Mesh Oriented datABase
(version 5.4.1)
#include "moab_mpi.h"#include "moab/Core.hpp"#include <sstream>#include <iostream>#include <cstdlib>#include <unistd.h>
Include dependency graph for parread.cpp:Go to the source code of this file.
Functions | |
| void | error (const char *argv0) |
| void | help (const char *argv0) |
| int | main (int argc, char *argv[]) |
Variables | |
| const char | usage [] = "[-b|-d|-f] [-P <rank>] [-p <name>] [-R] [-g <level>] [-O <option>] <filename>" |
| const char | DEFAULT_PARTITION_TAG [] = "PARALLEL_PARTITION" |
| void error | ( | const char * | argv0 | ) |
Definition at line 12 of file parread.cpp.
References usage.
Referenced by main(), and test_get_part_boundary().
std::cerr << "Usage: " << argv0 << " " << usage << std::endl;
exit( 1 );
| void help | ( | const char * | argv0 | ) |
Definition at line 18 of file parread.cpp.
References DEFAULT_PARTITION_TAG, and usage.
Referenced by ProgOptions::addOpt(), ProgOptions::addRequiredArg(), main(), and usage().
std::cout << argv0 << " " << usage << std::endl
<< "-P <rank> Specified processor will wait for debugger to attach." << std::endl
<< "-p <name> Tag identifying partition sets (default: \"" << DEFAULT_PARTITION_TAG << "\")" << std::endl
<< "-a Assign partitions to processes by matching part number to rank" << std::endl
<< "-R Do not resolve shared entities" << std::endl
<< "-b Use broadcast & delete read method" << std::endl
<< "-d Use read & delete method" << std::endl
<< "-f Use true parallel read (default)" << std::endl
<< "-g Set debug output level" << std::endl;
exit( 0 );
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 32 of file parread.cpp.
References DEFAULT_PARTITION_TAG, error(), ErrorCode, moab::Interface::get_error_string(), moab::Interface::get_last_error(), help(), moab::Interface::load_file(), mb, and MB_SUCCESS.
MPI_Init( &argc, &argv );
const char BCAST_MODE[] = "BCAST_DELETE";
const char DELETE_MODE[] = "READ_DELETE";
const char PART_MODE[] = "READ_PART";
const char* read_mode = PART_MODE;
const char* partition_tag_name = DEFAULT_PARTITION_TAG;
bool assign_by_id = false;
bool resolve_shared = true;
int debug_level = 0;
int pause_rank = -1;
const char* filename = 0;
std::ostringstream options;
options << ";";
int rank;
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
int expect_tag = 0;
int expect_level = 0;
int expect_opt = 0;
int expect_rank = 0;
bool no_more_flags = false;
for( int i = 1; i < argc; ++i )
int arg_pos = i;
if( expect_tag == i )
partition_tag_name = argv[i];
expect_tag = 0;
else if( expect_level == i )
char* endptr;
debug_level = (int)strtol( argv[i], &endptr, 0 );
if( *endptr || endptr == argv[i] || debug_level < 0 )
std::cerr << "Expected positive integer value following '-g' flag" << std::endl;
error( argv[0] );
expect_level = 0;
else if( expect_opt == i )
options << ";" << argv[i];
expect_opt = 0;
else if( expect_rank == i )
char* endptr;
pause_rank = (int)strtol( argv[i], &endptr, 0 );
if( *endptr || endptr == argv[i] || pause_rank < 0 )
std::cerr << "Expected positive integer value following '-P' flag" << std::endl;
error( argv[0] );
expect_rank = 0;
else if( argv[i][0] == '-' && !no_more_flags )
for( int j = 1; argv[i][j]; ++j )
switch( argv[i][j] )
case '-':
no_more_flags = true;
break;
case 'P':
expect_rank = ++arg_pos;
break;
case 'p':
expect_tag = ++arg_pos;
break;
case 'a':
assign_by_id = true;
break;
case 'R':
resolve_shared = false;
break;
case 'b':
read_mode = BCAST_MODE;
break;
case 'd':
read_mode = DELETE_MODE;
break;
case 'f':
break;
case 'g':
expect_level = ++arg_pos;
break;
case 'O':
expect_opt = ++arg_pos;
break;
case 'h':
help( argv[0] );
break;
default:
std::cerr << "Unknown flag: -" << argv[i][j] << std::endl;
error( argv[0] );
else if( filename )
std::cerr << "Unexpected argument: \"" << argv[i] << "\"" << std::endl;
error( argv[0] );
else
filename = argv[i];
if( expect_tag )
std::cerr << "Expected value following -p flag" << std::endl;
error( argv[0] );
if( expect_level )
std::cerr << "Expected value following -g flag" << std::endl;
error( argv[0] );
if( expect_opt )
std::cerr << "Expected value following -O flag" << std::endl;
error( argv[0] );
if( expect_rank )
std::cerr << "Expected rank following -P flag" << std::endl;
error( argv[0] );
if( !filename )
std::cerr << "No file name specified" << std::endl;
error( argv[0] );
options << ";PARTITION=" << partition_tag_name << ";PARALLEL=" << read_mode;
if( resolve_shared ) options << ";PARALLEL_RESOLVE_SHARED_ENTS";
if( assign_by_id ) options << ";PARTITION_BY_RANK";
if( debug_level ) options << ";DEBUG_IO=" << debug_level;
moab::Core core;
moab::Interface& mb = core;
if( pause_rank >= 0 )
if( pause_rank == rank )
std::cout << "Process " << rank << " with PID " << getpid() << " waiting for debugger" << std::endl
<< "Set local variable 'do_wait' to zero to continue" << std::endl;
volatile int do_wait = 1;
while( do_wait )
sleep( 1 );
MPI_Barrier( MPI_COMM_WORLD );
std::string opts = options.str();
if( rank == 0 ) std::cout << "Reading \"" << filename << "\" with options=\"" << opts << "\"." << std::endl;
double init_time = MPI_Wtime();
moab::ErrorCode rval = mb.load_file( filename, 0, opts.c_str() );
double fini_time = MPI_Wtime();
long send_data[2] = { (long)( 100 * ( fini_time - init_time ) ), rval };
long recv_data[2];
MPI_Allreduce( send_data, recv_data, 2, MPI_LONG, MPI_MAX, MPI_COMM_WORLD );
double time = recv_data[0] / 100.0;
if( moab::MB_SUCCESS != rval )
std::string estr = mb.get_error_string( rval );
std::string msg;
mb.get_last_error( msg );
std::cout << "Read failed for proccess " << rank << " with error code " << rval << " (" << estr << ")"
<< std::endl;
if( !msg.empty() ) std::cerr << '"' << msg << '"' << std::endl;
if( rank == 0 )
if( recv_data[1] == moab::MB_SUCCESS ) std::cout << "Success!" << std::endl;
std::cout << "Read returned in " << time << " seconds" << std::endl;
MPI_Finalize();
return ( moab::MB_SUCCESS != rval );
| const char DEFAULT_PARTITION_TAG[] = "PARALLEL_PARTITION" |
Definition at line 10 of file parread.cpp.
| const char usage[] = "[-b|-d|-f] [-P <rank>] [-p <name>] [-R] [-g <level>] [-O <option>] <filename>" |
Definition at line 8 of file parread.cpp.
Referenced by about(), error(), help(), smoab::detail::UsageTable::incrementUsage(), and main().
