MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2007 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2007) [email protected] 00024 00025 ***************************************************************** */ 00026 00027 /** \file main.cpp 00028 * \brief Try examples from "Formulation of a Target-Matrix Paradigm 00029 * for Mesh Optimization", Patrick Knupp. 00030 * \author Jason Kraftcheck 00031 */ 00032 00033 #define USE_GLOBAL_PATCH 00034 00035 #include "TestUtil.hpp" 00036 #include "Mesquite.hpp" 00037 00038 #include "PMeanPTemplate.hpp" 00039 #include "AffineMapMetric.hpp" 00040 #include "ConjugateGradient.hpp" 00041 #include "TerminationCriterion.hpp" 00042 #include "ElementPMeanP.hpp" 00043 #include "MsqError.hpp" 00044 #include "TSquared.hpp" 00045 #include "MeshImpl.hpp" 00046 #include "PlanarDomain.hpp" 00047 #include "InstructionQueue.hpp" 00048 #include "TargetCalculator.hpp" 00049 #include "MetricWeight.hpp" 00050 #include "InverseMetricWeight.hpp" 00051 #include "TargetWriter.hpp" 00052 #include "WeightReader.hpp" 00053 00054 #include <iostream> 00055 #include <cstdlib> 00056 00057 using namespace MBMesquite; 00058 using namespace std; 00059 00060 const double epsilon = 2e-2; 00061 const bool write_results = true; 00062 00063 #define CHKERR( A ) \ 00064 if( A ) \ 00065 { \ 00066 cerr << ( A ) << endl; \ 00067 exit( 1 ); \ 00068 } 00069 00070 enum Grouping 00071 { 00072 SAMPLE, 00073 ELEMENT, 00074 QUADRANT, 00075 HALF 00076 }; 00077 enum Weight 00078 { 00079 UNIT, 00080 METRIC, 00081 INV_METRIC 00082 }; 00083 00084 class IdentityTarget : public TargetCalculator 00085 { 00086 public: 00087 bool get_3D_target( PatchData&, size_t, Sample, MsqMatrix< 3, 3 >& W_out, MsqError& ) 00088 { 00089 W_out = MsqMatrix< 3, 3 >( 1.0 ); 00090 return true; 00091 } 00092 00093 bool get_surface_target( PatchData&, size_t, Sample, MsqMatrix< 3, 2 >& W_out, MsqError& ) 00094 { 00095 W_out = MsqMatrix< 3, 2 >( 1.0 ); 00096 return true; 00097 } 00098 00099 bool get_2D_target( PatchData&, size_t, Sample, MsqMatrix< 2, 2 >& W_out, MsqError& ) 00100 { 00101 W_out = MsqMatrix< 2, 2 >( 1.0 ); 00102 return true; 00103 } 00104 00105 bool have_surface_orient() const 00106 { 00107 return false; 00108 } 00109 }; 00110 00111 void run_test( Grouping grouping, int of_power, Weight w, const string filename ) 00112 { 00113 MsqError err; 00114 00115 IdentityTarget target; 00116 TSquared target_metric; 00117 AffineMapMetric qual_metric( &target, &target_metric ); 00118 ElementPMeanP elem_metric( of_power, &qual_metric ); 00119 QualityMetric* qm_ptr = ( grouping == ELEMENT ) ? (QualityMetric*)&elem_metric : (QualityMetric*)&qual_metric; 00120 00121 PMeanPTemplate OF( of_power, qm_ptr ); 00122 ConjugateGradient solver( &OF ); 00123 TerminationCriterion tc; 00124 TerminationCriterion itc; 00125 tc.add_absolute_vertex_movement( 1e-4 ); 00126 itc.add_iteration_limit( 2 ); 00127 #ifdef USE_GLOBAL_PATCH 00128 solver.use_global_patch(); 00129 solver.set_inner_termination_criterion( &tc ); 00130 #else 00131 solver.use_element_on_vertex_patch(); 00132 solver.set_inner_termination_criterion( &itc ); 00133 solver.set_outer_termination_criterion( &tc ); 00134 #endif 00135 00136 MeshImpl mesh, expected_mesh; 00137 std::string initfname = std::string( STRINGIFY( SRCDIR ) ) + "/2d_formulation_initial.vtk"; 00138 mesh.read_vtk( initfname.c_str(), err );CHKERR( err ) 00139 // expected_mesh.read_vtk( (filename + ".vtk").c_str(), err ); CHKERR(err) 00140 00141 PlanarDomain plane( PlanarDomain::XY ); 00142 00143 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &plane ); 00144 00145 MetricWeight mw( &qual_metric ); 00146 InverseMetricWeight imw( &qual_metric ); 00147 WeightReader reader; 00148 if( w == METRIC ) 00149 { 00150 TargetWriter writer( 0, &mw ); 00151 InstructionQueue tq; 00152 tq.add_target_calculator( &writer, err ); 00153 tq.run_instructions( &mesh_and_domain, err );CHKERR( err ); 00154 qual_metric.set_weight_calculator( &reader ); 00155 } 00156 else if( w == INV_METRIC ) 00157 { 00158 TargetWriter writer( 0, &imw ); 00159 InstructionQueue tq; 00160 tq.add_target_calculator( &writer, err ); 00161 tq.run_instructions( &mesh_and_domain, err );CHKERR( err ); 00162 qual_metric.set_weight_calculator( &reader ); 00163 } 00164 00165 InstructionQueue q; 00166 q.set_master_quality_improver( &solver, err ); 00167 q.run_instructions( &mesh_and_domain, err );CHKERR( err ) 00168 /* 00169 vector<Mesh::VertexHandle> vemain.cpprts; 00170 vector<MsqVertex> mesh_coords, expected_coords; 00171 mesh.get_all_vertices( verts, err ); CHKERR(err) 00172 mesh_coords.resize(verts.size()); 00173 mesh.vertices_get_coordinates( arrptr(verts), arrptr(mesh_coords), verts.size(), err 00174 );CHKERR(err) expected_mesh.get_all_vertices( verts, err ); CHKERR(err) 00175 expected_coords.resize(verts.size()); 00176 expected_mesh.vertices_get_coordinates( arrptr(verts), arrptr(expected_coords), verts.size(), 00177 err ); CHKERR(err) if (expected_coords.size() != mesh_coords.size()) { cerr << "Invlid 00178 expected mesh. Vertex count doesn't match" << endl; exit(1); 00179 } 00180 00181 unsigned error_count = 0; 00182 for (size_t i = 0; i < mesh_coords.size(); ++i) 00183 if ((expected_coords[i] - mesh_coords[i]).length_squared() > epsilon*epsilon) 00184 ++error_count; 00185 00186 if (!error_count) 00187 cout << filename << " : SUCCESS" << endl; 00188 else 00189 cout << filename << " : FAILURE (" << error_count 00190 << " vertices differ by more than " << epsilon << ")" << endl; 00191 */ 00192 if( write_results ) mesh.write_vtk( ( filename + ".results.vtk" ).c_str(), err );CHKERR( err ) 00193 } 00194 00195 int main() 00196 { 00197 run_test( SAMPLE, 1, UNIT, "1-1" ); 00198 run_test( SAMPLE, 2, UNIT, "1-2" ); 00199 run_test( SAMPLE, 4, UNIT, "1-4" ); 00200 run_test( SAMPLE, 8, UNIT, "1-8" ); 00201 00202 run_test( SAMPLE, 1, UNIT, "2-NW" ); 00203 run_test( ELEMENT, 1, UNIT, "2-NE" ); 00204 00205 run_test( SAMPLE, 1, UNIT, "3-Left" ); 00206 run_test( SAMPLE, 1, METRIC, "3-Mid" ); 00207 run_test( SAMPLE, 1, INV_METRIC, "3-Right" ); 00208 }
