MeshKit  1.0
MBSplitOp Class Reference
#include <MBSplitOp.hpp>
Inheritance diagram for MBSplitOp:
List of all members.
Public Member Functions
 MBSplitOp (MKCore *mk_core, const MEntVector &me_vec)
virtual ~MBSplitOp ()
void set_options (int globalId, double dirx, double diry, double dirz, int closed, double min_dot)
void add_points (double x, double y, double z)
virtual void setup_this ()
 Pure virtual, derived class must define.
virtual void execute_this ()
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Private Attributes
int _globalId
std::vector< double > _polyline
double _direction [3]
int _closed
double _min_dot
Detailed Description
Examples:
example_mbsplitop.cpp, and example_setpnt2quad.cpp.
Definition at line 15 of file MBSplitOp.hpp.
MBSplitOp ( MKCore *  mk_core,
const MEntVector &  me_vec
Definition at line 26 of file MBSplitOp.cpp.
~MBSplitOp ( ) [virtual]
Definition at line 36 of file MBSplitOp.cpp.
Member Function Documentation
void add_points ( double  x,
double  y,
double  z
Examples:
Definition at line 55 of file MBSplitOp.cpp.
static bool can_mesh ( iBase_EntityType  dim) [inline, static]
Definition at line 41 of file MBSplitOp.hpp.
static bool can_mesh ( ModelEnt *  me) [inline, static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 52 of file MBSplitOp.hpp.
void execute_this ( ) [virtual]
Implements GraphNode.
Definition at line 69 of file MBSplitOp.cpp.
virtual const moab::EntityType* mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 65 of file MBSplitOp.hpp.
static const char* name ( ) [inline, static]
Get class name.
Definition at line 36 of file MBSplitOp.hpp.
const moab::EntityType * output_types ( ) [static]
Returns:
Definition at line 21 of file MBSplitOp.cpp.
void set_options ( int  globalId,
double  dirx,
double  diry,
double  dirz,
int  closed,
double  min_dot
Examples:
Definition at line 41 of file MBSplitOp.cpp.
void setup_this ( ) [virtual]
Definition at line 63 of file MBSplitOp.cpp.
Member Data Documentation
int _closed [private]
Definition at line 74 of file MBSplitOp.hpp.
double _direction[3] [private]
Definition at line 73 of file MBSplitOp.hpp.
int _globalId [private]
Definition at line 71 of file MBSplitOp.hpp.
double _min_dot [private]
Definition at line 75 of file MBSplitOp.hpp.
std::vector<double> _polyline [private]
Definition at line 72 of file MBSplitOp.hpp.
