer + i];// node right above 00672 iBase_EntityHandle tBNode = (iBase_EntityHandle) topNode;// it is right above node i in loop 00673 TVertexList[index].gVertexHandle = tBNode; 00674 // now get the coordinates of the tBNode (node on boundary of target) 00675 rval = mb->get_coords(&topNode, 1, &(TVertexList[index].xyz[0])); 00676 MBERRCHK(rval, mb); 00677 00678 } 00679 00680 iBase_EntitySetHandle entityset; //this entityset is for storing the inner nodes on the target surface 00681 vector<iBase_EntityHandle> newNodehandle; 00682 00683 r_err = mk_core()->irel_pair(irelIndx)->getEntSetRelation(targetSurface, 0, entityset); 00684 if (r_err) //there is no entityset associated with targetSurface; this should be an error 00685 { 00686 m_err = mk_core()->imesh_instance()->createEntSet(1, entityset); 00687 IBERRCHK(m_err, "Trouble create the entity set"); 00688 } 00689 00690 // bool condition_harmonic = isConcave(); 00691 bool is_exe_harmonic = false; 00692 #ifdef HAVE_ARMADILLO 00693 //target surface mesh projection based on harmonic mapping 00694 if (condition_harmonic){ 00695 is_exe_harmonic = true; 00696 SurfMeshHarmonic(volume, newNodehandle); 00697 } 00698 #endif 00699 00700 if (!is_exe_harmonic){ 00702 // Based on the transformation in the physical space, project the mesh nodes on the source surface to the target surface 00704 Vector3D sPtsCenter(0.0), tPtsCenter(0.0); 00705 std::vector<Vector3D> sBndNodes(sizeBLayer), tBndNodes(sizeBLayer); 00706 int num_pts = 0; 00707 //calculate the barycenters for the source and target boundaries 00708 for (unsigned int i = 0; i < NodeList.size(); i++) 00709 { 00710 if (NodeList[i].onBoundary) 00711 { 00712 sPtsCenter += NodeList[i].xyz; 00713 tPtsCenter += TVertexList[i].xyz; 00714 sBndNodes[num_pts] = NodeList[i].xyz; 00715 tBndNodes[num_pts] = TVertexList[i].xyz; 00716 num_pts++; 00717 } 00718 } 00719 if (sizeBLayer != num_pts) 00720 MBERRCHK(moab::MB_FAILURE, mb); 00721 sPtsCenter = sPtsCenter / num_pts; 00722 tPtsCenter = tPtsCenter / num_pts; 00723 //done with the barycenter calculation 00724 00725 // compute transformation matrix from source boundary to target boundary 00726 Matrix3D transMatrix; 00727 computeTransformationFromSourceToTarget(sBndNodes, sPtsCenter, tBndNodes, tPtsCenter, transMatrix); 00728 00729 //calculate the inner nodes on the target surface 00730 for (unsigned int i = 0; i < NodeList.size(); i++) 00731 { 00732 if (!NodeList[i].onBoundary) 00733 { 00734 Vector3D xyz; 00735 xyz = transMatrix * (NodeList[i].xyz - 2 * sPtsCenter + tPtsCenter)+sPtsCenter; 00736 00737 iGeom::Error g_err = igeom_inst->getEntClosestPt(targetSurface, xyz[0], xyz[1], xyz[2], TVertexList[i].xyz[0], 00738 TVertexList[i].xyz[1], TVertexList[i].xyz[2]); 00739 IBERRCHK(g_err, "Trouble get the closest point on the targets surface."); 00740 00741 //create the node entities 00742 iMesh::Error m_err = mk_core()->imesh_instance()->createVtx(TVertexList[i].xyz[0], TVertexList[i].xyz[1], 00743 TVertexList[i].xyz[2], TVertexList[i].gVertexHandle); 00744 IBERRCHK(m_err, "Trouble create the node entity."); 00745 TVertexList[i].onBoundary = false; 00746 newNodehandle.push_back(TVertexList[i].gVertexHandle); 00747 } 00748 } 00749 } 00750 //add the inner nodes to the entityset 00751 m_err = mk_core()->imesh_instance()->addEntArrToSet(&newNodehandle[0], newNodehandle.size(), entityset); 00752 IBERRCHK(m_err, "Trouble add an array of nodes to the entityset."); 00753 00754 //until now, all the nodes have been generated on the target surface 00755 00756 // we need to decide the orientation with respect to the faces on the source (which are oriented correctly) 00757 // look at the first 2 nodes in the boundary, in target 00758 int sense_out = 1; 00759 std::vector<moab::EntityHandle> bdyTNodes; 00760 std::vector<int> group_sizes; 00761 target_surf-> boundary(0, bdyTNodes, NULL, &group_sizes);// we do not need the senses, yet. Or do we? 00762 // find the first node and second node in the bLayers[] list corresponding to the top 00763 moab::EntityHandle node1 = bdyTNodes[1], node2 = bdyTNodes[2]; 00764 int index = -1; 00765 for (index = 0; index < sizeBLayer; index++) 00766 { 00767 if (bLayers[numLayers * sizeBLayer + index] == node1) 00768 break; 00769 } 00770 if (index == sizeBLayer) 00771 MBERRCHK(moab::MB_FAILURE, mb); 00772 00773 int prevIndex = (index + sizeBLayer -1) % sizeBLayer; 00774 int nextIndex = (index + 1) % sizeBLayer; 00775 if (bLayers[numLayers * sizeBLayer + prevIndex] == node2) 00776 sense_out = -1; 00777 else if (bLayers[numLayers * sizeBLayer + nextIndex] == node2) 00778 sense_out = 1; 00779 else 00780 MBERRCHK(moab::MB_FAILURE, mb);// serious error in the logic, can't decide orientation 00781 00782 00783 //create the quadrilateral elements on the target surface 00784 vector<iBase_EntityHandle> mFaceHandle(FaceList.size()); 00785 vector<iBase_EntityHandle> connect(FaceList.size() * 4); 00786 for (unsigned int i = 0; i < FaceList.size(); i++) 00787 { 00788 if (sense_out < 0) 00789 { 00790 connect[4 * i + 0] = TVertexList[(FaceList[i].getVertex(0))->index].gVertexHandle; 00791 connect[4 * i + 1] = TVertexList[(FaceList[i].getVertex(3))->index].gVertexHandle; 00792 connect[4 * i + 2] = TVertexList[(FaceList[i].getVertex(2))->index].gVertexHandle; 00793 connect[4 * i + 3] = TVertexList[(FaceList[i].getVertex(1))->index].gVertexHandle; 00794 } 00795 else 00796 { 00797 connect[4 * i + 0] = TVertexList[(FaceList[i].getVertex(0))->index].gVertexHandle; 00798 connect[4 * i + 1] = TVertexList[(FaceList[i].getVertex(1))->index].gVertexHandle; 00799 connect[4 * i + 2] = TVertexList[(FaceList[i].getVertex(2))->index].gVertexHandle; 00800 connect[4 * i + 3] = TVertexList[(FaceList[i].getVertex(3))->index].gVertexHandle; 00801 } 00802 00803 } 00804 m_err = mk_core()->imesh_instance()->createEntArr(iMesh_QUADRILATERAL, &connect[0], connect.size(), &mFaceHandle[0]); 00805 IBERRCHK(m_err, "Trouble create the quadrilateral mesh."); 00806 00807 //add the inner face elements to the entityset 00808 m_err = mk_core()->imesh_instance()->addEntArrToSet(&mFaceHandle[0], FaceList.size(), entityset); 00809 IBERRCHK(m_err, "Trouble add an array of quadrilateral entities to the entity set."); 00810 00811 mk_core()->save_mesh("BeforeHex.vtk"); 00812 #ifdef HAVE_MESQUITE 00813 00814 SurfMeshOptimization(); 00815 00816 #endif 00817 00818 return 1; 00819 } 00820 // input: list of nodes on source, boundary center, list of nodes on target, target center 00821 // output: 3x3 matrix A such that 00822 // target= A * ( source - 2*sc + tc) + sc 00823 void OneToOneSwept::computeTransformationFromSourceToTarget(std::vector<Vector3D> & sNodes, Vector3D & sc, 00824 std::vector<Vector3D> & tNodes, Vector3D & tc, Matrix3D & transMatrix) 00825 { 00826 Matrix3D tmpMatrix(0.0); 00827 Matrix3D bMatrix(0.0); 00828 //transform the coordinates 00829 int size = (int)sNodes.size(); 00830 assert(sNodes.size() == tNodes.size()); 00831 for (int i = 0; i < size; i++) 00832 { 00833 //transform the boundary nodes 00834 sNodes[i] = sNodes[i] - 2 * sc + tc; 00835 tNodes[i] = tNodes[i] - sc; 00836 } 00837 00838 //calculate the transformation matrix: transform the nodes on the source surface to the target surface in the physical space 00839 for (int i = 0; i < size; i++) 00840 { 00841 tmpMatrix = tmpMatrix + sNodes[i]*transpose(sNodes[i]); 00842 bMatrix = bMatrix + tNodes[i]*transpose(sNodes[i]); 00843 } 00844 00845 //first determine the affine mapping matrix is singular or not 00846 double detValue = det(tmpMatrix); 00847 (void) detValue; 00848 assert(pow(detValue, 2)>1.0e-20); 00849 00850 //solve the affine mapping matrix, make use of inverse matrix to get affine mapping matrix 00851 Matrix3D InvMatrix = inverse(tmpMatrix); 00852 transMatrix = bMatrix*InvMatrix; 00853 00854 } 00855 // use similar code to TargetSurfProjection, but do not project on surface... 00856 int OneToOneSwept::ProjectInteriorLayers(std::vector<moab::EntityHandle> & boundLayers, vector<vector<Vertex> > & linkVertexList) 00857 { 00858 iMesh::Error m_err; 00859 Vector3D sPtsCenter(0.), tPtsCenter(0.); 00860 std::vector<Vector3D> PtsCenter(numLayers - 1); 00861 std::vector<Vector3D> sBoundaryNodes(0), tBoundaryNodes(0); 00862 00863 iBase_TagHandle taghandle = 0; 00864 m_err = mk_core()->imesh_instance()->getTagHandle("source", taghandle); 00865 IBERRCHK(m_err, "Trouble getting the source tag handle"); 00866 00867 std::vector<Vector3D> latCoords; 00868 latCoords.resize(boundLayers.size() - 2 * sizeBLayer);// to store the coordinates of the lateral points 00869 // (exclude the source and target, they are already in NodeList and TVertexList)... 00870 00871 moab::ErrorCode rval = mb->get_coords(&(boundLayers[sizeBLayer]), latCoords.size(), &(latCoords[0][0])); //these are the nodes for lateral sides 00872 MBERRCHK(rval, mb); 00873 00874 //calculate the center coordinates 00875 for (int i = 0; i < numLayers - 1; i++) 00876 PtsCenter[i].set(0.); 00877 00878 int numPts = sizeBLayer;// a lot of repetition ; do we really need 00879 sBoundaryNodes.resize(numPts);// another useless copy 00880 tBoundaryNodes.resize(numPts);// another useless copy 00881 for (int j = 0; j < sizeBLayer; j++) 00882 { 00883 iBase_EntityHandle sBNode = (iBase_EntityHandle) boundLayers[j]; 00884 int i; 00885 // this is the index in NodeList... 00886 m_err = mk_core()->imesh_instance()->getIntData(sBNode, taghandle, i); 00887 IBERRCHK(m_err, "Trouble get the int value for nodes in the mesh instance."); 00888 00889 sPtsCenter += NodeList[i].xyz; 00890 tPtsCenter += TVertexList[i].xyz; 00891 00892 sBoundaryNodes[j] = NodeList[i].xyz; 00893 tBoundaryNodes[j] = TVertexList[i].xyz; 00894 00895 for (int lay = 0; lay < numLayers - 1; lay++) 00896 { 00897 // interior layers 00898 int indexNodeOnSide = lay * sizeBLayer + j;// all p3d will be above index i 00899 Vector3D & p3d = latCoords[indexNodeOnSide]; 00900 PtsCenter[lay] += p3d; 00901 linkVertexList[lay][i].xyz = p3d; 00902 linkVertexList[lay][i].gVertexHandle = (iBase_EntityHandle) boundLayers[indexNodeOnSide + sizeBLayer]; 00903 } 00904 } 00905 00906 sPtsCenter = sPtsCenter / numPts; 00907 tPtsCenter = tPtsCenter / numPts; 00908 00909 //calculate the center coordinates for the ith layer 00910 for (int i = 0; i < numLayers - 1; i++) 00911 PtsCenter[i] = PtsCenter[i] / numPts; 00912 00913 std::vector<Vector3D> sNodes(numPts); //boundary nodes on the source surface 00914 std::vector<Vector3D> tNodes(numPts); //boundary nodes on the target surface 00915 std::vector<Vector3D> isBNodes(numPts), itBNodes(numPts); //boundary nodes on the different layers 00916 00917 //loop over different layers 00918 for (int i = 0; i < numLayers - 1; i++) 00919 { 00920 for (int j = 0; j < numPts; j++) 00921 { 00922 sNodes[j] = sBoundaryNodes[j]; 00923 tNodes[j] = tBoundaryNodes[j]; 00924 //coordinates on the different layers 00925 isBNodes[j] = itBNodes[j] = latCoords[i*sizeBLayer + j]; 00926 } 00927 00928 Matrix3D sA, tA; 00929 // from source to layer i 00930 computeTransformationFromSourceToTarget(sNodes, sPtsCenter, isBNodes, PtsCenter[i], sA); 00931 // from target to layer i 00932 computeTransformationFromSourceToTarget(tNodes, tPtsCenter, itBNodes, PtsCenter[i], tA); 00933 //calculate the inner nodes for different layers 00934 double s = (i + 1) / double(numLayers); // interpolation factor 00935 for (unsigned int j = 0; j < NodeList.size(); j++) 00936 { 00937 if (!(NodeList[j].onBoundary)) 00938 { 00939 Vector3D spts, tpts, pts; 00940 iBase_EntityHandle nodeHandle; 00941 spts = sA * (NodeList[j].xyz - 2 * sPtsCenter + PtsCenter[i])+sPtsCenter; 00942 tpts = tA * (TVertexList[j].xyz - 2 * tPtsCenter + PtsCenter[i])+tPtsCenter; 00943 // interpolate the 2 results 00944 pts = (1-s) * spts + s * tpts; 00945 00946 linkVertexList[i][j].xyz = pts; 00947 00948 m_err = mk_core()->imesh_instance()->createVtx(pts[0], pts[1], pts[2], nodeHandle); 00949 IBERRCHK(m_err, "Trouble create the vertex entity."); 00950 linkVertexList[i][j].gVertexHandle = nodeHandle; 00951 m_err = mk_core()->imesh_instance()->addEntToSet(nodeHandle, volumeSet); 00952 IBERRCHK(m_err, "Trouble add the node handle to the entity set."); 00953 } 00954 } 00955 } 00956 return 1; 00957 } 00958 00959 //****************************************************************************// 00960 // function : CreateElements 00961 // Author : Shengyong Cai 00962 // Date : Feb 16, 2011 00963 // Description: create hexahedral elements by connecting 8 nodes which have 00964 // already been created by previous functions 00965 //***************************************************************************// 00966 int OneToOneSwept::CreateElements(vector<vector<Vertex> > &linkVertexList) 00967 { 00968 //create the quadrilateral elements on the different layers 00969 //it is not necessary to create the quadrilateral elements on the different layers. Hex element can be created based on the eight nodes 00970 iMesh::Error m_err; 00971 vector<iBase_EntityHandle> mVolumeHandle(FaceList.size()); 00972 // first decide orientation, based on the FaceList orientation, and first node above 00973 // take one face on source, and first node above in layer 1 00974 Vertex * v1 = FaceList[0].connect[0]; 00975 Vertex * v2 = FaceList[0].connect[1]; 00976 Vertex * v3 = FaceList[0].connect[2]; 00977 // vertex 4 is on layer 1, above vertex 1 00978 int ind1 = v1->index; 00979 Vertex * v4; 00980 if (numLayers > 1) 00981 v4 = &linkVertexList[0][ind1]; 00982 else 00983 v4 = &TVertexList[ind1]; 00984 00985 Vector3D normal1 = (v2->xyz-v1->xyz)*(v3->xyz-v1->xyz); 00986 double vol6= normal1 % (v4->xyz-v1->xyz); 00987 std::cout << "Orientation is "; 00988 int skip = 0; 00989 if (vol6 < 0) 00990 { 00991 std::cout <<"negative\n"; 00992 skip=4; 00993 } 00994 else 00995 std::cout <<"positive\n"; 00996 00997 vector<iBase_EntityHandle> connect(8); 00998 for (int m = 0; m < numLayers; m++) 00999 { 01000 for (unsigned int i = 0; i < FaceList.size(); i++) 01001 { 01002 for (int k = 0; k < 4; k++) 01003 { 01004 if (m == 0) // the first layer is the source layer 01005 connect[k + skip] = NodeList 01006 [(FaceList[i].connect[k])->index].gVertexHandle; 01007 else // the first layer is an intermediate layer 01008 connect[k + skip] = linkVertexList[m - 1] 01009 [(FaceList[i].connect[k])->index].gVertexHandle; 01010 if (m == (numLayers - 1)) // the second layer is the target layer 01011 connect[(k + skip + 4) % 8] = TVertexList 01012 [(FaceList[i].connect[k])->index].gVertexHandle; 01013 else // the second layer is an intermediate layer 01014 connect[(k + skip + 4) % 8] = linkVertexList[m] 01015 [(FaceList[i].connect[k])->index].gVertexHandle; 01016 } 01017 m_err = mk_core()->imesh_instance()->createEnt(iMesh_HEXAHEDRON, 01018 &connect[0], 8, mVolumeHandle[i]); 01019 IBERRCHK(m_err, "Trouble creating the hexahedral element."); 01020 } 01021 m_err = mk_core()->imesh_instance()->addEntArrToSet(&mVolumeHandle[0], 01022 FaceList.size(), volumeSet); 01023 IBERRCHK(m_err, 01024 "Trouble adding an array of hexahedral elements to the entity set."); 01025 } 01026 return 1; 01027 } 01028 01029 #ifdef HAVE_MESQUITE 01030 //target surface mesh smoothing by Mesquite 01031 void OneToOneSwept::SurfMeshOptimization() 01032 { 01033 MEntSelection::iterator mit = mentSelection.begin(); 01034 ModelEnt *me = mit -> first; 01035 int irelPairIndex = me->iRelPairIndex(); 01036 iGeom * igeom_inst = mk_core()->igeom_instance(me->iGeomIndex()); 01037 //create a tag to attach the coordinates to nodes 01038 iBase_TagHandle mapped_tag = 0; 01039 iMesh::Error m_err = mk_core()->imesh_instance()->getTagHandle("MsqAltCoords", mapped_tag); 01040 if (m_err) 01041 { 01042 m_err = mk_core()->imesh_instance()->createTag("MsqAltCoords", 3, iBase_DOUBLE, mapped_tag); 01043 IBERRCHK(m_err, "Trouble create a tag."); 01044 01045 } 01046 //attach the coordinates to the nodes 01047 double tag_data[3*TVertexList.size()]; 01048 std::vector<iBase_EntityHandle> vertexHandle(TVertexList.size()); 01049 for (unsigned int i = 0; i < NodeList.size();i++) 01050 { 01051 tag_data[3*i] = NodeList[i].xyz[0]; 01052 tag_data[3*i+1] = NodeList[i].xyz[1]; 01053 tag_data[3*i+2] = NodeList[i].xyz[2]; 01054 vertexHandle[i] = TVertexList[i].gVertexHandle; 01055 } 01056 m_err = mk_core()->imesh_instance()->setDblArrData(&vertexHandle[0], NodeList.size(), mapped_tag, &tag_data[0]); 01057 IBERRCHK(m_err, "Trouble set an array of int data to nodes."); 01058 01059 //get the mesh entityset for target surface 01060 iBase_EntitySetHandle surfSets; 01061 iRel::Error r_err = mk_core()->irel_pair(irelPairIndex)->getEntSetRelation(targetSurface, 0, surfSets); 01062 IBERRCHK(r_err, "Trouble get the mesh entity set for the target surface."); 01063 //call the MeshImprove class to smooth the target surface mesh by using Mesquite 01064 MeshImprove meshopt(mk_core(), false, true, true, true, igeom_inst); 01065 meshopt.SurfMeshImprove(targetSurface, surfSets, iBase_FACE); 01066 } 01067 #endif 01068 } 01069
