Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for iMeshP_extensions.h:
This graph shows which files directly or indirectly include this file:Go to the source code of this file.
Functions | |
| void | iMeshP_getCommunicator (iMesh_Instance instance, int *fcomm, MPI_Comm *ccomm, int *err) |
| Convert a fortran to C communicator Given a Fortran communicator, convert to a C communicator that can be passed back to iMeshP. Though this is an iMeshP function, it doesn't take an iMeshP Partition handle, since the (C) communicator is needed by the function that creates the partition. COMMUNICATION: None. | |
| void | iMeshP_assignGlobalIds (iMesh_Instance instance, const iMeshP_PartitionHandle partition, const iBase_EntitySetHandle this_set, const int dimension, const int start_id, const int largest_dim_only, const int parallel, const int owned_only, int *err) |
| Assign a global id space to entities Assign a global id space to entities and vertices, and optionally intermediate-dimension entities. | |
| void iMeshP_assignGlobalIds | ( | iMesh_Instance | instance, |
| const iMeshP_PartitionHandle | partition, | ||
| const iBase_EntitySetHandle | this_set, | ||
| const int | dimension, | ||
| const int | start_id, | ||
| const int | largest_dim_only, | ||
| const int | parallel, | ||
| const int | owned_only, | ||
| int * | err | ||
COMMUNICATION: Collective.
Definition at line 1796 of file iMeshP_MOAB.cpp.
References moab::ParallelComm::assign_global_ids(), CHKERR, ErrorCode, moab::ParallelComm::get_pcomm(), iBase_FAILURE, itaps_cast(), MOABI, and RETURN.
ErrorCode rval;
// get partition set
EntityHandle partitionset = itaps_cast< EntityHandle >( partition );
if( !partitionset )
rval = MB_FAILURE;CHKERR( rval, "failed to get partition set" );
EntityHandle this_mb_set = itaps_cast< EntityHandle >( this_set );
// get ParallelComm for partition
MPI_Comm default_comm;
ParallelComm* pcomm = ParallelComm::get_pcomm( MOABI, partitionset, &default_comm );
if( !pcomm )
RETURN( iBase_FAILURE );
rval = pcomm->assign_global_ids( this_mb_set, dimension, start_id, largest_dim_only, parallel, owned_only );
RETURN( rval );
| void iMeshP_getCommunicator | ( | iMesh_Instance | instance, |
| int * | fcomm, | ||
| MPI_Comm * | ccomm, | ||
| int * | err | ||
| instance | (In) Mesh instance to contain the partition. |
| fcomm | (In) Pointer to fortran communicator |
| ccomm | (Out) Pointer to the C communicator |
| err | (Out) Error code. |
Definition at line 1830 of file iMeshP_MOAB.cpp.
References iBase_SUCCESS, and RETURN.
*ccomm = MPI_Comm_f2c( *fcomm );
RETURN( iBase_SUCCESS );
