connectivity.c File Reference
#include <H5Tpublic.h>
#include <H5Dpublic.h>
#include <H5Gpublic.h>
#include <H5Ppublic.h>
#include "mhdf.h"
#include "util.h"
#include "file-handle.h"
#include "status.h"
#include "names-and-paths.h"
+ Include dependency graph for connectivity.c:
Functions
hid_t mhdf_createConnectivity (mhdf_FileHandle file_handle, const char *elem_handle, int nodes_per_elem, long count, long *first_id_out, mhdf_Status *status)
 Create connectivity table for an element group.
hid_t mhdf_openConnectivity (mhdf_FileHandle file_handle, const char *elem_handle, int *num_nodes_per_elem_out, long *num_elements_out, long *first_elem_id_out, mhdf_Status *status)
 Open connectivity table for an element group.
hid_t mhdf_openConnectivitySimple (mhdf_FileHandle file_handle, const char *elem_handle, mhdf_Status *status)
void mhdf_writeConnectivity (hid_t table_id, long offset, long count, hid_t hdf_integer_type, const void *nodes, mhdf_Status *status)
 Write element coordinate data.
void mhdf_writeConnectivityWithOpt (hid_t table_id, long offset, long count, hid_t hdf_integer_type, const void *nodes, hid_t prop, mhdf_Status *status)
void mhdf_readConnectivity (hid_t table_id, long offset, long count, hid_t hdf_integer_type, void *nodes, mhdf_Status *status)
 Read element coordinate data.
void mhdf_readConnectivityWithOpt (hid_t table_id, long offset, long count, hid_t hdf_integer_type, void *nodes, hid_t prop, mhdf_Status *status)
void mhdf_createPolyConnectivity (mhdf_FileHandle file_handle, const char *elem_type, long num_poly, long data_list_length, long *first_id_out, hid_t handles_out[2], mhdf_Status *status)
 Create a new table for polygon or polyhedron connectivity data.
void mhdf_openPolyConnectivity (mhdf_FileHandle file_handle, const char *element_handle, long *num_poly_out, long *data_list_length_out, long *first_poly_id_out, hid_t handles_out[2], mhdf_Status *status)
 Open a table of polygon or polyhedron connectivity data.
void mhdf_writePolyConnIndices (hid_t table_id, long offset, long count, hid_t hdf_integer_type, const void *index_list, mhdf_Status *status)
 Write polygon or polyhedron index data.
void mhdf_writePolyConnIndicesWithOpt (hid_t table_id, long offset, long count, hid_t hdf_integer_type, const void *index_list, hid_t prop, mhdf_Status *status)
void mhdf_readPolyConnIndices (hid_t table_id, long offset, long count, hid_t hdf_integer_type, void *index_list, mhdf_Status *status)
 Read polygon or polyhedron index data.
void mhdf_readPolyConnIndicesWithOpt (hid_t table_id, long offset, long count, hid_t hdf_integer_type, void *index_list, hid_t prop, mhdf_Status *status)
void mhdf_writePolyConnIDs (hid_t table_id, long offset, long count, hid_t hdf_integer_type, const void *id_list, mhdf_Status *status)
 Write polygon or polyhedron connectivity data.
void mhdf_writePolyConnIDsWithOpt (hid_t table_id, long offset, long count, hid_t hdf_integer_type, const void *id_list, hid_t prop, mhdf_Status *status)
void mhdf_readPolyConnIDs (hid_t table_id, long offset, long count, hid_t hdf_integer_type, void *id_list, mhdf_Status *status)
 Read polygon or polyhedron connectivity data.
void mhdf_readPolyConnIDsWithOpt (hid_t table_id, long offset, long count, hid_t hdf_integer_type, void *id_list, hid_t prop, mhdf_Status *status)
