MeshKit  1.0
TFIMapping Class Reference
Generate the all-Quad mesh by TFI mapping. More...
#include <TFIMapping.hpp>
Inheritance diagram for TFIMapping:
List of all members.
Public Member Functions
 TFIMapping (MKCore *mk_core, const MEntVector &me_vec)
 ~TFIMapping ()
virtual void setup_this ()
 Pure virtual, derived class must define.
virtual void execute_this ()
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
void skip_improve ()
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
 Function returning whether this scheme can mesh entities of t the specified dimension.
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Private Member Functions
void parametricTFI3D (double *pts, double r, double s, double pt_0s[3], double pt_1s[3], double pt_r0[3], double pt_r1[3])
int SurfMapping (ModelEnt *ent)
int cylinderSurfMapping (ModelEnt *ent)
void computeTransformation (Vector3D &A, Vector3D &B, Vector3D &C, Vector3D &D, Matrix3D &transMatrix)
void SurfImprove (iBase_EntityHandle surface, iBase_EntitySetHandle surfMesh, iBase_EntityType entity_type)
void SmoothWinslow (std::vector< iBase_EntityHandle > &List_i, std::vector< iBase_EntityHandle > &List_ii, std::vector< iBase_EntityHandle > &List_j, std::vector< iBase_EntityHandle > &List_jj, std::vector< iBase_EntityHandle > &InteriorNodes, std::vector< iBase_EntityHandle > &quads, iBase_TagHandle &taghandle, ModelEnt *ent)
Private Attributes
bool _shapeImprove
Detailed Description
TFIMapping generates the all-quad mesh by trans-finite interpolation with i, j parameters
Examples:
example_basic.cpp, example_intassign.cpp, and example_tfimapping.cpp.
Definition at line 46 of file TFIMapping.hpp.
TFIMapping ( MKCore *  mk_core,
const MEntVector &  me_vec
Definition at line 31 of file TFIMapping.cpp.
~TFIMapping ( )
Definition at line 39 of file TFIMapping.cpp.
Member Function Documentation
static bool can_mesh ( iBase_EntityType  dim) [inline, static]
Parameters:
dimentity dimension
Definition at line 65 of file TFIMapping.hpp.
static bool can_mesh ( ModelEnt *  me) [inline, static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 76 of file TFIMapping.hpp.
void computeTransformation ( Vector3D &  A,
Vector3D &  B,
Vector3D &  C,
Vector3D &  D,
Matrix3D &  transMatrix
) [private]
Definition at line 988 of file TFIMapping.cpp.
int cylinderSurfMapping ( ModelEnt *  ent) [private]
Definition at line 288 of file TFIMapping.cpp.
void execute_this ( ) [virtual]
Implements GraphNode.
Definition at line 251 of file TFIMapping.cpp.
virtual const moab::EntityType* mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 89 of file TFIMapping.hpp.
static const char* name ( ) [inline, static]
Get class name.
Definition at line 56 of file TFIMapping.hpp.
const moab::EntityType * output_types ( ) [static]
Returns:
Definition at line 24 of file TFIMapping.cpp.
void parametricTFI3D ( double *  pts,
double  r,
double  s,
double  pt_0s[3],
double  pt_1s[3],
double  pt_r0[3],
double  pt_r1[3]
) [private]
void setup_this ( ) [virtual]
Definition at line 46 of file TFIMapping.cpp.
void skip_improve ( ) [inline]
Definition at line 93 of file TFIMapping.hpp.
void SmoothWinslow ( std::vector< iBase_EntityHandle > &  List_i,
std::vector< iBase_EntityHandle > &  List_ii,
std::vector< iBase_EntityHandle > &  List_j,
std::vector< iBase_EntityHandle > &  List_jj,
std::vector< iBase_EntityHandle > &  InteriorNodes,
std::vector< iBase_EntityHandle > &  quads,
iBase_TagHandle &  taghandle,
ModelEnt *  ent
) [private]
Definition at line 1029 of file TFIMapping.cpp.
void SurfImprove ( iBase_EntityHandle  surface,
) [private]
int SurfMapping ( ModelEnt *  ent) [private]
Definition at line 672 of file TFIMapping.cpp.
Member Data Documentation
bool _shapeImprove [private]
Definition at line 100 of file TFIMapping.hpp.
