Mesh Oriented datABase
(version 5.4.1)
#include <cassert>#include <ctime>#include <cstdlib>#include <cstring>#include <cstdarg>#include <limits>#include <cstdio>#include <iostream>#include "WriteHDF5.hpp"#include <H5Tpublic.h>#include <H5Ppublic.h>#include <H5Epublic.h>#include "moab/Interface.hpp"#include "Internals.hpp"#include "MBTagConventions.hpp"#include "moab/CN.hpp"#include "moab/FileOptions.hpp"#include "moab/CpuTimer.hpp"#include "IODebugTrack.hpp"#include "mhdf.h"
Include dependency graph for WriteHDF5.cpp:Go to the source code of this file.
Classes | |
| class | moab::CheckOpenWriteHDF5Handles |
Namespaces | |
| namespace | moab |
Class representing axis-aligned bounding box. | |
Defines | |
| #define | VALGRIND_CHECK_MEM_IS_DEFINED(a, b) ( (void)0 ) |
| #define | VALGRIND_CHECK_MEM_IS_ADDRESSABLE(a, b) ( (void)0 ) |
| #define | VALGRIND_MAKE_MEM_UNDEFINED(a, b) ( (void)0 ) |
| #define | WRITE_HDF5_BUFFER_SIZE ( 40 * 1024 * 1024 ) |
| #define | CHK_MHDF_ERR_0(A) |
| #define | CHK_MHDF_ERR_1(A, B) |
| #define | CHK_MHDF_ERR_2(A, B) |
| #define | CHK_MHDF_ERR_3(A, B) |
| #define | CHK_MHDF_ERR_2C(A, B, C, D) |
| #define | CHK_MB_ERR_0(A) |
| #define | CHK_MB_ERR_1(A, B, C) |
| #define | CHK_MB_ERR_2(A, B, C) |
| #define | CHK_MB_ERR_3(A, B, C) |
| #define | CHK_MB_ERR_2C(A, B, C, D, E) |
| #define | debug_barrier() debug_barrier_line( __LINE__ ) |
| #define | CHECK_OPEN_HANDLES CheckOpenWriteHDF5Handles check_open_handles_( filePtr, __LINE__ ) |
Functions | |
| template<typename T > | |
| void | VALGRIND_MAKE_VEC_UNDEFINED (std::vector< T > &) |
| static hid_t | moab::get_id_type () |
| static ErrorCode | moab::error (ErrorCode rval) |
| static herr_t | moab::handle_hdf5_error (void *data) |
| template<class HandleRangeIter > | |
| size_t | moab::count_num_handles (HandleRangeIter iter, HandleRangeIter end) |
| ErrorCode | moab::range_to_id_list_templ (HandleRangeIter begin, HandleRangeIter end, const RangeMap< EntityHandle, WriteHDF5::wid_t > &idMap, WriteHDF5::wid_t *array) |
| ErrorCode | moab::range_to_blocked_list_templ (HandleRangeIter begin, HandleRangeIter end, const RangeMap< EntityHandle, WriteHDF5::wid_t > &idMap, std::vector< WriteHDF5::wid_t > &output_id_list, bool &ranged_list) |
| #define CHECK_OPEN_HANDLES CheckOpenWriteHDF5Handles check_open_handles_( filePtr, __LINE__ ) |
Definition at line 325 of file WriteHDF5.cpp.
Referenced by moab::WriteHDF5::create_elem_table(), moab::WriteHDF5::create_set_meta(), moab::WriteHDF5::create_set_tables(), moab::WriteHDF5::create_tag(), moab::WriteHDF5::get_tag_size(), moab::WriteHDF5::write_adjacencies(), moab::WriteHDF5::write_dense_tag(), moab::WriteHDF5::write_elems(), moab::WriteHDF5::write_nodes(), moab::WriteHDF5::write_qa(), moab::WriteHDF5::write_sets(), moab::WriteHDF5::write_sparse_ids(), moab::WriteHDF5::write_sparse_tag(), moab::WriteHDF5::write_tag(), moab::WriteHDF5::write_tag_values(), moab::WriteHDF5::write_var_len_data(), moab::WriteHDF5::write_var_len_indices(), and moab::WriteHDF5::write_var_len_tag().
| #define CHK_MB_ERR_0 | ( | A | ) |
do \ { \ if( MB_SUCCESS != ( A ) ) \ { \ MB_CHK_ERR_CONT( ( A ) ); \ return error( A ); \ } \ } while( false )
Definition at line 227 of file WriteHDF5.cpp.
Referenced by moab::WriteHDF5::count_adjacencies(), moab::WriteHDF5::count_set_size(), moab::WriteHDF5::create_tag(), moab::WriteHDF5::gather_mesh_info(), moab::WriteHDF5::gather_tags(), moab::WriteHDF5::get_set_info(), moab::WriteHDF5::get_tag_size(), moab::WriteHDF5::init(), moab::WriteHDF5::serial_create_file(), moab::WriteHDF5::write_dense_tag(), moab::WriteHDF5::write_file_impl(), moab::WriteHDF5::write_nodes(), moab::WriteHDF5::write_set_data(), moab::WriteHDF5::write_sparse_ids(), moab::WriteHDF5::write_sparse_tag(), moab::WriteHDF5::write_tag_values(), moab::WriteHDF5::write_var_len_data(), moab::WriteHDF5::write_var_len_indices(), and moab::WriteHDF5::write_var_len_tag().
| #define CHK_MB_ERR_1 | ( | A, | |
| B, | |||
| C | |||
do \ { \ if( MB_SUCCESS != ( A ) ) \ { \ MB_CHK_ERR_CONT( ( A ) ); \ mhdf_closeData( filePtr, ( B ), &( C ) ); \ assert( 0 ); \ return error( A ); \ } \ } while( false )
Definition at line 237 of file WriteHDF5.cpp.
Referenced by moab::WriteHDF5::write_adjacencies(), moab::WriteHDF5::write_elems(), moab::WriteHDF5::write_nodes(), moab::WriteHDF5::write_sets(), and moab::WriteHDF5::write_var_len_tag().
| #define CHK_MB_ERR_2 | ( | A, | |
| B, | |||
| C | |||
do \ { \ if( MB_SUCCESS != ( A ) ) \ { \ MB_CHK_ERR_CONT( ( A ) ); \ mhdf_closeData( filePtr, ( B )[0], &( C ) ); \ mhdf_closeData( filePtr, ( B )[1], &( C ) ); \ write_finished(); \ assert( 0 ); \ return error( A ); \ } \ } while( false )
Definition at line 249 of file WriteHDF5.cpp.
Referenced by moab::WriteHDF5::write_sparse_tag(), and moab::WriteHDF5::write_var_len_tag().
| #define CHK_MB_ERR_2C | ( | A, | |
| B, | |||
| C, | |||
| D, | |||
| E | |||
do \ { \ if( MB_SUCCESS != ( A ) ) \ { \ MB_CHK_ERR_CONT( ( A ) ); \ mhdf_closeData( filePtr, ( B ), &( E ) ); \ if( C ) mhdf_closeData( filePtr, ( D ), &( E ) ); \ write_finished(); \ assert( 0 ); \ return error( A ); \ } \ } while( false )
Definition at line 278 of file WriteHDF5.cpp.
| #define CHK_MB_ERR_3 | ( | A, | |
| B, | |||
| C | |||
do \ { \ if( MB_SUCCESS != ( A ) ) \ { \ MB_CHK_ERR_CONT( ( A ) ); \ mhdf_closeData( filePtr, ( B )[0], &( C ) ); \ mhdf_closeData( filePtr, ( B )[1], &( C ) ); \ mhdf_closeData( filePtr, ( B )[2], &( C ) ); \ write_finished(); \ assert( 0 ); \ return error( A ); \ } \ } while( false )
Definition at line 263 of file WriteHDF5.cpp.
| #define CHK_MHDF_ERR_0 | ( | A | ) |
do \ { \ if( mhdf_isError( &( A ) ) ) \ { \ MB_SET_ERR_CONT( mhdf_message( &( A ) ) ); \ assert( 0 ); \ return error( MB_FAILURE ); \ } \ } while( false )
Definition at line 164 of file WriteHDF5.cpp.
Referenced by moab::WriteHDF5::create_elem_table(), moab::WriteHDF5::create_set_meta(), moab::WriteHDF5::create_set_tables(), moab::WriteHDF5::create_tag(), moab::WriteHDF5::serial_create_file(), moab::WriteHDF5::write_adjacencies(), moab::WriteHDF5::write_dense_tag(), moab::WriteHDF5::write_elems(), moab::WriteHDF5::write_nodes(), moab::WriteHDF5::write_qa(), moab::WriteHDF5::write_set_data(), moab::WriteHDF5::write_sets(), moab::WriteHDF5::write_sparse_ids(), moab::WriteHDF5::write_sparse_tag(), moab::WriteHDF5::write_tag_values(), moab::WriteHDF5::write_var_len_data(), moab::WriteHDF5::write_var_len_indices(), and moab::WriteHDF5::write_var_len_tag().
| #define CHK_MHDF_ERR_1 | ( | A, | |
| B | |||
do \ { \ if( mhdf_isError( &( A ) ) ) \ { \ MB_SET_ERR_CONT( mhdf_message( &( A ) ) ); \ assert( 0 ); \ mhdf_closeData( filePtr, ( B ), &( A ) ); \ return error( MB_FAILURE ); \ } \ } while( false )
Definition at line 175 of file WriteHDF5.cpp.
Referenced by moab::WriteHDF5::write_adjacencies(), moab::WriteHDF5::write_elems(), moab::WriteHDF5::write_nodes(), moab::WriteHDF5::write_sets(), moab::WriteHDF5::write_sparse_tag(), and moab::WriteHDF5::write_var_len_tag().
| #define CHK_MHDF_ERR_2 | ( | A, | |
| B | |||
do \ { \ if( mhdf_isError( &( A ) ) ) \ { \ MB_SET_ERR_CONT( mhdf_message( &( A ) ) ); \ assert( 0 ); \ mhdf_closeData( filePtr, ( B )[0], &( A ) ); \ mhdf_closeData( filePtr, ( B )[1], &( A ) ); \ return error( MB_FAILURE ); \ } \ } while( false )
Definition at line 187 of file WriteHDF5.cpp.
Referenced by moab::WriteHDF5::write_var_len_tag().
| #define CHK_MHDF_ERR_2C | ( | A, | |
| B, | |||
| C, | |||
| D | |||
do \ { \ if( mhdf_isError( &( A ) ) ) \ { \ MB_SET_ERR_CONT( mhdf_message( &( A ) ) ); \ assert( 0 ); \ mhdf_closeData( filePtr, ( B ), &( A ) ); \ if( C ) mhdf_closeData( filePtr, ( D ), &( A ) ); \ return error( MB_FAILURE ); \ } \ } while( false )
Definition at line 214 of file WriteHDF5.cpp.
| #define CHK_MHDF_ERR_3 | ( | A, | |
| B | |||
do \ { \ if( mhdf_isError( &( A ) ) ) \ { \ MB_SET_ERR_CONT( mhdf_message( &( A ) ) ); \ assert( 0 ); \ mhdf_closeData( filePtr, ( B )[0], &( A ) ); \ mhdf_closeData( filePtr, ( B )[1], &( A ) ); \ mhdf_closeData( filePtr, ( B )[2], &( A ) ); \ return error( MB_FAILURE ); \ } \ } while( false )
Definition at line 200 of file WriteHDF5.cpp.
| #define debug_barrier | ( | ) | debug_barrier_line( __LINE__ ) |
Definition at line 292 of file WriteHDF5.cpp.
Referenced by moab::WriteHDF5::write_adjacencies(), moab::WriteHDF5::write_elems(), moab::WriteHDF5::write_file_impl(), moab::WriteHDF5::write_nodes(), moab::WriteHDF5::write_set_data(), moab::WriteHDF5::write_sets(), and moab::WriteHDF5::write_tag().
| #define VALGRIND_CHECK_MEM_IS_ADDRESSABLE | ( | a, | |
| b | |||
| ) | ( (void)0 ) |
Definition at line 76 of file WriteHDF5.cpp.
| #define VALGRIND_CHECK_MEM_IS_DEFINED | ( | a, | |
| b | |||
| ) | ( (void)0 ) |
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition at line 73 of file WriteHDF5.cpp.
| #define VALGRIND_MAKE_MEM_UNDEFINED | ( | a, | |
| b | |||
| ) | ( (void)0 ) |
Definition at line 79 of file WriteHDF5.cpp.
Referenced by VALGRIND_MAKE_VEC_UNDEFINED(), moab::WriteHDF5::write_adjacencies(), moab::WriteHDF5::write_elems(), moab::WriteHDF5::write_nodes(), moab::WriteHDF5::write_sparse_ids(), moab::WriteHDF5::write_tag_values(), and moab::WriteHDF5::write_var_len_indices().
| #define WRITE_HDF5_BUFFER_SIZE ( 40 * 1024 * 1024 ) |
Definition at line 93 of file WriteHDF5.cpp.
Referenced by moab::WriteHDF5::write_file().
| void VALGRIND_MAKE_VEC_UNDEFINED | ( | std::vector< T > & | ) | [inline] |
Definition at line 83 of file WriteHDF5.cpp.
References VALGRIND_MAKE_MEM_UNDEFINED.
(void)VALGRIND_MAKE_MEM_UNDEFINED( 0, 0 );
