MeshKit
1.0
00001 #include "meshkit/Mesh.hpp" 00002 00003 using namespace Jaal; 00004 00006 00007 void MeshImporter ::readTriNodes( const string &fname) 00008 { 00009 string filename = fname + ".node"; 00010 00011 ifstream infile( filename.c_str(), ios::in); 00012 if( infile.fail() ) { 00013 cout << "Warning: cann't open node file " << filename << endl; 00014 return; 00015 } 00016 00017 cout << "Reading node file " << filename << endl; 00018 00019 int id, numnodes, ndim, numattrib, boundflag, bmark; 00020 00021 infile >> numnodes >> ndim >> numattrib >> boundflag; 00022 00023 assert( ndim == 2 ); 00024 assert( numattrib == 0); 00025 00026 mesh->reserve(numnodes, 0); 00027 00028 double x, y, z = 0.0; 00029 Point3D xyz; 00030 for( int i = 0; i < numnodes; i++) { 00031 infile >> id >> x >> y ; 00032 if( ndim == 3) infile >> z; 00033 if( boundflag ) infile >> bmark; 00034 global2local[id] = i; 00035 xyz[0] = x; 00036 xyz[1] = y; 00037 xyz[2] = z; 00038 Vertex *v = Vertex::newObject(); 00039 v->setID(i); 00040 v->setXYZCoords(xyz); 00041 mesh->addNode( v ); 00042 } 00043 } 00045 void MeshImporter::readTriEdges( const string &fname) 00046 { 00047 /* 00048 string filename = fname + ".edge"; 00049 ifstream infile( filename.c_str(), ios::in); 00050 if( infile.fail() ) { 00051 cout << "Warning: cann't open node file " << filename << endl; 00052 return; 00053 } 00054 00055 cout << "Reading edge file " << filename << endl; 00056 00057 int id, numedges, boundflag; 00058 int n0, n1; 00059 00060 infile >> numedges >> boundflag; 00061 edges.resize( numedges ); 00062 00063 for( int i = 0; i < numedges; i++) { 00064 infile >> id >> n0 >> n1; 00065 if( boundflag ) infile >> edges[i].gid; 00066 n0 = global2local[n0]; 00067 n1 = global2local[n1]; 00068 edges[i].connect[0] = n0; 00069 edges[i].connect[1] = n1; 00070 } 00071 */ 00072 } 00073 00075 00076 void MeshImporter ::readTriFaces( const string &fname) 00077 { 00078 string filename = fname + ".ele"; 00079 ifstream infile( filename.c_str(), ios::in); 00080 if( infile.fail() ) { 00081 cout << "Warning: cann't open node file " << filename << endl; 00082 return; 00083 } 00084 00085 int id, numfaces, numelemnodes, boundflag, bmark; 00086 int n0, n1, n2, n3, facetype; 00087 (void) facetype; 00088 00089 infile >> numfaces >> numelemnodes >> boundflag; 00090 00091 mesh->reserve( numfaces, 2); 00092 00093 vector<PNode> connect(3); 00094 Face *newface; 00095 00096 if( numelemnodes == 3 ) { 00097 facetype = 3; 00098 connect.resize(3); 00099 for( int i = 0; i < numfaces; i++) { 00100 infile >> id >> n0 >> n1 >> n2; 00101 if( boundflag ) infile >> bmark; 00102 n0 = global2local[n0]; 00103 n1 = global2local[n1]; 00104 n2 = global2local[n2]; 00105 00106 connect[0] = mesh->getNodeAt(n0); 00107 connect[1] = mesh->getNodeAt(n1); 00108 connect[2] = mesh->getNodeAt(n2); 00109 newface = new Face; 00110 newface->setNodes(connect); 00111 mesh->addFace( newface ); 00112 } 00113 } 00114 00115 if( numelemnodes == 4 ) { 00116 facetype = 4; 00117 connect.resize(4); 00118 for( int i = 0; i < numfaces; i++) { 00119 infile >> id >> n0 >> n1 >> n2 >> n3; 00120 if( boundflag ) infile >> bmark; 00121 n0 = global2local[n0]; 00122 n1 = global2local[n1]; 00123 n2 = global2local[n2]; 00124 n3 = global2local[n3]; 00125 connect[0] = mesh->getNodeAt(n0); 00126 connect[1] = mesh->getNodeAt(n1); 00127 connect[2] = mesh->getNodeAt(n2); 00128 connect[3] = mesh->getNodeAt(n3); 00129 newface = new Face; 00130 newface->setNodes(connect); 00131 mesh->addFace( newface ); 00132 } 00133 } 00134 00135 } 00136 00138 int MeshImporter ::triangle_file( const string &fname) 00139 { 00140 readTriNodes( fname ); 00141 readTriEdges( fname ); 00142 readTriFaces( fname ); 00143 mesh->enumerate(2); 00144 global2local.clear(); 00145 return 0; 00146 } 00147
