MeshKit  1.0
SubMapping Class Reference
Generate the structural mesh for linking surface. More...
#include <SubMapping.hpp>
Inheritance diagram for SubMapping:
List of all members.
Public Member Functions
 SubMapping (MKCore *mk_core, const MEntVector &me_vec)
 ~SubMapping ()
virtual void setup_this ()
 Pure virtual, derived class must define.
virtual void execute_this ()
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
void SetupMeshSize (double size=1.0)
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
 Function returning whether this scheme can mesh entities of t the specified dimension.
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Private Member Functions
void VertexClassification (ModelEnt *ent)
void EdgeClassification ()
void EdgeDiscretization (ModelEnt *me)
void VerEdgOrganize (std::set< iBase_EntityHandle > edge_set, std::vector< iBase_EntityHandle > g_edge, iBase_EntityHandle surf)
void InteriorNodeInterpolation (ModelEnt *me)
void GetAngle (iBase_EntityHandle surf, vector< double > &angle)
void AssignIJCoords (double &u, double &v, EdgeTypes type, int index)
void VtxClassificationLP ()
bool isOutSideSurf (vector< Vertex > corner, int i, int j)
double Angle2D (double x1, double y1, double x2, double y2)
void MeshSmoothing (ModelEnt *ent)
void buildAssociation ()
bool isCurved (int vtx_index, vector< double > u1, vector< double > u2, vector< double > u3, vector< double > u4, vector< vector< double > > tang_pre, vector< vector< double > > tang_next)
void LinearProgramming ()
Private Attributes
vector< VertexTypes > vertices_types
vector< Vertex > nodes
vector< Vertex > vertices
vector< Edge > edges
vector< double > interior_angle
vector< int > sorted_vertex_list
vector< int > sorted_node_list
vector< int > sorted_edge_list
vector< EdgeTypes > edges_types
iBase_TagHandle g_taghandle
iBase_TagHandle m_taghandle
vector< vector< int > > coordinate_i_j
double size_low_bound
unsigned int start_index
vector< int > edge_size
map< int, int > geom_mesh_node
map< int, int > mesh_geom_vertex
vector< Face > quads
Detailed Description
SubMapping generates the structural mesh 3 steps: vertex classification, assign each node on the bounary i-j coordinates subdivide the surface
Definition at line 53 of file SubMapping.hpp.
SubMapping ( MKCore *  mk_core,
const MEntVector &  me_vec
Definition at line 35 of file SubMapping.cpp.
~SubMapping ( )
Definition at line 43 of file SubMapping.cpp.
Member Function Documentation
double Angle2D ( double  x1,
double  y1,
double  x2,
double  y2
) [private]
Definition at line 1570 of file SubMapping.cpp.
void AssignIJCoords ( double &  u,
double &  v,
EdgeTypes  type,
int  index
) [private]
Definition at line 1155 of file SubMapping.cpp.
void buildAssociation ( ) [private]
static bool can_mesh ( iBase_EntityType  dim) [inline, static]
Parameters:
dimentity dimension
Definition at line 72 of file SubMapping.hpp.
static bool can_mesh ( ModelEnt *  me) [inline, static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 81 of file SubMapping.hpp.
void EdgeClassification ( ) [private]
Definition at line 581 of file SubMapping.cpp.
void EdgeDiscretization ( ModelEnt *  me) [private]
Definition at line 687 of file SubMapping.cpp.
void execute_this ( ) [virtual]
Implements GraphNode.
Definition at line 97 of file SubMapping.cpp.
void GetAngle ( iBase_EntityHandle  surf,
vector< double > &  angle
) [private]
Definition at line 395 of file SubMapping.cpp.
void InteriorNodeInterpolation ( ModelEnt *  me) [private]
Definition at line 1179 of file SubMapping.cpp.
bool isCurved ( int  vtx_index,
) [private]
Definition at line 468 of file SubMapping.cpp.
bool isOutSideSurf ( vector< Vertex >  corner,
int  i,
int  j
) [private]
Definition at line 1544 of file SubMapping.cpp.
void LinearProgramming ( ) [private]
virtual const moab::EntityType* mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 92 of file SubMapping.hpp.
void MeshSmoothing ( ModelEnt *  ent) [private]
Definition at line 1378 of file SubMapping.cpp.
static const char* name ( ) [inline, static]
Get class name.
Definition at line 65 of file SubMapping.hpp.
const moab::EntityType * output_types ( ) [static]
Returns:
Definition at line 30 of file SubMapping.cpp.
void setup_this ( ) [virtual]
Definition at line 50 of file SubMapping.cpp.
void SetupMeshSize ( double  size = 1.0)
Definition at line 147 of file SubMapping.cpp.
void VerEdgOrganize ( std::set< iBase_EntityHandle >  edge_set,
) [private]
Definition at line 516 of file SubMapping.cpp.
void VertexClassification ( ModelEnt *  ent) [private]
Definition at line 158 of file SubMapping.cpp.
void VtxClassificationLP ( ) [private]
Definition at line 273 of file SubMapping.cpp.
Member Data Documentation
vector<vector<int> > coordinate_i_j [private]
Definition at line 148 of file SubMapping.hpp.
vector<int> edge_size [private]
Definition at line 154 of file SubMapping.hpp.
vector<Edge> edges [private]
Definition at line 140 of file SubMapping.hpp.
vector<EdgeTypes> edges_types [private]
Definition at line 144 of file SubMapping.hpp.
iBase_TagHandle g_taghandle [private]
Definition at line 146 of file SubMapping.hpp.
map<int, int> geom_mesh_node [private]
Definition at line 155 of file SubMapping.hpp.
vector<double> interior_angle [private]
Definition at line 142 of file SubMapping.hpp.
iBase_TagHandle m_taghandle [private]
map<int, int> mesh_geom_vertex [private]
Definition at line 156 of file SubMapping.hpp.
vector<Vertex> nodes [private]
Definition at line 139 of file SubMapping.hpp.
vector<Face> quads [private]
Definition at line 158 of file SubMapping.hpp.
double size_low_bound [private]
Definition at line 150 of file SubMapping.hpp.
vector<int> sorted_edge_list [private]
Definition at line 143 of file SubMapping.hpp.
vector<int> sorted_node_list [private]
vector<int> sorted_vertex_list [private]
unsigned int start_index [private]
Definition at line 152 of file SubMapping.hpp.
vector<Vertex> vertices [private]
vector<VertexTypes> vertices_types [private]
Definition at line 138 of file SubMapping.hpp.
