MeshKit
1.0
The EBMesh tool can generate Cartesian meshes for solvers that use embedded boundary algorithms.
It uses a ray-tracing technique based on hierarchical oriented bounding boxes in MOAB.
Reads in an input geometry file from data directory (sphere),
Exports a mesh file with CutCell data.
#include "meshkit/MKCore.hpp" #include "meshkit/MeshOp.hpp" #include "meshkit/EBMesher.hpp" #include "meshkit/SCDMesh.hpp" #include "meshkit/ModelEnt.hpp" //#include "CGMApp.hpp" using namespace MeshKit; #ifdef HAVE_ACIS #define DEFAULT_TEST_FILE "sphere.sat" #elif defined(HAVE_OCC) #define DEFAULT_TEST_FILE "sphere.stp" #endif const bool debug_EBMesher = false; int load_and_mesh(const char *input_filename, const char *output_filename, int whole_geom, int* n_intervals, int mesh_based_geom, double box_increase, int vol_frac_res); int main(int argc, char **argv) { // check command line arg std::string input_filename; const char *output_filename = NULL; int whole_geom = 1; int n_interval[3] = {10, 10, 10}; int mesh_based_geom = 0; double box_increase = .03; int vol_frac_res = 0; if (argc > 2 && argc < 11) { input_filename += argv[1]; if (argc > 2) whole_geom = atoi(argv[2]); if (argc > 3) n_interval[0] = atoi(argv[3]); if (argc > 4) n_interval[1] = atoi(argv[4]); if (argc > 5) n_interval[2] = atoi(argv[5]); if (argc > 6) mesh_based_geom = atoi(argv[6]); if (argc > 7) output_filename = argv[7]; if (argc > 8) box_increase = atof(argv[8]); if (argc > 9) vol_frac_res = atoi(argv[9]); } else { std::cout << "Usage: " << argv[0] << "<input_geom_filename> <whole_geom> {x: # of intervals} {y: # of intervals} {z: # of intervals} {mesh_based_geom} {output_mesh_filename} {box_size_increase} {vol_frac_res}" << std::endl; std::cout << "<input_geom_filename> : input geometry file name" << std::endl; std::cout << "<whole_geom> : make mesh for whole geom or individually(1/0), default whole geom(1)" << std::endl; std::cout << "{x/y/z: # ofintervals} : optional argument. # of intervals. if it is not set, set to 10." << std::endl; std::cout << "<mesh_based_geom> : use mesh based geometry(1/0), default not-use(0)" << std::endl; std::cout << "{output_mesh_filename} : optional argument. if it is not set, dosn't export. can output mesh file (e.g. output.vtk.)" << std::endl; std::cout << "{box size increase} : optional argument. Cartesian mesh box increase form geometry. default 0.03" << std::endl; std::cout << "{vol_frac_res} : optional argument, volume fraction resolution of boundary cells for each material, you can specify it as # of divisions (e.g. 4)." << std::endl; std::cout << std::endl; if (argc != 1) return 1; std::cout << "No file specified. Defaulting to: " << DEFAULT_TEST_FILE << std::endl; std::string file_name = std::string(MESH_DIR) + "/" + DEFAULT_TEST_FILE; input_filename += std::string(MESH_DIR); input_filename += "/"; input_filename += DEFAULT_TEST_FILE; } if (load_and_mesh(input_filename.c_str(), output_filename, whole_geom, n_interval, mesh_based_geom, box_increase, vol_frac_res)) return 1; return 0; } int load_and_mesh(const char *input_filename, const char *output_filename, int whole_geom, int* n_interval, int mesh_based_geom, double box_increase, int vol_frac_res) { bool result; time_t start_time, load_time, mesh_time, vol_frac_time, export_time, query_time_techX, query_time; // start up MK and load the geometry MKCore mk; time(&start_time); mk.load_mesh(input_filename, NULL, 0, 0, 0, true); time(&load_time); if (debug_EBMesher) { mk.save_mesh("input.vtk"); } // get the volumes MEntVector vols; mk.get_entities_by_dimension(3, vols); // make EBMesher EBMesher *ebm = (EBMesher*) mk.construct_meshop("EBMesher", vols); ebm->use_whole_geom(whole_geom); ebm->use_mesh_geometry(mesh_based_geom); ebm->set_num_interval(n_interval); ebm->increase_box(box_increase); if (mesh_based_geom) ebm->set_obb_tree_box_dimension(); // mesh embedded boundary mesh, by calling execute mk.setup_and_execute(); time(&mesh_time); // caculate volume fraction, only for geometry input if (vol_frac_res > 0) { result = ebm->get_volume_fraction(vol_frac_res); if (!result) { std::cerr << "Couldn't get volume fraction." << std::endl; return 1; } } time(&vol_frac_time); // export mesh if (output_filename != NULL) { ebm->export_mesh(output_filename); } time(&export_time); if (whole_geom && debug_EBMesher) { // techX query function test double boxMin[3], boxMax[3]; int nDiv[3]; std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan > mdCutCellSurfEdge; std::vector<int> vnInsideCellTechX; ebm->get_grid_and_edges_techX(boxMin, boxMax, nDiv, mdCutCellSurfEdge, vnInsideCellTechX); time(&query_time_techX); // multiple intersection EBMesh_cpp_fraction query test std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan > mdCutCellEdge; std::vector<int> vnInsideCell; result = ebm->get_grid_and_edges(boxMin, boxMax, nDiv, mdCutCellEdge, vnInsideCell); if (!result) { std::cerr << "Couldn't get mesh information." << std::endl; return 1; } time(&query_time); std::cout << "# of TechX cut-cell surfaces: " << mdCutCellSurfEdge.size() << ", # of nInsideCell: " << vnInsideCell.size()/3 << std::endl; } std::cout << "EBMesh is succesfully finished." << std::endl; std::cout << "Time including loading: " << difftime(mesh_time, start_time) << " secs, Time excluding loading: " << difftime(mesh_time, load_time) << " secs, Time volume fraction: " << difftime(vol_frac_time, mesh_time) << " secs"; if (output_filename != NULL) { std::cout << ", Time export mesh: " << difftime(export_time, vol_frac_time) << " secs"; } if (whole_geom && debug_EBMesher) { std::cout << ", TechX query time: " << difftime(query_time_techX, export_time) << " secs, multiple intersection EBMesh_cpp_fraction query (elems, edge-cut fractions): " << difftime(query_time, query_time_techX) << " secs."; } std::cout << std::endl; mk.clear_graph(); return 0; }
