MeshKit
1.0
00001 #ifndef MESHKIT_MKCORE_HPP 00002 #define MESHKIT_MKCORE_HPP 00003 00006 #include "meshkit/Types.hpp" 00007 #include "meshkit/Error.hpp" 00008 #include "meshkit/MKGraph.hpp" 00009 #include "meshkit/iGeom.hpp" 00010 #include "moab/Interface.hpp" 00011 #include "meshkit/iMesh.hpp" 00012 #include "meshkit/iRel.hpp" 00013 #include "lemon/list_graph.h" 00014 #include <vector> 00015 00016 namespace MeshKit { 00017 00019 class SizingFunction; 00020 00022 class VertexMesher; 00023 00025 class EBMesher; 00026 00028 class MeshOpProxy; 00029 00045 class MKCore : public MKGraph 00046 { 00047 public: 00048 00060 MKCore(iGeom *igeom = NULL, 00061 moab::Interface *moab = NULL, 00062 iMesh *imesh = NULL, 00063 iRel *irel = NULL, 00064 bool construct_missing_ifaces = true); 00065 00067 virtual ~MKCore(); 00068 00074 static void register_meshop(MeshOpProxy* proxy); 00075 00080 static MeshOpProxy* meshop_proxy(const char *op_name); 00081 00086 static MeshOpProxy* meshop_proxy(unsigned index); 00087 00092 static unsigned num_meshops(); 00093 00098 static unsigned int meshop_index(const char *op_name); 00099 00111 void set_default_meshop(const char *op_name, unsigned short dims); 00112 00120 void set_default_meshop(unsigned op_index, unsigned short dims); 00121 00129 void set_default_meshop(MeshOpProxy* mesh_op, unsigned short dims); 00130 00140 MeshOpProxy* get_default_meshop( unsigned dimension ); 00141 00146 void meshop_by_mesh_type(moab::EntityType tp, std::vector<MeshOpProxy*> &ops); 00147 00152 void meshop_by_dimension(int dim, std::vector<MeshOpProxy*> &ops); 00153 00158 void meshop_by_modelent(ModelEnt * const ent, std::vector<MeshOpProxy*> &ops); 00159 00165 MeshOp *construct_meshop(MeshOpProxy* op_info, const MEntVector &me_vec = MEntVector()); 00166 00172 MeshOp *construct_meshop(std::string op_name, const MEntVector &me_vec = MEntVector()); 00173 00183 MeshOp *construct_meshop(unsigned int dim, const MEntVector &me_vec = MEntVector()); 00184 00202 void load_geometry_mesh(const char *geom_filename, 00203 const char *mesh_filename, 00204 const char *geom_options = NULL, 00205 const char *mesh_options = NULL, 00206 int geom_index = 0, 00207 int mesh_index = 0, 00208 int irel_index = 0, 00209 bool relate_too = true, 00210 bool populate_too = true); 00211 00221 void load_geometry(const char *filename, const char *options = NULL, 00222 int geom_index = 0, 00223 int mesh_index = 0, 00224 int irel_index = 0, 00225 bool relate_too = false, 00226 bool populate_too = true); 00227 00237 void load_mesh(const char *filename, const char *options = NULL, 00238 int geom_index = 0, 00239 int mesh_index = 0, 00240 int irel_index = 0, 00241 bool relate_too = false, 00242 bool populate_too = true); 00243 00249 void save_geometry(const char *filename, const char *options = NULL, 00250 int index = 0); 00251 00257 void save_mesh(const char *filename, const char *options = NULL, 00258 int index = 0); 00259 00266 void save_mesh_from_model_ents(const char *filename, MEntVector & ments, const char *options = NULL, 00267 int index = 0); 00268 00277 void populate_model_ents(int geom_index = 0, 00278 int mesh_index = 0, 00279 int irel_index = 0, bool only_geom = false); 00280 00286 void create_mbg_model_entities(moab::EntityHandle modelRootSet, bool geometry); 00287 00300 void get_entities_by_dimension(int dim, MEntVector &model_ents, 00301 int igindx = -1); 00302 00306 void get_entities_by_handle(MEntVector &model_ents); 00307 00317 iGeom *igeom_instance(unsigned index = 0); 00318 00322 unsigned int add_igeom_instance(iGeom * igeom); 00323 00327 moab::Interface *moab_instance(unsigned index = 0); 00328 00332 iMesh *imesh_instance(unsigned index = 0); 00333 00336 iRel *irel_instance(unsigned index = 0); 00337 00341 inline unsigned int add_irel_pair(iRel::PairHandle * pair); 00342 00345 iRel::PairHandle *irel_pair(unsigned index = 0); 00346 00349 iRel::PairHandle *group_set_pair(unsigned index = 0); 00350 00353 iGeom::TagHandle igeom_model_tag(unsigned index = 0); 00354 00357 moab::Tag moab_model_tag(unsigned index = 0); 00358 00361 moab::Tag moab_geom_dim_tag(unsigned index = 0); 00362 00365 moab::Tag moab_global_id_tag(unsigned index = 0); 00366 00376 VertexMesher *vertex_mesher() const; 00377 00381 void vertex_mesher(VertexMesher *vm); 00382 00386 EBMesher *eb_mesher() const; 00387 00391 void eb_mesher(EBMesher *ebm); 00392 00405 SizingFunction *sizing_function(int index); 00406 00413 SizingFunction *sizing_function(double size, bool create_if_missing); 00414 00423 int add_sizing_function(SizingFunction *sf); 00424 00433 void remove_sizing_function(int index, bool delete_too = true); 00434 00435 #if 1 00436 00444 int initialize_mesh_based_geometry(iBase_EntitySetHandle modelSet); 00445 00452 void remove_mesh_based_geometry(int index); 00453 #endif 00454 00459 int number_of_igeom_instances() 00460 { 00461 return (int)iGeomInstances.size(); 00462 } 00469 void delete_model_entities(); 00476 void delete_all(); 00479 private: 00481 void init(bool construct_missing_ifaces); 00482 00484 void init_opsbydim(); 00485 00487 std::vector<iGeom *> iGeomInstances; 00488 00490 std::vector<moab::Interface *> moabInstances; 00491 00493 std::vector<iMesh *> iMeshInstances; 00494 00496 std::vector<iRel *> iRelInstances; 00497 00499 std::vector<iRel::PairHandle *> iRelPairs; 00500 00502 std::vector<iRel::PairHandle *> groupSetPairs; 00503 00505 std::vector<iGeom::TagHandle> iGeomModelTags; 00506 00508 std::vector<moab::Tag> moabModelTags; 00509 00511 std::vector<moab::Tag> moabGeomDimTags; 00512 00514 std::vector<moab::Tag> moabIDTags; 00515 00517 std::vector<bool> iCreatedIgeoms, iCreatedMoabs, iCreatedImeshs, iCreatedIrels; 00518 00520 MEntVector modelEnts[5]; 00521 00523 VertexMesher *vertexMesher; 00524 00526 EBMesher *ebMesher; 00527 00529 MeshOpProxy* defaultMeshOps[4]; 00530 00532 std::vector<SizingFunction*> sizingFunctions; 00533 }; 00534 00535 inline iGeom *MKCore::igeom_instance(unsigned index) 00536 { 00537 if (iGeomInstances.size() <= index) 00538 throw Error(MK_BAD_INPUT, "No instance of that index."); 00539 00540 return iGeomInstances[index]; 00541 } 00542 00543 inline moab::Interface *MKCore::moab_instance(unsigned index) 00544 { 00545 if (moabInstances.size() <= index) 00546 throw Error(MK_BAD_INPUT, "No instance of that index."); 00547 00548 return moabInstances[index]; 00549 } 00550 00551 inline iMesh *MKCore::imesh_instance(unsigned index) 00552 { 00553 if (iMeshInstances.size() <= index) 00554 throw Error(MK_BAD_INPUT, "No instance of that index."); 00555 00556 return iMeshInstances[index]; 00557 } 00558 00559 inline iRel *MKCore::irel_instance(unsigned index) 00560 { 00561 if (iRelInstances.size() <= index) 00562 throw Error(MK_BAD_INPUT, "No instance of that index."); 00563 00564 return iRelInstances[index]; 00565 } 00566 00567 inline iRel::PairHandle *MKCore::irel_pair(unsigned index) 00568 { 00569 if (iRelPairs.size() <= index) 00570 throw Error(MK_BAD_INPUT, "No pair of that index."); 00571 00572 return iRelPairs[index]; 00573 } 00574 00575 inline unsigned int MKCore::add_irel_pair(iRel::PairHandle * pair) 00576 { 00577 iRelPairs.push_back(pair); 00578 return iRelPairs.size()-1; 00579 } 00580 00581 inline iRel::PairHandle *MKCore::group_set_pair(unsigned index) 00582 { 00583 if (groupSetPairs.size() <= index) 00584 throw Error(MK_BAD_INPUT, "No pair of that index."); 00585 00586 return groupSetPairs[index]; 00587 } 00588 00589 inline iGeom::TagHandle MKCore::igeom_model_tag(unsigned index) 00590 { 00591 if (iGeomModelTags.size() <= index) 00592 throw Error(MK_BAD_INPUT, "No tag of that index."); 00593 00594 return iGeomModelTags[index]; 00595 } 00596 00597 inline moab::Tag MKCore::moab_model_tag(unsigned index) 00598 { 00599 if (moabModelTags.size() <= index) 00600 throw Error(MK_BAD_INPUT, "No tag of that index."); 00601 00602 return moabModelTags[index]; 00603 } 00604 00605 inline moab::Tag MKCore::moab_geom_dim_tag(unsigned index) 00606 { 00607 if (moabGeomDimTags.size() <= index) 00608 throw Error(MK_BAD_INPUT, "No tag of that index."); 00609 00610 return moabGeomDimTags[index]; 00611 } 00612 00613 inline moab::Tag MKCore::moab_global_id_tag(unsigned index) 00614 { 00615 if (moabIDTags.size() <= index) 00616 throw Error(MK_BAD_INPUT, "No tag of that index."); 00617 00618 return moabIDTags[index]; 00619 } 00620 00621 inline void MKCore::vertex_mesher(VertexMesher *vm) 00622 { 00623 vertexMesher = vm; 00624 } 00625 00626 inline VertexMesher *MKCore::vertex_mesher() const 00627 { 00628 return vertexMesher; 00629 } 00630 00631 inline EBMesher *MKCore::eb_mesher() const 00632 { 00633 return ebMesher; 00634 } 00635 00636 inline void MKCore::eb_mesher(EBMesher *ebm) 00637 { 00638 ebMesher = ebm; 00639 } 00640 00641 inline SizingFunction *MKCore::sizing_function(int index) 00642 { 00643 // don't check for NULL here 'cuz sometimes we just want to know there isn't one 00644 // with that index 00645 if (index >= (int)sizingFunctions.size()) 00646 throw Error(MK_BAD_INPUT, "Sizing function index outside range of valid indices."); 00647 else if (index == -1) 00648 return NULL; 00649 00650 return sizingFunctions[index]; 00651 } 00652 00653 } // namespace MeshKit 00654 00655 #endif 00656 00657
