MeshKit
1.0
#include <ParRecvSurfMesh.hpp>
Public Member Functions | |
| ParRecvSurfMesh (MKCore *mkcore, const MEntVector &me_vec) | |
| virtual | ~ParRecvSurfMesh () |
| virtual const moab::EntityType * | mesh_types_arr () const |
| Return the mesh entity types operated on by this scheme. | |
| virtual void | setup_this () |
| Setup is a no-op, but must be provided since it's pure virtual. | |
| virtual void | execute_this () |
Static Public Member Functions | |
| static const char * | name () |
| Get class name. | |
| static bool | can_mesh (iBase_EntityType dim) |
| Function returning whether this scheme can mesh entities of t the specified dimension. | |
| static bool | can_mesh (ModelEnt *me) |
| Function returning whether this scheme can mesh the specified entity. | |
| static const moab::EntityType * | output_types () |
| Get list of mesh entity types that can be generated. | |
Private Member Functions | |
| int | get_shared_list (const int to_proc) |
Private Attributes | |
| ParallelComm * | m_mpcomm |
| unsigned int | m_rank |
| std::vector< Range * > | m_shared_entities |
| std::vector< unsigned int > | m_shared_procs |
Definition at line 12 of file ParRecvSurfMesh.hpp.
| ParRecvSurfMesh | ( | MKCore * | mkcore, |
| const MEntVector & | me_vec | ||
Definition at line 14 of file ParRecvSurfMesh.cpp.
| ~ParRecvSurfMesh | ( | ) | [virtual] |
Definition at line 25 of file ParRecvSurfMesh.cpp.
| static bool can_mesh | ( | iBase_EntityType | dim | ) | [inline, static] |
| dim | entity dimension |
Definition at line 28 of file ParRecvSurfMesh.hpp.
Used by MeshOpFactory to find scheme for an entity.
| me | ModelEnt being queried |
Definition at line 37 of file ParRecvSurfMesh.hpp.
| void execute_this | ( | ) | [virtual] |
\ The only setup/execute function we need, since meshing vertices is trivial
Implements GraphNode.
Definition at line 37 of file ParRecvSurfMesh.cpp.
| int get_shared_list | ( | const int | to_proc | ) | [private] |
Definition at line 137 of file ParRecvSurfMesh.cpp.
| virtual const moab::EntityType* mesh_types_arr | ( | ) | const [inline, virtual] |
moab::MBMAXTYPE Implements MeshOp.
Definition at line 48 of file ParRecvSurfMesh.hpp.
| static const char* name | ( | ) | [inline, static] |
Get class name.
Definition at line 21 of file ParRecvSurfMesh.hpp.
| const moab::EntityType * output_types | ( | ) | [static] |
moab::MBMAXTYPE Definition at line 11 of file ParRecvSurfMesh.cpp.
| void setup_this | ( | ) | [virtual] |
Definition at line 33 of file ParRecvSurfMesh.cpp.
ParallelComm* m_mpcomm [private] |
Definition at line 61 of file ParRecvSurfMesh.hpp.
unsigned int m_rank [private] |
Definition at line 63 of file ParRecvSurfMesh.hpp.
std::vector< Range* > m_shared_entities [private] |
Definition at line 65 of file ParRecvSurfMesh.hpp.
std::vector< unsigned int > m_shared_procs [private] |
Definition at line 67 of file ParRecvSurfMesh.hpp.
