MeshKit  1.0
IARoundingFar3StepNlp Class Reference
#include <IARoundingFar3StepNlp.hpp>
Inheritance diagram for IARoundingFar3StepNlp:
List of all members.
Public Member Functions
 IARoundingFar3StepNlp (const IAData *data_ptr, const IPData *ip_data_ptr, IASolution *solution_ptr)
virtual ~IARoundingFar3StepNlp ()
Overloaded from TNLP
virtual bool get_nlp_info (Index &n, Index &m, Index &nnz_jac_g, Index &nnz_h_lag, IndexStyleEnum &index_style)
virtual bool get_bounds_info (Index n, Number *x_l, Number *x_u, Index m, Number *g_l, Number *g_u)
virtual bool get_starting_point (Index n, bool init_x, Number *x_init, bool init_z, Number *z_L, Number *z_U, Index m, bool init_lambda, Number *lambda)
virtual bool eval_f (Index n, const Number *x, bool new_x, Number &obj_value)
virtual bool eval_grad_f (Index n, const Number *x, bool new_x, Number *grad_f)
virtual bool eval_g (Index n, const Number *x, bool new_x, Index m, Number *g)
virtual bool eval_jac_g (Index n, const Number *x, bool new_x, Index m, Index nele_jac, Index *iRow, Index *jCol, Number *values)
virtual bool eval_h (Index n, const Number *x, bool new_x, Number obj_factor, Index m, const Number *lambda, bool new_lambda, Index nele_hess, Index *iRow, Index *jCol, Number *values)
Solution Methods
virtual void finalize_solution (SolverReturn status, Index n, const Number *x, const Number *z_L, const Number *z_U, Index m, const Number *g, const Number *lambda, Number obj_value, const IpoptData *ip_data, IpoptCalculatedQuantities *ip_cq)
Private Types
enum  HessOptions { ZERO, ROUNDED }
Private Member Functions
double f_x_value (double I_i, double x_i) const
double get_f_xl (int i) const
double get_f_xh (int i) const
 IARoundingFar3StepNlp (const IARoundingFar3StepNlp &)
IARoundingFar3StepNlp & operator= (const IARoundingFar3StepNlp &)
Private Attributes
const IAData * data
const IPData * ipData
IAWeights h0
IAWeights hp
IAWeights hm
const int x01_start
const int xp_start
const int xm_start
const int sum_even_start
const int x_constraint_start
const int problem_n
const int problem_m
const int base_n
const int base_m
const HessOptions hess_option
IASolution * solution
IANlp baseNlp
const bool debugging
const bool verbose
Detailed Description
Definition at line 20 of file IARoundingFar3StepNlp.hpp.
Member Enumeration Documentation
enum HessOptions [private]
Enumerator:
ZERO
ROUNDED
Definition at line 112 of file IARoundingFar3StepNlp.hpp.
IARoundingFar3StepNlp ( const IAData *  data_ptr,
const IPData *  ip_data_ptr,
IASolution *  solution_ptr
default constructor
Definition at line 95 of file IARoundingFar3StepNlp.cpp.
~IARoundingFar3StepNlp ( ) [virtual]
default destructor
Definition at line 87 of file IARoundingFar3StepNlp.cpp.
IARoundingFar3StepNlp ( ) [private]
Member Function Documentation
bool eval_f ( Index  n,
const Number *  x,
bool  new_x,
Number &  obj_value
) [virtual]
Method to return the objective value
Definition at line 352 of file IARoundingFar3StepNlp.cpp.
bool eval_g ( Index  n,
const Number *  x,
bool  new_x,
Index  m,
Number *  g
) [virtual]
Method to return the constraint residuals
Definition at line 437 of file IARoundingFar3StepNlp.cpp.
bool eval_grad_f ( Index  n,
const Number *  x,
bool  new_x,
Number *  grad_f
) [virtual]
Method to return the gradient of the objective
Definition at line 403 of file IARoundingFar3StepNlp.cpp.
bool eval_h ( Index  n,
const Number *  x,
bool  new_x,
Number  obj_factor,
Index  m,
const Number *  lambda,
bool  new_lambda,
Index  nele_hess,
Index *  iRow,
Index *  jCol,
Number *  values
) [virtual]
Method to return: 1) The structure of the hessian of the lagrangian (if "values" is NULL) 2) The values of the hessian of the lagrangian (if "values" is not NULL)
Definition at line 509 of file IARoundingFar3StepNlp.cpp.
bool eval_jac_g ( Index  n,
const Number *  x,
bool  new_x,
Index  m,
Index  nele_jac,
Index *  iRow,
Index *  jCol,
Number *  values
) [virtual]
Method to return: 1) The structure of the jacobian (if "values" is NULL) 2) The values of the jacobian (if "values" is not NULL)
Definition at line 458 of file IARoundingFar3StepNlp.cpp.
double f_x_value ( double  I_i,
double  x_i
) const [private]
Definition at line 78 of file IARoundingFar3StepNlp.cpp.
void finalize_solution ( SolverReturn  status,
Index  n,
const Number *  x,
const Number *  z_L,
const Number *  z_U,
Index  m,
const Number *  g,
Number  obj_value,
const IpoptData *  ip_data,
IpoptCalculatedQuantities *  ip_cq
) [virtual]
This method is called when the algorithm is complete so the TNLP can store/write the solution
Definition at line 582 of file IARoundingFar3StepNlp.cpp.
bool get_bounds_info ( Index  n,
Number *  x_l,
Number *  x_u,
Index  m,
Number *  g_l,
Number *  g_u
) [virtual]
Method to return the bounds for my problem
Definition at line 276 of file IARoundingFar3StepNlp.cpp.
double get_f_xh ( int  i) const [inline, private]
Definition at line 345 of file IARoundingFar3StepNlp.cpp.
double get_f_xl ( int  i) const [inline, private]
Definition at line 339 of file IARoundingFar3StepNlp.cpp.
bool get_nlp_info ( Index &  n,
Index &  m,
Index &  nnz_jac_g,
Index &  nnz_h_lag,
IndexStyleEnum &  index_style
) [virtual]
Method to return some info about the nlp
Definition at line 253 of file IARoundingFar3StepNlp.cpp.
bool get_starting_point ( Index  n,
bool  init_x,
Number *  x_init,
bool  init_z,
Number *  z_L,
Number *  z_U,
Index  m,
bool  init_lambda,
Number *  lambda
) [virtual]
Method to return the starting point for the algorithm
Definition at line 314 of file IARoundingFar3StepNlp.cpp.
IARoundingFar3StepNlp& operator= ( const IARoundingFar3StepNlp &  ) [private]
Member Data Documentation
const int base_m [private]
Definition at line 106 of file IARoundingFar3StepNlp.hpp.
const int base_n [private]
IANlp baseNlp [private]
Definition at line 120 of file IARoundingFar3StepNlp.hpp.
const IAData* data [private]
Definition at line 95 of file IARoundingFar3StepNlp.hpp.
const bool debugging [private]
Definition at line 122 of file IARoundingFar3StepNlp.hpp.
IAWeights h0 [private]
Definition at line 97 of file IARoundingFar3StepNlp.hpp.
const HessOptions hess_option [private]
Definition at line 113 of file IARoundingFar3StepNlp.hpp.
IAWeights hm [private]
Definition at line 99 of file IARoundingFar3StepNlp.hpp.
IAWeights hp [private]
Definition at line 98 of file IARoundingFar3StepNlp.hpp.
const IPData* ipData [private]
Definition at line 96 of file IARoundingFar3StepNlp.hpp.
const int problem_m [private]
const int problem_n [private]
IASolution* solution [private]
Definition at line 116 of file IARoundingFar3StepNlp.hpp.
const int sum_even_start [private]
Definition at line 104 of file IARoundingFar3StepNlp.hpp.
const bool verbose [private]
Definition at line 123 of file IARoundingFar3StepNlp.hpp.
const int x01_start [private]
Definition at line 101 of file IARoundingFar3StepNlp.hpp.
const int x_constraint_start [private]
Definition at line 105 of file IARoundingFar3StepNlp.hpp.
const int xm_start [private]
Definition at line 103 of file IARoundingFar3StepNlp.hpp.
const int xp_start [private]
Definition at line 102 of file IARoundingFar3StepNlp.hpp.
