MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 [email protected] 00024 00025 ***************************************************************** */ 00026 #include <iostream> 00027 #include <sstream> 00028 using std::cerr; 00029 using std::cout; 00030 using std::endl; 00031 00032 #include <cstdlib> 00033 00034 #include "Mesquite.hpp" 00035 #include "MeshImpl.hpp" 00036 #include "MsqError.hpp" 00037 #include "InstructionQueue.hpp" 00038 #include "TerminationCriterion.hpp" 00039 #include "QualityAssessor.hpp" 00040 #include "PlanarDomain.hpp" 00041 00042 #include "IdealWeightInverseMeanRatio.hpp" 00043 #include "ElementPMeanP.hpp" 00044 #include "TInverseMeanRatio.hpp" 00045 #include "TQualityMetric.hpp" 00046 #include "TOffset.hpp" 00047 #include "TOffset.hpp" 00048 00049 #include "IdealShapeTarget.hpp" 00050 #include "PMeanPTemplate.hpp" 00051 #include "SteepestDescent.hpp" 00052 #include "ConjugateGradient.hpp" 00053 #include "QuasiNewton.hpp" 00054 00055 #include "MeshWriter.hpp" 00056 #include "MsqTimer.hpp" 00057 #include "TestUtil.hpp" 00058 00059 using namespace MBMesquite; 00060 00061 std::string DEFAULT_INPUT = TestDir + "unittest/mesquite/2D/vtk/tris/untangled/equil_tri2.vtk"; 00062 00063 /* Print usage or help information: exits if err == true */ 00064 void usage( const char* argv0 = 0, bool err = true ) 00065 { 00066 std::ostream& s = err ? cerr : cout; 00067 const char* defname = "main"; 00068 if( !argv0 ) argv0 = defname; 00069 00070 s << "Usage: " << defname << " [-n|-c|-q] [-e] [-t] [-a] [-N] [{-v|-g|-p} <output_file>] [<input_file>]" << endl 00071 << " " << defname << " -h" << std::endl; 00072 00073 if( err ) exit( 1 ); 00074 00075 s << " -n : Use SteepestDescent solver (default)" << endl 00076 << " -c : Use ConjugateGradient solver" << endl 00077 << " -q : Use QuasiNewton solver" << endl 00078 << " -e : Test IdealWeightInverseMeanRatio metric" << endl 00079 << " -t : Test InverseMeanRatio3D target metric" << endl 00080 << " -a : Test ElementPMeanP(InverseMeanRatio3D)" << endl 00081 << " -N : Test InverseMeanRatio3D with finite difference derivatives" << endl 00082 << " -C : Compare InverseMeanRatio3D and IdealWeightInverseMeanRatio" << endl 00083 << " -v : Write output mesh to specified VTK file" << endl 00084 << " -g : Write output mesh to specified GnuPlot file" << endl 00085 << " -p : Write output mesh to specified EPS file" << endl 00086 << " -P : Write solver plot data to specified file." << endl 00087 << "Default is all metrics if non specified." << endl 00088 << "Default input file: " << DEFAULT_INPUT << endl; 00089 } 00090 00091 const char* vtk_file = 0; /* vtk output file name */ 00092 const char* eps_file = 0; /* eps output file name */ 00093 const char* gpt_file = 0; /* GNUPlot output file name */ 00094 const char* plot_file = 0; /* Time-dependent plot of solver data */ 00095 00096 enum Solver 00097 { 00098 STEEP_DESCENT, 00099 CONJ_GRAD, 00100 QUASI_NEWT 00101 }; 00102 00103 /* Run an optimization: returns average quality of final mesh */ 00104 double run( QualityMetric* metric, Solver solver, const char* input_file, double& seconds_out, int& iterations_out ); 00105 00106 /* Force finite difference approximation of derivatives for 00107 * an existing quality metric */ 00108 class NumericQM : public QualityMetric 00109 { 00110 private: 00111 QualityMetric* realMetric; 00112 00113 public: 00114 NumericQM( QualityMetric* real_metric ) : realMetric( real_metric ) {} 00115 virtual MetricType get_metric_type() const; 00116 virtual std::string get_name() const; 00117 virtual int get_negate_flag() const; 00118 virtual void get_evaluations( PatchData& pd, 00119 std::vector< size_t >& handles, 00120 bool free_vertices_only, 00121 MsqError& err ); 00122 virtual bool evaluate( PatchData& pd, size_t handle, double& value, MsqError& err ); 00123 virtual bool evaluate_with_indices( PatchData& pd, 00124 size_t handle, 00125 double& value, 00126 std::vector< size_t >& indices, 00127 MsqError& err ); 00128 }; 00129 QualityMetric::MetricType NumericQM::get_metric_type() const 00130 { 00131 return realMetric->get_metric_type(); 00132 } 00133 std::string NumericQM::get_name() const 00134 { 00135 std::string r = realMetric->get_name(); 00136 r += " (FD)"; 00137 return r; 00138 } 00139 00140 /* At each evaluation of this metric, compare the values resulting 00141 * from the evaluation of two other metrics: flag an error if they 00142 * differ or return the common result if the same */ 00143 class CompareMetric : public QualityMetric 00144 { 00145 private: 00146 QualityMetric *metric1, *metric2; 00147 bool maskPlane; 00148 int maskAxis; 00149 std::vector< size_t > m2Handles; 00150 std::vector< Vector3D > m2Grad; 00151 std::vector< SymMatrix3D > m2Diag; 00152 std::vector< Matrix3D > m2Hess; 00153 static const double epsilon; 00154 00155 public: 00156 CompareMetric( QualityMetric* qm1, QualityMetric* qm2, bool mask_qm2_coord = false ) 00157 : metric1( qm1 ), metric2( qm2 ), maskPlane( mask_qm2_coord ), maskAxis( -1 ) 00158 { 00159 } 00160 00161 MetricType get_metric_type() const; 00162 00163 std::string get_name() const; 00164 00165 int get_negate_flag() const; 00166 00167 void get_evaluations( PatchData& pd, std::vector< size_t >& handles, bool free_vertices_only, MsqError& err ); 00168 00169 bool evaluate( PatchData& pd, size_t handle, double& value, MsqError& err ); 00170 00171 bool evaluate_with_indices( PatchData& pd, 00172 size_t handle, 00173 double& value, 00174 std::vector< size_t >& indices, 00175 MsqError& err ); 00176 00177 bool evaluate_with_gradient( PatchData& pd, 00178 size_t handle, 00179 double& value, 00180 std::vector< size_t >& indices, 00181 std::vector< Vector3D >& gradient, 00182 MsqError& err ); 00183 00184 bool evaluate_with_Hessian_diagonal( PatchData& pd, 00185 size_t handle, 00186 double& value, 00187 std::vector< size_t >& indices, 00188 std::vector< Vector3D >& gradient, 00189 std::vector< SymMatrix3D >& Hessian_diagonal, 00190 MsqError& err ); 00191 00192 bool evaluate_with_Hessian( PatchData& pd, 00193 size_t handle, 00194 double& value, 00195 std::vector< size_t >& indices, 00196 std::vector< Vector3D >& gradient, 00197 std::vector< Matrix3D >& Hessian, 00198 MsqError& err ); 00199 00200 void get_mask_axis( PatchData& pd ); 00201 bool equal( Vector3D grad1, const Vector3D& grad2 ) const; 00202 bool equal( SymMatrix3D hess1, const SymMatrix3D& hess2 ) const; 00203 bool equal( Matrix3D hess1, const Matrix3D& hess2 ) const; 00204 }; 00205 const double CompareMetric::epsilon = 5e-2; 00206 00207 /* Parse command line options and call 'run' */ 00208 int main( int argc, char* argv[] ) 00209 { 00210 Solver solver = STEEP_DESCENT; 00211 bool do_non_target_metric = false; 00212 bool do_new_target_metric = false; 00213 bool do_new_target_average = false; 00214 bool do_new_target_numeric = false; 00215 bool do_compare_metric = false; 00216 const char* input_file = DEFAULT_INPUT.c_str(); 00217 bool no_more_flags = false; 00218 00219 std::list< const char** > exp_list; 00220 for( int i = 1; i < argc; ++i ) 00221 { 00222 if( argv[i][0] == '-' && !no_more_flags ) 00223 { 00224 for( int k = 1; argv[i][k]; ++k ) 00225 { 00226 switch( argv[i][k] ) 00227 { 00228 case 'n': 00229 solver = STEEP_DESCENT; 00230 break; 00231 case 'c': 00232 solver = CONJ_GRAD; 00233 break; 00234 case 'q': 00235 solver = QUASI_NEWT; 00236 break; 00237 case 'e': 00238 do_non_target_metric = true; 00239 break; 00240 case 't': 00241 do_new_target_metric = true; 00242 break; 00243 case 'a': 00244 do_new_target_average = true; 00245 break; 00246 case 'N': 00247 do_new_target_numeric = true; 00248 break; 00249 case 'C': 00250 do_compare_metric = true; 00251 break; 00252 case 'v': 00253 exp_list.push_back( &vtk_file ); 00254 break; 00255 case 'g': 00256 exp_list.push_back( &gpt_file ); 00257 break; 00258 case 'p': 00259 exp_list.push_back( &eps_file ); 00260 break; 00261 case 'P': 00262 exp_list.push_back( &plot_file ); 00263 break; 00264 case 'h': 00265 usage( argv[0], false ); 00266 return 0; 00267 case '-': 00268 no_more_flags = true; 00269 break; 00270 default: 00271 cerr << "Invalid flag: '" << argv[i][k] << "'" << endl; 00272 usage( argv[0] ); 00273 } 00274 } 00275 } 00276 else if( !exp_list.empty() ) 00277 { 00278 const char** ptr = exp_list.front(); 00279 exp_list.pop_front(); 00280 *ptr = argv[i]; 00281 } 00282 else 00283 { 00284 if( !DEFAULT_INPUT.compare( input_file ) ) 00285 { 00286 cerr << "Unexpected argument: \"" << argv[i] << '"' << endl; 00287 usage( argv[0] ); 00288 } 00289 input_file = argv[i]; 00290 } 00291 } 00292 00293 int count = 0; 00294 if( do_non_target_metric ) ++count; 00295 if( do_new_target_metric ) ++count; 00296 if( do_new_target_average ) ++count; 00297 if( do_new_target_numeric ) ++count; 00298 if( do_compare_metric ) ++count; 00299 00300 if( !count ) 00301 { 00302 do_compare_metric = true; 00303 count = 1; 00304 } 00305 00306 if( ( vtk_file || gpt_file || eps_file ) && count != 1 ) 00307 { 00308 cerr << "Error: Cannot write output file if running multiple tests" << endl; 00309 return 2; 00310 } 00311 00312 IdealWeightInverseMeanRatio non_target_metric; 00313 IdealShapeTarget new_target; 00314 TInverseMeanRatio tmp; 00315 TOffset tmp_off( 1.0, &tmp ); // target metrics are zero-based 00316 TQualityMetric new_target_metric( &new_target, &tmp_off ); 00317 ElementPMeanP new_target_average( 1.0, &new_target_metric ); 00318 NumericQM new_target_numeric( &new_target_metric ); 00319 CompareMetric comp_metric( &non_target_metric, &new_target_average, true ); 00320 00321 std::ostringstream os; 00322 double secs, qual; 00323 if( do_non_target_metric ) 00324 { 00325 qual = run( &non_target_metric, solver, input_file, secs, count ); 00326 os << "IdealWeightInverseMeanRatio: " << qual << " after " << count << " iterations in " << secs << " seconds" 00327 << endl; 00328 } 00329 if( do_new_target_metric ) 00330 { 00331 qual = run( &new_target_metric, solver, input_file, secs, count ); 00332 os << "TQualityMetric : " << qual << " after " << count << " iterations in " << secs << " seconds" 00333 << endl; 00334 } 00335 if( do_new_target_average ) 00336 { 00337 qual = run( &new_target_average, solver, input_file, secs, count ); 00338 os << "ElementPMeanP : " << qual << " after " << count << " iterations in " << secs << " seconds" 00339 << endl; 00340 } 00341 if( do_new_target_numeric ) 00342 { 00343 qual = run( &new_target_numeric, solver, input_file, secs, count ); 00344 os << "TQualityMetric (FD) : " << qual << " after " << count << " iterations in " << secs << " seconds" 00345 << endl; 00346 } 00347 if( do_compare_metric ) 00348 { 00349 qual = run( &comp_metric, solver, input_file, secs, count ); 00350 os << "Metric comparison : " << qual << " after " << count << " iterations in " << secs << " seconds" 00351 << endl; 00352 } 00353 00354 cout << endl << os.str() << endl; 00355 return 0; 00356 } 00357 00358 double run( QualityMetric* metric, 00359 Solver solver_type, 00360 const char* input_file, 00361 double& seconds_out, 00362 int& iterations_out ) 00363 { 00364 MsqPrintError err( cerr ); 00365 IdealWeightInverseMeanRatio qa_metric; 00366 TerminationCriterion inner, outer; 00367 outer.add_iteration_limit( 1 ); 00368 inner.add_absolute_vertex_movement( 1e-4 ); 00369 inner.add_iteration_limit( 100 ); 00370 PMeanPTemplate of( 1.0, metric ); 00371 QualityAssessor qa( &qa_metric ); 00372 qa.add_quality_assessment( metric ); 00373 InstructionQueue q; 00374 SteepestDescent steep( &of ); 00375 QuasiNewton quasi( &of ); 00376 ConjugateGradient conj( &of ); 00377 VertexMover* solver = 0; 00378 switch( solver_type ) 00379 { 00380 case STEEP_DESCENT: 00381 solver = &steep; 00382 break; 00383 case QUASI_NEWT: 00384 solver = &quasi; 00385 break; 00386 case CONJ_GRAD: 00387 solver = &conj; 00388 break; 00389 } 00390 q.set_master_quality_improver( solver, err ); 00391 q.add_quality_assessor( &qa, err ); 00392 solver->set_inner_termination_criterion( &inner ); 00393 solver->set_outer_termination_criterion( &outer ); 00394 00395 if( plot_file ) inner.write_iterations( plot_file, err ); 00396 00397 MeshImpl mesh; 00398 mesh.read_vtk( input_file, err ); 00399 if( err ) 00400 { 00401 cerr << "Failed to read input file: \"" << input_file << '"' << endl; 00402 exit( 1 ); 00403 } 00404 00405 std::vector< Mesh::VertexHandle > handles; 00406 mesh.get_all_vertices( handles, err ); 00407 if( handles.empty() ) 00408 { 00409 cerr << "no veritces in mesh" << endl; 00410 exit( 1 ); 00411 } 00412 std::vector< MsqVertex > coords( handles.size() ); 00413 mesh.vertices_get_coordinates( arrptr( handles ), arrptr( coords ), handles.size(), err ); 00414 Vector3D min( HUGE_VAL ), max( -HUGE_VAL ); 00415 for( size_t i = 0; i < coords.size(); ++i ) 00416 { 00417 for( int j = 0; j < 3; ++j ) 00418 { 00419 if( coords[i][j] < min[j] ) min[j] = coords[i][j]; 00420 if( coords[i][j] > max[j] ) max[j] = coords[i][j]; 00421 } 00422 } 00423 00424 Vector3D size = max - min; 00425 PlanarDomain* domain = 0; 00426 if( size[0] < 1e-4 ) 00427 domain = new PlanarDomain( PlanarDomain::YZ, min[0] ); 00428 else if( size[1] < 1e-4 ) 00429 domain = new PlanarDomain( PlanarDomain::XZ, min[1] ); 00430 else if( size[2] < 1e-4 ) 00431 domain = new PlanarDomain( PlanarDomain::XY, min[2] ); 00432 00433 Timer timer; 00434 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, domain ); 00435 q.run_instructions( &mesh_and_domain, err ); 00436 seconds_out = timer.since_birth(); 00437 if( err ) 00438 { 00439 cerr << "Optimization failed." << endl << err << endl; 00440 abort(); 00441 } 00442 00443 if( vtk_file ) 00444 { 00445 MeshWriter::write_vtk( &mesh, vtk_file, err ); 00446 if( err ) cerr << vtk_file << ": failed to write file." << endl; 00447 } 00448 if( gpt_file ) 00449 { 00450 MeshWriter::write_gnuplot( &mesh, gpt_file, err ); 00451 if( err ) cerr << gpt_file << ": failed to write file." << endl; 00452 } 00453 if( eps_file ) 00454 { 00455 PlanarDomain xy( PlanarDomain::XY ); 00456 MeshWriter::Projection proj( domain ? domain : &xy ); 00457 MeshWriter::write_eps( &mesh, eps_file, proj, err ); 00458 if( err ) cerr << eps_file << ": failed to write file." << endl; 00459 } 00460 delete domain; 00461 00462 iterations_out = inner.get_iteration_count(); 00463 00464 const QualityAssessor::Assessor* a = qa.get_results( &qa_metric ); 00465 return a->get_average(); 00466 } 00467 00468 int NumericQM::get_negate_flag() const 00469 { 00470 return realMetric->get_negate_flag(); 00471 } 00472 00473 void NumericQM::get_evaluations( PatchData& pd, std::vector< size_t >& handles, bool free_vertices_only, MsqError& err ) 00474 { 00475 realMetric->get_evaluations( pd, handles, free_vertices_only, err ); 00476 } 00477 00478 bool NumericQM::evaluate( PatchData& pd, size_t handle, double& value, MsqError& err ) 00479 { 00480 return realMetric->evaluate( pd, handle, value, err ); 00481 } 00482 00483 bool NumericQM::evaluate_with_indices( PatchData& pd, 00484 size_t handle, 00485 double& value, 00486 std::vector< size_t >& indices, 00487 MsqError& err ) 00488 { 00489 return realMetric->evaluate_with_indices( pd, handle, value, indices, err ); 00490 } 00491 00492 QualityMetric::MetricType CompareMetric::get_metric_type() const 00493 { 00494 MetricType t1 = metric1->get_metric_type(); 00495 assert( metric2->get_metric_type() == t1 ); 00496 return t1; 00497 } 00498 00499 std::string CompareMetric::get_name() const 00500 { 00501 std::string n = metric1->get_name(); 00502 n += " =? "; 00503 n += metric2->get_name(); 00504 return n; 00505 } 00506 00507 int CompareMetric::get_negate_flag() const 00508 { 00509 assert( metric1->get_negate_flag() == metric2->get_negate_flag() ); 00510 return metric1->get_negate_flag(); 00511 } 00512 00513 void CompareMetric::get_evaluations( PatchData& pd, 00514 std::vector< size_t >& handles, 00515 bool free_vertices_only, 00516 MsqError& err ) 00517 { 00518 if( maskPlane ) get_mask_axis( pd ); 00519 00520 m2Handles.clear(); 00521 metric1->get_evaluations( pd, handles, free_vertices_only, err );MSQ_ERRRTN( err ); 00522 metric2->get_evaluations( pd, m2Handles, free_vertices_only, err );MSQ_ERRRTN( err ); 00523 bool same = ( handles.size() == m2Handles.size() ); 00524 std::sort( m2Handles.begin(), m2Handles.end() ); 00525 for( std::vector< size_t >::iterator i = handles.begin(); i != handles.end(); ++i ) 00526 if( !std::binary_search( m2Handles.begin(), m2Handles.end(), *i ) ) same = false; 00527 if( !same ) 00528 { 00529 MSQ_SETERR( err ) 00530 ( "Metrics have incompatible lists of evaluation handles.\n", MsqError::INVALID_STATE ); 00531 } 00532 } 00533 00534 bool CompareMetric::evaluate( PatchData& pd, size_t handle, double& value, MsqError& err ) 00535 { 00536 double m2val; 00537 bool r1, r2; 00538 r1 = metric1->evaluate( pd, handle, value, err ); 00539 MSQ_ERRZERO( err ); 00540 r2 = metric2->evaluate( pd, handle, m2val, err ); 00541 MSQ_ERRZERO( err ); 00542 if( r1 != r2 || ( r1 && fabs( value - m2val ) > epsilon ) ) 00543 { 00544 MSQ_SETERR( err ) 00545 ( MsqError::INVALID_STATE, 00546 "Metrics returned different values for handle %lu " 00547 "in evaluate:\n" 00548 "\t%s %f vs. %s %f\n", 00549 (unsigned long)handle, r1 ? "true" : "false", value, r2 ? "true" : "false", m2val ); 00550 } 00551 00552 return r1 && !err; 00553 } 00554 00555 bool CompareMetric::evaluate_with_indices( PatchData& pd, 00556 size_t handle, 00557 double& value, 00558 std::vector< size_t >& indices, 00559 MsqError& err ) 00560 { 00561 double m2val; 00562 bool r1, r2; 00563 m2Handles.clear(); 00564 r1 = metric1->evaluate_with_indices( pd, handle, value, indices, err ); 00565 MSQ_ERRZERO( err ); 00566 r2 = metric2->evaluate_with_indices( pd, handle, m2val, m2Handles, err ); 00567 MSQ_ERRZERO( err ); 00568 if( r1 != r2 || ( r1 && fabs( value - m2val ) > epsilon ) ) 00569 { 00570 MSQ_SETERR( err ) 00571 ( MsqError::INVALID_STATE, 00572 "Metrics returned different values for handle %lu " 00573 "in evaluate_with_indices:\n" 00574 "\t%s %f vs. %s %f\n", 00575 (unsigned long)handle, r1 ? "true" : "false", value, r2 ? "true" : "false", m2val ); 00576 } 00577 else 00578 { 00579 bool same = ( indices.size() == m2Handles.size() ); 00580 std::sort( m2Handles.begin(), m2Handles.end() ); 00581 for( std::vector< size_t >::iterator i = indices.begin(); i != indices.end(); ++i ) 00582 if( !std::binary_search( m2Handles.begin(), m2Handles.end(), *i ) ) same = false; 00583 if( !same ) 00584 { 00585 MSQ_SETERR( err ) 00586 ( MsqError::INVALID_STATE, 00587 "Metrics returned incompatible lists of vertex indices" 00588 " for handle %lu in evaluate_with_indices\n.", 00589 (unsigned long)handle ); 00590 } 00591 } 00592 00593 return r1 && !err; 00594 } 00595 00596 bool CompareMetric::evaluate_with_gradient( PatchData& pd, 00597 size_t handle, 00598 double& value, 00599 std::vector< size_t >& indices, 00600 std::vector< Vector3D >& gradient, 00601 MsqError& err ) 00602 { 00603 double m2val; 00604 bool r1, r2; 00605 m2Handles.clear(); 00606 m2Grad.clear(); 00607 r1 = metric1->evaluate_with_gradient( pd, handle, value, indices, gradient, err ); 00608 MSQ_ERRZERO( err ); 00609 r2 = metric2->evaluate_with_gradient( pd, handle, m2val, m2Handles, m2Grad, err ); 00610 MSQ_ERRZERO( err ); 00611 if( r1 != r2 || ( r1 && fabs( value - m2val ) > epsilon ) ) 00612 { 00613 MSQ_SETERR( err ) 00614 ( MsqError::INVALID_STATE, 00615 "Metrics returned different values for handle %lu in " 00616 "evaluate_with_gradient:\n" 00617 "\t%s %f vs. %s %f\n", 00618 (unsigned long)handle, r1 ? "true" : "false", value, r2 ? "true" : "false", m2val ); 00619 } 00620 else 00621 { 00622 std::vector< size_t >::const_iterator i, j; 00623 std::vector< Vector3D >::const_iterator r, s; 00624 int grad_diff = 0; 00625 bool same = ( indices.size() == m2Handles.size() ); 00626 std::sort( m2Handles.begin(), m2Handles.end() ); 00627 for( i = indices.begin(); i != indices.end(); ++i ) 00628 { 00629 j = std::lower_bound( m2Handles.begin(), m2Handles.end(), *i ); 00630 if( j == m2Handles.end() || *j != *i ) 00631 { 00632 same = false; 00633 continue; 00634 } 00635 00636 r = gradient.begin() + ( i - indices.begin() ); 00637 s = m2Grad.begin() + ( j - m2Handles.begin() ); 00638 if( !equal( *r, *s ) ) ++grad_diff; 00639 } 00640 00641 if( !same ) 00642 { 00643 MSQ_SETERR( err ) 00644 ( MsqError::INVALID_STATE, 00645 "Metrics returned incompatible lists of vertex indices" 00646 " for handle %lu in evaluate_with_gradient\n.", 00647 (unsigned long)handle ); 00648 } 00649 else if( grad_diff ) 00650 { 00651 MSQ_SETERR( err ) 00652 ( MsqError::INVALID_STATE, 00653 "Metrics returned different gradient vectors for " 00654 " %d of %u vertices for handle %lu in " 00655 "evaluate_with_gradient\n.", 00656 grad_diff, (unsigned)gradient.size(), (unsigned long)handle ); 00657 } 00658 } 00659 00660 return r1 && !err; 00661 } 00662 00663 bool CompareMetric::evaluate_with_Hessian_diagonal( PatchData& pd, 00664 size_t handle, 00665 double& value, 00666 std::vector< size_t >& indices, 00667 std::vector< Vector3D >& gradient, 00668 std::vector< SymMatrix3D >& diagonal, 00669 MsqError& err ) 00670 { 00671 double m2val; 00672 bool r1, r2; 00673 m2Handles.clear(); 00674 m2Grad.clear(); 00675 m2Diag.clear(); 00676 r1 = metric1->evaluate_with_Hessian_diagonal( pd, handle, value, indices, gradient, diagonal, err ); 00677 MSQ_ERRZERO( err ); 00678 r2 = metric2->evaluate_with_Hessian_diagonal( pd, handle, m2val, m2Handles, m2Grad, m2Diag, err ); 00679 MSQ_ERRZERO( err ); 00680 if( r1 != r2 || ( r1 && fabs( value - m2val ) > epsilon ) ) 00681 { 00682 MSQ_SETERR( err ) 00683 ( MsqError::INVALID_STATE, 00684 "Metrics returned different values for handle %lu in " 00685 "evaluate_with_Hessian_diagonal:\n" 00686 "\t%s %f vs. %s %f\n", 00687 (unsigned long)handle, r1 ? "true" : "false", value, r2 ? "true" : "false", m2val ); 00688 } 00689 else 00690 { 00691 std::vector< size_t >::const_iterator i, j; 00692 std::vector< Vector3D >::const_iterator r, s; 00693 std::vector< SymMatrix3D >::const_iterator u, v; 00694 int grad_diff = 0, hess_diff = 0; 00695 bool same = ( indices.size() == m2Handles.size() ); 00696 std::sort( m2Handles.begin(), m2Handles.end() ); 00697 for( i = indices.begin(); i != indices.end(); ++i ) 00698 { 00699 j = std::lower_bound( m2Handles.begin(), m2Handles.end(), *i ); 00700 if( j == m2Handles.end() || *j != *i ) 00701 { 00702 same = false; 00703 continue; 00704 } 00705 00706 r = gradient.begin() + ( i - indices.begin() ); 00707 s = m2Grad.begin() + ( j - m2Handles.begin() ); 00708 if( !equal( *r, *s ) ) ++grad_diff; 00709 00710 u = diagonal.begin() + ( i - indices.begin() ); 00711 v = m2Diag.begin() + ( j - m2Handles.begin() ); 00712 if( !equal( *u, *v ) ) ++hess_diff; 00713 } 00714 00715 if( !same ) 00716 { 00717 MSQ_SETERR( err ) 00718 ( MsqError::INVALID_STATE, 00719 "Metrics returned incompatible lists of vertex indices" 00720 " for handle %lu in evaluate_with_Hessian_diagonal\n.", 00721 (unsigned long)handle ); 00722 } 00723 else if( grad_diff ) 00724 { 00725 MSQ_SETERR( err ) 00726 ( MsqError::INVALID_STATE, 00727 "Metrics returned different gradient vectors for " 00728 " %d of %u vertices for handle %lu in " 00729 "evaluate_with_Hessian_diagonal\n.", 00730 grad_diff, (unsigned)gradient.size(), (unsigned long)handle ); 00731 } 00732 else if( hess_diff ) 00733 { 00734 MSQ_SETERR( err ) 00735 ( MsqError::INVALID_STATE, 00736 "Metrics returned different Hessian blocks for " 00737 " %d of %u vertices for handle %lu in " 00738 "evaluate_with_Hessian_diagonal\n.", 00739 hess_diff, (unsigned)diagonal.size(), (unsigned long)handle ); 00740 } 00741 } 00742 00743 return r1 && !err; 00744 } 00745 00746 bool CompareMetric::evaluate_with_Hessian( PatchData& pd, 00747 size_t handle, 00748 double& value, 00749 std::vector< size_t >& indices, 00750 std::vector< Vector3D >& gradient, 00751 std::vector< Matrix3D >& Hessian, 00752 MsqError& err ) 00753 { 00754 double m2val; 00755 bool r1, r2; 00756 m2Handles.clear(); 00757 m2Grad.clear(); 00758 m2Hess.clear(); 00759 r1 = metric1->evaluate_with_Hessian( pd, handle, value, indices, gradient, Hessian, err ); 00760 MSQ_ERRZERO( err ); 00761 r2 = metric2->evaluate_with_Hessian( pd, handle, m2val, m2Handles, m2Grad, m2Hess, err ); 00762 MSQ_ERRZERO( err ); 00763 if( r1 != r2 || fabs( value - m2val ) > epsilon ) 00764 { 00765 MSQ_SETERR( err ) 00766 ( MsqError::INVALID_STATE, 00767 "Metrics returned different values for handle %lu in " 00768 "evaluate_with_Hessian:\n" 00769 "\t%s %f vs. %s %f\n", 00770 (unsigned long)handle, r1 ? "true" : "false", value, r2 ? "true" : "false", m2val ); 00771 } 00772 else 00773 { 00774 std::vector< size_t >::const_iterator i, j; 00775 std::vector< Vector3D >::const_iterator r, s; 00776 int grad_diff = 0, hess_diff = 0; 00777 bool same = ( indices.size() == m2Handles.size() ); 00778 std::sort( m2Handles.begin(), m2Handles.end() ); 00779 for( i = indices.begin(); i != indices.end(); ++i ) 00780 { 00781 j = std::lower_bound( m2Handles.begin(), m2Handles.end(), *i ); 00782 if( j == m2Handles.end() || *j != *i ) 00783 { 00784 same = false; 00785 continue; 00786 } 00787 00788 r = gradient.begin() + ( i - indices.begin() ); 00789 s = m2Grad.begin() + ( j - m2Handles.begin() ); 00790 if( !equal( *r, *s ) ) 00791 { 00792 ++grad_diff; 00793 // call again for so debugger can step into it after failure is found 00794 std::vector< size_t > i2; 00795 std::vector< Vector3D > g2; 00796 std::vector< Matrix3D > h2; 00797 metric2->evaluate_with_Hessian( pd, handle, m2val, i2, g2, h2, err ); 00798 } 00799 } 00800 00801 if( !same ) 00802 { 00803 MSQ_SETERR( err ) 00804 ( MsqError::INVALID_STATE, 00805 "Metrics returned incompatible lists of vertex indices" 00806 " for handle %lu in evaluate_with_Hessian\n.", 00807 (unsigned long)handle ); 00808 } 00809 else if( grad_diff ) 00810 { 00811 MSQ_SETERR( err ) 00812 ( MsqError::INVALID_STATE, 00813 "Metrics returned different gradient vectors for " 00814 " %d of %u vertices for handle %lu in " 00815 "evaluate_with_Hessian\n.", 00816 grad_diff, (unsigned)gradient.size(), (unsigned long)handle ); 00817 } 00818 else 00819 { 00820 size_t row, col, row2, col2, idx, idx2; 00821 for( row = idx = 0; row < indices.size(); ++row ) 00822 { 00823 row2 = std::lower_bound( m2Handles.begin(), m2Handles.end(), indices[row] ) - m2Handles.begin(); 00824 for( col = row; col < indices.size(); ++col, ++idx ) 00825 { 00826 col2 = std::lower_bound( m2Handles.begin(), m2Handles.end(), indices[col] ) - m2Handles.begin(); 00827 if( row2 <= col2 ) 00828 { 00829 idx2 = indices.size() * row2 - row2 * ( row2 + 1 ) / 2 + col2; 00830 if( !equal( Hessian[idx], m2Hess[idx2] ) ) ++hess_diff; 00831 } 00832 else 00833 { 00834 idx2 = indices.size() * col2 - col2 * ( col2 + 1 ) / 2 + row2; 00835 if( !equal( Hessian[idx], transpose( m2Hess[idx2] ) ) ) ++hess_diff; 00836 } 00837 } 00838 } 00839 00840 if( hess_diff ) 00841 { 00842 MSQ_SETERR( err ) 00843 ( MsqError::INVALID_STATE, 00844 "Metrics returned different Hessian blocks for " 00845 " %d of %u vertices for handle %lu in " 00846 "evaluate_with_Hessian\n.", 00847 hess_diff, (unsigned)Hessian.size(), (unsigned long)handle ); 00848 } 00849 } 00850 } 00851 00852 return r1 && !err; 00853 } 00854 00855 void CompareMetric::get_mask_axis( PatchData& pd ) 00856 { 00857 maskAxis = -1; 00858 PlanarDomain* dom = reinterpret_cast< PlanarDomain* >( pd.get_domain() ); 00859 int bits = 0; 00860 if( dom ) 00861 { 00862 Vector3D n = dom->get_normal(); 00863 for( int i = 0; i < 3; ++i ) 00864 if( fabs( n[i] ) < epsilon ) bits |= ( 1 << i ); 00865 switch( bits ) 00866 { 00867 case 3: 00868 maskAxis = 2; 00869 break; 00870 case 5: 00871 maskAxis = 1; 00872 break; 00873 case 6: 00874 maskAxis = 0; 00875 break; 00876 } 00877 } 00878 } 00879 00880 bool CompareMetric::equal( Vector3D grad1, const Vector3D& grad2 ) const 00881 { 00882 if( maskAxis >= 0 ) grad1[maskAxis] = grad2[maskAxis]; 00883 return ( grad1 - grad2 ).length_squared() <= epsilon * epsilon; 00884 } 00885 00886 bool CompareMetric::equal( SymMatrix3D hess1, const SymMatrix3D& hess2 ) const 00887 { 00888 if( maskAxis >= 0 ) 00889 { 00890 for( unsigned i = 0; i < 3; ++i ) 00891 { 00892 hess1( maskAxis, i ) = hess2( maskAxis, i ); 00893 hess1( i, maskAxis ) = hess2( i, maskAxis ); 00894 } 00895 } 00896 return Frobenius_2( hess1 - hess2 ) <= epsilon * epsilon; 00897 } 00898 00899 bool CompareMetric::equal( Matrix3D hess1, const Matrix3D& hess2 ) const 00900 { 00901 if( maskAxis >= 0 ) 00902 { 00903 for( unsigned i = 0; i < 3; ++i ) 00904 { 00905 hess1[maskAxis][i] = hess2[maskAxis][i]; 00906 hess1[i][maskAxis] = hess2[i][maskAxis]; 00907 } 00908 } 00909 return Frobenius_2( hess1 - hess2 ) <= epsilon * epsilon; 00910 }
