MeshKit
1.0
A simple class for meshing copy moving meshes. More...
#include <meshkit/CopyMesh.hpp>
Public Member Functions | |
| CopyMesh (MKCore *mkcore, const MEntVector &me_vec) | |
| Bare constructor. | |
| virtual | ~CopyMesh () |
| Destructor. | |
| virtual const moab::EntityType * | mesh_types_arr () const |
| Return the mesh entity types operated on by this scheme. | |
| virtual bool | add_modelent (ModelEnt *model_ent) |
| Re-implemented here so we can check topological dimension of model_ent. | |
| virtual void | setup_this () |
| Setup is a no-op, but must be provided since it's pure virtual. | |
| virtual void | execute_this () |
| The only setup/execute function we need, since meshing vertices is trivial. | |
| iBase_TagHandle | copy_tag () |
| void | set_transform (const Copy::Transform &transform) |
| void | update_sets () |
| void | reset_sets () |
| CESets & | copy_sets () |
| CESets & | expand_sets () |
| void | tag_copied_sets (const char **tag_names, const char **tag_vals, const int num_tags) |
| void | tag_copied_sets (iMesh::TagHandle *tags, const char **tag_vals, const int num_tags) |
Static Public Member Functions | |
| static const char * | name () |
| Get class name. | |
| static bool | can_mesh (iBase_EntityType dim) |
| Function returning whether this scheme can mesh entities of t the specified dimension. | |
| static bool | can_mesh (ModelEnt *me) |
| Function returning whether this scheme can mesh the specified entity. | |
| static const moab::EntityType * | output_types () |
| Get list of mesh entity types that can be generated. | |
Public Attributes | |
| bool | flag_process_ce_set |
Private Member Functions | |
| void | do_copy (iMesh::EntitySetHandle set_handle) |
| void | get_copy_expand_sets (iMesh::EntitySetHandle *©_sets, int &num_copy_sets, iMesh::EntitySetHandle *&expand_sets, int &num_expand_sets) |
| void | get_tagged_sets (iMesh::EntitySetHandle from_set, iMesh::TagHandle *tag_handles, const char **tag_vals, int num_tags, iMesh::EntitySetHandle *&tagged_sets, int &num_tagged_sets) |
| int | getStructure (iMesh_Instance instance, iBase_EntitySetHandle set, std::vector< iBase_EntityHandle > &ents, std::vector< iBase_EntityHandle > &unique_adj, std::vector< int > &indices, std::vector< int > &offsets) |
Private Attributes | |
| iMesh * | mesh |
| LocalTag | copyTag |
| Copy::Transform * | transform |
| CESets | copySets |
| CESets | expandSets |
INPUT: ModelEnts representing meshes MESH TYPE(S): ALL TYPES OUTPUT: Copied mesh along with the existing mesh DEPENDENCIES: (none) CONSTRAINTS: (none)
This class performs the trivial task of copy moving meshes. There can be multiple instances of this class, and therefore it is pointed to and managed by ....
Each instance of this class stores all the ModelEnt's representing the mesh data, and after execution after meshing new entities are created and tag propagation happens.
Definition at line 38 of file CopyMesh.hpp.
| CopyMesh | ( | MKCore * | mkcore, |
| const MEntVector & | me_vec | ||
Bare constructor.
Definition at line 29 of file CopyMesh.cpp.
| ~CopyMesh | ( | ) | [virtual] |
Destructor.
Definition at line 40 of file CopyMesh.cpp.
| bool add_modelent | ( | ModelEnt * | model_ent | ) | [virtual] |
| model_ent | ModelEnt being added |
Reimplemented from MeshOp.
Definition at line 46 of file CopyMesh.cpp.
| bool can_mesh | ( | iBase_EntityType | dim | ) | [inline, static] |
| dim | entity dimension |
Definition at line 177 of file CopyMesh.hpp.
Used by MeshOpFactory to find scheme for an entity.
| me | ModelEnt being queried |
Definition at line 184 of file CopyMesh.hpp.
Definition at line 211 of file CopyMesh.hpp.
| iBase_TagHandle copy_tag | ( | ) | [inline] |
Definition at line 200 of file CopyMesh.hpp.
| void do_copy | ( | iMesh::EntitySetHandle | set_handle | ) | [private] |
Definition at line 153 of file CopyMesh.cpp.
| void execute_this | ( | ) | [virtual] |
Implements GraphNode.
Definition at line 55 of file CopyMesh.cpp.
| CESets & expand_sets | ( | ) | [inline] |
Definition at line 216 of file CopyMesh.hpp.
| void get_copy_expand_sets | ( | iMesh::EntitySetHandle *& | copy_sets, |
| int & | num_copy_sets, | ||
| iMesh::EntitySetHandle *& | expand_sets, | ||
| int & | num_expand_sets | ||
| ) | [private] |
| void get_tagged_sets | ( | iMesh::EntitySetHandle | from_set, |
| iMesh::TagHandle * | tag_handles, | ||
| const char ** | tag_vals, | ||
| int | num_tags, | ||
| iMesh::EntitySetHandle *& | tagged_sets, | ||
| int & | num_tagged_sets | ||
| ) | [private] |
| int getStructure | ( | iMesh_Instance | instance, |
| iBase_EntitySetHandle | set, | ||
| std::vector< iBase_EntityHandle > & | ents, | ||
| std::vector< iBase_EntityHandle > & | unique_adj, | ||
| std::vector< int > & | indices, | ||
| std::vector< int > & | offsets | ||
| ) | [private] |
Definition at line 81 of file CopyMesh.cpp.
| const moab::EntityType * mesh_types_arr | ( | ) | const [inline, virtual] |
moab::MBMAXTYPE Implements MeshOp.
Definition at line 189 of file CopyMesh.hpp.
| const char * name | ( | ) | [inline, static] |
Get class name.
Definition at line 172 of file CopyMesh.hpp.
| const moab::EntityType * output_types | ( | ) | [static] |
moab::MBMAXTYPE Definition at line 26 of file CopyMesh.cpp.
| void reset_sets | ( | ) | [inline] |
Definition at line 205 of file CopyMesh.hpp.
| void set_transform | ( | const Copy::Transform & | transform | ) | [inline] |
Definition at line 194 of file CopyMesh.hpp.
| void setup_this | ( | ) | [virtual] |
Definition at line 51 of file CopyMesh.cpp.
| void tag_copied_sets | ( | const char ** | tag_names, |
| const int | num_tags | ||
Definition at line 200 of file CopyMesh.cpp.
| void tag_copied_sets | ( | iMesh::TagHandle * | tags, |
Definition at line 212 of file CopyMesh.cpp.
| void update_sets | ( | ) |
Definition at line 194 of file CopyMesh.cpp.
Definition at line 148 of file CopyMesh.hpp.
Definition at line 145 of file CopyMesh.hpp.
CESets expandSets [private] |
Definition at line 149 of file CopyMesh.hpp.
| bool flag_process_ce_set |
Definition at line 117 of file CopyMesh.hpp.
Definition at line 144 of file CopyMesh.hpp.
Copy::Transform* transform [private] |
Definition at line 146 of file CopyMesh.hpp.
