MeshKit
1.0
00001 #include "meshkit/SwapEdges.hpp" 00002 #include "meshkit/QuadCleanUp.hpp" 00003 00004 using namespace Jaal; 00006 00007 int 00008 QuadEdge::commit() 00009 { 00010 if (newFaces.empty()) return 1; 00011 00012 int numfaces = newFaces.size(); 00013 int numnodes = newNodes.size(); 00014 00015 for (int i = 0; i < numfaces; i++) 00016 if (newFaces[i] == NULL) return 2; 00017 00018 if (adjFaces[0]->isRemoved() || adjFaces[1]->isRemoved()) { 00019 for (int i = 0; i < numnodes; i++) 00020 delete newNodes[i]; 00021 newNodes.clear(); 00022 00023 for (int i = 0; i < numfaces; i++) 00024 delete newFaces[i]; 00025 newFaces.clear(); 00026 return 3; 00027 } 00028 00029 Vertex *vertex; 00030 for (int i = 0; i < 4; i++) { 00031 vertex = adjFaces[0]->getNodeAt(i); 00032 if (vertex->isVisited()) return 4; 00033 00034 vertex = adjFaces[1]->getNodeAt(i); 00035 if (vertex->isVisited()) return 4; 00036 } 00037 00038 mesh->remove( adjFaces[0] ); 00039 mesh->remove( adjFaces[1] ); 00040 00041 assert(mesh); 00042 00043 for (int i = 0; i < numnodes; i++) 00044 mesh->addNode(newNodes[i]); 00045 00046 for (int i = 0; i < numfaces; i++) 00047 mesh->addFace(newFaces[i]); 00048 00049 for (int i = 0; i < 4; i++) { 00050 vertex = adjFaces[0]->getNodeAt(i); 00051 vertex->setVisitMark(1); 00052 vertex = adjFaces[1]->getNodeAt(i); 00053 vertex->setVisitMark(1); 00054 } 00055 00056 return 0; 00057 } 00058 00060 00061 bool 00062 SwapQuadEdge::is_topologically_valid_swap(int d1, int d2, int d3, int d4) 00063 { 00064 if (d1 < 4 || d2 < 4) return 0; 00065 if ((d1 > 4) && (d2 > 4) && (d3 == 3) && (d4 == 3)) return 1; 00066 if ((d1 == 5) && (d2 == 5) && (d3 == 3) && (d4 == 4)) return 1; 00067 if ((d1 == 5) && (d2 == 5) && (d3 == 4) && (d4 == 3)) return 1; 00068 if (max(d1, d2) > max(d3 + 1, d4 + 1)) return 1; 00069 return 0; 00070 } 00072 00073 int 00074 SwapQuadEdge::getPosOf(const Vertex *vertex) const 00075 { 00076 for (int i = 0; i < 6; i++) 00077 if (bound_nodes[i] == vertex) return i; 00078 00079 return -1; 00080 } 00082 00083 int 00084 SwapQuadEdge::build_boundary() 00085 { 00086 assert(mesh); 00087 00088 assert(connect[0]); 00089 assert(connect[1]); 00090 00091 adjFaces.resize(2); 00092 adjFaces[0] = NULL; 00093 adjFaces[1] = NULL; 00094 00095 assert(mesh->getAdjTable(0, 2)); 00096 00097 // Since the degree of each node of an existing edge decreases by 00098 // one, by restricting the swapping to degree greater than 3 will 00099 // ensure that no doublet is created. 00100 // 00101 int nsize1 = connect[0]->getNumRelations(2); 00102 00103 if (connect[0]->isBoundary()) { 00104 if (nsize1 < 3) return 1; 00105 } else { 00106 if (nsize1 < 4) return 1; 00107 } 00108 00109 int nsize2 = connect[1]->getNumRelations(2); 00110 00111 if (connect[1]->isBoundary()) { 00112 if (nsize2 < 3) return 1; 00113 } else { 00114 if (nsize2 < 4) return 1; 00115 } 00116 00117 // Possibility of doublet creation is ruled out now.. 00118 FaceSequence nghs; 00119 Mesh::getRelations112(connect[0], connect[1], nghs); 00120 00121 if (nghs.size() != 2) return 1; 00122 00123 if (firstFace == NULL) { 00124 adjFaces[0] = nghs[0]; 00125 adjFaces[1] = nghs[1]; 00126 } 00127 00128 if (nghs[0] == firstFace) { 00129 adjFaces[0] = nghs[0]; 00130 adjFaces[1] = nghs[1]; 00131 } 00132 00133 if (nghs[1] == firstFace) { 00134 adjFaces[0] = nghs[1]; 00135 adjFaces[1] = nghs[0]; 00136 } 00137 00138 int err = get_boundary_nodes_chain(); 00139 00140 if (err) return 2; 00141 00142 return 0; 00143 } 00144 00146 00147 int 00148 SwapQuadEdge::get_boundary_nodes_chain() 00149 { 00150 vector<Edge> bndedges; 00151 bndedges.reserve(6); 00152 00153 Edge sharededge(connect[0], connect[1]); 00154 for (int i = 0; i < 2; i++) { 00155 for (int j = 0; j < 4; j++) { 00156 Vertex *vf0 = adjFaces[i]->getNodeAt(j + 0); 00157 Vertex *vf1 = adjFaces[i]->getNodeAt(j + 1); 00158 Edge edge(vf0, vf1); 00159 if (!edge.isSameAs(sharededge)) 00160 bndedges.push_back(edge); 00161 } 00162 } 00163 00164 Mesh::make_chain(bndedges); 00165 Mesh::rotate_chain(bndedges, connect[0]); 00166 bound_nodes = Mesh::chain_nodes(bndedges); 00167 assert(bound_nodes.size() == 6); 00168 return 0; 00169 } 00170 00172 00173 void SwapQuadEdge::update_front() 00174 { 00175 cout << "Update front : " << endl; 00176 exit(0); 00177 00178 /* 00179 size_t nSize; 00180 if (check_fronts) { 00181 NodeSequence vneighs; 00182 while (1) { 00183 int values_updated = 0; 00184 for (int i = 0; i < 6; i++) { 00185 bound_nodes[i]->getRelations( vneighs ); 00186 int minid = bound_nodes[i]->getLayerID(); 00187 nSize = vneighs.size(); 00188 for (size_t j = 0; j < nSize; j++) 00189 minid = min(minid, vneighs[j]->getLayerID() + 1); 00190 00191 if (bound_nodes[i]->getLayerID() != minid) { 00192 bound_nodes[i]->setLayerID(minid); 00193 values_updated = 1; 00194 } 00195 } 00196 if (!values_updated) break; 00197 } 00198 } 00199 */ 00200 } 00201 00203 00204 void 00205 SwapQuadEdge::backup() 00206 { 00207 bkp_data.diagonalConnect[0] = connect[0]; 00208 bkp_data.diagonalConnect[1] = connect[1]; 00209 bkp_data.face1Connect = adjFaces[0]->getNodes(); 00210 bkp_data.face2Connect = adjFaces[1]->getNodes(); 00211 for (int i = 0; i < 6; i++) { 00212 Vertex *v = bound_nodes[i]; 00213 bkp_data.pCoords[v] = v->getXYZCoords(); 00214 } 00215 } 00217 00218 void 00219 SwapQuadEdge::rollback() 00220 { 00221 // We need to manual delete the relation 00222 connect[0]->removeRelation(connect[1]); 00223 connect[1]->removeRelation(connect[0]); 00224 00225 // remove all relations by deactivating the elements ... 00226 mesh->deactivate(adjFaces[0]); 00227 mesh->deactivate(adjFaces[1]); 00228 00229 // Change the connectivity of the two quads and reactivate the element... 00230 adjFaces[0]->setNodes(bkp_data.face1Connect); 00231 adjFaces[1]->setNodes(bkp_data.face2Connect); 00232 00233 mesh->reactivate(adjFaces[0]); 00234 mesh->reactivate(adjFaces[1]); 00235 00236 connect[0] = bkp_data.diagonalConnect[0]; 00237 connect[1] = bkp_data.diagonalConnect[1]; 00238 00239 for (int i = 0; i < 6; i++) { 00240 Vertex *v = bound_nodes[i]; 00241 v->setXYZCoords(bkp_data.pCoords[v]); 00242 } 00243 00244 assert(!adjFaces[0]->isRemoved()); 00245 assert(!adjFaces[1]->isRemoved()); 00246 00247 // update_front(); 00248 } 00250 00251 int 00252 SwapQuadEdge::make_new_diagonal_at(int pos, bool bound_check) 00253 { 00254 // 00255 // Given closednodes ( exactly six nodes) in an order ( clockwise or 00256 // counter-clockwise) and create two quads having common diagonal between 00257 // (pos, pos+3). 00258 // 00259 assert(pos >= 0 && pos < 6); 00260 00261 if (bound_check) { 00262 if (bound_nodes[(pos + 0) % 6]->isBoundary()) return 1; 00263 if (bound_nodes[(pos + 3) % 6]->isBoundary()) return 1; 00264 } 00265 00266 // First perform full backup of the data structures. 00267 backup(); 00268 00269 // Remove the vertex-vertex relationship. 00270 connect[0]->removeRelation(connect[1]); 00271 connect[1]->removeRelation(connect[0]); 00272 00273 mesh->deactivate(adjFaces[0]); 00274 mesh->deactivate(adjFaces[1]); 00275 00276 // Change the connectivity of the two quads. 00277 NodeSequence qConnect(4); 00278 qConnect[0] = bound_nodes[(pos + 0) % 6]; 00279 qConnect[1] = bound_nodes[(pos + 1) % 6]; 00280 qConnect[2] = bound_nodes[(pos + 2) % 6]; 00281 qConnect[3] = bound_nodes[(pos + 3) % 6]; 00282 connect[0] = qConnect[0]; 00283 adjFaces[0]->setNodes(qConnect); 00284 mesh->reactivate(adjFaces[0]); 00285 00286 qConnect[0] = bound_nodes[(pos + 3) % 6]; 00287 qConnect[1] = bound_nodes[(pos + 4) % 6]; 00288 qConnect[2] = bound_nodes[(pos + 5) % 6]; 00289 qConnect[3] = bound_nodes[(pos + 6) % 6]; 00290 connect[1] = qConnect[0]; 00291 adjFaces[1]->setNodes(qConnect); 00292 mesh->reactivate(adjFaces[1]); 00293 00294 assert(!adjFaces[0]->isRemoved()); 00295 assert(!adjFaces[1]->isRemoved()); 00296 00297 int con1 = adjFaces[0]->concaveAt(); 00298 int con2 = adjFaces[1]->concaveAt(); 00299 // int con1 = adjFaces[0]->isSimple(); 00300 // int con2 = adjFaces[1]->isSimple(); 00301 // if( con1 && con2 ) return 0; 00302 00303 if( con1 >= 0 || con2 >=0) { 00304 rollback(); 00305 return 1; 00306 } 00307 return 0; 00308 00309 // The change may produce concave or tangled mesh. Do some local 00310 // Laplacian smoothing at the six nodes only. Hopefully, the elements 00311 // will be acceptable. If not, we need to rollback this operation. 00312 00313 LaplaceLengthWeight lw; 00314 LaplaceSmoothing lapsmooth(mesh); 00315 lapsmooth.setWeight(&lw); 00316 lapsmooth.setNumIterations(10); 00317 lapsmooth.localized_at(bound_nodes); 00318 00319 // Look at the neighbors, if some elements is inverted. Here we create 00320 // a set of neighbours, to avoid duplicate checking. 00321 FaceSet neighSet; 00322 FaceSequence vfaces; 00323 for (int i = 0; i < 6; i++) { 00324 Vertex *v = bound_nodes[i]; 00325 v->getRelations( vfaces ); 00326 size_t nSize = vfaces.size(); 00327 for (size_t j = 0; j < nSize; j++) 00328 neighSet.insert(vfaces[j]); 00329 } 00330 assert(!neighSet.empty()); 00331 00332 FaceSet::const_iterator it; 00333 for (it = neighSet.begin(); it != neighSet.end(); ++it) { 00334 Face *face = *it; 00335 int pos = face->concaveAt(); 00336 if (pos >= 0) { 00337 Vertex *v = face->getNodeAt(pos); 00338 if (!v->isBoundary()) { 00339 rollback(); 00340 return 1; 00341 } 00342 } 00343 } 00344 update_front(); 00345 00346 return 0; 00347 } 00348 00350 00351 int 00352 SwapQuadEdge::apply_reduce_degree_rule() 00353 { 00354 if (build_boundary() != 0) return 1; 00355 00356 NodeSequence neighs; 00357 00358 connect[0]->getRelations( neighs ); 00359 int d1 = neighs.size(); 00360 if (d1 < 4) return 1; 00361 00362 connect[1]->getRelations( neighs ); 00363 int d2 = neighs.size(); 00364 if (d2 < 4) return 1; 00365 00366 int start_pos = getPosOf(connect[0]); 00367 assert(start_pos >= 0); 00368 00369 for (int i = 0; i < 2; i++) { 00370 int pos = (start_pos + i + 1) % 6; 00371 Vertex *v0 = bound_nodes[ pos ]; 00372 if (v0->isBoundary()) continue; 00373 v0->getRelations( neighs ); 00374 int d3 = neighs.size(); 00375 00376 Vertex *v3 = bound_nodes[(pos + 3) % 6]; 00377 if (v3->isBoundary()) continue; 00378 v3->getRelations( neighs ); 00379 int d4 = neighs.size(); 00380 00381 if (SwapQuadEdge::is_topologically_valid_swap(d1, d2, d3, d4)) { 00382 int err = make_new_diagonal_at(pos); 00383 if (!err) return 0; 00384 } 00385 } 00386 return 1; 00387 } 00388 00390 00391 int 00392 SwapQuadEdge::apply_concave_rule() 00393 { 00394 if (build_boundary() != 0) return 1; 00395 00396 int start_pos = getPosOf(connect[0]); 00397 for (int i = 0; i < 2; i++) { 00398 int err = make_new_diagonal_at((start_pos + 1 + i) % 6); 00399 if (!err) return 0; 00400 } 00401 return 1; 00402 } 00403 00405 00406 int 00407 SwapQuadEdge::apply_bound_rule() 00408 { 00409 if (!connect[0]->isBoundary()) return 1; 00410 if (connect[1]->isBoundary()) return 1; 00411 00412 if (build_boundary() != 0) return 2; 00413 00414 for (int i = 0; i < 3; i++) { 00415 Vertex *v0 = bound_nodes[(i + 0) % 6]; 00416 Vertex *v3 = bound_nodes[(i + 3) % 6]; 00417 if ((!v0->isBoundary()) && (!v3->isBoundary())) { 00418 int err = make_new_diagonal_at(i, 0); 00419 if (!err) return 0; 00420 } 00421 } 00422 00423 return 3; 00424 } 00425 00427 00428 int 00429 SwapQuadEdge::apply_advance_front_rule() 00430 { 00431 if (build_boundary() != 0) return 1; 00432 00433 /* 00434 int layerid = connect[0]->getLayerID(); 00435 for (int i = 0; i < 3; i++) { 00436 Vertex *v0 = bound_nodes[(i + 0) % 6]; 00437 Vertex *v3 = bound_nodes[(i + 3) % 6]; 00438 if ((v0->getLayerID() > layerid) && (v3->getLayerID() > layerid)) { 00439 int err = make_new_diagonal_at(i); 00440 if (!err) return 0; 00441 } 00442 } 00443 */ 00444 return 3; 00445 } 00446 00448 00449 int 00450 SwapQuadEdge::apply_singlet_rule(Vertex *singlet) 00451 { 00452 // The first node must be boundary and the other node must be internal.. 00453 assert(connect[0]->isBoundary()); 00454 00455 if (connect[1]->isBoundary()) return 1; 00456 00457 if (build_boundary() != 0) return 1; 00459 // Objective :: Swap quads common diagonal such that the resulting diagonal 00460 // contains the Singlet node. 00462 assert(QuadCleanUp::isSinglet(singlet)); 00463 00464 if (adjFaces[0] == NULL || adjFaces[1] == NULL) return 2; 00465 00466 assert(QuadCleanUp::hasSinglet(adjFaces[0])); 00467 00468 // Make sure that other face doesn't have a singlet 00469 if (QuadCleanUp::hasSinglet(adjFaces[1])) return 3; 00470 00471 //Find the position of singlet in the contour ... 00472 int pos = this->getPosOf(singlet); 00473 assert(pos >= 0); 00474 00475 // Create new quads whose common diagonal must contain the singlet. 00476 return make_new_diagonal_at(pos, 0); 00477 } 00478 00480 00481 int 00482 SwapQuadEdge::apply_deficient_rule(Vertex *vertex) 00483 { 00484 00485 #ifdef NEEDS_RECONSIDER 00486 assert(firstFace); 00487 if (vertex->isBoundary()) return 1; 00488 00489 00490 int d1 = connect[0]->getNumRelations( 2 ); 00491 int d2 = connect[1]->getNumRelations( 2 ); 00492 00493 // Note 1: Just near the deficient node, there must be atleast 5 nodes in 00494 // order to swap the edge,otherwise, things may not converge, on the 00495 // same level, the deficient node will keep changing the location. 00496 // 00497 // Note 2: The node connect[1] is opposite to the deficient node and 00498 // most probably on the next level. If we keep moving the deficient 00499 // node inside the domain, then it is fine to have its degree to 4, so 00500 // that the deficient node will be generated there. 00501 if( d2 < 4 ) return 1; 00502 00503 FaceSequence faces; 00504 if (d1 == 4) { 00505 vertex->getRelations( faces ); 00506 if (faces.size() != 3) return 1; 00507 int layerid = connect[0]->getLayerID(); 00508 Face *f0 = firstFace; 00509 Mesh::getRelations112(connect[0], connect[1], faces); 00510 assert(faces.size() == 2); 00511 Face *f1 = NULL; 00512 if (faces[0] == f0) f1 = faces[1]; 00513 if (faces[1] == f0) f1 = faces[0]; 00514 assert(f1); 00515 00516 00517 int pos = f1->getPosOf(connect[0]); 00518 Vertex *vopp = f1->getNodeAt(pos + 2); 00519 if (connect[1]->getLayerID() > layerid && vopp->getLayerID() > layerid) { 00520 set_no_tags(mesh); 00521 connect[1]->setTag(1); 00522 vopp->setTag(1); 00523 mesh->saveAs("dbg.dat"); 00524 Break(); 00525 SwapQuadEdge edge(mesh, connect[1], vopp, f1); 00526 int err = edge.apply_deficient_rule(connect[0]); 00527 if (err) return 1; 00528 } 00529 } 00530 exit(0); 00531 00532 d1 = connect[0]->getNumRelations(2); 00533 d2 = connect[1]->getNumRelations(2); 00534 00535 // Don't create doublet at two nodes... 00536 if( d1 == 3 || d2 == 3 ) return 1; 00537 00538 // Having these conditions set, now build the structure. 00539 if (build_boundary() != 0) return 3; 00540 00541 update_front(); 00542 00543 //Find the position of triplet in the contour ... 00544 int pos = this->getPosOf(vertex); 00545 assert(pos == 1 || pos == 5); 00546 00547 if (check_fronts) { 00548 int layerid = vertex->getLayerID(); 00549 if (bound_nodes[ (pos + 3) % 6]->getLayerID() <= layerid) return 1; 00550 00551 if( connect[0]->getLayerID() <= layerid && d1 < 5 ) return 1; 00552 if( connect[1]->getLayerID() <= layerid && d2 < 5 ) return 1; 00553 } 00554 00555 // Create new quads whose common diagonal must contain the singlet. 00556 int err = make_new_diagonal_at(pos); 00557 00558 /* 00559 if( err ) { 00560 for (int i = 0; i < 6; i++) { 00561 NodeSequence vneighs = bound_nodes[i]->getRelations0(); 00562 int minid = bound_nodes[i]->getLayerID(); 00563 for( int j = 0; j < vneighs.size(); j++) 00564 minid = min( minid, vneighs[j]->getLayerID() ); 00565 assert( bound_nodes[i]->getLayerID() == minid+1); 00566 } 00567 } 00568 */ 00569 00570 return err; 00571 #endif 00572 return 1; 00573 00574 } 00575 00577 00578 int 00579 QuadCleanUp::swap_concave_faces() 00580 { 00581 int relexist0 = mesh->build_relations(0, 0); 00582 int relexist2 = mesh->build_relations(0, 2); 00583 00584 mesh->search_boundary(); 00585 00586 size_t numfaces = mesh->getSize(2); 00587 for (size_t i = 0; i < numfaces; i++) { 00588 Face *face = mesh->getFaceAt(i); 00589 face->setVisitMark(0); 00590 } 00591 00592 size_t numnodes = mesh->getSize(0); 00593 for (size_t i = 0; i < numnodes; i++) { 00594 Vertex *vertex = mesh->getNodeAt(i); 00595 vertex->setVisitMark(0); 00596 } 00597 00598 size_t ncount = 0; 00599 for (size_t iface = 0; iface < numfaces; iface++) { 00600 Face *face = mesh->getFaceAt(iface); 00601 int pos = face->concaveAt(); 00602 if (pos >= 0) { 00603 for (int i = 0; i < 2; i++) { 00604 Vertex *v0 = face->getNodeAt(pos + 1 + i); 00605 Vertex *v1 = face->getNodeAt(pos + 2 + i); 00606 SwapQuadEdge edge(mesh, v0, v1); 00607 int err = edge.apply_concave_rule(); 00608 if (!err) { 00609 ncount++; 00610 break; 00611 } 00612 } 00613 } 00614 } 00615 00616 if (ncount) { 00617 mesh->prune(); 00618 mesh->enumerate(0); 00619 mesh->enumerate(2); 00620 cout << "Info: # of swapped edges " << ncount << endl; 00621 } 00622 00623 if (!relexist0) mesh->clear_relations(0, 0); 00624 if (!relexist2) mesh->clear_relations(0, 2); 00625 00626 return ncount; 00627 } 00628 00630
