MeshKit
1.0
00001 // IASolverToolInt.hpp 00002 // Interval Assignment for Meshkit 00003 // common integer problem tools 00004 00005 #ifndef MESHKIT_IA_IASOLVERTOOLINT_HP 00006 #define MESHKIT_IA_IASOLVERTOOLINT_HP 00007 00008 #include "meshkit/IASolverTool.hpp" 00009 00010 namespace MeshKit { 00011 00012 class IPData; 00013 class IAWeights; 00014 00015 class IASolverToolInt : public IASolverTool 00016 { 00017 // no data or inheritance, except debugging flags 00018 public: 00020 IASolverToolInt(); 00021 IASolverToolInt(const bool debugging_set); 00022 IASolverToolInt(const IAData *ia_data, IASolution *ia_solution, bool debugging_set = false); 00023 00025 virtual ~IASolverToolInt(); 00026 00027 // member get/set 00028 IPData *ip_data() {return ipData;} 00029 void ip_data(IPData *set_data) {ipData = set_data;} 00030 virtual void set_debug(const bool debugging_set) {debuggingToolInt = debugging_set; IASolverTool::set_debug(debugging_set);} 00031 00032 // tools 00033 // round solution in place 00034 void round_solution(); 00035 00036 // standardize epsilon for determining if x is an integer solution 00037 bool solution_is_integer(const bool print_non_integer = false); 00038 00039 // measures how far above or below floor( relaxed solution ) x is, in whole integers and fractional 00040 void get_frac( double x, int &integer, double &frac) const; 00041 double get_xl( int i ) const; // floor of relaxed solution 00042 double get_xh( int i ) const; // xl + 1 00043 00044 double get_km( int i, double x ) const; // how much bigger x is than xh, or zero if less 00045 double get_kp( int i, double x ) const; // xl - x, or zero if negative 00046 void get_km( int i, double x, int &km_integer, double &km_frac ) const; // split into integer and fractional part 00047 void get_kp( int i, double x, int &kp_integer, double &kp_frac ) const; 00048 00049 // randomize the value of weights for the non-integer values 00050 // return true if any weights were changed 00051 bool randomize_weights_of_non_int(IAWeights* weights, const double rand_factor); 00052 00053 protected: 00054 00055 IPData *ipData; 00056 00057 // debugging 00058 bool debuggingToolInt; 00059 00060 }; 00061 00062 } // namespace MeshKit 00063 #endif
