MeshKit
1.0
00001 /* 00002 * MBSplitOp.hpp 00003 * 00004 * Created on: Oct 2, 2011 00005 * Author: iulian 00006 */ 00007 00008 #ifndef MBSPLITOP_HPP_ 00009 #define MBSPLITOP_HPP_ 00010 00011 #include "meshkit/MeshScheme.hpp" 00012 00013 namespace MeshKit { 00014 00015 class MBSplitOp: public MeshKit::MeshScheme 00016 { 00017 public: 00018 MBSplitOp(MKCore *mk_core, const MEntVector &me_vec); 00019 virtual ~MBSplitOp(); 00020 00021 // set options polyline[3*nPoints], closed (1 or 0, closed loop or open polyline, 00022 // intersect the boundary) 00023 // globalId: to identify / single out the gface to be split 00024 // the gface will be found among gfaces in the mentSelection 00025 void set_options(int globalId, 00026 double dirx, double diry, double dirz, int closed, double min_dot); 00027 00028 void add_points(double x, double y, double z); 00029 //set up the splitting of a gface, with a polyline or loop 00030 virtual void setup_this(); 00031 00032 // construct the mesh 00033 virtual void execute_this(); 00034 00036 static const char* name() 00037 { 00038 return "MBSplitOp"; 00039 } 00040 00041 static bool can_mesh(iBase_EntityType dim) 00042 { 00043 return false; 00044 } 00045 00052 static bool can_mesh(ModelEnt *me) 00053 { 00054 return false;// this is not used for meshing, but for geometry creation 00055 } 00056 00060 static const moab::EntityType* output_types(); 00061 00065 virtual const moab::EntityType* mesh_types_arr() const 00066 { 00067 return output_types(); 00068 } 00069 00070 private: 00071 int _globalId; 00072 std::vector<double>_polyline; 00073 double _direction[3]; 00074 int _closed; 00075 double _min_dot; 00076 }; 00077 00078 } 00079 00080 #endif /* MBSPLITOP_HPP_ */
