Mesh Oriented datABase
(version 5.4.1)
#include "Tqdcfr.hpp"#include "moab/Core.hpp"#include "moab/Range.hpp"#include "moab/FileOptions.hpp"#include <iostream>#include <string>#include "moab/ReadUtilIface.hpp"#include "SequenceManager.hpp"#include "moab/GeomTopoTool.hpp"#include "MBTagConventions.hpp"#include "moab/CN.hpp"#include "Internals.hpp"#include "moab/HigherOrderFactory.hpp"#include "exodus_order.h"#include <sstream>#include <cassert>#include <cstring>
Include dependency graph for Tqdcfr.cpp:Go to the source code of this file.
Namespaces | |
| namespace | moab |
Class representing axis-aligned bounding box. | |
Defines | |
| #define | RR if( MB_SUCCESS != result ) return result |
| #define | IO_ASSERT(C) INT_IO_ERROR( C, __LINE__ ) |
| #define | MAX(a, b) ( ( a ) > ( b ) ? ( a ) : ( b ) ) |
| #define | MIN(a, b) ( ( a ) < ( b ) ? ( a ) : ( b ) ) |
| #define | REC records[current_record] |
Functions | |
| static void | moab::INT_IO_ERROR (bool condition, unsigned line) |
| static void | moab::swap8_voff (long *data) |
| static void | moab::swap4_uint (unsigned int *data) |
Variables | |
| static int | moab::major = -1 |
| static int | moab::minor = -1 |
| const int *const *const *const | moab::cub_elem_order_map = exodus_elem_order_map |
| const char *const | moab::BLOCK_NODESET_OFFSET_TAG_NAME = "BLOCK_NODESET_OFFSET" |
| const char *const | moab::BLOCK_SIDESET_OFFSET_TAG_NAME = "BLOCK_SIDESET_OFFSET" |
| #define IO_ASSERT | ( | C | ) | INT_IO_ERROR( C, __LINE__ ) |
Definition at line 112 of file Tqdcfr.cpp.
Referenced by moab::Tqdcfr::FREADCA(), moab::Tqdcfr::FREADDA(), moab::Tqdcfr::FREADIA(), moab::Tqdcfr::FSEEK(), and moab::Tqdcfr::read_file_header().
| #define MAX | ( | a, | |
| b | |||
| ) | ( ( a ) > ( b ) ? ( a ) : ( b ) ) |
| #define MIN | ( | a, | |
| b | |||
| ) | ( ( a ) < ( b ) ? ( a ) : ( b ) ) |
| #define REC records[current_record] |
Referenced by moab::Tqdcfr::interpret_acis_records().
| #define RR if( MB_SUCCESS != result ) return result |
Definition at line 106 of file Tqdcfr.cpp.
Referenced by moab::Tqdcfr::load_file(), and moab::Tqdcfr::read_nodes().
