MeshKit
1.0
00001 #include "meshkit/SubMapping.hpp" 00002 #include "meshkit/MKCore.hpp" 00003 #include "meshkit/iMesh.hpp" 00004 #include "meshkit/RegisterMeshOp.hpp" 00005 #include "meshkit/EdgeMesher.hpp" 00006 #include "meshkit/VertexMesher.hpp" 00007 #include "meshkit/TFIMapping.hpp" 00008 #include "meshkit/SimpleArray.hpp" 00009 #include "lp_lib.h" 00010 #include "meshkit/MeshImprove.hpp" 00011 #include "LPSolveClass.hpp" 00012 #include "IsoLaplace.hpp" 00013 #include "EquipotentialSmooth.hpp" 00014 #ifdef HAVE_MESQUITE 00015 #include "meshkit/MeshImprove.hpp" 00016 #endif 00017 #include <iostream> 00018 #include <algorithm> 00019 #include <math.h> 00020 #include <map> 00021 00022 00023 00024 namespace MeshKit 00025 { 00026 00027 //---------------------------------------------------------------------------// 00028 //Entity Type initilization for SubMapping meshing 00029 moab::EntityType SubMapping_tps[] = {moab::MBVERTEX, moab::MBEDGE, moab::MBQUAD, moab::MBMAXTYPE}; 00030 const moab::EntityType* SubMapping::output_types() 00031 { return SubMapping_tps; } 00032 00033 //---------------------------------------------------------------------------// 00034 // construction function for SubMapping class 00035 SubMapping::SubMapping(MKCore *mk_core, const MEntVector &me_vec) : MeshScheme(mk_core, me_vec) 00036 { 00037 //buildAssociation(); 00038 } 00039 00040 00041 //---------------------------------------------------------------------------// 00042 // deconstruction function for SubMapping class 00043 SubMapping::~SubMapping() 00044 { 00045 00046 } 00047 00048 //---------------------------------------------------------------------------// 00049 // setup function: define the size between the different layers 00050 void SubMapping::setup_this() 00051 { 00052 if (mentSelection.empty()) 00053 return; 00054 //compute the number of intervals for the associated ModelEnts, from the size set on them 00055 //the sizing function they point to, or a default sizing function 00056 for (MEntSelection::iterator mit = mentSelection.begin(); mit != mentSelection.end(); mit++) 00057 { 00058 ModelEnt *me = mit -> first; 00059 int dimension = me->dimension(); 00060 if (dimension != 2) 00061 ECERRCHK(MK_FAILURE, "bad input for TFI Mapping, we can only mesh surfaces"); 00062 //first check whether the surface is meshed or not 00063 if (me->get_meshed_state() >= COMPLETE_MESH) 00064 continue; 00065 00066 00067 SizingFunction *sf = mk_core()->sizing_function(me->sizing_function_index()); 00068 if (!sf && me -> mesh_intervals() < 0 && me -> interval_firmness() == DEFAULT && 00069 mk_core()->sizing_function(0)) 00070 sf = mk_core()->sizing_function(0); 00071 00072 if (!sf && me -> mesh_intervals() < 0 && me -> interval_firmness() == DEFAULT){ 00073 //no sizing set, just assume default #intervals as 20 00074 me->mesh_intervals(20); 00075 me->interval_firmness(DEFAULT); 00076 } 00077 else{ 00078 //check # intervals first, then size, and just choose for now 00079 if (sf->intervals() > 0) 00080 throw Error(MK_INCOMPLETE_MESH_SPECIFICATION, "Sizing function for edge should have edge size instead of intervals for submapping."); 00081 else if (sf->size()>0){ 00082 size_low_bound = sf->size(); 00083 me->interval_firmness(SOFT); 00084 } 00085 else 00086 throw Error(MK_INCOMPLETE_MESH_SPECIFICATION, "Sizing function for edge had neither positive size nor positive intervals."); 00087 } 00088 } 00089 00090 00091 } 00092 00093 00094 //---------------------------------------------------------------------------// 00095 // execute function: generate the all-hex mesh through sweeping from source 00096 // surface to target surface 00097 void SubMapping::execute_this() 00098 { 00099 std::vector<double> coords; 00100 std::vector<moab::EntityHandle> nodes; 00101 00102 iBase_TagHandle global_tag, global_tag1; 00103 iGeom::Error g_err = mk_core()->igeom_instance()->getTagHandle("GLOBAL_ID", global_tag); 00104 IBERRCHK(g_err, "Trouble get the mesh entity set from geometric edges."); 00105 00106 iMesh::Error m_err = mk_core()->igeom_instance()->getTagHandle("GLOBAL_ID", global_tag1); 00107 IBERRCHK(m_err, "Trouble get the mesh entity set from geometric edges."); 00108 00109 for (MEntSelection::iterator mit = mentSelection.begin(); mit != mentSelection.end(); mit++) 00110 { 00111 ModelEnt *me = mit -> first; 00112 //first check whether the surface is meshed or not 00113 if (me->get_meshed_state() >= COMPLETE_MESH) 00114 continue; 00115 00116 //classify the vertex as END, CORNER, REVERSAL, SIDE 00117 VertexClassification(me); 00118 //classify the edge as +I, -I, +J and -J 00119 EdgeClassification(); 00120 //low bound for mesh size 00121 EdgeDiscretization(me); 00122 00123 InteriorNodeInterpolation(me); 00124 MeshSmoothing(me); 00125 00126 //ok, we are done! 00127 vertices_types.clear(); 00128 nodes.clear(); 00129 vertices.clear(); 00130 edges.clear(); 00131 interior_angle.clear(); 00132 sorted_vertex_list.clear(); 00133 sorted_node_list.clear(); 00134 sorted_edge_list.clear(); 00135 edges_types.clear(); 00136 coordinate_i_j.clear(); 00137 edge_size.clear(); 00138 quads.clear(); 00139 00140 me->commit_mesh(mit->second, COMPLETE_MESH); 00141 mk_core()->save_mesh("test_cai.vtk"); 00142 } 00143 00144 } 00145 00146 //setup the mesh size 00147 void SubMapping::SetupMeshSize(double size) 00148 { 00149 size_low_bound = size; 00150 } 00151 00152 00153 //classify the vertices as side, end, reversal and corner 00154 //end --an interior angle of approximately 90 degrees 00155 //side --an interior angle of approximately 180 degrees = 0 00156 //corner --an interior angle of approximately 270 degrees = -90 00157 //reversal --an interior angle of approximately 360 degrees = -180 00158 void SubMapping::VertexClassification(ModelEnt *ent) 00159 { 00160 //create a taghandle 00161 iGeom::Error g_err = mk_core()->igeom_instance()->getTagHandle("GEOM_SUBMAPPING", g_taghandle); 00162 if (g_err){ 00163 g_err = mk_core()->igeom_instance()->createTag("GEOM_SUBMAPPING", 1, iBase_INTEGER, g_taghandle); 00164 IBERRCHK(g_err, "Trouble create a taghandle."); 00165 } 00166 00167 //get the geometric vertices from the surface 00168 vertices.clear(); 00169 vector<iBase_EntityHandle> tmp; 00170 g_err = mk_core()->igeom_instance()->getEntAdj(ent->geom_handle(), iBase_VERTEX, tmp); 00171 IBERRCHK(g_err, "Trouble get the adjacent geometric vertices on a surface."); 00172 assert(tmp.size()>0); 00173 00174 vertices.resize(tmp.size()); 00175 for (unsigned int i = 0; i < tmp.size(); i++){ 00176 vertices[i].index = i; 00177 vertices[i].gVertexHandle = tmp[i]; 00178 00179 g_err = mk_core()->igeom_instance()->getVtxCoord(vertices[i].gVertexHandle, vertices[i].xyz[0], vertices[i].xyz[1], vertices[i].xyz[2]); 00180 IBERRCHK(g_err, "Trouble get the coordinates from vertices."); 00181 00182 g_err = mk_core()->igeom_instance()->setIntData(vertices[i].gVertexHandle, g_taghandle, i); 00183 IBERRCHK(g_err, "Trouble set the int data for the geometric vertex."); 00184 } 00185 00186 vertices_types.resize(vertices.size()); 00187 00188 //get the geometric edges 00189 edges.clear(); 00190 00191 tmp.clear(); 00192 g_err = mk_core()->igeom_instance()->getEntAdj(ent->geom_handle(), iBase_EDGE, tmp); 00193 IBERRCHK(g_err, "Trouble get the adjacent geometric vertices on a surface."); 00194 00195 std::set<iBase_EntityHandle> edge_set; 00196 edges.resize(tmp.size()); 00197 for (unsigned int i = 0; i < tmp.size(); i++){ 00198 edges[i].connect.resize(2); 00199 edges[i].index = i; 00200 edges[i].gEdgeHandle = tmp[i]; 00201 edge_set.insert(tmp[i]); 00202 00203 g_err = mk_core()->igeom_instance()->setIntData(edges[i].gEdgeHandle, g_taghandle, i); 00204 IBERRCHK(g_err, "Trouble set the int data for the geometric edge."); 00205 00206 vector<iBase_EntityHandle> adj_vertices; 00207 g_err = mk_core()->igeom_instance()->getEntAdj(edges[i].gEdgeHandle, iBase_VERTEX, adj_vertices); 00208 IBERRCHK(g_err, "Trouble get the adjacent vertices for the geometric edge."); 00209 00210 assert(adj_vertices.size()<=2); 00211 for (unsigned int j = 0; j < adj_vertices.size(); j++){ 00212 int index = -1; 00213 g_err = mk_core()->igeom_instance()->getIntData(adj_vertices[j], g_taghandle, index); 00214 IBERRCHK(g_err, "Trouble get the int data of geometric vertex."); 00215 00216 edges[i].connect[j] = &vertices[index]; 00217 } 00218 } 00219 00220 //organize the vertices and edges on the boundaries 00221 VerEdgOrganize(edge_set, tmp, ent->geom_handle()); 00222 00223 //calculate the angle for vertices on the boundaries 00224 interior_angle.resize(vertices.size()); 00225 GetAngle(ent->geom_handle(), interior_angle); 00226 00227 //initial vertex classification, 00228 //need to use the linear programming method to produce the valid vertex classification 00229 //if the initial vertex classification is not a valid vertex classification 00230 vertices_types.resize(vertices.size()); 00231 for (unsigned int i = 0; i < interior_angle.size(); i++){ 00232 if ((interior_angle[i] >= 45)&&(interior_angle[i] <= 130)){ 00233 vertices_types[i] = END; 00234 } 00235 else if ((interior_angle[i] < 225)&&(interior_angle[i] > 130)){ 00236 vertices_types[i] = SIDE; 00237 } 00238 else if ((interior_angle[i] > 225)&&(interior_angle[i] < 315)){ 00239 vertices_types[i] = CORNER; 00240 } 00241 else{ 00242 vertices_types[i] = REVERSAL; 00243 } 00244 } 00245 00246 //extra step 00247 for (unsigned int m = 0; m < vertices_types.size(); m++){ 00248 00249 if (vertices_types[m] == REVERSAL) 00250 vertices_types[m] = SIDE; 00251 } 00252 00253 00254 00255 00256 int sum = 0; 00257 for (std::vector<VertexTypes>::iterator it = vertices_types.begin(); it != vertices_types.end(); it++) 00258 sum += *it; 00259 00260 std::cout << "\n\n\nbefore, sum of vertex type is " << sum << std::endl; 00261 00262 if (sum != 4){//check whether the initial vertex classification is valid or not 00263 //use the linear programming to produce a valid vertex classification 00264 00265 VtxClassificationLP(); 00266 } 00267 00268 00269 std::cout << "\n\n\nsum = " << sum << std::endl; 00270 } 00271 00272 //use the lpsolve library to solve the linear programming 00273 void SubMapping::VtxClassificationLP() 00274 { 00275 LPSolveClass lp; 00276 vector<int> VtxType1(vertices_types.size()), VtxType2; 00277 int m = 0; 00278 for (std::vector<VertexTypes>::iterator it = vertices_types.begin(); it != vertices_types.end(); it++){ 00279 00280 if (*it == REVERSAL) 00281 vertices_types[m] = SIDE; 00282 00283 VtxType1[m] = int(vertices_types[m]); 00284 m++; 00285 } 00286 00287 //setup the objective function: minimize the max value, first half variables are new variables, the latter half variables are old variables 00288 vector<double> b(2*vertices_types.size()); 00289 for (unsigned int i = 0; i < vertices_types.size(); i++){ 00290 b[i] = 1.0; 00291 b[vertices_types.size()+i] = 0.0; 00292 } 00293 lp.SetupObj(b, 0.0); 00294 00295 //setup the equality constraint 00296 vector<vector<double> > left; 00297 vector<double> right; 00298 right.push_back(4.0); 00299 left.resize(1); 00300 left[0].resize(2*vertices_types.size()); 00301 for (unsigned int i = 0; i < vertices_types.size(); i++){ 00302 left[0][i] = 0.0; 00303 left[0][vertices_types.size()+i] = 1.0; 00304 } 00305 /* 00306 for (unsigned int i = 0; i < vertices_types.size(); i++){ 00307 right.push_back(0.0); 00308 left[i+1].resize(2*vertices_types.size()); 00309 for (unsigned int j = 0; j < vertices_types.size(); j++){ 00310 left[i+1][j] = 0.0; 00311 left[i+1][vertices_types.size()+j] = 0.0; 00312 if ((i==j)&&(vertices_types[i]==END)){//fix the END vertex type 00313 left[i+1][vertices_types.size()+j] = 1.0; 00314 right[i+1] = 1.0; 00315 } 00316 } 00317 } 00318 */ 00319 lp.SetupEqu(left, right); 00320 00321 //setup the inequality constraint 00322 left.clear(); 00323 right.clear(); 00324 left.resize(6*vertices_types.size()); 00325 right.resize(6*vertices_types.size()); 00326 for (unsigned int i = 0; i < vertices_types.size(); i++){ 00327 right[i] = VtxType1[i]; 00328 right[vertices_types.size()+i] = VtxType1[i]; 00329 right[2*vertices_types.size()+i] = 1; 00330 right[3*vertices_types.size()+i] = 2; 00331 right[4*vertices_types.size()+i] = 1+VtxType1[i]; 00332 right[5*vertices_types.size()+i] = 1-VtxType1[i]; 00333 } 00334 for (unsigned int i = 0; i < vertices_types.size(); i++){ 00335 left[i].resize(2*vertices_types.size()); 00336 left[vertices_types.size()+i].resize(2*vertices_types.size()); 00337 for (unsigned int j= 0; j < vertices_types.size(); j++){ 00338 left[i][j] = -1.0; 00339 left[i][vertices_types.size()+j] = 1.0; 00340 left[vertices_types.size()+i][j] = -1.0; 00341 left[vertices_types.size()+i][vertices_types.size()+j] = -1.0; 00342 } 00343 //constrain the variable range 00344 left[2*vertices_types.size()+i].resize(2*vertices_types.size()); 00345 left[3*vertices_types.size()+i].resize(2*vertices_types.size()); 00346 left[4*vertices_types.size()+i].resize(2*vertices_types.size()); 00347 left[5*vertices_types.size()+i].resize(2*vertices_types.size()); 00348 for (unsigned int j = 0; j < 2*vertices_types.size(); j++){ 00349 left[2*vertices_types.size()+i][j] = 0.0; 00350 left[3*vertices_types.size()+i][j] = 0.0; 00351 left[4*vertices_types.size()+i][j] = 0.0; 00352 left[5*vertices_types.size()+i][j] = 0.0; 00353 } 00354 left[2*vertices_types.size()+i][vertices_types.size()+i] = 1.0; 00355 left[3*vertices_types.size()+i][vertices_types.size()+i] = -1.0; 00356 00357 //constrain the difference between new vertex type and initial vertex type 00358 left[4*vertices_types.size()+i][vertices_types.size()+i] = 1.0; 00359 left[5*vertices_types.size()+i][vertices_types.size()+i] = -1.0; 00360 00361 } 00362 lp.SetupInEqu(left, right); 00363 00364 lp.Execute(); 00365 //get the solved variables 00366 vector<int> vtx_types; 00367 lp.GetVariables(vtx_types); 00368 for (unsigned int i = 0; i < vertices_types.size(); i++){ 00369 switch(vtx_types[vertices_types.size()+i]){ 00370 case 1: 00371 vertices_types[i] = END; 00372 break; 00373 case 0: 00374 vertices_types[i] = SIDE; 00375 break; 00376 case -1: 00377 vertices_types[i] = CORNER; 00378 break; 00379 case -2: 00380 vertices_types[i] = REVERSAL; 00381 break; 00382 default: 00383 break; 00384 } 00385 } 00386 00387 //check whether sum = 4; 00388 int sum = 0; 00389 for (std::vector<VertexTypes>::iterator it = vertices_types.begin(); it != vertices_types.end(); it++) 00390 sum += *it; 00391 assert(sum == 4); 00392 } 00393 00394 //calculate the angle for vertices on the boundaries 00395 void SubMapping::GetAngle(iBase_EntityHandle surf, vector<double> &angle) 00396 { 00397 angle.resize(sorted_vertex_list.size()); 00398 for (unsigned int i = 0; i < sorted_vertex_list.size(); i++){ 00399 //vertices = i, previous edge = (i+sorted_edge_list.size()-1)%sorted_edge_list.size(), next edge = (i+sorted_edge_list.size()+1)%sorted_edge_list.size() 00400 00401 //calculate the tangent vector at the previous edge 00402 double tangvector_p[3]; 00403 int previous = (i+sorted_edge_list.size()-1)%sorted_edge_list.size(); 00404 //calculate the tangent vector and edge sense with respect to two vertices 00405 iGeom::Error g_err = mk_core()->igeom_instance()->getEntTgntXYZ(edges[sorted_edge_list[previous]].gEdgeHandle, vertices[sorted_vertex_list[i]].xyz[0], vertices[sorted_vertex_list[i]].xyz[1], vertices[sorted_vertex_list[i]].xyz[2], tangvector_p[0], tangvector_p[1], tangvector_p[2]); 00406 IBERRCHK(g_err, "Trouble get the tangent vector at a vertex of an edge."); 00407 00408 int sense = -10; 00409 g_err = mk_core()->igeom_instance()->getEgVtxSense(edges[sorted_edge_list[previous]].gEdgeHandle, vertices[sorted_vertex_list[i]].gVertexHandle, vertices[sorted_vertex_list[(i+vertices.size()-1)%vertices.size()]].gVertexHandle, sense); 00410 IBERRCHK(g_err, "Trouble get edge sense with respect to two vertices."); 00411 00412 int pre_edge_sense_face = -10; 00413 g_err = mk_core()->igeom_instance()->getEgFcSense(edges[sorted_edge_list[previous]].gEdgeHandle, surf, pre_edge_sense_face); 00414 IBERRCHK(g_err, "Trouble get edge sense with respect to the face."); 00415 std::cout << "-------------------\nvertex index = " << i << "\tprevious edge sense with respect to face = " << pre_edge_sense_face << std::endl; 00416 00417 if (sense < 0){ 00418 tangvector_p[0] = -1.0*tangvector_p[0]; 00419 tangvector_p[1] = -1.0*tangvector_p[1]; 00420 tangvector_p[2] = -1.0*tangvector_p[2]; 00421 } 00422 00423 //calculate the tangent vector at next edge 00424 double tangvector_n[3]; 00425 int next = (i+sorted_edge_list.size())%sorted_edge_list.size(); 00426 g_err = mk_core()->igeom_instance()->getEntTgntXYZ(edges[sorted_edge_list[next]].gEdgeHandle, vertices[sorted_vertex_list[i]].xyz[0], vertices[sorted_vertex_list[i]].xyz[1], vertices[sorted_vertex_list[i]].xyz[2], tangvector_n[0], tangvector_n[1], tangvector_n[2]); 00427 IBERRCHK(g_err, "Trouble get the tangent vector at a vertex of an edge."); 00428 g_err = mk_core()->igeom_instance()->getEgVtxSense(edges[sorted_edge_list[next]].gEdgeHandle, vertices[sorted_vertex_list[i]].gVertexHandle, vertices[sorted_vertex_list[(i+1)%vertices.size()]].gVertexHandle, sense); 00429 IBERRCHK(g_err, "Trouble get edge sense with respect to two vertices."); 00430 00431 int next_edge_sense_face = -10; 00432 g_err = mk_core()->igeom_instance()->getEgFcSense(edges[sorted_edge_list[next]].gEdgeHandle, surf, next_edge_sense_face); 00433 IBERRCHK(g_err, "Trouble get edge sense with respect to the face."); 00434 std::cout << "\t" << i << "\tnext edge sense with respect to face = " << next_edge_sense_face << std::endl; 00435 00436 if (sense < 0){ 00437 tangvector_n[0] = -1.0*tangvector_n[0]; 00438 tangvector_n[1] = -1.0*tangvector_n[1]; 00439 tangvector_n[2] = -1.0*tangvector_n[2]; 00440 } 00441 00442 00443 //calculate the crossproduct 00444 double crossproduct[3]; 00445 crossproduct[0] = tangvector_n[1]*tangvector_p[2]-tangvector_n[2]*tangvector_p[1]; 00446 crossproduct[1] = tangvector_n[2]*tangvector_p[0]-tangvector_n[0]*tangvector_p[2]; 00447 crossproduct[2] = tangvector_n[0]*tangvector_p[1]-tangvector_n[1]*tangvector_p[0]; 00448 00449 //calculate the dotproduct 00450 double dotproduct = tangvector_n[0]*tangvector_p[0] + tangvector_n[1]*tangvector_p[1] + tangvector_n[2]*tangvector_p[2]; 00451 double theta_pi = acos(dotproduct/(sqrt(pow(tangvector_n[0],2)+pow(tangvector_n[1], 2)+pow(tangvector_n[2], 2))*sqrt(pow(tangvector_p[0],2)+pow(tangvector_p[1],2)+pow(tangvector_p[2],2)))); 00452 double theta = theta_pi*180.0/3.1415926; 00453 00454 //get the surface norm at a specific point 00455 double normal[3]; 00456 g_err = mk_core()->igeom_instance()->getEntNrmlXYZ(surf, vertices[sorted_vertex_list[i]].xyz[0], vertices[sorted_vertex_list[i]].xyz[1], vertices[sorted_vertex_list[i]].xyz[2], normal[0], normal[1], normal[2]); 00457 IBERRCHK(g_err, "Trouble get the normal at a specific point on the surface."); 00458 dotproduct = crossproduct[0]*normal[0]+crossproduct[1]*normal[1]+crossproduct[2]*normal[2]; 00459 00460 if (dotproduct < 0) 00461 theta = 360.0 - theta; 00462 00463 angle[sorted_vertex_list[i]] = theta; 00464 } 00465 00466 } 00467 00468 bool SubMapping::isCurved(int vtx_index, vector<double> u1, vector<double> u2, vector<double> u3, vector<double> u4, vector<vector<double> > tang_pre, vector<vector<double> > tang_next) 00469 { 00470 int previous = (vtx_index+sorted_edge_list.size()-1)%sorted_edge_list.size(), next = (vtx_index+sorted_edge_list.size())%sorted_edge_list.size(); 00471 double dotproduct, vec[3], theta1, theta2, pts2[3], pts1[3], u, length; 00472 u = u1[vtx_index] + 0.5*(u2[vtx_index]-u1[vtx_index]); 00473 iGeom::Error g_err = mk_core()->igeom_instance()->getEntUtoXYZ(edges[sorted_edge_list[previous]].gEdgeHandle, u, pts1[0], pts1[1], pts1[2]); 00474 IBERRCHK(g_err, "Trouble get xyz coordinates from parametric coordinates on edge."); 00475 u = u1[vtx_index] + 0.501*(u2[vtx_index]-u1[vtx_index]); 00476 g_err = mk_core()->igeom_instance()->getEntUtoXYZ(edges[sorted_edge_list[previous]].gEdgeHandle, u, pts2[0], pts2[1], pts2[2]); 00477 IBERRCHK(g_err, "Trouble get xyz coordinates from parametric coordinates on edge."); 00478 for (int j = 0; j < 3; j++) 00479 vec[j] = pts2[j] - pts1[j]; 00480 dotproduct = vec[0]*tang_pre[vtx_index][0] + vec[1]*tang_pre[vtx_index][1] + vec[2]*tang_pre[vtx_index][2]; 00481 length = sqrt(pow(vec[0],2)+pow(vec[1], 2)+pow(vec[2], 2))*sqrt(pow(tang_pre[vtx_index][0],2)+pow(tang_pre[vtx_index][1],2)+pow(tang_pre[vtx_index][2],2)); 00482 if (fabs(dotproduct) > length){ 00483 if (dotproduct > 0) 00484 dotproduct = length; 00485 else 00486 dotproduct = -1.0*length; 00487 } 00488 theta1 = 180.0/3.1415926*acos(dotproduct/length); 00489 u = u3[vtx_index] + 0.5*(u4[vtx_index]-u3[vtx_index]); 00490 g_err = mk_core()->igeom_instance()->getEntUtoXYZ(edges[sorted_edge_list[next]].gEdgeHandle, u, pts1[0], pts1[1], pts1[2]); 00491 IBERRCHK(g_err, "Trouble get xyz coordinates from parametric coordinates on edge."); 00492 u = u3[vtx_index] + 0.501*(u4[vtx_index]-u3[vtx_index]); 00493 g_err = mk_core()->igeom_instance()->getEntUtoXYZ(edges[sorted_edge_list[next]].gEdgeHandle, u, pts2[0], pts2[1], pts2[2]); 00494 IBERRCHK(g_err, "Trouble get xyz coordinates from parametric coordinates on edge."); 00495 for (int j = 0; j < 3; j++) 00496 vec[j] = pts2[j] - pts1[j]; 00497 dotproduct = vec[0]*tang_next[vtx_index][0] + vec[1]*tang_next[vtx_index][1] + vec[2]*tang_next[vtx_index][2]; 00498 length = sqrt(pow(vec[0],2)+pow(vec[1], 2)+pow(vec[2], 2))*sqrt(pow(tang_next[vtx_index][0],2)+pow(tang_next[vtx_index][1],2)+pow(tang_next[vtx_index][2],2)); 00499 if (fabs(dotproduct) > length){ 00500 if (dotproduct > 0) 00501 dotproduct = length; 00502 else 00503 dotproduct = -1.0*length; 00504 } 00505 theta2 = 180.0/3.1415926*acos(dotproduct/length); 00506 00507 if ((fabs(theta1) > 0.5)&&(fabs(theta2) > 0.5)) 00508 return true; 00509 else 00510 return false; 00511 00512 } 00513 00514 00515 //reorganize the vertices and edges on the boudnaries of geometry 00516 void SubMapping::VerEdgOrganize(std::set<iBase_EntityHandle> edge_set, std::vector<iBase_EntityHandle> g_edge, iBase_EntityHandle surf) 00517 { 00518 int first_edge_index = 0; 00519 int first_index = edges[0].connect[1]->index; 00520 int second_index = edges[0].connect[0]->index; 00521 int start_index = edges[0].connect[0]->index; 00522 00523 int test_sense = -10; 00524 iGeom::Error g_err = mk_core()->igeom_instance()->getEgVtxSense(edges[first_edge_index].gEdgeHandle, vertices[second_index].gVertexHandle, vertices[first_index].gVertexHandle, test_sense); 00525 IBERRCHK(g_err, "Trouble get the sense of edge with respect to two vertices."); 00526 00527 int test_face_sense = -10; 00528 g_err = mk_core()->igeom_instance()->getEgFcSense(edges[first_edge_index].gEdgeHandle, surf, test_face_sense); 00529 IBERRCHK(g_err, "Trouble get the sense of edge with respect to two vertices."); 00530 std::cout << "edge sense = " << test_sense << "\tface sense = " << test_face_sense << "combined(multiply) = " << test_sense*test_face_sense << std::endl; 00531 00532 if ((test_sense*test_face_sense) < 0){ 00533 int tmp = second_index; 00534 second_index = first_index; 00535 first_index = tmp; 00536 start_index = second_index; 00537 } 00538 00539 00540 sorted_vertex_list.push_back(start_index); 00541 00542 sorted_edge_list.push_back(first_edge_index); 00543 00544 while(start_index != first_index){ 00545 sorted_vertex_list.push_back(first_index); 00546 00547 vector<iBase_EntityHandle> adj_edges; 00548 g_err = mk_core()->igeom_instance()->getEntAdj(vertices[first_index].gVertexHandle, iBase_EDGE, adj_edges); 00549 IBERRCHK(g_err, "Trouble get the adjacent edges w.r.t a vertex."); 00550 00551 int index = -1; 00552 for (unsigned int i = 0; i < adj_edges.size(); i++){ 00553 if ((adj_edges[i] != edges[first_edge_index].gEdgeHandle)&&(edge_set.find(adj_edges[i]) != edge_set.end())){ 00554 g_err = mk_core()->igeom_instance()->getIntData(adj_edges[i], g_taghandle, index); 00555 IBERRCHK(g_err, "Trouble get the int data for geometric edge."); 00556 break; 00557 } 00558 else 00559 continue; 00560 } 00561 00562 //insert the new edge into sorted_edge_list 00563 if (index > -1){ 00564 00565 first_edge_index = index; 00566 sorted_edge_list.push_back(first_edge_index); 00567 second_index = first_index; 00568 if (edges[first_edge_index].connect[0]->index == first_index) 00569 first_index = edges[first_edge_index].connect[1]->index; 00570 else 00571 first_index = edges[first_edge_index].connect[0]->index; 00572 00573 } 00574 else 00575 break; 00576 } 00577 } 00578 00579 00580 //classify the boundary edges as -I, +I, -J, +J 00581 void SubMapping::EdgeClassification() 00582 { 00583 edges_types.resize(sorted_edge_list.size()); 00584 00585 //Find a starting END vertex 00586 start_index = 0; 00587 for (; start_index < sorted_vertex_list.size(); start_index++) 00588 if (vertices_types[sorted_vertex_list[start_index]]==END) 00589 break; 00590 00591 //setting up the initial direction for i-j coordinate system(positive i and positive j direction) 00592 int pre_edge = (start_index + sorted_edge_list.size() -1)%sorted_edge_list.size(), next_edge = start_index; 00593 00594 edges_types[sorted_edge_list[next_edge]] = POSI_J; 00595 edges_types[sorted_edge_list[pre_edge]] = NEG_I; 00596 EdgeTypes i_direction = NEG_I, j_direction = POSI_J; 00597 VertexTypes pre_vertex_type = END; 00598 00599 int vertex_index = start_index; 00600 for (unsigned int i = 1; i < sorted_vertex_list.size()-1; i++){ 00601 pre_edge = (start_index + i + sorted_edge_list.size() -1)%sorted_edge_list.size(); //index in the sorted_edge_list 00602 next_edge = (start_index + i)%sorted_edge_list.size(); //index in the sorted_edge_list 00603 vertex_index = (i + start_index)%sorted_vertex_list.size(); 00604 00605 switch(vertices_types[sorted_vertex_list[vertex_index]]){ 00606 case END://switch from i to j or from j to i 00607 if ((edges_types[sorted_edge_list[pre_edge]] == POSI_I)||(edges_types[sorted_edge_list[pre_edge]] == NEG_I)){ 00608 if (j_direction == POSI_J) 00609 if (pre_vertex_type == END) 00610 edges_types[sorted_edge_list[next_edge]] = NEG_J; 00611 else 00612 edges_types[sorted_edge_list[next_edge]] = POSI_J; 00613 else 00614 if (pre_vertex_type == END) 00615 edges_types[sorted_edge_list[next_edge]] = POSI_J; 00616 else 00617 edges_types[sorted_edge_list[next_edge]] = NEG_J; 00618 j_direction = edges_types[sorted_edge_list[next_edge]]; 00619 } 00620 else{//switch from j-direction to i-direction 00621 if (i_direction == POSI_I) 00622 if (pre_vertex_type == END) 00623 edges_types[sorted_edge_list[next_edge]] = NEG_I; 00624 else 00625 edges_types[sorted_edge_list[next_edge]] = POSI_I; 00626 else 00627 if (pre_vertex_type == END) 00628 edges_types[sorted_edge_list[next_edge]] = POSI_I; 00629 else 00630 edges_types[sorted_edge_list[next_edge]] = NEG_I; 00631 i_direction = edges_types[sorted_edge_list[next_edge]]; 00632 } 00633 pre_vertex_type = END; 00634 break; 00635 case SIDE://keep the same as previous 00636 edges_types[sorted_edge_list[next_edge]] = edges_types[sorted_edge_list[pre_edge]]; 00637 break; 00638 00639 case CORNER://switch from i to j or from j to i 00640 if ((edges_types[sorted_edge_list[pre_edge]] == POSI_I)||(edges_types[sorted_edge_list[pre_edge]] == NEG_I)){ 00641 if (j_direction == POSI_J) 00642 if (pre_vertex_type == END) 00643 edges_types[sorted_edge_list[next_edge]] = POSI_J; 00644 else 00645 edges_types[sorted_edge_list[next_edge]] = NEG_J; 00646 else 00647 if (pre_vertex_type == END) 00648 edges_types[sorted_edge_list[next_edge]] = NEG_J; 00649 else 00650 edges_types[sorted_edge_list[next_edge]] = POSI_J; 00651 j_direction = edges_types[sorted_edge_list[next_edge]]; 00652 } 00653 else{ 00654 if (i_direction == POSI_I) 00655 if (pre_vertex_type == END) 00656 edges_types[sorted_edge_list[next_edge]] = POSI_I; 00657 else 00658 edges_types[sorted_edge_list[next_edge]] = NEG_I; 00659 else 00660 if (pre_vertex_type == END) 00661 edges_types[sorted_edge_list[next_edge]] = NEG_I; 00662 else 00663 edges_types[sorted_edge_list[next_edge]] = POSI_I; 00664 i_direction = edges_types[sorted_edge_list[next_edge]]; 00665 } 00666 pre_vertex_type = CORNER; 00667 break; 00668 00669 case REVERSAL://need to consider this point later on 00670 if (edges_types[sorted_edge_list[pre_edge]] == POSI_I) 00671 edges_types[sorted_edge_list[next_edge]] = NEG_I; 00672 else if (edges_types[sorted_edge_list[pre_edge]] == NEG_I) 00673 edges_types[sorted_edge_list[next_edge]] = POSI_I; 00674 else if (edges_types[sorted_edge_list[pre_edge]] == POSI_J) 00675 edges_types[sorted_edge_list[next_edge]] = NEG_J; 00676 else 00677 edges_types[sorted_edge_list[next_edge]] = POSI_J; 00678 break; 00679 00680 default://do nothing 00681 break; 00682 } 00683 } 00684 } 00685 00686 //assign the i,j coordinates for each node on the boundary 00687 void SubMapping::EdgeDiscretization(ModelEnt *me) 00688 { 00689 edge_size.resize(sorted_edge_list.size()); 00690 for (unsigned int i = 0; i < sorted_edge_list.size(); i++){ 00691 double measure; 00692 iGeom::Error g_err = mk_core()->igeom_instance()->measure(&(edges[sorted_edge_list[i]].gEdgeHandle), 1, &measure); 00693 IBERRCHK(g_err, "Trouble measure the boundary edges."); 00694 edge_size[sorted_edge_list[i]] = int(measure/size_low_bound); 00695 } 00696 00697 //linear programming to get # of line segments for each boundary edge 00698 LPSolveClass lp; 00699 //setup the model for linear programming 00700 vector<vector<double> > coeffs; 00701 vector<double> b(edges.size(), 1.0); 00702 00703 //setup the objective function for linear programming 00704 lp.SetupObj(b, 0.0); 00705 00706 //setup the equality constraint for linear programming 00707 coeffs.resize(2); 00708 coeffs[0].resize(edges.size()); 00709 coeffs[1].resize(edges.size()); 00710 b.clear(); 00711 b.resize(2, 0.0); 00712 for (unsigned int i = 0; i < edges.size(); i++){ 00713 if ((edges_types[i] == POSI_I)||(edges_types[i] == NEG_I)){//positive i and negative i 00714 if (edges_types[i] == POSI_I) 00715 coeffs[0][i] = 1.0; 00716 else if (edges_types[i] == NEG_I) 00717 coeffs[0][i] = -1.0; 00718 coeffs[1][i] = 0.0; 00719 } 00720 else{//positive j and negative j 00721 if (edges_types[i] == POSI_J) 00722 coeffs[1][i] = 1.0; 00723 else if (edges_types[i] == NEG_J) 00724 coeffs[1][i] = -1.0; 00725 coeffs[0][i] = 0.0; 00726 } 00727 } 00728 lp.SetupEqu(coeffs, b); 00729 00730 //setup the constant constraint there is already mesh on the geometric edge 00731 vector<int> num_line_segments(edges.size()); 00732 for (unsigned int i = 0; i < edges.size(); i++){ 00733 iBase_EntitySetHandle entityset; 00734 iRel::Error r_err = mk_core()->irel_pair()->getEntSetRelation(edges[i].gEdgeHandle, 0, entityset); 00735 IBERRCHK(r_err, "Trouble get the entity set for geometric edge."); 00736 iMesh::Error m_err = mk_core()->imesh_instance()->getNumOfType(entityset, iBase_EDGE, num_line_segments[i]); 00737 IBERRCHK(m_err, "Trouble get # of line segments on the edge mesh."); 00738 00739 if ((num_line_segments[i] < 1)&&(!m_err)) 00740 num_line_segments[i] = -1; 00741 } 00742 lp.SetupConst(num_line_segments); 00743 00744 //setup the inequality constraint for linear programming 00745 coeffs.clear(); 00746 coeffs.resize(edges.size(), vector<double>(edges.size())); 00747 for (unsigned int i = 0; i < edges.size(); i++)//diagonal matrix 00748 coeffs[i][i] = -1.0; 00749 b.clear(); 00750 b.resize(edges.size()); 00751 int min_line_segment = 1.0e10; 00752 for (unsigned int i = 0; i < num_line_segments.size(); i++) 00753 if ((num_line_segments[i] < min_line_segment)&&(num_line_segments[i]>0)) 00754 min_line_segment = num_line_segments[i]; 00755 00756 //preprocess the inequality constraints 00757 int sum_posi_I = 0, sum_neg_I = 0, sum_posi_J = 0, sum_neg_J = 0; 00758 vector<int> posi_i, neg_i, posi_j, neg_j; 00759 for (int i = 0; i < num_line_segments.size(); i++){ 00760 if (num_line_segments[i] > 0){ 00761 switch(edges_types[i]){ 00762 case POSI_I: 00763 sum_posi_I += num_line_segments[i]; break; 00764 case NEG_I: 00765 sum_neg_I += num_line_segments[i]; break; 00766 case POSI_J: 00767 sum_posi_J += num_line_segments[i]; break; 00768 case NEG_J: 00769 sum_neg_J += num_line_segments[i]; break; 00770 default: 00771 break; 00772 } 00773 } 00774 else{ 00775 switch(edges_types[i]){ 00776 case POSI_I: 00777 posi_i.push_back(i); break; 00778 case NEG_I: 00779 neg_i.push_back(i); break; 00780 case POSI_J: 00781 posi_j.push_back(i); break; 00782 case NEG_J: 00783 neg_j.push_back(i); break; 00784 default: 00785 break; 00786 } 00787 } 00788 } 00789 //preprocess the edge size 00790 int tmp_sum_POS_I = sum_posi_I, tmp_sum_POS_J = sum_posi_J, tmp_sum_NEG_I = sum_neg_I, tmp_sum_NEG_J = sum_neg_J; 00791 for (unsigned int i = 0; i < posi_i.size(); i++) 00792 tmp_sum_POS_I += edge_size[posi_i[i]]; 00793 for (unsigned int i = 0; i < posi_j.size(); i++) 00794 tmp_sum_POS_J += edge_size[posi_j[i]]; 00795 for (unsigned int i = 0; i < neg_i.size(); i++) 00796 tmp_sum_NEG_I += edge_size[neg_i[i]]; 00797 for (unsigned int i = 0; i < neg_j.size(); i++) 00798 tmp_sum_NEG_J += edge_size[neg_j[i]]; 00799 00800 //process i-direction ----new 00801 if (tmp_sum_POS_I == tmp_sum_NEG_I) 00802 {}//do nothing, it is always true 00803 else if (tmp_sum_POS_I > tmp_sum_NEG_I){//adjust the NEG_I 00804 if (neg_i.size() > 0){ 00805 for (unsigned int i = 0; i < neg_i.size(); i++) 00806 edge_size[neg_i[i]] = int(double(tmp_sum_POS_I-sum_neg_I)*double(edge_size[neg_i[i]])/double(tmp_sum_NEG_I-sum_neg_I)); 00807 } 00808 else{//neg_i.size == 0 00809 if (posi_i.size() == 0){ 00810 std::cout << "Constraint check fails in i-direction_a\n";exit(1); 00811 } 00812 else{ 00813 if (sum_posi_I >= tmp_sum_NEG_I){//here, tmp_sum_NEG_I = sum_neg_I 00814 std::cout << "Constraint check fails in i-direction_b\n";exit(1); 00815 } 00816 else{//sum_posi_I < tmp_sum_NEG_I, adjust the edge posi_i 00817 for (unsigned int i = 0; i < posi_i.size(); i++){ 00818 edge_size[posi_i[i]] = int(double(tmp_sum_NEG_I-sum_posi_I)*double(edge_size[posi_i[i]])/double(tmp_sum_POS_I-sum_posi_I)); 00819 } 00820 } 00821 } 00822 } 00823 } 00824 else{//tmp_sum_POS_I < tmp_sum_NEG_I, //adjust the POSS_I 00825 if (posi_i.size() > 0){ 00826 for (unsigned int i = 0; i < posi_i.size(); i++) 00827 edge_size[posi_i[i]] = int(double(tmp_sum_NEG_I-sum_posi_I)*double(edge_size[posi_i[i]])/double(tmp_sum_POS_I-sum_posi_I)); 00828 } 00829 else{//posi_i.size() == 0 00830 //further constraints, 00831 if (neg_i.size() == 0){ 00832 std::cout << "Constraint check fails in i-direction_c\n";exit(1); 00833 } 00834 else{ 00835 if (sum_neg_I >= tmp_sum_POS_I){//here tmp_sum_POS_I = sum_posi_I 00836 std::cout << "Constraint check fails in i-direction_d\n";exit(1); 00837 } 00838 else{//sum_neg_I < tmp_sum_POS_I, adjust the edge neg_i 00839 for (unsigned int i = 0; i < neg_i.size(); i++){ 00840 edge_size[neg_i[i]] = int(double(tmp_sum_POS_I-sum_neg_I)*double(edge_size[neg_i[i]])/double(tmp_sum_NEG_I-sum_neg_I)); 00841 } 00842 } 00843 } 00844 } 00845 } 00846 00847 00848 00849 //process j-direction ----new 00850 if (tmp_sum_POS_J == tmp_sum_NEG_J) 00851 {}//do nothing, it is always true 00852 else if (tmp_sum_POS_J > tmp_sum_NEG_J){//adjust the NEG_J 00853 if (neg_j.size() > 0){ 00854 for (unsigned int i = 0; i < neg_j.size(); i++) 00855 edge_size[neg_j[i]] = int(double(tmp_sum_POS_J-sum_neg_J)*double(edge_size[neg_j[i]])/double(tmp_sum_NEG_J-sum_neg_J)); 00856 } 00857 else{//neg_j.size == 0 00858 if (posi_j.size() == 0){ 00859 std::cout << "Constraint check fails in j-direction_a\n";exit(1); 00860 } 00861 else{ 00862 if (sum_posi_J >= tmp_sum_NEG_J){//here, tmp_sum_NEG_J = sum_neg_J 00863 std::cout << "Constraint check fails in j-direction_b\n";exit(1); 00864 } 00865 else{//sum_posi_J < tmp_sum_NEG_J, adjust the edge posi_j 00866 for (unsigned int i = 0; i < posi_j.size(); i++){ 00867 edge_size[posi_j[i]] = int(double(tmp_sum_NEG_J-sum_posi_J)*double(edge_size[posi_j[i]])/double(tmp_sum_POS_J-sum_posi_J)); 00868 } 00869 } 00870 } 00871 } 00872 } 00873 else{//tmp_sum_POS_J < tmp_sum_NEG_J, //adjust the POS_I 00874 if (posi_j.size() > 0){ 00875 for (unsigned int i = 0; i < posi_j.size(); i++) 00876 edge_size[posi_j[i]] = int(double(tmp_sum_NEG_J-sum_posi_J)*double(edge_size[posi_j[i]])/double(tmp_sum_POS_J-sum_posi_J)); 00877 } 00878 else{//posi_j.size() == 0 00879 //further constraints, 00880 if (neg_j.size() == 0){ 00881 std::cout << "Constraint check fails in j-direction_c\n";exit(1); 00882 } 00883 else{ 00884 if (sum_neg_J >= tmp_sum_POS_J){//here tmp_sum_POS_J = sum_posi_J 00885 std::cout << "Constraint check fails in j-direction_d\n";exit(1); 00886 } 00887 else{//sum_neg_J < tmp_sum_POS_J, adjust the edge neg_j 00888 for (unsigned int i = 0; i < neg_j.size(); i++){ 00889 edge_size[neg_j[i]] = int(double(tmp_sum_POS_J-sum_neg_J)*double(edge_size[neg_j[i]])/double(tmp_sum_NEG_J-sum_neg_J)); 00890 } 00891 } 00892 } 00893 } 00894 } 00895 00896 00897 00898 00899 00900 //process i-direction 00901 if ((sum_posi_I == sum_neg_I)&&(sum_posi_I != 0)){ 00902 if ((posi_i.size() != 0)&&(neg_i.size() != 0)) 00903 {}//these constraints should work 00904 else if ((posi_i.size() == 0)&&(neg_i.size() == 0)) 00905 {}//these constraints should work 00906 else if ((posi_i.size() != 0)&&(neg_i.size() == 0))//this constraints won't work 00907 {std::cout << "Constraint check fails in i-direction3\n";exit(1);} 00908 else//these constraints won't work 00909 {std::cout << "Constraint check fails in i-direction4\n";exit(1);} 00910 } 00911 else{ 00912 if (sum_posi_I > sum_neg_I){ 00913 if (sum_neg_I == 0){//low bound for NEG_I edges should be less than {sum_posi_I+edge_size[POSI_I]} 00914 //this work 00915 } 00916 else{//sum_neg_I > 0 00917 if ((int(posi_i.size()) == 0)&&(int(neg_i.size()) == 0))//these constraints won't work 00918 {std::cout << "Constraint check fails in i-direction5\n";exit(1);} 00919 else if ((int(posi_i.size()) == 0)&&(int(neg_i.size()) > 0)){//sum_neg_I + edge_size[NEG_I] <= sum_posi_I 00920 //this works 00921 } 00922 else if ((int(posi_i.size()) > 0)&&(int(neg_i.size()) == 0))//these constraints won't work 00923 {std::cout << "Constraint check fails in i-direction6\n";exit(1);} 00924 else{ //((int(posi_i.size()) > 0)&&(int(neg_i.size()) > 0)) 00925 //these constraints should work. 00926 } 00927 } 00928 } 00929 else{//sum_posi_I < sum_neg_I 00930 if (sum_posi_I == 0){//low bound for POSI_I edges should be less than {sum_neg_I+edge_size[NEG_I]} 00931 //this works 00932 } 00933 else{//sum_posi_I > 0 00934 if ((int(posi_i.size()) == 0)&&(int(neg_i.size()) == 0))//these constraints won't work 00935 {std::cout << "Constraint check fails in i-direction7\n";exit(1);} 00936 else if ((int(neg_i.size()) == 0)&&(int(posi_i.size()) > 0)){//sum_posi_I + edge_size[POSI_I] <= sum_neg_I 00937 //this works 00938 } 00939 else if ((int(neg_i.size()) > 0)&&(int(posi_i.size()) == 0))//these constraints won't work 00940 {std::cout << "Constraint check fails in i-direction8\n";exit(1);} 00941 else{ //((int(posi_i.size()) > 0)&&(int(neg_i.size()) > 0)) 00942 //these constraints should work. 00943 } 00944 } 00945 } 00946 } 00947 //process j direction 00948 if ((sum_posi_J == sum_neg_J)&&(sum_posi_J != 0)){ 00949 if ((posi_j.size() != 0)&&(neg_j.size() != 0))//these constraints should work 00950 {} 00951 else if ((posi_j.size() == 0)&&(neg_j.size() == 0)) 00952 {}//these constraints should work 00953 else if ((posi_j.size() != 0)&&(neg_j.size() == 0))//this constraints won't work 00954 {std::cout << "Constraint check fails in j-direction3\n";exit(1);} 00955 else//these constraints won't work 00956 {std::cout << "Constraint check fails in j-direction4\n";exit(1);} 00957 } 00958 else{//sum_posi_J != sum_neg_J 00959 if (sum_posi_J > sum_neg_J){ 00960 if (sum_neg_J == 0){//low bound for NEG_J edges should be less than {sum_posi_J+edge_size[POSI_J]} 00961 //this works 00962 } 00963 else{//sum_neg_J > 0 00964 if ((int(posi_j.size()) == 0)&&(int(neg_j.size()) == 0))//these constraints won't work 00965 {std::cout << "Constraint check fails in j-direction5\n";exit(1);} 00966 else if ((int(posi_j.size()) == 0)&&(int(neg_j.size()) > 0)){//sum_neg_J + edge_size[NEG_J] <= sum_posi_J 00967 //this works 00968 } 00969 else if ((int(posi_j.size()) > 0)&&(int(neg_j.size()) == 0))//these constraints won't work 00970 {std::cout << "Constraint check fails in j-direction6\n";exit(1);} 00971 else{ //((int(posi_j.size()) > 0)&&(int(neg_j.size()) > 0)) 00972 //these constraints should work. 00973 } 00974 } 00975 } 00976 else{//sum_posi_J < sum_neg_J 00977 if (sum_posi_J == 0){//low bound for POSI_J edges should be less than {sum_neg_J+edge_size[NEG_J]} 00978 //this works 00979 } 00980 else{//sum_posi_J > 0 00981 if ((int(posi_j.size()) == 0)&&(int(neg_j.size()) == 0))//these constraints won't work 00982 {std::cout << "Constraint check fails in j-direction7\n";exit(1);} 00983 else if ((int(neg_j.size()) == 0)&&(int(posi_j.size()) > 0)){//sum_posi_J + edge_size[POSI_J] <= sum_neg_J 00984 //this works 00985 } 00986 else if ((int(neg_j.size()) > 0)&&(int(posi_j.size()) == 0))//these constraints won't work 00987 {std::cout << "Constraint check fails in j-direction8\n";exit(1);} 00988 else{ //((int(posi_j.size()) > 0)&&(int(neg_j.size()) > 0)) 00989 //these constraints should work. 00990 } 00991 } 00992 } 00993 } 00994 00995 for (unsigned int i = 0; i < edges.size(); i++) 00996 if (min_line_segment < 1.0e9){ 00997 if ((num_line_segments[i] < edge_size[i])&&(num_line_segments[i] > 0)){//avoid the conflicts between const constraints and inequality constraints; 00998 b[i] = -1.0*num_line_segments[i]; 00999 } 01000 else{ 01001 //if (min_line_segment < edge_size[i]) 01002 // b[i] = -1.0*min_line_segment; 01003 //else 01004 b[i] = -1.0*edge_size[i]; 01005 } 01006 } 01007 else 01008 b[i] = -1.0*edge_size[i]; 01009 01010 lp.SetupInEqu(coeffs, b); 01011 01012 lp.Execute(); 01013 lp.GetVariables(edge_size); 01014 01015 //do the vertex mesher 01016 //get the mesh node on the geometric vertex 01017 for (unsigned int i = 0; i < sorted_vertex_list.size(); i++){ 01018 iBase_EntitySetHandle entityset; 01019 iRel::Error r_err = mk_core()->irel_pair()->getEntSetRelation(vertices[sorted_vertex_list[i]].gVertexHandle, 0, entityset); 01020 IBERRCHK(r_err, "Trouble get the entity set for edge from geometric vertex."); 01021 01022 vector<iBase_EntityHandle> points; 01023 points.clear(); 01024 iMesh::Error m_err = mk_core()->imesh_instance()->getEntities(entityset, iBase_VERTEX, iMesh_POINT, points); 01025 IBERRCHK(m_err, "Trouble get the node entities from mesh entity sets."); 01026 01027 if (points.size()==0){ 01028 points.resize(1); 01029 //there is no mesh nodes on the geometric vertices, it need to create a mesh node on the geometric vertex 01030 m_err = mk_core()->imesh_instance()->createVtx(vertices[sorted_vertex_list[i]].xyz[0], vertices[sorted_vertex_list[i]].xyz[1], vertices[sorted_vertex_list[i]].xyz[2], points[0]); 01031 IBERRCHK(m_err, "Trouble create the mesh nodes on the geometric vertex."); 01032 m_err = mk_core()->imesh_instance()->addEntToSet(points[0], entityset); 01033 IBERRCHK(m_err, "Trouble add the mesh node entity to entity set."); 01034 } 01035 } 01036 01037 //do the edge mesher 01038 MEntVector curves; 01039 me->get_adjacencies(1, curves); 01040 assert(curves.size()==edges.size()); 01041 01042 //call the edge mesher to discretize the boundary edges 01043 for (unsigned int i = 0; i < edges.size(); i++){ 01044 //initial size functon for edges, get the number of edges and assign it to the edge 01045 01046 //do the edge mesher 01047 SizingFunction esize(mk_core(), edge_size[i], -1); 01048 me->sizing_function_index(esize.core_index()); 01049 01050 //detect the edge on the surface 01051 MEntVector edge_curve; 01052 edge_curve.resize(1); 01053 01054 for (unsigned int j = 0; j < curves.size(); j++){ 01055 int index_id; 01056 iGeom::Error g_err = mk_core()->igeom_instance()->getIntData(curves[j]->geom_handle(), g_taghandle, index_id); 01057 IBERRCHK(g_err, "Trouble get the int data for geometric edges."); 01058 01059 if (index_id == (int)i){ 01060 edge_curve[0] = curves[j]; 01061 break; 01062 } 01063 } 01064 01065 //do the edge mesher 01066 EdgeMesher *em = (EdgeMesher*) mk_core()->construct_meshop("EdgeMesher", edge_curve); 01067 //mk_core()->setup_and_execute(); 01068 em->setup_this(); 01069 em->execute_this(); 01071 } 01072 01073 //extract the mesh info 01074 iMesh::Error m_err = mk_core()->imesh_instance()->getTagHandle("MeshSubMapping", m_taghandle); 01075 if (m_err){ 01076 m_err = mk_core()->imesh_instance()->createTag("MeshSubMapping", 1, iBase_INTEGER, m_taghandle); 01077 IBERRCHK(m_err, "Trouble create a taghandle."); 01078 } 01079 01080 int index = 0; 01081 for (unsigned int i = 0; i < sorted_vertex_list.size(); i++){ 01082 int next_edge = sorted_edge_list[i%sorted_edge_list.size()]; 01083 int pre_edge = sorted_edge_list[(i+sorted_edge_list.size()-1)%sorted_edge_list.size()]; 01084 int next_vertex = sorted_vertex_list[(i+1)%sorted_vertex_list.size()]; 01085 iBase_EntitySetHandle entityset; 01086 01087 //get the mesh node on the geometric vertex 01088 iRel::Error r_err = mk_core()->irel_pair()->getEntSetRelation(vertices[sorted_vertex_list[i]].gVertexHandle, 0, entityset); 01089 IBERRCHK(r_err, "Trouble get the entity set for edge from geometric vertex."); 01090 01091 vector<iBase_EntityHandle> points; 01092 points.clear(); 01093 m_err = mk_core()->imesh_instance()->getEntities(entityset, iBase_VERTEX, iMesh_POINT, points); 01094 IBERRCHK(m_err, "Trouble get the node entities from mesh entity sets."); 01095 01096 assert(points.size()==1); 01097 index++; 01098 nodes.resize(index); 01099 nodes[index-1].index = index-1; 01100 nodes[index-1].onBoundary = false; 01101 nodes[index-1].onCorner = true; 01102 geom_mesh_node[sorted_vertex_list[i]] = index -1; 01103 mesh_geom_vertex[index-1] = sorted_vertex_list[i]; 01104 nodes[index-1].gVertexHandle = points[0]; 01105 m_err = mk_core()->imesh_instance()->setIntData(nodes[index-1].gVertexHandle, m_taghandle, index-1); 01106 IBERRCHK(m_err, "Trouble set the int data for mesh nodes."); 01107 for (int j = 0; j < 3; j++) 01108 nodes[index-1].xyz[j] = vertices[sorted_vertex_list[i]].xyz[j]; 01109 01110 //assign the i-j coordinates for boundary nodes 01111 if (i == 0){ 01112 nodes[index-1].uv[0] = 0.0; 01113 nodes[index-1].uv[1] = 0.0; 01114 } 01115 else{ 01116 AssignIJCoords(nodes[index-1].uv[0], nodes[index-1].uv[1], edges_types[pre_edge], index -1); 01117 } 01118 01119 //get the mesh nodes on the geometric edges 01120 r_err = mk_core()->irel_pair()->getEntSetRelation(edges[next_edge].gEdgeHandle, 0, entityset); 01121 IBERRCHK(r_err, "Trouble get the entity set for edge from geometric vertex."); 01122 01123 points.clear(); 01124 m_err = mk_core()->imesh_instance()->getEntities(entityset, iBase_VERTEX, iMesh_POINT, points); 01125 IBERRCHK(m_err, "Trouble get the node entities from mesh entity sets."); 01126 01127 int sense = 0; 01128 iGeom::Error g_err = mk_core()->igeom_instance()->getEgVtxSense(edges[next_edge].gEdgeHandle, vertices[sorted_vertex_list[i]].gVertexHandle, vertices[next_vertex].gVertexHandle, sense); 01129 IBERRCHK(g_err, "Trouble get the edge sense with respect to two vertices."); 01130 01131 unsigned int j; 01132 if (sense < 0) 01133 j = points.size()-1; 01134 else 01135 j = 0; 01136 for (; ((j < points.size())&&(j>=0));){ 01137 index++; 01138 nodes.resize(index); 01139 nodes[index-1].index = index-1; 01140 nodes[index-1].gVertexHandle = points[j]; 01141 nodes[index-1].onBoundary = true; 01142 nodes[index-1].onCorner = false; 01143 m_err = mk_core()->imesh_instance()->setIntData(nodes[index-1].gVertexHandle, m_taghandle, index-1); 01144 IBERRCHK(m_err, "Trouble set the int data for mesh nodes."); 01145 m_err = mk_core()->imesh_instance()->getVtxCoord(nodes[index-1].gVertexHandle, nodes[index-1].xyz[0], nodes[index-1].xyz[1], nodes[index-1].xyz[2]); 01146 IBERRCHK(m_err, "Trouble get the coordinates from mesh nodes."); 01147 AssignIJCoords(nodes[index-1].uv[0], nodes[index-1].uv[1], edges_types[next_edge], index -1); 01148 if (sense < 0) j--; 01149 else j++; 01150 } 01151 } 01152 } 01153 01154 //Assign the i j coordinates for boundary nodes 01155 void SubMapping::AssignIJCoords(double &u, double &v, EdgeTypes type, int index){ 01156 switch(type){ 01157 case POSI_I: 01158 nodes[index].uv[0] = nodes[index-1].uv[0]+1; 01159 nodes[index].uv[1] = nodes[index-1].uv[1]; 01160 break; 01161 case NEG_I: 01162 nodes[index].uv[0] = nodes[index-1].uv[0]-1; 01163 nodes[index].uv[1] = nodes[index-1].uv[1]; 01164 break; 01165 case POSI_J: 01166 nodes[index].uv[0] = nodes[index-1].uv[0]; 01167 nodes[index].uv[1] = nodes[index-1].uv[1]+1; 01168 break; 01169 case NEG_J: 01170 nodes[index].uv[0] = nodes[index-1].uv[0]; 01171 nodes[index].uv[1] = nodes[index-1].uv[1]-1; 01172 break; 01173 default: 01174 break; 01175 } 01176 } 01177 01178 //subdivide the surface 01179 void SubMapping::InteriorNodeInterpolation(ModelEnt *me) 01180 { 01181 iBase_EntitySetHandle entityset; 01182 iRel::Error r_err = mk_core()->irel_pair()->getEntSetRelation(me->geom_handle(), 0, entityset); 01183 IBERRCHK(r_err, "Trouble get the entity set for edge from geometric vertex."); 01184 01185 int i_max = -1.0e5, i_min = 1.0e5, j_max = -1.0e5, j_min = 1.0e5; 01186 //calculate the bounding i-j: i_max, i_min, j_max, j_min, these, these extreme points should be on the geometric vertices 01187 for (unsigned int i = 0; i < sorted_vertex_list.size(); i++){ 01188 int index = geom_mesh_node[sorted_vertex_list[i]]; 01189 if (nodes[index].uv[0] < i_min) 01190 i_min = int(nodes[index].uv[0]); 01191 if (nodes[index].uv[0] > i_max) 01192 i_max = int(nodes[index].uv[0]); 01193 if (nodes[index].uv[1] < j_min) 01194 j_min = int(nodes[index].uv[1]); 01195 if (nodes[index].uv[1] > j_max) 01196 j_max = int(nodes[index].uv[1]); 01197 } 01198 vector<Vertex> boundary_ij; 01199 for (unsigned int i = 0; i < nodes.size(); i++) 01200 if (nodes[i].onCorner){ 01201 boundary_ij.resize(boundary_ij.size()+1); 01202 boundary_ij[boundary_ij.size()-1] = nodes[i]; 01203 } 01204 01205 //i_min, i_max, j_min and j_max are the boundaries 01206 int index = nodes.size(); 01207 int num_node_boundary = index; 01208 for (int i = i_min+1; i < i_max; i++){ 01209 for (int j = j_min+1; j < j_max; j++){ 01210 double j_coord[2] = {j_min, j_max}, i_coord[2] = {i_min, i_max}; 01211 int j_index[2] = {-1, -1}, i_index[2] = {-1, -1}; 01212 for (int k = 0; k < num_node_boundary; k++){ 01213 if ((int(nodes[k].uv[0]) == i)&&(int(nodes[k].uv[1]) == j)){ 01214 //this point is a boundary node, i_index and j_index are always -1 01215 for (int m = 0; m < 2; m++){ 01216 i_index[m] = -1; 01217 j_index[m] = -1; 01218 } 01219 break; 01220 } 01221 else if ((int(nodes[k].uv[0]) == i)&&(int(nodes[k].uv[1]) != j)){ 01222 //this point has vertical nodes 01223 if ((nodes[k].uv[1] > j)&&(nodes[k].uv[1] <= j_coord[1])){//top point 01224 j_index[1] = k; 01225 j_coord[1] = nodes[k].uv[1]; 01226 } 01227 else if ((nodes[k].uv[1] < j)&&(nodes[k].uv[1] >= j_coord[0])){//bottom point 01228 j_index[0] = k; 01229 j_coord[0] = nodes[k].uv[1]; 01230 } 01231 else 01232 continue; 01233 } 01234 else if ((int(nodes[k].uv[0]) != i)&&(int(nodes[k].uv[1]) == j)){ 01235 //this point has horizontal nodes 01236 if ((nodes[k].uv[0] > i)&&(nodes[k].uv[0] <= i_coord[1])){ 01237 i_index[1] = k; 01238 i_coord[1] = nodes[k].uv[0]; 01239 } 01240 else if ((nodes[k].uv[0] < i)&&(nodes[k].uv[0] >= i_coord[0])){ 01241 i_index[0] = k; 01242 i_coord[0] = nodes[k].uv[0]; 01243 } 01244 else 01245 continue; 01246 } 01247 else//this point is not interesting for me 01248 continue; 01249 } 01250 if ((i_index[0]!= -1)&&(i_index[1] != -1)&&(j_index[0] != -1)&&(j_index[1] != -1)){ 01251 //interpolate the interior point 01252 double xyz[3]; 01253 double weight[2] = {fabs(i-nodes[i_index[1]].uv[0]), fabs(j-nodes[j_index[1]].uv[1])}; 01254 if (fabs(j-nodes[j_index[0]].uv[1]) < fabs(j-nodes[j_index[1]].uv[1])) 01255 weight[1] = double(fabs(j-nodes[j_index[0]].uv[1])); 01256 if (fabs(i-nodes[i_index[0]].uv[0]) < fabs(i-nodes[i_index[1]].uv[0])) 01257 weight[0] = fabs(i-nodes[i_index[0]].uv[0]); 01258 double total = weight[0]+weight[1]; 01259 double i_weight = weight[1]/total, j_weight = weight[0]/total; 01260 01261 for (int k = 0; k < 3; k++){ 01262 double firstpart = nodes[j_index[1]].xyz[k]*fabs(j-nodes[j_index[0]].uv[1])/fabs(nodes[j_index[1]].uv[1]-nodes[j_index[0]].uv[1]); 01263 double secondpart = nodes[j_index[0]].xyz[k]*fabs(nodes[j_index[1]].uv[1]-j)/fabs(nodes[j_index[1]].uv[1]-nodes[j_index[0]].uv[1]); 01264 double j_value = firstpart + secondpart; 01265 double thirdpart = nodes[i_index[1]].xyz[k]*fabs(i-nodes[i_index[0]].uv[0])/fabs(nodes[i_index[1]].uv[0]-nodes[i_index[0]].uv[0]); 01266 double fourthpart = nodes[i_index[0]].xyz[k]*fabs(nodes[i_index[1]].uv[0]-i)/fabs(nodes[i_index[1]].uv[0]-nodes[i_index[0]].uv[0]); 01267 double i_value = thirdpart + fourthpart; 01268 xyz[k] = j_weight*firstpart+j_weight*secondpart+i_weight*thirdpart+i_weight*fourthpart; 01269 } 01270 iGeom::Error g_err = mk_core()->igeom_instance()->getEntClosestPt(me->geom_handle(), xyz[0], xyz[1], xyz[2], xyz[0], xyz[1], xyz[2]); 01271 IBERRCHK(g_err, "Trouble get the closest point on the surface."); 01272 if (isOutSideSurf(boundary_ij, i, j)){ 01273 //if ((num_i[0]%2==1)||(num_i[1]%2==1)||(num_j[0]%2==1)||(num_j[1]%2==1)) 01274 //create the vertex entity 01275 index++; 01276 nodes.resize(index); 01277 nodes[index-1].index = index - 1; 01278 for (int k = 0; k < 3; k++) 01279 nodes[index-1].xyz[k] = xyz[k]; 01280 nodes[index-1].onBoundary = false; 01281 nodes[index-1].onCorner = false; 01282 nodes[index-1].uv[0] = i; 01283 nodes[index-1].uv[1] = j; 01284 } 01285 } 01286 } 01287 } 01288 01289 01290 std::cout << "number of boundary nodes is " << num_node_boundary << std::endl; 01291 //create the interior node entities 01292 vector<iBase_EntityHandle> m_nodes; 01293 m_nodes.resize(nodes.size()-num_node_boundary); 01294 for (unsigned int i = num_node_boundary; i < nodes.size(); i++){ 01295 iMesh::Error m_err = mk_core()->imesh_instance()->createVtx(nodes[i].xyz[0], nodes[i].xyz[1], nodes[i].xyz[2], m_nodes[i-num_node_boundary]); 01296 IBERRCHK(m_err, "Trouble create the node entity."); 01297 nodes[i].gVertexHandle = m_nodes[i-num_node_boundary]; 01298 m_err = mk_core()->imesh_instance()->addEntToSet(m_nodes[i-num_node_boundary], entityset); 01299 IBERRCHK(m_err, "Trouble add the mesh node into the entityset."); 01300 m_err = mk_core()->imesh_instance()->setIntData(m_nodes[i-num_node_boundary], m_taghandle, i); 01301 IBERRCHK(m_err, "Trouble set the int data."); 01302 } 01303 //ok, we are done with the node entities 01304 01305 //trick here, create an array of int data to quickly locate the node index 01306 vector<int> node_index((j_max-j_min+1)*(i_max-i_min+1),-1);//here, invalid position is -1 01307 for (unsigned int i = 0; i < nodes.size(); i++){ 01308 node_index[(nodes[i].uv[1]-j_min)*(i_max-i_min+1)+nodes[i].uv[0]-i_min] = i; 01309 } 01310 01311 int face_sense; 01312 iGeom::Error g_err = mk_core()->igeom_instance()->getEgFcSense(edges[sorted_edge_list[0]].gEdgeHandle, me->geom_handle(), face_sense); 01313 IBERRCHK(g_err, "Trouble get the edge sense with respect to a geometrical face."); 01314 01315 int edge_sense; 01316 g_err = mk_core()->igeom_instance()->getEgVtxSense(edges[sorted_edge_list[0]].gEdgeHandle, vertices[sorted_vertex_list[0]].gVertexHandle, vertices[sorted_vertex_list[1]].gVertexHandle, edge_sense); 01317 IBERRCHK(g_err, "Trouble get the sense of edge with respect to two vertices."); 01318 01319 int test_sense = face_sense * edge_sense; 01320 01321 index = 0; 01322 //create the quadrilateral elements on the surface 01323 for (int j = j_min; j < j_max; j++){ 01324 for (int i = i_min; i < i_max; i++){ 01325 01326 if (node_index[(j-j_min)*(i_max-i_min+1)+i-i_min] != -1){//there exists such a mesh node 01327 //check the other three vertices whether they exist or not 01328 if ((j+1)>j_max) 01329 continue; 01330 if ((i+1)>i_max) 01331 continue; 01332 if ((node_index[(j+1-j_min)*(i_max-i_min+1)+i-i_min] != -1)&&(node_index[(j-j_min)*(i_max-i_min+1)+i+1-i_min] != -1)&&(node_index[(j+1-j_min)*(i_max-i_min+1)+i+1-i_min] != -1)){ 01333 index++; 01334 quads.resize(index); 01335 quads[index-1].connect.resize(4); 01336 if (test_sense < 0){ 01337 quads[index-1].connect[0] = &nodes[node_index[(j-j_min)*(i_max-i_min+1)+i-i_min]]; 01338 quads[index-1].connect[3] = &nodes[node_index[(j+1-j_min)*(i_max-i_min+1)+i-i_min]]; 01339 quads[index-1].connect[2] = &nodes[node_index[(j+1-j_min)*(i_max-i_min+1)+i+1-i_min]]; 01340 quads[index-1].connect[1] = &nodes[node_index[(j-j_min)*(i_max-i_min+1)+i+1-i_min]]; 01341 } 01342 else{ 01343 quads[index-1].connect[0] = &nodes[node_index[(j-j_min)*(i_max-i_min+1)+i-i_min]]; 01344 quads[index-1].connect[1] = &nodes[node_index[(j+1-j_min)*(i_max-i_min+1)+i-i_min]]; 01345 quads[index-1].connect[2] = &nodes[node_index[(j+1-j_min)*(i_max-i_min+1)+i+1-i_min]]; 01346 quads[index-1].connect[3] = &nodes[node_index[(j-j_min)*(i_max-i_min+1)+i+1-i_min]]; 01347 } 01348 } 01349 } 01350 } 01351 } 01352 std::cout << "test quad size = " << quads.size() << std::endl; 01353 01354 vector<iBase_EntityHandle> m_faces; 01355 m_faces.resize(quads.size()); 01356 for (unsigned int i = 0; i < quads.size(); i++){ 01357 vector<iBase_EntityHandle> n_nodes; 01358 n_nodes.resize(4); 01359 for (int k = 0; k < 4; k++) 01360 n_nodes[k] = nodes[quads[i].connect[k]->index].gVertexHandle; 01361 01362 iMesh::Error m_err = mk_core()->imesh_instance()->createEnt(iMesh_QUADRILATERAL, &n_nodes[0], 4, m_faces[i]); 01363 IBERRCHK(m_err, "Trouble create the quadrilateral element."); 01364 quads[i].gFaceHandle = m_faces[i]; 01365 m_err = mk_core()->imesh_instance()->addEntToSet(m_faces[i], entityset); 01366 IBERRCHK(m_err, "Trouble add the mesh node into the entityset."); 01367 m_err = mk_core()->imesh_instance()->setIntData(m_faces[i], m_taghandle, i); 01368 IBERRCHK(m_err, "Trouble set the int data."); 01369 01370 n_nodes.clear(); 01371 } 01372 01373 std::cout << "Quad size = " << quads.size() << std::endl; 01374 std::cout << "imax = " << i_max << "\timin = " << i_min << "\tjmax = " << j_max << "\tjmin = " << j_min << std::endl; 01375 } 01376 01377 //smooth the structured mesh 01378 void SubMapping::MeshSmoothing(ModelEnt *ent) 01379 { 01380 std::vector<std::set<int> > AdjElements; 01381 std::vector<std::vector<int> > Quads(quads.size(), vector<int>(4)); 01382 std::vector<std::vector<double> > coords(nodes.size(), vector<double>(3)); 01383 std::vector<bool> isBnd(nodes.size(), false); 01384 std::vector<std::vector<int> > connect(nodes.size(), std::vector<int>(9)); 01385 01386 AdjElements.resize(nodes.size()); 01387 for (unsigned int i = 0; i < quads.size(); i++){ 01388 std::vector<iBase_EntityHandle> adjEnts; 01389 adjEnts.clear(); 01390 iMesh::Error m_err = mk_core()->imesh_instance()->getEntAdj(quads[i].gFaceHandle, iBase_VERTEX, adjEnts); 01391 IBERRCHK(m_err, "Trouble get the adjacent nodes wrt a quad."); 01392 01393 assert(adjEnts.size()==4); 01394 01395 for (unsigned int j = 0; j < adjEnts.size(); j++){ 01396 int index_id = -1; 01397 m_err = mk_core()->imesh_instance()->getIntData(adjEnts[j], m_taghandle, index_id); 01398 IBERRCHK(m_err, "Trouble get int data for nodes."); 01399 Quads[i][j] = index_id; 01400 } 01401 } 01402 01403 for (unsigned int i = 0; i < nodes.size(); i++){ 01404 if (nodes[i].onBoundary || nodes[i].onCorner) 01405 isBnd[i] = true; 01406 for (int j = 0; j < 3; j++) 01407 coords[i][j] = nodes[i].xyz[j]; 01408 if (!isBnd[i]){ 01409 vector<iBase_EntityHandle> adjEnts; 01410 iMesh::Error m_err = mk_core()->imesh_instance()->getEntAdj(nodes[i].gVertexHandle, iBase_FACE, adjEnts); 01411 IBERRCHK(m_err, "Trouble get the adjacent quads wrt a node."); 01412 for (unsigned int j = 0; j < adjEnts.size(); j++){ 01413 int index_id = -1; 01414 m_err = mk_core()->imesh_instance()->getIntData(adjEnts[j], m_taghandle, index_id); 01415 IBERRCHK(m_err, "Trouble get int data for quads."); 01416 AdjElements[i].insert(index_id); 01417 } 01418 01419 //process the connect info 01420 //there are 4 adjacent quadrilateral elements around node i 01421 assert(AdjElements[i].size() == 4); 01422 std::set<int>::iterator it = AdjElements[i].begin(); 01423 int st_index[4]; 01424 //process 4 quad elements 01425 int j = -1; 01426 for (; it != AdjElements[i].end(); it++){ 01427 j++; 01428 if (int(i) == Quads[*it][0]) 01429 st_index[j] = 0; 01430 else if (int(i) == Quads[*it][1]) 01431 st_index[j] = 1; 01432 else if (int(i) == Quads[*it][2]) 01433 st_index[j] = 2; 01434 else 01435 st_index[j] = 3; 01436 } 01437 it = AdjElements[i].begin(); 01438 connect[i][2] = Quads[*it][(st_index[0]+3)%4]; 01439 connect[i][8] = Quads[*it][(st_index[0]+1)%4]; 01440 connect[i][1] = Quads[*it][(st_index[0]+2)%4]; 01441 //finish processing the quad 1 01442 std::set<int>::iterator it1 = AdjElements[i].begin(); 01443 it1++; 01444 for (j = 1; j < 4; j++, it1++){ 01445 if (connect[i][8] == Quads[*it1][(st_index[j]+1)%4]){ 01446 connect[i][7] = Quads[*it1][(st_index[j]+2)%4]; 01447 connect[i][6] = Quads[*it1][(st_index[j]+3)%4]; 01448 break; 01449 } 01450 else if (connect[i][8] == Quads[*it1][(st_index[j]+3)%4]){ 01451 connect[i][7] = Quads[*it1][(st_index[j]+2)%4]; 01452 connect[i][6] = Quads[*it1][(st_index[j]+1)%4]; 01453 break; 01454 } 01455 else 01456 continue; 01457 } 01458 //finish processing the quad 2 01459 std::set<int>::iterator it2 = AdjElements[i].begin(); 01460 it2++; 01461 for (j=1; it2 != AdjElements[i].end(); it2++,j++){ 01462 if (connect[i][2] == Quads[*it2][(st_index[j]+1)%4]){ 01463 connect[i][3] = Quads[*it2][(st_index[j]+2)%4]; 01464 connect[i][4] = Quads[*it2][(st_index[j]+3)%4]; 01465 break; 01466 } 01467 else if (connect[i][2] == Quads[*it2][(st_index[j]+3)%4]){ 01468 connect[i][3] = Quads[*it2][(st_index[j]+2)%4]; 01469 connect[i][4] = Quads[*it2][(st_index[j]+1)%4]; 01470 break; 01471 } 01472 else 01473 continue; 01474 } 01475 //finish processing the quad 4; 01476 std::set<int>::iterator it3 = AdjElements[i].begin(); 01477 it3++; 01478 for (j=1; it3 != AdjElements[i].end(); it3++,j++){ 01479 if ((it3 != it1)&&(it3 != it2)){ 01480 connect[i][5] = Quads[*it2][(st_index[j]+2)%4]; 01481 } 01482 else 01483 continue; 01484 } 01485 } 01486 } 01487 01488 mk_core()->save_mesh("BeforeEquipotential.vtk"); 01489 01490 EquipotentialSmooth smoother; 01491 01492 smoother.SetupData(AdjElements, Quads, coords, isBnd, connect); 01493 smoother.Execute(); 01494 01495 std::vector<std::vector<double> > coors(nodes.size(), vector<double>(3)); 01496 smoother.GetCoords(coors); 01497 01498 //update the new position for nodes 01499 for (unsigned int i = 0; i < nodes.size(); i++){ 01500 if (!isBnd[i]){ 01501 double tmp_coord[3] = {coords[i][0], coords[i][1], coords[i][2]}; 01502 01503 iGeom::Error g_err = mk_core()->igeom_instance()->getEntClosestPt(ent->geom_handle(), coords[i][0], coords[i][1], coords[i][2], tmp_coord[0], tmp_coord[1], tmp_coord[2]); 01504 IBERRCHK(g_err, "Trouble get a closest point on the linking surface."); 01505 iMesh::Error m_err = mk_core()->imesh_instance()->setVtxCoord(nodes[i].gVertexHandle, tmp_coord[0], tmp_coord[1], tmp_coord[2]); 01506 IBERRCHK(m_err, "Trouble set the new coordinates for nodes."); 01507 } 01508 } 01509 01510 01511 #ifdef HAVE_MESQUITE 01512 iBase_EntitySetHandle entityset; 01513 iRel::Error r_err = mk_core()->irel_pair()->getEntSetRelation(ent->geom_handle(), 0, entityset); 01514 IBERRCHK(r_err, "Trouble get the entity set for edge from geometric vertex."); 01515 MeshImprove shapesmooth(mk_core(), true, true, false, false, false); 01516 shapesmooth.SurfMeshImprove(ent->geom_handle(), entityset, iBase_FACE); 01517 01518 #endif 01519 vector<iBase_EntityHandle> entities; 01520 for (unsigned int i = 0; i < nodes.size(); i++) 01521 entities.push_back(nodes[i].gVertexHandle); 01522 iMesh::Error m_err = mk_core()->imesh_instance()->rmvArrTag(&entities[0], entities.size(), m_taghandle); 01523 IBERRCHK(m_err, "Trouble remove the tag values from an array of entities."); 01524 entities.clear(); 01525 for (unsigned int i = 0; i < quads.size(); i++) 01526 entities.push_back(quads[i].gFaceHandle); 01527 m_err = mk_core()->imesh_instance()->rmvArrTag(&entities[0], entities.size(), m_taghandle); 01528 IBERRCHK(m_err, "Trouble remove the tag values from an array of entities."); 01529 entities.clear(); 01530 for (unsigned int i = 0; i < vertices.size(); i++) 01531 entities.push_back(vertices[i].gVertexHandle); 01532 iGeom::Error g_err = mk_core()->igeom_instance()->rmvArrTag(&entities[0], entities.size(), g_taghandle); 01533 IBERRCHK(g_err, "Trouble remove the tag values from an array of entities."); 01534 entities.clear(); 01535 for (unsigned int i = 0; i < edges.size(); i++) 01536 entities.push_back(edges[i].gEdgeHandle); 01537 g_err = mk_core()->igeom_instance()->rmvArrTag(&entities[0], entities.size(), g_taghandle); 01538 IBERRCHK(g_err, "Trouble remove the tag values from an array of entities."); 01539 01540 01541 } 01542 01543 //check whether a point is outside the surface or not 01544 bool SubMapping::isOutSideSurf(vector<Vertex> corner, int i, int j) 01545 {//test whether the point (i,j) is inside the polygon or outside 01546 //use the wind number 01547 unsigned int m; 01548 double angle=0; 01549 double p1[2],p2[2]; 01550 01551 for (m = 0; m < corner.size(); m++) { 01552 p1[0] = corner[m].uv[0] - i; 01553 p1[1] = corner[m].uv[1] - j; 01554 p2[0] = corner[(m+1)%corner.size()].uv[0] - i; 01555 p2[1] = corner[(m+1)%corner.size()].uv[1] - j; 01556 angle += Angle2D(p1[0],p1[1],p2[0],p2[1]); 01557 } 01558 01559 if (fabs(angle) < PI) 01560 return false; 01561 else 01562 return true; 01563 } 01564 01565 /* 01566 Return the angle between two vectors on a plane 01567 The angle is from vector 1 to vector 2, positive anticlockwise 01568 The result is between -pi -> pi 01569 */ 01570 double SubMapping::Angle2D(double x1, double y1, double x2, double y2) 01571 { 01572 double dtheta,theta1,theta2; 01573 01574 theta1 = atan2(y1,x1); 01575 theta2 = atan2(y2,x2); 01576 dtheta = theta2 - theta1; 01577 while (dtheta > PI) 01578 dtheta -= 2.0*PI; 01579 while (dtheta < -PI) 01580 dtheta += 2.0*PI; 01581 01582 return dtheta; 01583 } 01584 01585 } 01586
