MeshKit
1.0
00001 // IASolverBend.hpp 00002 // Interval Assignment for Meshkit 00003 // Meshkit calls this class function to find the intervals 00004 // this class calls underlying solvers 00005 // 00006 #ifndef MESHKIT_IA_IASOLVERBEND_HP 00007 #define MESHKIT_IA_IASOLVERBEND_HP 00008 00009 #include <map> 00010 00011 #include "meshkit/IASolverToolInt.hpp" 00012 #include "meshkit/IPBend.hpp" 00013 #include "meshkit/IAWeights.hpp" 00014 // #include "IPData.hpp" 00015 // #include "IABendNlp.hpp" 00016 00017 namespace MeshKit { 00018 00019 class IAData; 00020 class IASolution; 00021 class IABendNlp; 00022 class IPData; 00023 00024 class IASolverBend : public IASolverToolInt 00025 { 00026 public: 00028 IASolverBend(const IAData * ia_data_ptr, IASolution *relaxed_solution_ptr, const bool set_silent = true); 00029 00031 virtual ~IASolverBend(); 00032 00033 bool solve(); 00034 // return true if solved; false if not solved (e.g. infeasible) 00035 00036 private: 00037 // hide untrusted default methods 00039 IASolverBend(const IASolverBend&); 00040 IASolverBend& operator=(const IASolverBend&); 00042 00043 // if true, then sum-even constraints are enforced, otherwise ignored. 00044 // must remain the same during a call to solve() = ipopt as it changes the 00045 // problem size and structure. 00046 bool evenConstraintsActive; 00047 00048 // debug 00049 const bool silent; 00050 const bool debugging; 00051 00052 // top level 00053 00054 // set initial ip bends from relaxed solution 00055 void initialize_ip_bends(); 00056 00057 // update them based on fractional solutions, large deltas 00058 bool update_ip_bends(); 00059 00060 // return the weight (slope) between xbig and xlit given g 00061 double raw_weight( const double g, double xlit, double xbig); 00062 00063 // combine tilts for the same exact interval into a much larger tilt, to try to address the problem more quickly. Basically doubling the tilt rather than adding to it. 00064 void merge_tilts(IPBend::TiltVec &tilts); 00065 00066 // actually change the weight of the delta based on the tilt 00067 void tilt_weight(const IPBend::TiltVec &tilts, const int tilt_direction, const double g, const double xlit, const double xbig, const int delta_direction, double &w); 00068 00069 // call the nlp solver 00070 bool solve_nlp(); 00071 00072 void cleanup(); 00073 00074 // round solution to nearest integer 00075 // if its feasible, then replace current solution and return true 00076 bool round_solution(); 00077 00078 IABendNlp *myianlp; 00079 00080 IPBendData bendData; 00081 00082 // weight index for deltas start at delta_i_start - num_variables 00083 IAWeights weights; 00084 00085 // convert IPBends to IAWeights 00086 void add_bend_weights(unsigned int i); 00087 // void add_bend_sum_weights(unsigned int i, const double factor); 00088 00089 // utility 00090 double f_x_value( double I_i, double x_i ) const; 00091 double fpow(double f) const; 00092 double get_f_xl(int i) const; // obj function value at xl 00093 double get_f_xh(int i) const; // obj function value at xh 00094 00095 00096 }; 00097 00098 } // namespace MeshKit 00099 00100 #endif
