MOAB: Mesh Oriented datABase
(version 5.4.1)
The TerminationCriterion class contains functionality to terminate the VertexMover's optimization. More...
#include <TerminationCriterion.hpp>
The Termination Criterion class has three roles. It is used to terminate the optimization on a single patch; it is used to terminate the iterations over all patches in the mesh; and it is used to cull vertices from the optimization processes. Thus, for each optimization, two TerminationCriterion objects are used. The class contains five important member functions used in the VertexMover: initialize(), reset(), terminate(), cull_vertices(), and cleanup(). These functions are each explained in detail below. In general, the only one of these functions called directly from a concrete VertexMover is terminate() which allows the concrete VertexMover to determine when to stop producing new iterates on a given patch. All other functionality is handled from the base VertexMover base class.
There are several different types of termination criteria available. Multiple criteria types can be set on a given Termination Criterion object, and when this occurs, the optimization process will terminate whenever any of the criteria have been satisfied.
The following is a brief description of how TerminationCriterion is used within Mesquite. Functions called during QualityImprovement can be divided into three groups: reset_* - Initialize data for an iteration accumulate_* - Update TC for changed data during iteration terminate - Check if the termination criterion has been met. There are three different forms of the reset_* and accumulate_* functions which are called on the inner, outer, or both TerminationCriterion classes: _outer - Called on outer termination criterion. _inner - Called on inner termination criterion. _patch - Called on outer termination criterion for each patch and on inner termination criterion for each inner iteration.
If implementing a new TerminationCriterion, the following rules should be followed. If the value must be calculated on a global patch for the outer TC, then: o The functionality should be added to *_inner (yes, INNER) o The *_outer methods should be updated to call the *_inner with a global patch when your TC is requested. o The internal data for any such TC should be initialized in the reset_inner method. If the value for the outer criterion can be calculated from each local patch when iterating over the mesh with local patches, then: o The functionality should be added to *_patch o Any state values pertaining to the entire iteration must be initialized in reset_inner(..) and cleared in terminate() o Any patch-specific data should be initialized in reset_patch o Care should be taken that terminate() does not check uninitialized data if called before the first call to accumulate_patch()
Definition at line 121 of file TerminationCriterion.hpp.
Definition at line 254 of file TerminationCriterion.hpp.
{ TYPE_UNKNOWN, TYPE_INNER, TYPE_OUTER };
Definition at line 282 of file TerminationCriterion.hpp.
MBMesquite::TerminationCriterion::TerminationCriterion | ( | std::string | name = "" , |
InnerOuterType | pinnerOuterType = TYPE_UNKNOWN |
Constructor which does not take any arguements.
Constructor initializes all of the data members which are not necessarily automatically initialized in their constructors.
Definition at line 145 of file TerminationCriterion.cpp.
References boundedVertexMovementEps, cullingEps, cullingGlobalPatch, cullingMethodFlag, currentOFValue, globalInvertedCount, gradInfNormAbsoluteEps, gradInfNormRelativeEps, gradL2NormAbsoluteEpsSquared, gradL2NormRelativeEpsSquared, initialGradInfNorm, initialGradL2NormSquared, initialOFValue, iterationBound, iterationCounter, lowerOFBound, MBMesquite::NONE, patchInvertedCount, previousOFValue, qualityImprovementAbsoluteEps, qualityImprovementRelativeEps, successiveImprovementsAbsoluteEps, successiveImprovementsRelativeEps, terminationCriterionFlag, timeBound, vertexMovementAbsoluteAvgEdge, vertexMovementAbsoluteEps, vertexMovementAvgBeta, and vertexMovementRelativeEps.
: mGrad( 8 ), initialVerticesMemento( 0 ), previousVerticesMemento( 0 ), debugLevel( 2 ), timeStepFileType( NOTYPE ), moniker( name ), innerOuterType( pinnerOuterType ) { terminationCriterionFlag = NONE; cullingMethodFlag = NONE; cullingEps = 0.0; cullingGlobalPatch = false; initialOFValue = 0.0; previousOFValue = 0.0; currentOFValue = 0.0; lowerOFBound = 0.0; initialGradL2NormSquared = 0.0; initialGradInfNorm = 0.0; // initial size of the gradient array gradL2NormAbsoluteEpsSquared = 0.0; gradL2NormRelativeEpsSquared = 0.0; gradInfNormAbsoluteEps = 0.0; gradInfNormRelativeEps = 0.0; qualityImprovementAbsoluteEps = 0.0; qualityImprovementRelativeEps = 0.0; iterationBound = 0; iterationCounter = 0; timeBound = 0.0; vertexMovementAbsoluteEps = 0.0; vertexMovementRelativeEps = 0.0; vertexMovementAvgBeta = -1; vertexMovementAbsoluteAvgEdge = -1; successiveImprovementsAbsoluteEps = 0.0; successiveImprovementsRelativeEps = 0.0; boundedVertexMovementEps = 0.0; globalInvertedCount = 0; patchInvertedCount = 0; }
void MBMesquite::TerminationCriterion::accumulate_inner | ( | PatchData & | pd, |
OFEvaluator & | eval, | ||
MsqError & | err | ||
Accumulate data during inner iteration.
Definition at line 552 of file TerminationCriterion.cpp.
References MBMesquite::arrptr(), b, MBMesquite::OFEvaluator::evaluate(), MBMesquite::GRAD_FLAGS, MBMesquite::MsqError::INVALID_MESH, mGrad, MSQ_CHKERR, MSQ_ERRRTN, MSQ_SETERR, MBMesquite::PatchData::num_free_vertices(), MBMesquite::OF_FLAGS, and terminationCriterionFlag.
Referenced by accumulate_outer(), MBMesquite::NonGradient::evaluate(), MBMesquite::QuasiNewton::optimize_vertex_positions(), MBMesquite::TrustRegion::optimize_vertex_positions(), MBMesquite::ConjugateGradient::optimize_vertex_positions(), MBMesquite::SteepestDescent::optimize_vertex_positions(), MBMesquite::FeasibleNewton::optimize_vertex_positions(), TerminationCriterionTest::test_absolute_vertex_movement_edge_length(), TerminationCriterionTest::test_cpu_time_common(), TerminationCriterionTest::test_gradient_common(), TerminationCriterionTest::test_number_of_iterates_inner(), TerminationCriterionTest::test_quality_common(), TerminationCriterionTest::test_untangled_mesh(), TerminationCriterionTest::test_vertex_bound(), and TerminationCriterionTest::test_vertex_movement_common().
{ double of_value = 0; if( terminationCriterionFlag & GRAD_FLAGS ) { mGrad.resize( pd.num_free_vertices() ); bool b = of_eval.evaluate( pd, of_value, mGrad, err );MSQ_ERRRTN( err ); if( !b ) { MSQ_SETERR( err ) ( "Initial patch is invalid for gradient compuation.", MsqError::INVALID_MESH ); return; } } else if( terminationCriterionFlag & OF_FLAGS ) { bool b = of_eval.evaluate( pd, of_value, err );MSQ_ERRRTN( err ); if( !b ) { MSQ_SETERR( err ) ( "Invalid patch passed to TerminationCriterion.", MsqError::INVALID_MESH ); return; } } accumulate_inner( pd, of_value, mGrad.empty() ? 0 : arrptr( mGrad ), err );MSQ_CHKERR( err ); }
double | of_value, | ||
Vector3D * | of_grads, | ||
Definition at line 581 of file TerminationCriterion.cpp.
References currentGradInfNorm, currentGradL2NormSquared, currentOFValue, debugLevel, MBMesquite::PatchData::get_max_vertex_movement_squared(), globalInvertedCount, MBMesquite::GRADIENT_INF_NORM_ABSOLUTE, MBMesquite::GRADIENT_INF_NORM_RELATIVE, MBMesquite::GRADIENT_L2_NORM_ABSOLUTE, MBMesquite::GRADIENT_L2_NORM_RELATIVE, initialVerticesMemento, iterationCounter, MBMesquite::length_squared(), MBMesquite::Linf(), maxSquaredInitialMovement, maxSquaredMovement, MSQ_DBGOUT_P0_ONLY, MSQ_ERRRTN, mTimer, MBMesquite::PatchData::num_free_vertices(), MBMesquite::OF_FLAGS, par_string(), plotFile, previousOFValue, RPM, MBMesquite::Timer::since_birth(), terminationCriterionFlag, timeStepFileType, MBMesquite::VERTEX_MOVEMENT_RELATIVE, and write_timestep().
{ // if terminating on the norm of the gradient // currentGradL2NormSquared = HUGE_VAL; if( terminationCriterionFlag & ( GRADIENT_L2_NORM_ABSOLUTE | GRADIENT_L2_NORM_RELATIVE ) ) { currentGradL2NormSquared = length_squared( grad_array, pd.num_free_vertices() ); // get the L2 norm MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o Info -- gradient L2 norm: " << " " << RPM( std::sqrt( currentGradL2NormSquared ) ) << std::endl; } // currentGradInfNorm = 10e6; if( terminationCriterionFlag & ( GRADIENT_INF_NORM_ABSOLUTE | GRADIENT_INF_NORM_RELATIVE ) ) { currentGradInfNorm = Linf( grad_array, pd.num_free_vertices() ); // get the Linf norm MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o Info -- gradient Inf norm: " << " " << RPM( currentGradInfNorm ) << std::endl; } if( terminationCriterionFlag & VERTEX_MOVEMENT_RELATIVE ) { maxSquaredInitialMovement = pd.get_max_vertex_movement_squared( initialVerticesMemento, err );MSQ_ERRRTN( err ); MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o Info -- max initial vertex movement: " << " " << RPM( maxSquaredInitialMovement ) << std::endl; } previousOFValue = currentOFValue; currentOFValue = of_value; if( terminationCriterionFlag & OF_FLAGS ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o Info -- OF Value: " << " " << RPM( of_value ) << " iterationCounter= " << iterationCounter << std::endl; } else if( grad_array ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o OF Value: " << " " << RPM( of_value ) << " iterationCounter= " << iterationCounter //<< " terminationCriterionFlag= " << // terminationCriterionFlag << " OF_FLAGS = " << OF_FLAGS << std::endl; } ++iterationCounter; if( timeStepFileType ) write_timestep( pd, grad_array, err ); if( plotFile.is_open() ) plotFile << iterationCounter << '\t' << mTimer.since_birth() << '\t' << of_value << '\t' << std::sqrt( currentGradL2NormSquared ) << '\t' << currentGradInfNorm << '\t' << ( maxSquaredMovement > 0.0 ? std::sqrt( maxSquaredMovement ) : 0.0 ) << '\t' << globalInvertedCount << std::endl; }
void MBMesquite::TerminationCriterion::accumulate_outer | ( | Mesh * | ms, |
MeshDomain * | dm, | ||
const Settings * | settings, | ||
Definition at line 634 of file TerminationCriterion.cpp.
References accumulate_inner(), MBMesquite::PatchData::attach_settings(), MBMesquite::PatchData::fill_global_patch(), MBMesquite::GRAD_FLAGS, MSQ_ERRRTN, MBMesquite::OF_FLAGS, MBMesquite::PatchData::set_domain(), MBMesquite::PatchData::set_mesh(), terminationCriterionFlag, timeStepFileType, and MBMesquite::VERTEX_MOVEMENT_RELATIVE.
Referenced by MBMesquite::VertexMover::loop_over_mesh(), TerminationCriterionTest::test_cpu_time_common(), and TerminationCriterionTest::test_number_of_iterates_outer().
{ PatchData global_patch; if( settings ) global_patch.attach_settings( settings ); // if we need to fill out the global patch data object. if( ( terminationCriterionFlag & ( GRAD_FLAGS | OF_FLAGS | VERTEX_MOVEMENT_RELATIVE ) ) || timeStepFileType ) { global_patch.set_mesh( mesh ); global_patch.set_domain( domain ); global_patch.fill_global_patch( err );MSQ_ERRRTN( err ); } accumulate_inner( global_patch, of_eval, err );MSQ_ERRRTN( err ); }
void MBMesquite::TerminationCriterion::accumulate_patch | ( | PatchData & | pd, |
Common code for both inner and outer termination criteria during inner iteration.
Definition at line 654 of file TerminationCriterion.cpp.
References MBMesquite::BOUNDED_VERTEX_MOVEMENT, boundedVertexMovementEps, count_inverted(), cullingMethodFlag, MBMesquite::PatchData::get_max_vertex_movement_squared(), MBMesquite::PatchData::get_vertex_array(), globalInvertedCount, maxSquaredMovement, MBMesquite::MOVEMENT_FLAGS, MSQ_ERRRTN, MBMesquite::PatchData::num_free_vertices(), patchInvertedCount, previousVerticesMemento, MBMesquite::PatchData::recreate_vertices_memento(), terminationCriterionFlag, MBMesquite::UNTANGLED_MESH, and vertexMovementExceedsBound.
Referenced by MBMesquite::VertexMover::loop_over_mesh(), MBMesquite::QuasiNewton::optimize_vertex_positions(), MBMesquite::TrustRegion::optimize_vertex_positions(), MBMesquite::ConjugateGradient::optimize_vertex_positions(), MBMesquite::SteepestDescent::optimize_vertex_positions(), MBMesquite::FeasibleNewton::optimize_vertex_positions(), TerminationCriterionTest::test_absolute_vertex_movement_edge_length(), TerminationCriterionTest::test_cpu_time_common(), TerminationCriterionTest::test_gradient_common(), TerminationCriterionTest::test_number_of_iterates_inner(), TerminationCriterionTest::test_number_of_iterates_outer(), TerminationCriterionTest::test_quality_common(), TerminationCriterionTest::test_untangled_mesh(), TerminationCriterionTest::test_vertex_bound(), and TerminationCriterionTest::test_vertex_movement_common().
{ if( terminationCriterionFlag & MOVEMENT_FLAGS ) { double patch_max_dist = pd.get_max_vertex_movement_squared( previousVerticesMemento, err ); if( patch_max_dist > maxSquaredMovement ) maxSquaredMovement = patch_max_dist; pd.recreate_vertices_memento( previousVerticesMemento, err );MSQ_ERRRTN( err ); } // if terminating on bounded vertex movement (a bounding box for the mesh) if( terminationCriterionFlag & BOUNDED_VERTEX_MOVEMENT ) { const MsqVertex* vert = pd.get_vertex_array( err ); int num_vert = pd.num_free_vertices(); int i = 0; // for each vertex for( i = 0; i < num_vert; ++i ) { // if any of the coordinates are greater than eps if( ( vert[i][0] > boundedVertexMovementEps ) || ( vert[i][1] > boundedVertexMovementEps ) || ( vert[i][2] > boundedVertexMovementEps ) ) { ++vertexMovementExceedsBound; } } } if( ( terminationCriterionFlag | cullingMethodFlag ) & UNTANGLED_MESH ) { size_t new_count = count_inverted( pd, err ); // be careful here because size_t is unsigned globalInvertedCount += new_count; globalInvertedCount -= patchInvertedCount; patchInvertedCount = new_count; // if (innerOuterType==TYPE_OUTER) // MSQ_DBGOUT_P0_ONLY(debugLevel) << par_string() << " o Num Patch Inverted: " << " " << // patchInvertedCount << " globalInvertedCount= " << globalInvertedCount << std::endl; MSQ_ERRRTN( err ); } }
void MBMesquite::TerminationCriterion::add_absolute_gradient_inf_norm | ( | double | value | ) |
checks the gradient \(\nabla f \) of objective function \(f : I\!\!R^{3N} \rightarrow I\!\!R \) against a double \(d\) and stops when \( \max_{i=1}^{3N} \nabla f_i < d \)
Definition at line 197 of file TerminationCriterion.cpp.
References eps, MBMesquite::GRADIENT_INF_NORM_ABSOLUTE, gradInfNormAbsoluteEps, and terminationCriterionFlag.
Referenced by TerminationCriterionTest::test_gradient_common().
void MBMesquite::TerminationCriterion::add_absolute_gradient_L2_norm | ( | double | value | ) |
checks the gradient \(\nabla f \) of objective function \(f : I\!\!R^{3N} \rightarrow I\!\!R \) against a double \(d\) and stops when \(\sqrt{\sum_{i=1}^{3N}\nabla f_i^2}<d\)
Definition at line 191 of file TerminationCriterion.cpp.
References eps, MBMesquite::GRADIENT_L2_NORM_ABSOLUTE, gradL2NormAbsoluteEpsSquared, and terminationCriterionFlag.
Referenced by MBMesquite::FeasibleNewton::FeasibleNewton(), MBMesquite::ShapeImprovementWrapper::run_wrapper(), ParShapeImprover::ParShapeImprovementWrapper::run_wrapper(), and TerminationCriterionTest::test_gradient_common().
void MBMesquite::TerminationCriterion::add_absolute_quality_improvement | ( | double | value | ) |
Terminates when the objective function value is smaller than the given scalar value.
Definition at line 215 of file TerminationCriterion.cpp.
References eps, MBMesquite::QUALITY_IMPROVEMENT_ABSOLUTE, qualityImprovementAbsoluteEps, and terminationCriterionFlag.
Referenced by main(), MBMesquite::ShapeImprovementWrapper::run_wrapper(), ParShapeImprover::ParShapeImprovementWrapper::run_wrapper(), and TerminationCriterionTest::test_quality_common().
void MBMesquite::TerminationCriterion::add_absolute_successive_improvement | ( | double | value | ) |
Terminates when the decrease in the objective function value since the previous iteration is below the given value.
Definition at line 247 of file TerminationCriterion.cpp.
References eps, MBMesquite::SUCCESSIVE_IMPROVEMENTS_ABSOLUTE, successiveImprovementsAbsoluteEps, and terminationCriterionFlag.
Referenced by MBMesquite::ShapeImprovementWrapper::run_wrapper(), VertexCullingRegressionTest::test_laplacian_smoothing_with_cull(), and TerminationCriterionTest::test_quality_common().
void MBMesquite::TerminationCriterion::add_absolute_vertex_movement | ( | double | value | ) |
Terminates when a the maximum distance moved by any vertex during the previous iteration is below the given value.
Definition at line 227 of file TerminationCriterion.cpp.
References eps, terminationCriterionFlag, MBMesquite::VERTEX_MOVEMENT_ABSOLUTE, and vertexMovementAbsoluteEps.
Referenced by BCDTest::compare_bcd(), create_instruction_queue(), do_smoother(), main(), run(), run_global_smoother(), run_local_smoother(), run_local_smoother2(), run_quality_optimizer(), run_smoother(), run_solution_mesh_optimizer(), run_test(), MBMesquite::SizeAdaptShapeWrapper::run_wrapper(), MBMesquite::PaverMinEdgeLengthWrapper::run_wrapper(), MBMesquite::ViscousCFDTetShapeWrapper::run_wrapper(), ParShapeImprover::ParShapeImprovementWrapper::run_wrapper(), smooth_mesh(), TerminationCriterionTest::test_abs_vtx_movement_culling(), and TerminationCriterionTest::test_vertex_movement_common().
{ terminationCriterionFlag |= VERTEX_MOVEMENT_ABSOLUTE; // we actually compare squared movement to squared epsilon vertexMovementAbsoluteEps = ( eps * eps ); }
void MBMesquite::TerminationCriterion::add_absolute_vertex_movement_edge_length | ( | double | value | ) |
Calculates a constant \( \delta = \beta \times (a - \sigma) \) and terminates when the maximum vertex movement of an iteration is less than delta.
\( \beta \) is the passed value, \( a \) is the average edge length of the initial mesh and \( \sigma \) is the standard deviation of the edge lengths of the initial mesh. The initial mesh values are (re)calcualted for each time the instruction queue is run.
value | \( beta \). Must be in range (0,1), exclusive. |
Definition at line 234 of file TerminationCriterion.cpp.
References beta, terminationCriterionFlag, MBMesquite::VERTEX_MOVEMENT_ABS_EDGE_LENGTH, and vertexMovementAvgBeta.
Referenced by MBMesquite::ShapeImprover::run_wrapper(), MBMesquite::DeformingDomainWrapper::run_wrapper(), and TerminationCriterionTest::test_absolute_vertex_movement_edge_length().
void MBMesquite::TerminationCriterion::add_bounded_vertex_movement | ( | double | value | ) |
Terminates when any vertex leaves the bounding box, defined by the given value, d. That is, when the absolute value of a single coordinate of vertex's position exceeds d.
Definition at line 271 of file TerminationCriterion.cpp.
References MBMesquite::BOUNDED_VERTEX_MOVEMENT, boundedVertexMovementEps, eps, and terminationCriterionFlag.
Referenced by TerminationCriterionTest::test_vertex_bound().
void MBMesquite::TerminationCriterion::add_cpu_time | ( | double | seconds | ) |
Terminates when the algorithm exceeds an allotted time limit (given in seconds).
Definition at line 259 of file TerminationCriterion.cpp.
References MBMesquite::CPU_TIME, terminationCriterionFlag, and timeBound.
Referenced by main(), MBMesquite::ShapeImprover::run_wrapper(), MBMesquite::ShapeImprovementWrapper::run_wrapper(), MBMesquite::DeformingDomainWrapper::run_wrapper(), and TerminationCriterionTest::test_cpu_time_common().
{ terminationCriterionFlag |= CPU_TIME; timeBound = seconds; }
void MBMesquite::TerminationCriterion::add_iteration_limit | ( | unsigned int | max_iterations | ) |
Terminates when the number of iterations exceeds a given integer.
Definition at line 265 of file TerminationCriterion.cpp.
References iterationBound, MBMesquite::NUMBER_OF_ITERATES, and terminationCriterionFlag.
Referenced by BCDTest::compare_bcd(), MBMesquite::ConjugateGradient::ConjugateGradient(), create_instruction_queue(), do_smoother(), MBMesquite::VertexMover::loop_over_mesh(), main(), MBMesquite::NonGradient::NonGradient(), MBMesquite::QualityImprover::QualityImprover(), run(), run_global_smoother(), run_local_smoother(), run_local_smoother2(), run_smoother(), run_solution_mesh_optimizer(), run_test(), MBMesquite::PaverMinEdgeLengthWrapper::run_wrapper(), MBMesquite::SizeAdaptShapeWrapper::run_wrapper(), MBMesquite::ViscousCFDTetShapeWrapper::run_wrapper(), MBMesquite::ShapeImprovementWrapper::run_wrapper(), ParShapeImprover::ParShapeImprovementWrapper::run_wrapper(), MBMesquite::DeformingDomainWrapper::run_wrapper(), smooth_mesh(), smooth_mixed_mesh(), TerminationCriterionTest::test_abs_vtx_movement_culling(), SphericalGeometryTest::test_cg_mesh_cond_sphere(), SphericalGeometryTest::test_lapl_geo_sphere(), VertexCullingRegressionTest::test_laplacian_smoothing_with_cull(), TerminationCriterionTest::test_number_of_iterates_inner(), TerminationCriterionTest::test_number_of_iterates_outer(), PlanarGeometryTest::test_plane_quad_tangled(), PlanarGeometryTest::test_plane_tri_tangled(), PlanarGeometryTest::test_plane_tri_xz(), and SphericalGeometryTest::test_smart_lapl_sphere().
{ terminationCriterionFlag |= NUMBER_OF_ITERATES; iterationBound = max_iterations; }
void MBMesquite::TerminationCriterion::add_relative_gradient_inf_norm | ( | double | value | ) |
terminates on the j_th iteration when \(\max_{i=1 \cdots 3N}\nabla f_{i,j}<d \max_{i=1 \cdots 3N}\nabla f_{i,0}\) That is, terminates when the norm of the gradient is small than some scaling factor times the norm of the original gradient. (Using the infinity norm.)
Definition at line 209 of file TerminationCriterion.cpp.
References eps, MBMesquite::GRADIENT_INF_NORM_RELATIVE, gradInfNormRelativeEps, and terminationCriterionFlag.
void MBMesquite::TerminationCriterion::add_relative_gradient_L2_norm | ( | double | value | ) |
terminates on the j_th iteration when \(\sqrt{\sum_{i=1}^{3N}\nabla f_{i,j}^2}<d\sqrt{\sum_{i=1}^{3N}\nabla f_{i,0}^2}\) That is, terminates when the norm of the gradient is smaller than the specified fraction of the initial norm of the gradient.
Definition at line 203 of file TerminationCriterion.cpp.
References eps, MBMesquite::GRADIENT_L2_NORM_RELATIVE, gradL2NormRelativeEpsSquared, and terminationCriterionFlag.
void MBMesquite::TerminationCriterion::add_relative_quality_improvement | ( | double | value | ) |
Terminates when the objective function value is smaller than the given scalar value times the original objective function value.
Definition at line 221 of file TerminationCriterion.cpp.
References eps, MBMesquite::QUALITY_IMPROVEMENT_RELATIVE, qualityImprovementRelativeEps, and terminationCriterionFlag.
Referenced by main(), smooth_mixed_mesh(), and TerminationCriterionTest::test_quality_common().
void MBMesquite::TerminationCriterion::add_relative_successive_improvement | ( | double | value | ) |
Terminates when the decrease in the objective function value since the previous iteration is below the given value times the decrease in the objective function value since the beginning of this optimization process.
Definition at line 253 of file TerminationCriterion.cpp.
References eps, MBMesquite::SUCCESSIVE_IMPROVEMENTS_RELATIVE, successiveImprovementsRelativeEps, and terminationCriterionFlag.
Referenced by MBMesquite::ShapeImprovementWrapper::run_wrapper(), and TerminationCriterionTest::test_quality_common().
void MBMesquite::TerminationCriterion::add_relative_vertex_movement | ( | double | value | ) |
Terminates when a the maximum distance moved by any vertex during the previous iteration is below the given value times the maximum distance moved by any vertex over the entire course of the optimization.
Definition at line 240 of file TerminationCriterion.cpp.
References eps, terminationCriterionFlag, MBMesquite::VERTEX_MOVEMENT_RELATIVE, and vertexMovementRelativeEps.
Referenced by TerminationCriterionTest::test_vertex_movement_common().
{ terminationCriterionFlag |= VERTEX_MOVEMENT_RELATIVE; // we actually compare squared movement to squared epsilon vertexMovementRelativeEps = ( eps * eps ); }
Terminates when the mesh is detected to be untangled. Uses the same approach as QualityAssessor, checks the tau values at all the sample points.
Definition at line 277 of file TerminationCriterion.cpp.
References terminationCriterionFlag, and MBMesquite::UNTANGLED_MESH.
Referenced by TerminationCriterionTest::test_untangled_mesh().
void MBMesquite::TerminationCriterion::cleanup | ( | Mesh * | ms, |
MeshDomain * | domain, | ||
Cleans up after the TerminationCriterion is finished.
Currently this only deletes the memento of the vertex positions and the mGrad vector if neccessary. When culling, we remove the soft fixed flags from all of the vertices.
Definition at line 1122 of file TerminationCriterion.cpp.
References initialVerticesMemento, and previousVerticesMemento.
Referenced by MBMesquite::VertexMover::loop_over_mesh().
{ delete previousVerticesMemento; delete initialVerticesMemento; previousVerticesMemento = 0; initialVerticesMemento = 0; }
size_t MBMesquite::TerminationCriterion::count_inverted | ( | PatchData & | pd, |
) | [static, protected] |
Definition at line 1104 of file TerminationCriterion.cpp.
References MBMesquite::MsqMeshEntity::check_element_orientation(), MBMesquite::PatchData::element_by_index(), and MBMesquite::PatchData::num_elements().
Referenced by accumulate_patch(), reset_inner(), and reset_patch().
{ size_t num_elem = pd.num_elements(); size_t count = 0; int inverted, samples; for( size_t i = 0; i < num_elem; i++ ) { pd.element_by_index( i ).check_element_orientation( pd, inverted, samples, err ); if( inverted ) ++count; } return count; }
Check if at least one termination criterion is set.
Definition at line 890 of file TerminationCriterion.cpp.
References terminationCriterionFlag.
{ if( !terminationCriterionFlag ) return false; else return true; }
void MBMesquite::TerminationCriterion::cull_for_global_patch | ( | bool | val = true | ) |
Cull for a global patch - sets soft fixed flags for vertices that touch elements that are culled by above flags.
Definition at line 332 of file TerminationCriterion.cpp.
References cullingGlobalPatch.
{ cullingGlobalPatch = val; }
void MBMesquite::TerminationCriterion::cull_on_absolute_quality_improvement | ( | double | limit | ) |
Cull when the objective function value is smaller than the given scalar value.
Definition at line 287 of file TerminationCriterion.cpp.
References cullingEps, cullingMethodFlag, and MBMesquite::QUALITY_IMPROVEMENT_ABSOLUTE.
{ cullingMethodFlag = QUALITY_IMPROVEMENT_ABSOLUTE; cullingEps = limit; }
void MBMesquite::TerminationCriterion::cull_on_absolute_successive_improvement | ( | double | limit | ) |
Cull when the decrease in the objective function value since the previous iteration is below the given value.
Definition at line 312 of file TerminationCriterion.cpp.
References cullingEps, cullingMethodFlag, and MBMesquite::SUCCESSIVE_IMPROVEMENTS_ABSOLUTE.
{ cullingMethodFlag = SUCCESSIVE_IMPROVEMENTS_ABSOLUTE; cullingEps = limit; }
void MBMesquite::TerminationCriterion::cull_on_absolute_vertex_movement | ( | double | limit | ) |
Cull when a the maximum distance moved by any vertex during the previous iteration is below the given value.
Definition at line 297 of file TerminationCriterion.cpp.
References cullingEps, cullingMethodFlag, and MBMesquite::VERTEX_MOVEMENT_ABSOLUTE.
Referenced by TerminationCriterionTest::test_abs_vtx_movement_culling(), and VertexCullingRegressionTest::test_laplacian_smoothing_with_cull().
{ cullingMethodFlag = VERTEX_MOVEMENT_ABSOLUTE; cullingEps = limit; }
void MBMesquite::TerminationCriterion::cull_on_absolute_vertex_movement_edge_length | ( | double | value | ) |
Calculates a constant \( \delta = \beta \times (a - \sigma) \) and culls when the vertex movement is less than delta.
Definition at line 307 of file TerminationCriterion.cpp.
References cullingMethodFlag, MBMesquite::VERTEX_MOVEMENT_ABS_EDGE_LENGTH, and vertexMovementAvgBeta.
Referenced by MBMesquite::LaplaceWrapper::run_wrapper(), and MBMesquite::DeformingDomainWrapper::run_wrapper().
{ cullingMethodFlag = VERTEX_MOVEMENT_ABS_EDGE_LENGTH; vertexMovementAvgBeta = limit; }
void MBMesquite::TerminationCriterion::cull_on_relative_quality_improvement | ( | double | limit | ) |
Cull when the objective function value is smaller than the given scalar value times the original objective function value.
Definition at line 292 of file TerminationCriterion.cpp.
References cullingEps, cullingMethodFlag, and MBMesquite::QUALITY_IMPROVEMENT_RELATIVE.
{ cullingMethodFlag = QUALITY_IMPROVEMENT_RELATIVE; cullingEps = limit; }
void MBMesquite::TerminationCriterion::cull_on_relative_successive_improvement | ( | double | limit | ) |
Cull when the decrease in the objective function value since the previous iteration is below the given value times the decrease in the objective function value since the beginning of this optimization process.
Definition at line 317 of file TerminationCriterion.cpp.
References cullingEps, cullingMethodFlag, and MBMesquite::SUCCESSIVE_IMPROVEMENTS_RELATIVE.
{ cullingMethodFlag = SUCCESSIVE_IMPROVEMENTS_RELATIVE; cullingEps = limit; }
void MBMesquite::TerminationCriterion::cull_on_relative_vertex_movement | ( | double | limit | ) |
Cull when a the maximum distance moved by any vertex during the previous iteration is below the given value times the maximum distance moved by any vertex over the entire course of the optimization.
Definition at line 302 of file TerminationCriterion.cpp.
References cullingEps, cullingMethodFlag, and MBMesquite::VERTEX_MOVEMENT_RELATIVE.
{ cullingMethodFlag = VERTEX_MOVEMENT_RELATIVE; cullingEps = limit; }
Cull when the mesh is detected to be untangled. Uses the same approach as QualityAssessor, checks the tau values at all the sample points.
Definition at line 322 of file TerminationCriterion.cpp.
References cullingMethodFlag, and MBMesquite::UNTANGLED_MESH.
{ cullingMethodFlag = UNTANGLED_MESH; }
bool MBMesquite::TerminationCriterion::cull_vertices | ( | PatchData & | pd, |
OFEvaluator & | of_eval, | ||
Function which determines whether this patch should be 'culled'.
This function checks the culling method criterion supplied to the object by the user. If the user does not supply a culling method criterion, the default criterion is NONE, and in that case, no culling is performed. If the culling method criterion is satisfied, the interior vertices of the given patch are flagged as soft_fixed. Otherwise, the soft_fixed flag is removed from each of the vertices in the patch (interior and boundary vertices). Also, if the criterion was satisfied, then the function returns true. Otherwise, the function returns false.
Definition at line 907 of file TerminationCriterion.cpp.
References b, cullingEps, cullingMethodFlag, currentOFValue, MBMesquite::OFEvaluator::evaluate(), MBMesquite::PatchData::get_max_vertex_movement_squared(), initialOFValue, initialVerticesMemento, MBMesquite::MsqError::INVALID_MESH, lowerOFBound, MSQ_CHKERR, MSQ_ERRZERO, MSQ_SETERR, MBMesquite::NONE, NOT_IMPLEMENTED, patchInvertedCount, previousVerticesMemento, MBMesquite::QUALITY_IMPROVEMENT_ABSOLUTE, MBMesquite::QUALITY_IMPROVEMENT_RELATIVE, MBMesquite::PatchData::set_all_vertices_soft_free(), MBMesquite::PatchData::set_free_vertices_soft_fixed(), MBMesquite::UNTANGLED_MESH, MBMesquite::VERTEX_MOVEMENT_ABS_EDGE_LENGTH, MBMesquite::VERTEX_MOVEMENT_ABSOLUTE, and MBMesquite::VERTEX_MOVEMENT_RELATIVE.
Referenced by cull_vertices_global(), and MBMesquite::VertexMover::loop_over_mesh().
{ // PRINT_INFO("CULLING_METHOD FLAG = %i",cullingMethodFlag); // cull_bool will be changed to true if the criterion is satisfied bool b, cull_bool = false; double prev_m, init_m; switch( cullingMethodFlag ) { // if no culling is requested, always return false case NONE: return cull_bool; // if culling on quality improvement absolute case QUALITY_IMPROVEMENT_ABSOLUTE: // get objective function value b = of_eval.evaluate( pd, currentOFValue, err ); if( MSQ_CHKERR( err ) ) return false; if( !b ) { MSQ_SETERR( err )( MsqError::INVALID_MESH ); return false; } // if the improvement was enough, cull if( currentOFValue <= cullingEps ) { cull_bool = true; } // PRINT_INFO("\ncurrentOFValue = %f, bool = %i\n",currentOFValue,cull_bool); break; // if culing on quality improvement relative case QUALITY_IMPROVEMENT_RELATIVE: // get objective function value b = of_eval.evaluate( pd, currentOFValue, err ); if( MSQ_CHKERR( err ) ) return false; if( !b ) { MSQ_SETERR( err )( MsqError::INVALID_MESH ); return false; } // if the improvement was enough, cull if( ( currentOFValue - lowerOFBound ) <= ( cullingEps * ( initialOFValue - lowerOFBound ) ) ) { cull_bool = true; } break; // if culling on vertex movement absolute case VERTEX_MOVEMENT_ABSOLUTE: case VERTEX_MOVEMENT_ABS_EDGE_LENGTH: // if movement was enough, cull prev_m = pd.get_max_vertex_movement_squared( previousVerticesMemento, err ); MSQ_ERRZERO( err ); if( prev_m <= cullingEps * cullingEps ) { cull_bool = true; } break; // if culling on vertex movement relative case VERTEX_MOVEMENT_RELATIVE: // if movement was small enough, cull prev_m = pd.get_max_vertex_movement_squared( previousVerticesMemento, err ); MSQ_ERRZERO( err ); init_m = pd.get_max_vertex_movement_squared( initialVerticesMemento, err ); MSQ_ERRZERO( err ); if( prev_m <= ( cullingEps * cullingEps * init_m ) ) { cull_bool = true; } break; case UNTANGLED_MESH: if( !patchInvertedCount ) cull_bool = true; break; default: MSQ_SETERR( err ) ( "Requested culling method not yet implemented.", MsqError::NOT_IMPLEMENTED ); return false; }; // Now actually have patch data cull vertices if( cull_bool ) { pd.set_free_vertices_soft_fixed( err ); MSQ_ERRZERO( err ); } else { pd.set_all_vertices_soft_free( err ); MSQ_ERRZERO( err ); } return cull_bool; }
bool MBMesquite::TerminationCriterion::cull_vertices_global | ( | PatchData & | global_patch, |
Mesh * | mesh, | ||
experimental, first cut at culling for global patches - not finished
This function is activated when cullingGlobalPatch is true. It supplies cull_vertices with a single vertex-based patch at a time. If the patch satisfies the culling criterion, it's free vertices are then soft-fixed.
Definition at line 1003 of file TerminationCriterion.cpp.
References MBMesquite::PatchData::attach_settings(), cull_vertices(), cullingGlobalPatch, MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::get_all_vertices(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::PatchData::get_vertex_handles_array(), ie, MBMesquite::MsqVertex::is_free_vertex(), MBMesquite::MsqVertex::MSQ_CULLED, MBMesquite::PatchData::num_nodes(), MBMesquite::PatchData::set_domain(), MBMesquite::MsqVertex::set_flags(), MBMesquite::PatchData::set_mesh(), MBMesquite::PatchData::set_mesh_entities(), MBMesquite::PatchData::set_vertex_culled(), MBMesquite::Mesh::vertex_get_byte(), and MBMesquite::Mesh::vertices_get_attached_elements().
{ if( !cullingGlobalPatch ) return false; // PRINT_INFO("CULLING_METHOD FLAG = %i",cullingMethodFlag); // cull_bool will be changed to true if the criterion is satisfied bool cull_bool = false; std::vector< Mesh::VertexHandle > mesh_vertices; // std::vector<Mesh::VertexHandle> patch_vertices; // std::vector<Mesh::ElementHandle> patch_elements; // std::vector<Mesh::VertexHandle> fixed_vertices; // std::vector<Mesh::VertexHandle> free_vertices; // FIXME, verify global_patch is a global patch... how, is this right? mesh->get_all_vertices( mesh_vertices, err ); size_t mesh_num_nodes = mesh_vertices.size(); size_t global_patch_num_nodes = global_patch.num_nodes(); if( 0 ) std::cout << "tmp srk mesh_num_nodes= " << mesh_num_nodes << " global_patch_num_nodes= " << global_patch_num_nodes << std::endl; if( mesh_num_nodes != global_patch_num_nodes ) { std::cout << "tmp srk cull_vertices_global found non global patch" << std::endl; exit( 123 ); return false; } PatchData patch; patch.set_mesh( (Mesh*)mesh ); patch.set_domain( domain ); patch.attach_settings( settings ); // const MsqVertex* global_patch_vertex_array = global_patch.get_vertex_array( err ); Mesh::VertexHandle* global_patch_vertex_handles = global_patch.get_vertex_handles_array(); int num_culled = 0; for( unsigned iv = 0; iv < global_patch_num_nodes; iv++ ) { // form a patch for this vertex; if it is culled, set it to be soft fixed Mesh::VertexHandle vert = global_patch_vertex_handles[iv]; std::vector< Mesh::ElementHandle > elements; std::vector< size_t > offsets; mesh->vertices_get_attached_elements( &vert, 1, elements, offsets, err ); std::set< Mesh::VertexHandle > patch_free_vertices_set; for( unsigned ie = 0; ie < elements.size(); ie++ ) { std::vector< Mesh::VertexHandle > vert_handles; std::vector< size_t > v_offsets; mesh->elements_get_attached_vertices( &elements[ie], 1, vert_handles, v_offsets, err ); for( unsigned jv = 0; jv < vert_handles.size(); jv++ ) { unsigned char bt; mesh->vertex_get_byte( vert_handles[jv], &bt, err ); MsqVertex v; v.set_flags( bt ); if( v.is_free_vertex() ) patch_free_vertices_set.insert( vert_handles[jv] ); } } std::vector< Mesh::VertexHandle > patch_free_vertices_vector( patch_free_vertices_set.begin(), patch_free_vertices_set.end() ); // std::vector<unsigned char> byte_vector(patch_vertices_vector.size()); // mesh->vertices_get_byte(&vert_handles[0], &byte_vector[0], vert_handles.size(), err); patch.set_mesh_entities( elements, patch_free_vertices_vector, err ); if( cull_vertices( patch, of_eval, err ) ) { // std::cout << "tmp srk cull_vertices_global found culled patch" << std::endl; Mesh::VertexHandle* patch_vertex_handles = patch.get_vertex_handles_array(); const MsqVertex* patch_vertex_array = patch.get_vertex_array( err ); for( unsigned jv = 0; jv < patch.num_nodes(); jv++ ) { if( patch_vertex_handles[jv] == global_patch_vertex_handles[iv] ) { if( patch_vertex_array[jv].is_flag_set( MsqVertex::MSQ_CULLED ) ) { global_patch.set_vertex_culled( iv ); ++num_culled; cull_bool = true; // std::cout << "tmp srk cull_vertices_global found culled vertex" << // std::endl; } } } } } if( 0 ) std::cout << "tmp srk cull_vertices_global found " << num_culled << " culled vertices out of " << global_patch_num_nodes << std::endl; return cull_bool; }
MESQUITE_EXPORT double MBMesquite::TerminationCriterion::get_current_function_value | ( | ) | [inline] |
This function returns the current function value.
Definition at line 272 of file TerminationCriterion.hpp.
References currentOFValue.
{ return currentOFValue; }
MESQUITE_EXPORT int MBMesquite::TerminationCriterion::get_iteration_count | ( | ) | const [inline] |
Definition at line 316 of file TerminationCriterion.hpp.
References iterationCounter.
Referenced by MBMesquite::SteepestDescent::optimize_vertex_positions(), run(), TerminationCriterionTest::test_number_of_iterates_inner(), and TerminationCriterionTest::test_number_of_iterates_outer().
{ return iterationCounter; }
void MBMesquite::TerminationCriterion::initialize_queue | ( | MeshDomainAssoc * | mesh_and_domain, |
Definition at line 1159 of file TerminationCriterion.cpp.
References MBMesquite::SimpleStats::average(), cullingEps, cullingMethodFlag, MBMesquite::MeshUtil::edge_length_distribution(), MBMesquite::MeshDomainAssoc::get_mesh(), mesh, MSQ_ERRRTN, MBMesquite::SimpleStats::standard_deviation(), terminationCriterionFlag, MBMesquite::VERTEX_MOVEMENT_ABS_EDGE_LENGTH, vertexMovementAbsoluteAvgEdge, and vertexMovementAvgBeta.
Referenced by MBMesquite::QualityImprover::initialize_queue(), and TerminationCriterionTest::test_absolute_vertex_movement_edge_length().
{ if( VERTEX_MOVEMENT_ABS_EDGE_LENGTH & ( terminationCriterionFlag | cullingMethodFlag ) ) { Mesh* mesh = mesh_and_domain->get_mesh(); MeshUtil tool( mesh ); SimpleStats stats; tool.edge_length_distribution( stats, err );MSQ_ERRRTN( err ); double limit = vertexMovementAvgBeta * ( stats.average() - stats.standard_deviation() ); // we actually calculate the square of the length vertexMovementAbsoluteAvgEdge = limit * limit; if( VERTEX_MOVEMENT_ABS_EDGE_LENGTH & cullingMethodFlag ) cullingEps = limit; } }
std::string MBMesquite::TerminationCriterion::par_string | ( | ) | [protected] |
Definition at line 180 of file TerminationCriterion.cpp.
References MBMesquite::get_parallel_rank(), MBMesquite::get_parallel_size(), and moniker.
Referenced by accumulate_inner(), reset_inner(), and terminate().
{ if( get_parallel_size() ) { std::ostringstream str; str << "P[" << get_parallel_rank() << "] " + moniker + " "; return str.str(); } return moniker + " "; }
Definition at line 282 of file TerminationCriterion.cpp.
{ terminationCriterionFlag = 0; }
Definition at line 327 of file TerminationCriterion.cpp.
References cullingMethodFlag, and MBMesquite::NONE.
{ cullingMethodFlag = NONE; }
void MBMesquite::TerminationCriterion::reset_inner | ( | PatchData & | pd, |
OFEvaluator & | obj_eval, | ||
Clear any data accumulated during an inner iteration.
Reset function using using a PatchData object. This function is called for the inner-stopping criterion directly from the loop over mesh function in VertexMover. For outer criterion, it is called from the reset function which takes a MeshSet object. This function prepares the object to be used by setting the initial values of some of the data members. As examples, if needed, it resets the cpu timer to zero, the iteration counter to zero, and the initial and previous objective function values to the current objective function value for this patch. The return value for this function is similar to that of terminate(). The function returns false if the checked criteria have not been satisfied, and true if they have been. reset() only checks the GRADIENT_INF_NORM_ABSOLUTE, GRADIENT_L2_NORM_ABSOLUTE, and the QUALITY_IMPROVEMENT_ABSOLUTE criteria. Checking these criteria allows the QualityImprover to skip the entire optimization if the initial mesh satisfies the appropriate conditions.
Definition at line 380 of file TerminationCriterion.cpp.
References MBMesquite::arrptr(), b, MBMesquite::MsqError::clear(), count_inverted(), MBMesquite::CPU_TIME, MBMesquite::PatchData::create_vertices_memento(), cullingMethodFlag, currentGradInfNorm, currentGradL2NormSquared, currentOFValue, debugLevel, MBMesquite::OFEvaluator::evaluate(), globalInvertedCount, MBMesquite::GRAD_FLAGS, MBMesquite::GRADIENT_INF_NORM_ABSOLUTE, MBMesquite::GRADIENT_INF_NORM_RELATIVE, MBMesquite::GRADIENT_L2_NORM_ABSOLUTE, MBMesquite::GRADIENT_L2_NORM_RELATIVE, MBMesquite::OFEvaluator::have_objective_function(), initialGradInfNorm, initialGradL2NormSquared, initialOFValue, initialVerticesMemento, MBMesquite::MsqError::INVALID_STATE, iterationCounter, MBMesquite::length_squared(), MBMesquite::Linf(), maxSquaredInitialMovement, maxSquaredMovement, mGrad, MSQ_DBGOUT_P0_ONLY, MSQ_ERRRTN, MSQ_SETERR, mTimer, MBMesquite::PatchData::num_free_vertices(), MBMesquite::OF_FLAGS, par_string(), patchInvertedCount, plotFile, previousOFValue, MBMesquite::PatchData::recreate_vertices_memento(), MBMesquite::Timer::reset(), RPM, MBMesquite::Timer::since_birth(), terminationCriterionFlag, timeStepFileType, MBMesquite::UNTANGLED_MESH, MBMesquite::VERTEX_MOVEMENT_RELATIVE, vertexMovementExceedsBound, and write_timestep().
Referenced by MBMesquite::VertexMover::loop_over_mesh(), reset_outer(), TerminationCriterionTest::test_absolute_vertex_movement_edge_length(), TerminationCriterionTest::test_cpu_time_common(), TerminationCriterionTest::test_gradient_common(), TerminationCriterionTest::test_number_of_iterates_inner(), TerminationCriterionTest::test_quality_common(), TerminationCriterionTest::test_untangled_mesh(), TerminationCriterionTest::test_vertex_bound(), and TerminationCriterionTest::test_vertex_movement_common().
{ const unsigned long totalFlag = terminationCriterionFlag | cullingMethodFlag; // clear flag for BOUNDED_VERTEX_MOVEMENT vertexMovementExceedsBound = 0; // Use -1 to denote that this isn't initialized yet. // As all valid values must be >= 0.0, a negative // value indicates that it is uninitialized and is // always less than any valid value. maxSquaredMovement = -1; // Clear the iteration count. iterationCounter = 0; // reset the inner timer if needed if( totalFlag & CPU_TIME ) { mTimer.reset(); } // GRADIENT currentGradInfNorm = initialGradInfNorm = 0.0; currentGradL2NormSquared = initialGradL2NormSquared = 0.0; if( totalFlag & GRAD_FLAGS ) { if( !obj_eval.have_objective_function() ) { MSQ_SETERR( err ) ( "Error termination criteria set which uses objective " "functions, but no objective function is available.", MsqError::INVALID_STATE ); return; } int num_vertices = pd.num_free_vertices(); mGrad.resize( num_vertices ); // get gradient and make sure it is valid bool b = obj_eval.evaluate( pd, currentOFValue, mGrad, err );MSQ_ERRRTN( err ); if( !b ) { MSQ_SETERR( err ) ( "Initial patch is invalid for gradient computation.", MsqError::INVALID_STATE ); return; } // get the gradient norms if( totalFlag & ( GRADIENT_INF_NORM_ABSOLUTE | GRADIENT_INF_NORM_RELATIVE ) ) { currentGradInfNorm = initialGradInfNorm = Linf( mGrad ); MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o Initial gradient Inf norm: " << " " << RPM( initialGradInfNorm ) << std::endl; } if( totalFlag & ( GRADIENT_L2_NORM_ABSOLUTE | GRADIENT_L2_NORM_RELATIVE ) ) { currentGradL2NormSquared = initialGradL2NormSquared = length_squared( mGrad ); MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o Initial gradient L2 norm: " << " " << RPM( std::sqrt( initialGradL2NormSquared ) ) << std::endl; } // the OFvalue comes for free, so save it previousOFValue = currentOFValue; initialOFValue = currentOFValue; } // find the initial objective function value if needed and not already // computed. If we needed the gradient, we have the OF value for free. // Also, if possible, get initial OF value if writing plot file. Solvers // often supply the OF value for subsequent iterations so by calculating // the initial value we can generate OF value plots. else if( ( totalFlag & OF_FLAGS ) || ( plotFile.is_open() && pd.num_free_vertices() && obj_eval.have_objective_function() ) ) { // ensure the obj_ptr is not null if( !obj_eval.have_objective_function() ) { MSQ_SETERR( err ) ( "Error termination criteria set which uses objective " "functions, but no objective function is available.", MsqError::INVALID_STATE ); return; } bool b = obj_eval.evaluate( pd, currentOFValue, err );MSQ_ERRRTN( err ); if( !b ) { MSQ_SETERR( err ) ( "Initial patch is invalid for evaluation.", MsqError::INVALID_STATE ); return; } // std::cout<<"\nReseting initial of value = "<<initialOFValue; previousOFValue = currentOFValue; initialOFValue = currentOFValue; } if( totalFlag & ( GRAD_FLAGS | OF_FLAGS ) ) MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o Initial OF value: " << " " << RPM( initialOFValue ) << std::endl; // Store current vertex locations now, because we'll // need them later to compare the current movement with. if( totalFlag & VERTEX_MOVEMENT_RELATIVE ) { if( initialVerticesMemento ) { pd.recreate_vertices_memento( initialVerticesMemento, err ); } else { initialVerticesMemento = pd.create_vertices_memento( err ); } MSQ_ERRRTN( err ); maxSquaredInitialMovement = DBL_MAX; } else { maxSquaredInitialMovement = 0; } if( terminationCriterionFlag & UNTANGLED_MESH ) { globalInvertedCount = count_inverted( pd, err ); // if (innerOuterType==TYPE_OUTER) MSQ_DBGOUT_P0_ONLY(debugLevel) << par_string() << " o // Num Inverted: " << " " << globalInvertedCount << std::endl; patchInvertedCount = 0;MSQ_ERRRTN( err ); } if( timeStepFileType ) { // If didn't already calculate gradient abive, calculate it now. if( !( totalFlag & GRAD_FLAGS ) ) { mGrad.resize( pd.num_free_vertices() ); obj_eval.evaluate( pd, currentOFValue, mGrad, err ); err.clear(); } write_timestep( pd, mGrad.empty() ? 0 : arrptr( mGrad ), err ); } if( plotFile.is_open() ) { // two newlines so GNU plot knows that we are starting a new data set plotFile << std::endl << std::endl; // write column headings as comment in data file plotFile << "#Iter\tCPU\tObjFunc\tGradL2\tGradInf\tMovement\tInverted" << std::endl; // write initial values plotFile << 0 << '\t' << mTimer.since_birth() << '\t' << initialOFValue << '\t' << std::sqrt( currentGradL2NormSquared ) << '\t' << currentGradInfNorm << '\t' << 0.0 << '\t' << globalInvertedCount << std::endl; } }
void MBMesquite::TerminationCriterion::reset_outer | ( | Mesh * | mesh, |
Clear any data accumulated during an outer iteration.
This version of reset is called using a MeshSet, which implies it is only called when this criterion is used as the 'outer' termination criterion.
Definition at line 341 of file TerminationCriterion.cpp.
References MBMesquite::PatchData::attach_settings(), cullingMethodFlag, MBMesquite::PatchData::fill_global_patch(), MBMesquite::GRAD_FLAGS, MSQ_ERRRTN, MBMesquite::OF_FLAGS, reset_inner(), MBMesquite::PatchData::set_domain(), MBMesquite::PatchData::set_mesh(), terminationCriterionFlag, timeStepFileType, MBMesquite::UNTANGLED_MESH, and MBMesquite::VERTEX_MOVEMENT_RELATIVE.
{ const unsigned long totalFlag = terminationCriterionFlag | cullingMethodFlag; PatchData global_patch; if( settings ) global_patch.attach_settings( settings ); // if we need to fill out the global patch data object. if( ( totalFlag & ( GRAD_FLAGS | OF_FLAGS | VERTEX_MOVEMENT_RELATIVE | UNTANGLED_MESH ) ) || timeStepFileType ) { global_patch.set_mesh( mesh ); global_patch.set_domain( domain ); global_patch.fill_global_patch( err );MSQ_ERRRTN( err ); } // now call the other reset reset_inner( global_patch, obj_eval, err );MSQ_ERRRTN( err ); }
void MBMesquite::TerminationCriterion::reset_patch | ( | PatchData & | pd, |
Shared inner and outer initialization during inner loop.
Definition at line 533 of file TerminationCriterion.cpp.
References count_inverted(), MBMesquite::PatchData::create_vertices_memento(), cullingMethodFlag, MBMesquite::MOVEMENT_FLAGS, MSQ_ERRRTN, patchInvertedCount, previousVerticesMemento, MBMesquite::PatchData::recreate_vertices_memento(), terminationCriterionFlag, and MBMesquite::UNTANGLED_MESH.
Referenced by MBMesquite::VertexMover::loop_over_mesh(), TerminationCriterionTest::test_absolute_vertex_movement_edge_length(), TerminationCriterionTest::test_cpu_time_common(), TerminationCriterionTest::test_gradient_common(), TerminationCriterionTest::test_number_of_iterates_inner(), TerminationCriterionTest::test_number_of_iterates_outer(), TerminationCriterionTest::test_quality_common(), TerminationCriterionTest::test_untangled_mesh(), TerminationCriterionTest::test_vertex_bound(), and TerminationCriterionTest::test_vertex_movement_common().
{ const unsigned long totalFlag = terminationCriterionFlag | cullingMethodFlag; if( totalFlag & MOVEMENT_FLAGS ) { if( previousVerticesMemento ) pd.recreate_vertices_memento( previousVerticesMemento, err ); else previousVerticesMemento = pd.create_vertices_memento( err );MSQ_ERRRTN( err ); } if( totalFlag & UNTANGLED_MESH ) { patchInvertedCount = count_inverted( pd, err ); // MSQ_DBGOUT_P0_ONLY(debugLevel) << par_string() << " o Num Patch Inverted: " << " " << // patchInvertedCount << std::endl;MSQ_ERRRTN( err ); } }
MESQUITE_EXPORT void MBMesquite::TerminationCriterion::set_debug_output_level | ( | int | i | ) | [inline] |
Definition at line 277 of file TerminationCriterion.hpp.
References debugLevel.
Referenced by MBMesquite::VertexMover::loop_over_mesh(), and run_global_smoother().
{ debugLevel = i; }
Check if termination criterion has been met.
This function evaluates the needed information and then evaluates the termination criteria. If any of the selected criteria are satisfied, the function returns true. Otherwise, the function returns false.
Definition at line 700 of file TerminationCriterion.cpp.
References MBMesquite::BOUNDED_VERTEX_MOVEMENT, MBMesquite::CPU_TIME, currentGradInfNorm, currentGradL2NormSquared, currentOFValue, debugLevel, MBMesquite::get_parallel_rank(), globalInvertedCount, GNUPLOT, MBMesquite::GRADIENT_INF_NORM_ABSOLUTE, MBMesquite::GRADIENT_INF_NORM_RELATIVE, MBMesquite::GRADIENT_L2_NORM_ABSOLUTE, MBMesquite::GRADIENT_L2_NORM_RELATIVE, gradInfNormAbsoluteEps, gradInfNormRelativeEps, gradL2NormAbsoluteEpsSquared, gradL2NormRelativeEpsSquared, initialGradInfNorm, initialGradL2NormSquared, initialOFValue, innerOuterType, MBMesquite::MsqInterrupt::interrupt(), iterationBound, iterationCounter, lowerOFBound, maxSquaredInitialMovement, maxSquaredMovement, moniker, MBMesquite::MOVEMENT_FLAGS, MSQ_DBG, MSQ_DBGOUT, MSQ_DBGOUT_P0_ONLY, mTimer, MBMesquite::NUMBER_OF_ITERATES, par_string(), previousOFValue, MBMesquite::QUALITY_IMPROVEMENT_ABSOLUTE, MBMesquite::QUALITY_IMPROVEMENT_RELATIVE, qualityImprovementAbsoluteEps, qualityImprovementRelativeEps, RPM, MBMesquite::Timer::since_birth(), MBMesquite::SUCCESSIVE_IMPROVEMENTS_ABSOLUTE, MBMesquite::SUCCESSIVE_IMPROVEMENTS_RELATIVE, successiveImprovementsAbsoluteEps, successiveImprovementsRelativeEps, terminationCriterionFlag, timeBound, timeStepFileName, timeStepFileType, TYPE_OUTER, MBMesquite::UNTANGLED_MESH, MBMesquite::VERTEX_MOVEMENT_ABS_EDGE_LENGTH, MBMesquite::VERTEX_MOVEMENT_ABSOLUTE, MBMesquite::VERTEX_MOVEMENT_RELATIVE, vertexMovementAbsoluteAvgEdge, vertexMovementAbsoluteEps, vertexMovementExceedsBound, vertexMovementRelativeEps, and MBMesquite::MeshWriter::write_gnuplot_overlay().
Referenced by MBMesquite::VertexMover::loop_over_mesh(), MBMesquite::QuasiNewton::optimize_vertex_positions(), MBMesquite::TrustRegion::optimize_vertex_positions(), MBMesquite::ConjugateGradient::optimize_vertex_positions(), MBMesquite::SteepestDescent::optimize_vertex_positions(), MBMesquite::FeasibleNewton::optimize_vertex_positions(), MBMesquite::NonGradient::optimize_vertex_positions(), TerminationCriterionTest::test_absolute_vertex_movement_edge_length(), TerminationCriterionTest::test_cpu_time_common(), TerminationCriterionTest::test_gradient_common(), TerminationCriterionTest::test_number_of_iterates_inner(), TerminationCriterionTest::test_number_of_iterates_outer(), TerminationCriterionTest::test_quality_common(), TerminationCriterionTest::test_untangled_mesh(), TerminationCriterionTest::test_vertex_bound(), and TerminationCriterionTest::test_vertex_movement_common().
{ bool return_flag = false; // std::cout<<"\nInside terminate(pd,of,err): flag = "<<terminationCriterionFlag << std::endl; int type = 0; // First check for an interrupt signal if( MsqInterrupt::interrupt() ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- INTERRUPTED" << " " << std::endl; return true; } // if terminating on numbering of inner iterations if( NUMBER_OF_ITERATES & terminationCriterionFlag && iterationCounter >= iterationBound ) { return_flag = true; type = 1; MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- Reached " << " " << iterationBound << " iterations." << std::endl; } if( CPU_TIME & terminationCriterionFlag && mTimer.since_birth() >= timeBound ) { return_flag = true; type = 2; MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- Exceeded CPU time. " << " " << std::endl; } if( MOVEMENT_FLAGS & terminationCriterionFlag && maxSquaredMovement >= 0.0 ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o Info -- Maximum vertex movement: " << " " << RPM( sqrt( maxSquaredMovement ) ) << std::endl; if( VERTEX_MOVEMENT_ABSOLUTE & terminationCriterionFlag && maxSquaredMovement <= vertexMovementAbsoluteEps ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- VERTEX_MOVEMENT_ABSOLUTE: " << " " << RPM( sqrt( maxSquaredMovement ) ) << std::endl; return_flag = true; type = 3; } if( VERTEX_MOVEMENT_RELATIVE & terminationCriterionFlag && maxSquaredMovement <= vertexMovementRelativeEps * maxSquaredInitialMovement ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- VERTEX_MOVEMENT_RELATIVE: " << " " << RPM( sqrt( maxSquaredMovement ) ) << std::endl; return_flag = true; type = 4; } if( VERTEX_MOVEMENT_ABS_EDGE_LENGTH & terminationCriterionFlag ) { assert( vertexMovementAbsoluteAvgEdge > -1e-12 ); // make sure value actually got calculated if( maxSquaredMovement <= vertexMovementAbsoluteAvgEdge ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- VERTEX_MOVEMENT_ABS_EDGE_LENGTH: " << " " << RPM( sqrt( maxSquaredMovement ) ) << std::endl; return_flag = true; type = 5; } } } if( GRADIENT_L2_NORM_ABSOLUTE & terminationCriterionFlag && currentGradL2NormSquared <= gradL2NormAbsoluteEpsSquared ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- GRADIENT_L2_NORM_ABSOLUTE: " << " " << RPM( currentGradL2NormSquared ) << std::endl; return_flag = true; type = 6; } if( GRADIENT_INF_NORM_ABSOLUTE & terminationCriterionFlag && currentGradInfNorm <= gradInfNormAbsoluteEps ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- GRADIENT_INF_NORM_ABSOLUTE: " << " " << RPM( currentGradInfNorm ) << std::endl; return_flag = true; type = 7; } if( GRADIENT_L2_NORM_RELATIVE & terminationCriterionFlag && currentGradL2NormSquared <= ( gradL2NormRelativeEpsSquared * initialGradL2NormSquared ) ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- GRADIENT_L2_NORM_RELATIVE: " << " " << RPM( currentGradL2NormSquared ) << std::endl; return_flag = true; type = 8; } if( GRADIENT_INF_NORM_RELATIVE & terminationCriterionFlag && currentGradInfNorm <= ( gradInfNormRelativeEps * initialGradInfNorm ) ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- GRADIENT_INF_NORM_RELATIVE: " << " " << RPM( currentGradInfNorm ) << std::endl; return_flag = true; type = 9; } // Quality Improvement and Successive Improvements are below. // The relative forms are only valid after the first iteration. if( ( QUALITY_IMPROVEMENT_ABSOLUTE & terminationCriterionFlag ) && currentOFValue <= qualityImprovementAbsoluteEps ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- QUALITY_IMPROVEMENT_ABSOLUTE: " << " " << RPM( currentOFValue ) << std::endl; return_flag = true; type = 10; } // only valid if an iteration has occurred, see above. if( iterationCounter > 0 ) { if( SUCCESSIVE_IMPROVEMENTS_ABSOLUTE & terminationCriterionFlag && ( previousOFValue - currentOFValue ) <= successiveImprovementsAbsoluteEps ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- SUCCESSIVE_IMPROVEMENTS_ABSOLUTE: previousOFValue= " << " " << previousOFValue << " currentOFValue= " << RPM( currentOFValue ) << " successiveImprovementsAbsoluteEps= " << successiveImprovementsAbsoluteEps << std::endl; return_flag = true; type = 11; } if( QUALITY_IMPROVEMENT_RELATIVE & terminationCriterionFlag && ( currentOFValue - lowerOFBound ) <= qualityImprovementRelativeEps * ( initialOFValue - lowerOFBound ) ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- QUALITY_IMPROVEMENT_RELATIVE: " << " " << std::endl; return_flag = true; type = 12; } if( SUCCESSIVE_IMPROVEMENTS_RELATIVE & terminationCriterionFlag && ( previousOFValue - currentOFValue ) <= successiveImprovementsRelativeEps * ( initialOFValue - currentOFValue ) ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- SUCCESSIVE_IMPROVEMENTS_RELATIVE: previousOFValue= " << " " << previousOFValue << " currentOFValue= " << RPM( currentOFValue ) << " successiveImprovementsRelativeEps= " << successiveImprovementsRelativeEps << std::endl; return_flag = true; type = 13; } } if( BOUNDED_VERTEX_MOVEMENT & terminationCriterionFlag && vertexMovementExceedsBound ) { return_flag = true; type = 14; MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- " << " " << vertexMovementExceedsBound << " vertices out of bounds." << std::endl; } if( UNTANGLED_MESH & terminationCriterionFlag ) { if( innerOuterType == TYPE_OUTER ) { // MSQ_DBGOUT_P0_ONLY(debugLevel) MSQ_DBGOUT( debugLevel ) << par_string() << " o Num Inverted: " << " " << globalInvertedCount << std::endl; } if( !globalInvertedCount ) { MSQ_DBGOUT_P0_ONLY( debugLevel ) << par_string() << " o TermCrit -- UNTANGLED_MESH: " << " " << std::endl; return_flag = true; type = 15; } } // clear this value at the end of each iteration vertexMovementExceedsBound = 0; maxSquaredMovement = -1.0; if( timeStepFileType == GNUPLOT && return_flag ) { MsqError err; MeshWriter::write_gnuplot_overlay( iterationCounter, timeStepFileName.c_str(), err ); } if( 0 && return_flag && MSQ_DBG( 2 ) ) std::cout << "P[" << get_parallel_rank() << "] tmp TerminationCriterion::terminate: " << moniker << " return_flag= " << return_flag << " type= " << type << " terminationCriterionFlag= " << terminationCriterionFlag << " debugLevel= " << debugLevel << std::endl; // if none of the criteria were satisfied return return_flag; }
void MBMesquite::TerminationCriterion::write_iterations | ( | const char * | filename, |
Definition at line 1145 of file TerminationCriterion.cpp.
References MBMesquite::MsqError::FILE_ACCESS, filename, MSQ_SETERR, and plotFile.
Referenced by run().
{ if( filename ) { plotFile.open( filename, std::ios::trunc ); if( !plotFile ) MSQ_SETERR( err ) ( MsqError::FILE_ACCESS, "Failed to open plot data file: '%s'", filename ); } else { plotFile.close(); } }
MESQUITE_EXPORT void MBMesquite::TerminationCriterion::write_mesh_steps | ( | const char * | filename, |
TimeStepFileType | type = VTK |
) | [inline] |
Write mesh improvement animation.
Write mesh at each iteration such that the sequence of mesh files can be used to produce an animation of the mesh through the quality improvement process.
Files can be written either as VTK timesteps for viewing in a tool such as Paraview or as GNU plot data files and a GNU plot script which, in combination with recent versions of GNU plot, can be used to produce an animated GIF image.
Writing of mesh steps can be disabled by calling this function with type == NOTYPE and filename ==NULL.
Definition at line 301 of file TerminationCriterion.hpp.
References filename, timeStepFileName, and timeStepFileType.
Referenced by main().
{ timeStepFileName = filename; timeStepFileType = type; }
void MBMesquite::TerminationCriterion::write_timestep | ( | PatchData & | pd, |
const Vector3D * | gradient, | ||
) | [protected] |
Definition at line 1130 of file TerminationCriterion.cpp.
References MBMesquite::PatchData::get_mesh(), GNUPLOT, MBMesquite::gradient(), iterationCounter, timeStepFileName, timeStepFileType, VTK, write_gnuplot(), and write_vtk.
Referenced by accumulate_inner(), and reset_inner().
{ std::ostringstream str; if( timeStepFileType == VTK ) { str << timeStepFileName << '_' << iterationCounter << ".vtk"; MeshWriter::write_vtk( pd, str.str().c_str(), err, gradient ); } else if( timeStepFileType == GNUPLOT ) { str << timeStepFileName << '.' << iterationCounter; MeshWriter::write_gnuplot( pd.get_mesh(), str.str().c_str(), err ); } }
friend class VertexMover [friend] |
Definition at line 364 of file TerminationCriterion.hpp.
double MBMesquite::TerminationCriterion::boundedVertexMovementEps [private] |
Definition at line 424 of file TerminationCriterion.hpp.
Referenced by accumulate_patch(), add_bounded_vertex_movement(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::cullingEps [private] |
Definition at line 378 of file TerminationCriterion.hpp.
Referenced by cull_on_absolute_quality_improvement(), cull_on_absolute_successive_improvement(), cull_on_absolute_vertex_movement(), cull_on_relative_quality_improvement(), cull_on_relative_successive_improvement(), cull_on_relative_vertex_movement(), cull_vertices(), initialize_queue(), and TerminationCriterion().
bool MBMesquite::TerminationCriterion::cullingGlobalPatch [private] |
enable culling of pieces of a global patch
Definition at line 380 of file TerminationCriterion.hpp.
Referenced by cull_for_global_patch(), cull_vertices_global(), and TerminationCriterion().
long unsigned int MBMesquite::TerminationCriterion::cullingMethodFlag [private] |
Bit flag of criterion for culling
Definition at line 376 of file TerminationCriterion.hpp.
Referenced by accumulate_patch(), cull_on_absolute_quality_improvement(), cull_on_absolute_successive_improvement(), cull_on_absolute_vertex_movement(), cull_on_absolute_vertex_movement_edge_length(), cull_on_relative_quality_improvement(), cull_on_relative_successive_improvement(), cull_on_relative_vertex_movement(), cull_untangled_mesh(), cull_vertices(), initialize_queue(), remove_culling(), reset_inner(), reset_outer(), reset_patch(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::currentGradInfNorm [private] |
Definition at line 395 of file TerminationCriterion.hpp.
double MBMesquite::TerminationCriterion::currentGradL2NormSquared [private] |
Definition at line 391 of file TerminationCriterion.hpp.
double MBMesquite::TerminationCriterion::currentOFValue [private] |
Definition at line 385 of file TerminationCriterion.hpp.
Referenced by accumulate_inner(), cull_vertices(), get_current_function_value(), reset_inner(), terminate(), and TerminationCriterion().
int MBMesquite::TerminationCriterion::debugLevel [private] |
Definition at line 431 of file TerminationCriterion.hpp.
Referenced by accumulate_inner(), reset_inner(), set_debug_output_level(), and terminate().
size_t MBMesquite::TerminationCriterion::globalInvertedCount [private] |
number of inverted elements in entire mesh
Definition at line 428 of file TerminationCriterion.hpp.
Referenced by accumulate_inner(), accumulate_patch(), MBMesquite::VertexMover::loop_over_mesh(), reset_inner(), terminate(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::gradInfNormAbsoluteEps [private] |
Definition at line 396 of file TerminationCriterion.hpp.
Referenced by add_absolute_gradient_inf_norm(), terminate(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::gradInfNormRelativeEps [private] |
Definition at line 397 of file TerminationCriterion.hpp.
Referenced by add_relative_gradient_inf_norm(), terminate(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::gradL2NormAbsoluteEpsSquared [private] |
Definition at line 392 of file TerminationCriterion.hpp.
Referenced by add_absolute_gradient_L2_norm(), terminate(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::gradL2NormRelativeEpsSquared [private] |
Definition at line 393 of file TerminationCriterion.hpp.
Referenced by add_relative_gradient_L2_norm(), terminate(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::initialGradInfNorm [private] |
Definition at line 394 of file TerminationCriterion.hpp.
Referenced by reset_inner(), terminate(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::initialGradL2NormSquared [private] |
Definition at line 390 of file TerminationCriterion.hpp.
double MBMesquite::TerminationCriterion::initialOFValue [private] |
Definition at line 383 of file TerminationCriterion.hpp.
Referenced by cull_vertices(), reset_inner(), terminate(), and TerminationCriterion().
Definition at line 410 of file TerminationCriterion.hpp.
Referenced by accumulate_inner(), cleanup(), cull_vertices(), and reset_inner().
Definition at line 440 of file TerminationCriterion.hpp.
Referenced by terminate().
int MBMesquite::TerminationCriterion::iterationBound [private] |
Definition at line 404 of file TerminationCriterion.hpp.
Referenced by add_iteration_limit(), terminate(), and TerminationCriterion().
int MBMesquite::TerminationCriterion::iterationCounter [private] |
Definition at line 405 of file TerminationCriterion.hpp.
Referenced by accumulate_inner(), get_iteration_count(), reset_inner(), terminate(), TerminationCriterion(), and write_timestep().
double MBMesquite::TerminationCriterion::lowerOFBound [private] |
Definition at line 386 of file TerminationCriterion.hpp.
Referenced by cull_vertices(), terminate(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::maxSquaredInitialMovement [private] |
Definition at line 417 of file TerminationCriterion.hpp.
double MBMesquite::TerminationCriterion::maxSquaredMovement [private] |
Definition at line 418 of file TerminationCriterion.hpp.
Referenced by accumulate_inner(), accumulate_patch(), reset_inner(), and terminate().
std::vector< Vector3D > MBMesquite::TerminationCriterion::mGrad [private] |
Definition at line 389 of file TerminationCriterion.hpp.
std::string MBMesquite::TerminationCriterion::moniker [private] |
Definition at line 439 of file TerminationCriterion.hpp.
Referenced by par_string(), and terminate().
Definition at line 407 of file TerminationCriterion.hpp.
size_t MBMesquite::TerminationCriterion::patchInvertedCount [private] |
number of inverted elements in previously tested patch
Definition at line 429 of file TerminationCriterion.hpp.
Referenced by accumulate_patch(), cull_vertices(), MBMesquite::VertexMover::loop_over_mesh(), reset_inner(), reset_patch(), and TerminationCriterion().
std::ofstream MBMesquite::TerminationCriterion::plotFile [private] |
Plot data.
Definition at line 434 of file TerminationCriterion.hpp.
Referenced by accumulate_inner(), reset_inner(), and write_iterations().
double MBMesquite::TerminationCriterion::previousOFValue [private] |
Definition at line 384 of file TerminationCriterion.hpp.
Referenced by accumulate_inner(), reset_inner(), terminate(), and TerminationCriterion().
Definition at line 411 of file TerminationCriterion.hpp.
Referenced by accumulate_patch(), cleanup(), cull_vertices(), and reset_patch().
double MBMesquite::TerminationCriterion::qualityImprovementAbsoluteEps [private] |
Definition at line 401 of file TerminationCriterion.hpp.
Referenced by add_absolute_quality_improvement(), terminate(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::qualityImprovementRelativeEps [private] |
Definition at line 402 of file TerminationCriterion.hpp.
Referenced by add_relative_quality_improvement(), terminate(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::successiveImprovementsAbsoluteEps [private] |
Definition at line 421 of file TerminationCriterion.hpp.
Referenced by add_absolute_successive_improvement(), terminate(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::successiveImprovementsRelativeEps [private] |
Definition at line 422 of file TerminationCriterion.hpp.
Referenced by add_relative_successive_improvement(), terminate(), and TerminationCriterion().
long unsigned int MBMesquite::TerminationCriterion::terminationCriterionFlag [private] |
Bit flag of termination crit.
Definition at line 375 of file TerminationCriterion.hpp.
Referenced by accumulate_inner(), accumulate_outer(), accumulate_patch(), add_absolute_gradient_inf_norm(), add_absolute_gradient_L2_norm(), add_absolute_quality_improvement(), add_absolute_successive_improvement(), add_absolute_vertex_movement(), add_absolute_vertex_movement_edge_length(), add_bounded_vertex_movement(), add_cpu_time(), add_iteration_limit(), add_relative_gradient_inf_norm(), add_relative_gradient_L2_norm(), add_relative_quality_improvement(), add_relative_successive_improvement(), add_relative_vertex_movement(), add_untangled_mesh(), criterion_is_set(), initialize_queue(), remove_all_criteria(), reset_inner(), reset_outer(), reset_patch(), terminate(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::timeBound [private] |
Definition at line 408 of file TerminationCriterion.hpp.
Referenced by add_cpu_time(), terminate(), and TerminationCriterion().
std::string MBMesquite::TerminationCriterion::timeStepFileName [private] |
Base name for timestep files.
Definition at line 437 of file TerminationCriterion.hpp.
Referenced by terminate(), write_mesh_steps(), and write_timestep().
Definition at line 438 of file TerminationCriterion.hpp.
Referenced by accumulate_inner(), accumulate_outer(), reset_inner(), reset_outer(), terminate(), write_mesh_steps(), and write_timestep().
double MBMesquite::TerminationCriterion::vertexMovementAbsoluteAvgEdge [private] |
calculated constant for VERTEX_MOVEMENT_ABS_EDGE_LENGTH
Definition at line 415 of file TerminationCriterion.hpp.
Referenced by initialize_queue(), terminate(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::vertexMovementAbsoluteEps [private] |
Definition at line 412 of file TerminationCriterion.hpp.
Referenced by add_absolute_vertex_movement(), terminate(), and TerminationCriterion().
double MBMesquite::TerminationCriterion::vertexMovementAvgBeta [private] |
input beta value used to calculate vertexMovementAbsoluteAvg
Definition at line 414 of file TerminationCriterion.hpp.
Referenced by add_absolute_vertex_movement_edge_length(), cull_on_absolute_vertex_movement_edge_length(), initialize_queue(), and TerminationCriterion().
Definition at line 425 of file TerminationCriterion.hpp.
Referenced by accumulate_patch(), reset_inner(), and terminate().
double MBMesquite::TerminationCriterion::vertexMovementRelativeEps [private] |
Definition at line 413 of file TerminationCriterion.hpp.
Referenced by add_relative_vertex_movement(), terminate(), and TerminationCriterion().
