MeshKit
1.0
00001 00006 #include "meshkit/Mesh.hpp" 00007 #include "meshkit/MeshRefine2D.hpp" 00008 #include "meshkit/QuadCleanUp.hpp" 00009 #include <unistd.h> 00010 #include "meshkit/DijkstraShortestPath.hpp" 00011 #include "meshkit/ObjectPool.hpp" 00012 00013 #include "TestUtil.hpp" 00014 #define DEFAULT_TEST_FILE "quadclean.vtk" 00015 00016 extern int QuadPatches(Jaal::Mesh *mesh); 00017 void run(); 00018 00019 using namespace Jaal; 00020 00021 void usage() 00022 { 00023 cout << "Usage: Executable -i in_meshfile -o out_meshfile -c cleanOp " << endl; 00024 00025 cout << " *****************************************************************" << endl; 00026 cout << " Option : Mesh Cleanup Operation " << endl; 00027 cout << " *****************************************************************" << endl; 00028 cout << " 0 : Report Mesh Quality " << endl; 00029 cout << " 1 : Remove interior doublets " << endl; 00030 cout << " 2 : Remove boundary singlets " << endl; 00031 cout << " 3 : Remove diamonds " << endl; 00032 cout << " 4 : Vertex Degree Reduction " << endl; 00033 cout << " 5 : Laplace Smoothing (No Weight) " << endl; 00034 cout << " 6 : Laplace Smoothing (Area Weight) " << endl; 00035 cout << " 7 : Laplace Smoothing (Edge Length Weight) " << endl; 00036 cout << " 8 : Advancing front Edge Swapping " << endl; 00037 cout << " 9 : Shape Optimization " << endl; 00038 cout << " 10 : Reverse Elements Connectivity " << endl; 00039 cout << " 11 : Refine QuadMesh ( Scheme 14 ) " << endl; 00040 cout << " 12 : Refine QuadMesh ( Scheme 15 ) " << endl; 00041 cout << " 13 : Swap Concave Faces " << endl; 00042 cout << " 14 : Refine Degree 3 Faces " << endl; 00043 cout << " 15 : Search Structured Submesh " << endl; 00044 cout << " 16 : Regularization with remeshing " << endl; 00045 cout << " 17 : Generate Quad-Irregular(Motorcycle) Graph " << endl; 00046 cout << " 18 : Generate Quad-to-Tri4 " << endl; 00047 cout << " 19 : Generate Quad-to-Tri2 " << endl; 00048 cout << " 20 : Shift irregular nodes inside domain " << endl; 00049 cout << " 21 : Everything automatic " << endl; 00050 } 00051 00053 string infilename, outfilename; 00054 00055 int iopt, numiters = 1000, topo_improve = 1; 00056 int cleanup_op = 0; 00057 Mesh *mesh = new Jaal::Mesh; 00058 MeshOptimization mopt; 00059 00060 int main(int argc, char **argv) 00061 { 00062 /* 00063 double origin[] = { 0.0, 0.0, 0.0}; 00064 double length[] = { 1.0, 1.0, 1.0}; 00065 int gridim[] = { 6, 7, 2}; 00066 mesh = Jaal::create_structured_mesh(origin, length, gridim, 2 ); 00067 cout << mesh->getSize(1) << endl; 00068 Face *f = mesh->getFaceAt(0); 00069 mesh->remove(f); 00070 00071 f = mesh->getFaceAt(1); 00072 mesh->remove(f); 00073 00074 cout << mesh->getSize(1) << endl; 00075 mesh->saveAs( "tmp.off"); 00076 exit(0); 00077 */ 00078 00079 // string infilename, outfilename; 00080 00081 // int iopt, numiters = 100, topo_improve = 1; 00082 // int cleanup_op = 0; 00083 00084 while( (iopt = getopt( argc, argv, "hgtc:i:o:") ) != -1) { 00085 switch(iopt) { 00086 case 'c': 00087 cleanup_op = atoi( optarg ); 00088 break; 00089 case 'h': 00090 usage(); 00091 break; 00092 case 'i': 00093 infilename = optarg; // Input QuadMesh File 00094 break; 00095 case 'o': 00096 outfilename = optarg; // Output QuadMesh File 00097 break; 00098 case 'l': 00099 numiters = atoi( optarg ); // Number of iterations for Laplacian Smoothing. 00100 break; 00101 case 't': 00102 topo_improve = atoi( optarg ); // Should we do topological Improvement: Default( Yes ); 00103 break; 00104 default: 00105 cout << "Usage: Executable t [0 1] -l #num -i in_meshfile -o out_meshfile -c cleanOp " << endl; 00106 break; 00107 } 00108 } 00109 00110 if( infilename.empty() ) { 00111 cout <<"Warning: No input file specified " << endl; 00112 usage(); 00113 cout << "Running default problem" << endl; 00114 infilename = TestDir + "/" + DEFAULT_TEST_FILE; 00115 outfilename = "out_quadcleanup.vtk"; 00116 cleanup_op = 21; 00117 run(); 00118 return 0; 00119 } 00120 00121 if( outfilename.empty() ) { 00122 cout <<"Warning: No output file specified " << endl; 00123 usage(); 00124 return 2; 00125 } 00126 run(); 00127 return 0; 00128 } 00129 00130 void run(){ 00131 mesh->readFromFile( infilename ); 00132 string orig_file = "orig.vtk"; 00133 mesh->saveAs(orig_file); 00134 size_t ninvert = mesh->count_inverted_faces(); 00135 size_t numfaces = mesh->getSize(2); 00136 size_t numBound = mesh->getBoundarySize(0); 00137 size_t nireg0 = mesh->count_irregular_nodes(4); 00138 00139 cout << "# of irregular nodes before cleanup : " << nireg0 << endl; 00140 mesh->get_topological_statistics(); 00141 00142 if( ninvert > 0.5*numfaces ) 00143 mesh->reverse(); 00144 00145 LaplaceSmoothing lapsmooth(mesh); 00146 LaplaceWeight *lapweight = NULL; 00147 00148 QuadCleanUp qClean(mesh); 00149 00150 vector<QTrack> qpath; 00151 vector<Vertex*> steiner; 00152 Mesh *q2t; 00153 // int algo, numiter; 00154 00155 StopWatch swatch; 00156 swatch.start(); 00157 00158 switch( cleanup_op) { 00159 case 0: 00160 qClean.report(); 00161 exit(0); 00162 break; 00163 case 1: 00164 qClean.remove_interior_doublets(); 00165 break; 00166 case 2: 00167 qClean.remove_boundary_singlets(); 00168 break; 00169 case 3: 00170 qClean.remove_diamonds(); 00171 break; 00172 case 4: 00173 qClean.vertex_degree_reduction(); 00174 break; 00175 case 5: 00176 lapsmooth.setMethod(0); 00177 lapweight = new LaplaceNoWeight(); 00178 lapsmooth.setWeight(lapweight); 00179 lapsmooth.setNumIterations(100); 00180 lapsmooth.execute(); 00181 break; 00182 case 6: 00183 lapsmooth.setMethod(0); 00184 lapweight = new LaplaceAreaWeight(); 00185 lapsmooth.setWeight(lapweight); 00186 lapsmooth.setNumIterations(100); 00187 lapsmooth.execute(); 00188 break; 00189 case 7: 00190 lapsmooth.setMethod(0); 00191 lapweight = new LaplaceLengthWeight(); 00192 lapsmooth.setWeight(lapweight); 00193 lapsmooth.setNumIterations(100); 00194 lapsmooth.execute(); 00195 break; 00196 case 8: 00197 // qClean.advancing_front_edges_swap(); 00198 break; 00199 case 9: 00200 /* 00201 cout << "Choose algorithm : " << endl; 00202 cout << " Steepest Descent : 0 " << endl; 00203 cout << " Quasi Newton(default) : 1 " << endl; 00204 cout << " Trust Region : 2 " << endl; 00205 cout << " Feasible Newton : 3 " << endl; 00206 cout << " Laplacian : 4 " << endl; 00207 cin >> algo; 00208 cout << "Give number of iterations " << endl; 00209 cin >> numiter; 00210 mopt.shape_optimize( mesh, algo, numiter ); 00211 */ 00212 mopt.shape_optimize( mesh ); 00213 break; 00214 case 10: 00215 mesh->reverse(); 00216 break; 00217 case 11: 00218 mesh->refine_quads14(); 00219 break; 00220 case 12: 00221 mesh->refine_quads15(); 00222 break; 00223 case 13: 00224 qClean.swap_concave_faces(); 00225 break; 00226 case 14: 00227 qClean.refine_degree3_faces(); 00228 break; 00229 case 15: 00230 mesh->search_quad_patches(); 00231 break; 00232 case 16: 00233 qClean.remesh_defective_patches(); 00234 break; 00235 case 17: 00236 qpath = Jaal::generate_quad_partitioning(mesh); 00237 // Jaal::set_irregular_path_tag(mesh, qpath); 00238 break; 00239 case 18: 00240 q2t = Jaal::quad_to_tri4( mesh, steiner); 00241 q2t->saveAs("tmesh.off"); 00242 break; 00243 case 19: 00244 q2t = Jaal::quad_to_tri2( mesh ); 00245 mopt.shape_optimize( q2t ); 00246 q2t->saveAs("tmesh.off"); 00247 break; 00248 case 20: 00249 qClean.shift_irregular_nodes(); 00250 break; 00251 case 21: 00252 qClean.automatic(); 00253 break; 00254 } 00255 swatch.stop(); 00256 cout << "CleanUp time : " << swatch.getSeconds() << endl; 00257 00258 if( cleanup_op ) { 00259 00260 cout << "# Nodes : " << mesh->getSize(0) << endl; 00261 cout << "# Faces : " << mesh->getSize(2) << endl; 00262 cout << "# Inverted Faces : " << mesh->count_inverted_faces() << endl; 00263 cout << "# Concave Faces : " << mesh->count_concave_faces() << endl; 00264 cout << "# Irregular nodes : " << mesh->count_irregular_nodes(4) << endl; 00265 // cout << "Mesh Consistency : " << mesh->is_consistently_oriented() << endl; 00266 00267 // Jaal::set_large_area_tag(mesh); 00268 // Jaal::set_boundary_tag(mesh); 00269 // Jaal::set_tiny_area_tag(mesh); 00270 00271 // Jaal::set_layer_tag(mesh); 00272 // Jaal::set_constrained_tag(mesh); 00273 // Jaal::set_doublet_tag(mesh); 00274 // Jaal::set_bridge_tag(mesh); 00275 // Jaal::set_singlet_tag(mesh); 00276 // Jaal::set_regular_node_tag(mesh); 00277 } 00278 00279 mesh->collect_garbage(); 00280 // Jaal::set_diamond_tag(mesh); 00281 00282 cout << " Saving Mesh " << outfilename << endl; 00283 mesh->saveAs( outfilename); 00284 00285 mesh->get_topological_statistics(); 00286 plot_all_quad_quality_measures( mesh ); 00287 00288 if( numBound != mesh->getBoundarySize(0) ) 00289 cout<<" error in numBound\n"; 00290 00291 // if( lapweight ) delete lapweight; 00292 00293 // if( mesh ) mesh->deleteAll(); 00294 00295 //delete mesh; 00296 } 00297
