MeshKit  1.0
ParExchangeMesh Class Reference
#include <ParExchangeMesh.hpp>
Inheritance diagram for ParExchangeMesh:
List of all members.
Public Member Functions
 ParExchangeMesh (MKCore *mkcore, const MEntVector &me_vec)
virtual ~ParExchangeMesh ()
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
virtual void setup_this ()
 Setup is a no-op, but must be provided since it's pure virtual.
virtual void execute_this ()
void print_mesh ()
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
 Function returning whether this scheme can mesh entities of t the specified dimension.
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Private Member Functions
int get_shared_list (const int to_proc)
Private Attributes
ParallelComm * m_mpcomm
unsigned int m_rank
unsigned int m_proc_size
iBase_TagHandle m_mPuniqueIDTag
std::vector< Range * > m_shared_entities
std::vector< unsigned int > m_shared_procs
std::vector< MPI_Request > m_recv_reqs
std::vector< MPI_Request > m_recv_remoteh_reqs
Detailed Description
Definition at line 16 of file ParExchangeMesh.hpp.
ParExchangeMesh ( MKCore *  mkcore,
const MEntVector &  me_vec
Definition at line 16 of file ParExchangeMesh.cpp.
~ParExchangeMesh ( ) [virtual]
Definition at line 34 of file ParExchangeMesh.cpp.
Member Function Documentation
static bool can_mesh ( iBase_EntityType  dim) [inline, static]
Parameters:
dimentity dimension
Definition at line 32 of file ParExchangeMesh.hpp.
static bool can_mesh ( ModelEnt *  me) [inline, static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 41 of file ParExchangeMesh.hpp.
void execute_this ( ) [virtual]
\ The only setup/execute function we need, since meshing vertices is trivial
Implements GraphNode.
Definition at line 46 of file ParExchangeMesh.cpp.
int get_shared_list ( const int  to_proc) [private]
Definition at line 116 of file ParExchangeMesh.cpp.
virtual const moab::EntityType* mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 52 of file ParExchangeMesh.hpp.
static const char* name ( ) [inline, static]
Get class name.
Definition at line 25 of file ParExchangeMesh.hpp.
const moab::EntityType * output_types ( ) [static]
Returns:
Definition at line 13 of file ParExchangeMesh.cpp.
void print_mesh ( )
Definition at line 131 of file ParExchangeMesh.cpp.
void setup_this ( ) [virtual]
Definition at line 42 of file ParExchangeMesh.cpp.
Member Data Documentation
ParallelComm* m_mpcomm [private]
Definition at line 68 of file ParExchangeMesh.hpp.
iBase_TagHandle m_mPuniqueIDTag [private]
Definition at line 72 of file ParExchangeMesh.hpp.
unsigned int m_proc_size [private]
Definition at line 70 of file ParExchangeMesh.hpp.
unsigned int m_rank [private]
std::vector< MPI_Request > m_recv_remoteh_reqs [private]
Definition at line 78 of file ParExchangeMesh.hpp.
std::vector< MPI_Request > m_recv_reqs [private]
std::vector< Range* > m_shared_entities [private]
Definition at line 74 of file ParExchangeMesh.hpp.
std::vector< unsigned int > m_shared_procs [private]
Definition at line 76 of file ParExchangeMesh.hpp.
